I am using my SD card image that has been upgraded continually for 1 year. I have the virgin SD image so that I can compare the 2, but I want to use my original SD card image as it has all my software on.
Here is my full dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2280) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Sep 24 16:07:04 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefaa000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=tt
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 28992(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3570228K/4159488K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 114124K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001693] Console: colour dummy device 80x25
[ 0.001703] console [tty0] enabled
[ 0.001709] bootconsole [uart8250] disabled
[ 0.001726] kmemleak: Kernel memory leak detector disabled
[ 0.001745] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001757] pid_max: default: 32768 minimum: 301
[ 0.002198] Security Framework initialized
[ 0.002419] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002428] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003545] ftrace: allocating 47104 entries in 185 pages
[ 0.171477] sched-energy: CPU device node has no sched-energy-costs
[ 0.171511] ASID allocator initialised with 65536 entries
[ 0.207805] tegra-id: chipid=22117.
[ 0.207819] tegra-id: opt_subrevision=0.
[ 0.207835] Tegra Speedo/IDDQ fuse revision 4
[ 0.207840] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.207845] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.207851] Tegra: CPU Speedo Value 2090, SoC Speedo Value 1998, GPU Speedo Value 2099
[ 0.207856] Tegra: CPU IDDQ Value 2628, SoC IDDQ Value 2968, GPU IDDQ Value 3480
[ 0.207875] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.207890] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.207898] DTB Build time: Sep 24 2020 16:11:18
[ 0.257053] CPU1: Booted secondary processor [411fd071]
[ 0.288950] CPU2: Booted secondary processor [411fd071]
[ 0.320936] CPU3: Booted secondary processor [411fd071]
[ 0.321024] Brought up 4 CPUs
[ 0.321032] SMP: Total of 4 processors activated.
[ 0.321040] CPU features: detected feature: 32-bit EL0 Support
[ 0.321304] CPU: All CPU(s) started at EL2
[ 0.321321] alternatives: patching kernel code
[ 0.329370] devtmpfs: initialized
[ 0.368487] Initilizing CustomIPI irq domain
[ 0.368860] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.368883] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.379363] pinctrl core: initialized pinctrl subsystem
[ 0.379999] OS set in device tree is not L4T.
[ 0.380408] regulator-dummy: no parameters
[ 0.380678] Initializing plugin-manager
[ 0.380789] Plugin module not found
[ 0.381022] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.381608] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.382479] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.382897] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.383314] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.383709] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.388437] NET: Registered protocol family 16
[ 0.390186] pstore: using zlib compression
[ 0.390219] console [pstore-1] enabled
[ 0.390223] pstore: Registered ramoops as persistent store backend
[ 0.390229] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.409071] cpuidle: using governor menu
[ 0.413192] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.415156] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.415176] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.417527] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.419827] Serial: AMBA PL011 UART driver
[ 0.420334] tegra_powergate_init: DONE
[ 0.420350] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.420358] DTB Build time: Sep 24 2020 16:11:18
[ 0.422241] Tegra reboot handler registered.
