Jetson Nano Audio Codec
I see Nano Design Guide about I2S audio codec use ALC5639, I can use other audio codec like ALC5640, driver can Compatible.
Hello!
Please can you point me to the design guide you are referring to? The RT5639 and RT5640 use the same Linux driver and from a driver standpoint I don’t see any difference. So if there is a working configuration for one then it should work for the other as well.
Regards,
Jon
