Jetson Nano Android emulation/Virtualization
Hi, im trying to run an application based on ARCore but is run through jetson nano, Im trying to find a way to run the application on nano’s linux OS through emulation/Virtualization as it is a small application before investing in changing the OS of the nano itself. Is there a way to integrate this things? thank you in advance for helps
To run the Android on Jetson Nano is currently not supported, but you can refer to this project: Lineage Android OS for the Jetson Nano - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums.
Update on the post. trying the qemu virtualization for the jetson nano with activated kvm to try and run simple apps without changing the OS itself