[ 0.426692] iommu: Adding device tegra-carveouts to group 0
[ 0.426830] platform tegra-carveouts: domain=ffffffc0f9be73d8 allocates as[0]=ffffffc0f94480a8
[ 0.427182] iommu: Adding device smmu_test to group 1
[ 0.427233] platform smmu_test: domain=ffffffc0f9be7618 allocates as[0]=ffffffc0f9448110
[ 0.428022] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.428077] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.428129] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.428138] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.428161] mc-err: mcerr ops are set to t21x
[ 0.437565] iommu: Adding device 70090000.xusb to group 2
[ 0.437864] iommu: Adding device 70006000.serial to group 3
[ 0.437920] platform 70006000.serial: domain=ffffffc0f9bf0cd8 allocates as[0]=ffffffc0f9448178
[ 0.438336] iommu: Adding device 70006040.serial to group 4
[ 0.438594] iommu: Adding device 70006200.serial to group 5
[ 0.438785] iommu: Adding device sound to group 6
[ 0.438826] platform sound: domain=ffffffc0f94b6258 allocates as[0]=ffffffc0f94481e0
[ 0.439372] iommu: Adding device 7000d400.spi to group 7
[ 0.439626] iommu: Adding device 7000d600.spi to group 8
[ 0.439923] iommu: Adding device 70410000.spi to group 9
[ 0.440220] iommu: Adding device 50000000.host1x to group 10
[ 0.440496] iommu: Adding device 54080000.vi to group 11
[ 0.440883] iommu: Adding device 54600000.isp to group 12
[ 0.441169] iommu: Adding device 54680000.isp to group 13
[ 0.441431] iommu: Adding device tegradc.0 to group 14
[ 0.441481] platform tegradc.0: domain=ffffffc0f9520198 allocates as[0]=ffffffc0f9448248
[ 0.441993] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.442310] iommu: Adding device tegradc.1 to group 15
[ 0.442355] platform tegradc.1: domain=ffffffc0f95203d8 allocates as[0]=ffffffc0f94482b0
[ 0.442854] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.443110] iommu: Adding device 54340000.vic to group 16
[ 0.443301] iommu: Adding device 544c0000.nvenc to group 17
[ 0.443492] iommu: Adding device 54500000.tsec to group 18
[ 0.443683] iommu: Adding device 54100000.tsecb to group 19
[ 0.443879] iommu: Adding device 54480000.nvdec to group 20
[ 0.444064] iommu: Adding device 54380000.nvjpg to group 21
[ 0.445132] iommu: Adding device 546c0000.i2c to group 22
[ 0.445463] iommu: Adding device 57000000.gpu to group 23
[ 0.445520] platform 57000000.gpu: domain=ffffffc0f952a3d8 allocates as[0]=ffffffc0f9448318
[ 0.445576] platform 57000000.gpu: domain=ffffffc0f952a3d8 allocates as[1]=ffffffc0f9448380
[ 0.445615] platform 57000000.gpu: domain=ffffffc0f952a3d8 allocates as[2]=ffffffc0f94483e8
[ 0.445647] platform 57000000.gpu: domain=ffffffc0f952a3d8 allocates as[3]=ffffffc0f9448450
[ 0.446489] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.446499] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.446511] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.446516] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.446520] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.497243] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.497253] tegra-pmc: Clear bootloader IO dpd settings
[ 0.497275] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.497340] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.497623] iommu: Adding device 70012000.se to group 24
[ 0.498376] iommu: Adding device 7000c000.i2c to group 25
[ 0.498643] iommu: Adding device 7000c400.i2c to group 26
[ 0.498887] iommu: Adding device 7000c500.i2c to group 27
[ 0.499134] iommu: Adding device 7000c700.i2c to group 28
[ 0.499382] iommu: Adding device 7000d000.i2c to group 29
[ 0.499618] iommu: Adding device 7000d100.i2c to group 30
[ 0.499898] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.499953] platform sdhci-tegra.0: domain=ffffffc0f9584558 allocates as[0]=ffffffc0f94484b8
[ 0.500774] iommu: Adding device 700d0000.xudc to group 32
[ 0.504071] vdd-ac-bat: 5000 mV
[ 0.504420] vdd-5v0-sys: 5000 mV
[ 0.505396] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.505440] vdd-5v0-hdmi: 5000 mV
[ 0.505861] vdd-1v8-sys: 1800 mV
[ 0.506266] vdd-fan: supplied by vdd-5v0-sys
[ 0.506301] vdd-fan: 5000 mV
[ 0.506677] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.506712] vdd-usb-vbus: 5000 mV
[ 0.507208] vdd-usb-vbus2: 5000 mV
[ 0.542118] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.544539] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.546035] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.546055] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.546405] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.554134] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.554464] SCSI subsystem initialized
[ 0.554678] libata version 3.00 loaded.
