I am using JetPack 4.4.1 on Jetson Nano.
OpenCV 4.5.1 was built from source with CUDA and OpenGL support
(patch was applied to cuda_gl_interop.h. Not sure, whether it is still required, but I think it can’t hurt).
cv::getBuildInformation reports openGL support present with correct path to the .so libraries.
In c++ program, I am using opencv named window:
cv::namedWindow (m_name, cv::WINDOW_KEEPRATIO | v::WINDOW_OPENGL);
along with cv::imshow
The output window keeps black!
(Also tried different settings, window and full screen, and different openCV versions - nothing helps)
No errors are reported. Just black output.
Imshow works when not using the WINDOW_OPENGL flag.
OpenGL seems to be ok: Gstreamer glimagesink produces correct output.
Any help appreciated!