[ 0.554913] usbcore: registered new interface driver usbfs
[ 0.554977] usbcore: registered new interface driver hub
[ 0.555061] usbcore: registered new device driver usb
[ 0.558920] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.564343] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.565010] random: fast init done
[ 0.565385] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.568300] vdd-ddr-1v1: 1150 mV
[ 0.573009] vdd-pre-reg-1v35: 1350 mV
[ 0.576970] vdd-1v8: 1800 mV
[ 0.580962] avdd-sys-1v2: 1200 mV
[ 0.584954] vdd-pex-1v0: 1050 mV
[ 0.585617] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.586153] max77620-ldo3: at 3100 mV
[ 0.588961] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.589496] max77620-ldo5: at 3100 mV
[ 0.590033] max77620-ldo6: at 2800 mV
[ 0.592960] avdd-1v05-pll: 1050 mV
[ 0.596957] avdd-io-hdmi-dp: 1050 mV
[ 0.599600] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.599875] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.600149] max77620 4-003c: max77620 probe successful
[ 0.602822] media: Linux media interface: v0.10
[ 0.602878] Linux video capture interface: v2.00
[ 0.603773] pps_core: LinuxPPS API ver. 1 registered
[ 0.603780] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.603796] PTP clock support registered
[ 0.606930] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.607717] Advanced Linux Sound Architecture Driver Initialized.
[ 0.608346] Bluetooth: Core ver 2.22
[ 0.608394] NET: Registered protocol family 31
[ 0.608398] Bluetooth: HCI device and connection manager initialized
[ 0.608412] Bluetooth: HCI socket layer initialized
[ 0.608422] Bluetooth: L2CAP socket layer initialized
[ 0.608449] Bluetooth: SCO socket layer initialized
[ 0.610299] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.610318] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.610370] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.610387] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.614007] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.615197] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.615257] vdd-3v3-sys: 3300 mV
[ 0.615511] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.617126] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.617627] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.617664] vdd-3v3-sd: 3300 mV
[ 0.618751] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.618795] avdd-io-edp-1v05: 1050 mV
[ 0.619269] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.619326] vdd-usb-hub-en: 5000 mV
[ 0.620715] camchar: rtcpu character device driver loaded
[ 0.621426] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.623038] clocksource: Switched to clocksource arch_sys_counter
[ 0.663007] VFS: Disk quotas dquot_6.6.0
[ 0.663193] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.663673] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.664075] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.664091] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.664318] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.664324] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.664337] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.664367] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.664373] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.664388] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.664396] nvmap_page_pool_init: Total RAM pages: 1011341
[ 0.664401] nvmap_page_pool_init: nvmap page pool size: 126417 pages (493 MB)
[ 0.664485] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.664914] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.665622] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.675492] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.675902] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.676141] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.676338] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.676510] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.676796] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.676800] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.677230] NET: Registered protocol family 2
[ 0.678192] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.678402] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.678900] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.679128] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.679210] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.679634] NET: Registered protocol family 1
[ 0.680352] RPC: Registered named UNIX socket transport module.
[ 0.680357] RPC: Registered udp transport module.
[ 0.680361] RPC: Registered tcp transport module.
[ 0.680365] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.680378] PCI: CLS 0 bytes, default 64
[ 0.680624] Trying to unpack rootfs image as initramfs...
[ 0.910219] Freeing initrd memory: 5356K
[ 0.919857] host1x 50000000.host1x: initialized
[ 0.921877] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.925043] audit: initializing netlink subsys (disabled)
[ 0.925146] audit: type=2000 audit(0.775:1): initialized
[ 0.925910] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.935886] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.937345] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.938135] 9p: Installing v9fs 9p2000 file system support
[ 0.941426] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.941569] io scheduler noop registered
[ 0.941878] io scheduler cfq registered (default)
[ 0.944489] gic 702f9000.agic: GIC IRQ controller registered
[ 0.947886] iommu: Adding device 702ef000.adsp to group 33
[ 0.956698] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.956854] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.957443] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x71a740f
[ 0.957451] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.959084] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.959194] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.959289] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.959471] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.959556] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.959646] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.959729] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.959817] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.959903] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.959989] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.965948] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.967691] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.969572] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.970838] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.971226] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.972400] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.972623] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.972829] Adding domain tsec-pd to PM domain host1x-pd
[ 0.974975] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.976083] tsec 54500000.tsec: initialized
[ 0.977613] tsec 54100000.tsecb: initialized
[ 0.978303] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.981710] nvdec 54480000.nvdec: initialized
[ 0.982732] Adding domain vic03-pd to PM domain host1x-pd
[ 0.982910] Adding domain msenc-pd to PM domain host1x-pd
[ 0.983102] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.987213] falcon 54340000.vic: initialized
[ 0.988453] falcon 544c0000.nvenc: initialized
[ 0.989771] falcon 54380000.nvjpg: initialized
[ 0.993970] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 0.994008] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 0.994043] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 0.994115] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.994236] display board info: id 0x0, fab 0x0
[ 0.994309] generic_infoframe_type: 0x87
[ 0.994322] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 0.994328] tegra_cec 70015000.tegra_cec: probed
[ 0.994464] tegradc tegradc.0: DT parsed successfully
[ 0.994510] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 0.998473] tegradc tegradc.0: probed
[ 0.999234] Console: switching to colour frame buffer device 80x30
[ 0.999271] tegradc tegradc.0: fb registered
[ 1.000603] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.000680] tegradc tegradc.1: No lt-data, using default setting
[ 1.000711] tegradc tegradc.1: No hpd-gpio in DT
[ 1.000741] tegradc tegradc.1: DT parsed successfully
[ 1.000794] tegradc tegradc.1: Display dc.ffffff800ad00000 registered with id=1
[ 1.002362] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.002876] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.509101] Host read timeout at address 545c00c4
[ 1.510298] tegradc tegradc.1: probed
[ 1.510692] tegradc tegradc.1: fb registered
[ 1.510835] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.511578] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.511585] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.511870] kfuse 7000fc00.kfuse: initialized
[ 1.512762] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.513511] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.514441] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.514452] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.514855] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.515742] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.515754] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.515760] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.515766] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.515773] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.515814] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.515918] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.516158] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.516234] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.516423] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.516433] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.516585] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[ 1.516635] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 1.516863] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 1.518117] V_FRONT_PORCH < (V_REF_TO_SYNC + 1)
[ 1.518155] tegradc tegradc.1: Display timing doesn't meet restrictions.
[ 1.518175] tegradc tegradc.1: tegra_dc_set_fbcon_boot_mode: set DC mode from modedb, err = -22
[ 1.518193] tegradc tegradc.1: Failed to set fbcon mode for DC 1
[ 1.518213] vdd-gpu: applied init 1000000uV constraint
[ 1.518220] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.518810] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.522750] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.522848] No Device Node present for smmu client: serial8250 !!
[ 1.522857] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.522898] iommu: Adding device serial8250 to group 35
[ 1.525794] console [ttyS0] disabled
[ 1.525899] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.525984] tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
[ 1.528314] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x0 did not specify bpp
[ 1.531180] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.531405] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.531435] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.531470] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.531493] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.531666] pci 0000:02:00.0: supports D1 D2
[ 1.531669] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.531934] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.536508] dp lt: state 0 (Reset), pending_lt_evt 1
[ 1.536512] dp lt: switching from state 0 (Reset) to state 0 (Reset)
[ 1.536515] dp lt: state 0 (Reset), pending_lt_evt 0
[ 1.537721] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 1.537866] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 1.537870] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 1.538109] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 1.538119] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 1.538129] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 1.538138] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 1.538147] dp lt: tx_pu: 0x20
[ 1.539037] dp lt: CR done
[ 1.539041] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 1.539045] dp lt: state 3 (channel equalization), pending_lt_evt 0
[ 1.541444] dp lt: CE done
[ 1.541448] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[ 1.541596] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.541602] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.547132] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.547204] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.547210] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 1.547215] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.547225] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 1.547251] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.547259] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.547270] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 1.547289] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 1.547307] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.547315] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.547319] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.547324] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 1.547908] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.547913] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.547920] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.548051] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 1.548279] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.548283] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.548289] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.548392] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 1.569810] console [ttyS0] enabled
[ 1.570922] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.571259] serial-tegra 70006200.serial: RX in PIO mode
[ 1.571345] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.572289] [drm] Initialized
[ 1.582216] brd: module loaded
[ 1.587787] loop: module loaded
[ 1.587886] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.588025] tegra_profiler: auth: init
[ 1.589360] THERMAL EST: found 2 subdevs
[ 1.589369] THERMAL EST num_resources: 0
[ 1.589375] [THERMAL EST subdev 0]
[ 1.589383] [THERMAL EST subdev 1]
[ 1.589835] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.589839] THERMAL EST: thz register success.
[ 1.590008] THERMAL EST: end of probe, return err: 0
[ 1.591205] sd: No Scsi addr parsed to reserve index
[ 1.591246] hisi_sas: driver version v1.6
[ 1.595898] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.597029] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.597040] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.599927] libphy: Fixed MDIO Bus: probed
[ 1.600631] tun: Universal TUN/TAP device driver, 1.6
[ 1.600636] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.601580] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.601585] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.601645] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.601648] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.601695] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.601700] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.601750] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.601754] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.602765] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.602797] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.617083] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.617263] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:b7:a3 from device tree
[ 1.617848] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.617906] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.618533] PPP generic driver version 2.4.2
[ 1.618735] PPP BSD Compression module registered
[ 1.618742] PPP Deflate Compression module registered
[ 1.618783] PPP MPPE Compression module registered
[ 1.618789] NET: Registered protocol family 24
[ 1.618855] usbcore: registered new interface driver r8152
[ 1.618906] usbcore: registered new interface driver asix
[ 1.618966] usbcore: registered new interface driver ax88179_178a
[ 1.619002] usbcore: registered new interface driver cdc_ether
[ 1.619200] usbcore: registered new interface driver net1080
[ 1.619245] usbcore: registered new interface driver cdc_subset
[ 1.619290] usbcore: registered new interface driver zaurus
[ 1.619342] usbcore: registered new interface driver cdc_ncm
[ 1.619513] VFIO - User Level meta-driver version: 0.3
[ 1.620859] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.620883] ehci-pci: EHCI PCI platform driver
[ 1.620937] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.620950] ohci-pci: OHCI PCI platform driver
[ 1.621000] ohci-platform: OHCI generic platform driver
[ 1.623729] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.624332] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.625498] tegra-xusb 70090000.xusb: extcon 0: ffffffc0fa5d3800 id
[ 1.627773] usbcore: registered new interface driver uas
[ 1.627845] usbcore: registered new interface driver usb-storage
[ 1.627976] usbcore: registered new interface driver usbserial
[ 1.628368] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.628438] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.628466] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.629242] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.629302] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.629515] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.629522] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.629528] usb usb1: Product: xHCI Host Controller
[ 1.629533] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.629537] usb usb1: SerialNumber: 70090000.xusb
[ 1.630192] hub 1-0:1.0: USB hub found
[ 1.630237] hub 1-0:1.0: 5 ports detected
[ 1.630885] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.630900] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.631010] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.631140] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.631147] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.631152] usb usb2: Product: xHCI Host Controller
[ 1.631156] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.631161] usb usb2: SerialNumber: 70090000.xusb
[ 1.631791] hub 2-0:1.0: USB hub found
[ 1.631827] hub 2-0:1.0: 4 ports detected
[ 1.634231] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.635570] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.635585] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.635619] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.635865] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.636547] mousedev: PS/2 mouse device common for all mice
[ 1.636653] usbcore: registered new interface driver xpad
[ 1.643071] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.643084] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.651051] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.656645] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10200080 did not specify bpp
[ 1.677002] tegradc tegradc.1: pclk is zero!
[ 1.677082] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10200080 did not specify bpp
[ 1.677320] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[ 1.677553] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[ 1.677785] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[ 1.678016] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[ 1.678247] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[ 1.678255] tegradc tegradc.1: blank - powerdown
[ 1.731149] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.731211] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.743110] tegradc tegradc.1: sor_poll_register 0x16: timeout
[ 1.743115] tegradc tegradc.1: dc timeout waiting for HEAD MODE = SLEEP
[ 1.768083] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.770894] rtc rtc1: alarm rtc device
[ 1.770912] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.770946] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.771850] i2c /dev entries driver
[ 1.774112] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.797432] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.797497] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.797525] imx219 6-0010: board setup failed
[ 1.797622] imx219: probe of 6-0010 failed with error -121
[ 1.798887] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.801752] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.801757] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.802209] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.802227] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.802236] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.802371] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.802381] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.802386] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.802533] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.802544] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.802549] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.802754] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.803617] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.803672] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.803699] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.803716] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.803724] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.804620] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.804642] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.804834] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.804862] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.805259] parse_throttle_dt_data: Num cap clks = 6
[ 1.805265] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.805279] parse_throttle_dt_data: clk=gpu type=4
[ 1.805303] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.805321] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.805340] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.805344] parse_throttle_dt_data: clk=emc type=3
[ 1.805800] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.805952] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.806149] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.806994] FAN dev name: pwm-fan
[ 1.807126] FAN:gpio request success.
[ 1.807200] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.807530] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.807702] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.807712] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.807817] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.807823] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.807827] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.807831] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.807835] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.807839] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.807843] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.807847] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.807852] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.807856] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.808769] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.809122] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.810007] device-mapper: uevent: version 1.0.3
[ 1.810476] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.815886] tegra210-cpufreq cpufreq: probe()...completed
[ 1.816582] sdhci: Secure Digital Host Controller Interface driver
[ 1.816583] sdhci: Copyright(c) Pierre Ossman
[ 1.816585] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.817059] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.817392] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.817513] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.821727] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.822206] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.823312] usbcore: registered new interface driver usbhid
[ 1.823313] usbhid: USB HID core driver
[ 1.825300] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.825454] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.827356] nvpmodel: initialized successfully
[ 1.828416] usbcore: registered new interface driver snd-usb-audio
[ 1.828469] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.828473] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.828493] iommu: Adding device snd-soc-dummy to group 36
[ 1.834058] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.842898] OPE platform probe
[ 1.842985] OPE platform probe successful
[ 1.843009] OPE platform probe
[ 1.843150] OPE platform probe successful
[ 1.863246] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.865413] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.865534] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.865652] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.865785] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.865899] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.866020] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.866136] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.866259] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.866377] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.866491] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.878163] u32 classifier
[ 1.878164] Actions configured
[ 1.878237] Initializing XFRM netlink socket
[ 1.878947] NET: Registered protocol family 10
[ 1.879732] NET: Registered protocol family 17
[ 1.879742] NET: Registered protocol family 15
[ 1.879817] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.879910] Bluetooth: RFCOMM socket layer initialized
[ 1.879917] Bluetooth: RFCOMM ver 1.11
[ 1.879921] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.879925] Bluetooth: HIDP socket layer initialized
[ 1.879943] 9pnet: Installing 9P2000 support
[ 1.879977] Key type dns_resolver registered
[ 1.880582] Registered cp15_barrier emulation handler
[ 1.880597] Registered setend emulation handler
[ 1.882004] registered taskstats version 1
[ 1.882631] Adding domain ve2-pd to PM domain host1x-pd
[ 1.882867] Adding domain ve-pd to PM domain host1x-pd
[ 1.884916] isp 54600000.isp: initialized
[ 1.885889] isp 54680000.isp: initialized
[ 1.896151] last reset is due to power on reset
[ 1.896154] KERNEL: PMC reset status reg: 0x0
[ 1.896229] BL: PMC reset status reg: 0x0
[ 1.896230] BL: PMIC poweroff Event Recorder: 0x40
[ 1.897653] clk_cbus_recalc_rate: no gbus parent
[ 1.897658] clk_cbus_round_rate: no gbus parent
[ 1.897659] clk_cbus_round_rate: no gbus parent
[ 1.897666] clk_cbus_recalc_rate: no gbus parent
[ 1.897768] clk_cbus_recalc_rate: no gbus parent
[ 1.897770] clk_cbus_round_rate: no gbus parent
[ 1.897772] clk_cbus_round_rate: no gbus parent
[ 1.897775] clk_cbus_recalc_rate: no gbus parent
[ 1.898470] tegra_dvfs: GPU-cap: registered
[ 1.898527] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.898529] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.898531] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.900045] tegra_dvfs: vdd-gpu-vts: registered
[ 1.900696] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.901246] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.901702] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.935566] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:14 UTC (946688414)
[ 1.936546] vi 54080000.vi: vi_probe: ++
[ 1.939672] vi 54080000.vi: initialized
[ 1.941633] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.943134] Disable partitions left on by BL
[ 1.943137] disb
[ 1.943177] bwmgr: missing cdev-type property
[ 1.943258] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.943263] DRAM derating cdev registered.
[ 1.944192] vdd-fan: disabling
[ 1.944194] vdd-usb-vbus: disabling
[ 1.944196] vdd-usb-vbus2: disabling
[ 1.944291] ALSA device list:
[ 1.944293] #0: tegra-hda at 0x70038000 irq 83
[ 1.944295] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.955047] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.991206] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.991210] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.991212] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.991215] usb 1-2: Manufacturer: Generic
[ 1.992464] hub 1-2:1.0: USB hub found
[ 1.993723] hub 1-2:1.0: 4 ports detected
[ 2.004046] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.004049] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.062785] mmc0: Applying tuning correction
[ 2.062797] mmc0: Tap value after applying correction 63
[ 2.062813] mmc0: hw tuning done ...
[ 2.062843] mmc0: new ultra high speed SDR104 SDXC card at address e624
[ 2.063155] mmcblk0: mmc0:e624 SR128 119 GiB
[ 2.068240] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.115098] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.119094] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 2.137052] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 2.137057] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.139043] usb 1-2: usb_suspend_both: status 0
[ 2.707127] dp lt: state 5 (link training pass), pending_lt_evt 1
[ 2.707129] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[ 2.707131] dp lt: state 0 (Reset), pending_lt_evt 0
[ 2.707135] dp lt: link training force disable
[ 2.707137] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[ 2.759032] tegradc tegradc.1: dc_poll_register 0x41: timeout
[ 2.759035] tegradc tegradc.1: dc timeout waiting for DC to stop
[ 2.771341] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10200080 did not specify bpp
[ 2.771353] tegradc tegradc.1: unblank
[ 2.802283] tegradc tegradc.1: nominal-pclk:108000000 parent:108000000 div:1.0 pclk:108000000 106920000~117720000
[ 2.803653] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10200080 did not specify bpp
[ 2.807237] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 2.811653] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[ 2.811655] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[ 2.811657] dp lt: state 0 (Reset), pending_lt_evt 0
[ 2.812848] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 2.812991] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 2.812995] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 2.813230] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 2.813238] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 2.813247] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 2.813256] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 2.813261] dp lt: tx_pu: 0x20
[ 2.814166] dp lt: CR done
[ 2.814169] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 2.814173] dp lt: state 3 (channel equalization), pending_lt_evt 0
[ 2.816543] dp lt: CE done
[ 2.816545] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[ 2.816842] tegradc tegradc.1: sync windows ret = 250
[ 2.857478] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10200080 did not specify bpp
[ 2.857710] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[ 2.857940] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[ 2.858170] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[ 2.858399] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000000 did not specify bpp
[ 2.858628] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10000080 did not specify bpp
[ 2.858632] tegradc tegradc.1: blank - powerdown
[ 2.900016] dp lt: state 5 (link training pass), pending_lt_evt 1
[ 2.900018] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[ 2.900020] dp lt: state 0 (Reset), pending_lt_evt 0
[ 2.900023] dp lt: link training force disable
[ 2.900025] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[ 2.921027] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10200080 did not specify bpp
[ 2.921035] tegradc tegradc.1: unblank
[ 2.951869] tegradc tegradc.1: nominal-pclk:108000000 parent:108000000 div:1.0 pclk:108000000 106920000~117720000
[ 2.953237] tegradc tegradc.1: tegra_dp_get_bpp: vmode=0x10200080 did not specify bpp
[ 2.956820] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 2.961233] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[ 2.961235] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[ 2.961237] dp lt: state 0 (Reset), pending_lt_evt 0
[ 2.962428] tegradc tegradc.1: DP: no prod_c_hbr prod settings node in device tree
[ 2.962571] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 2.962575] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 2.962809] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 2.962818] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 2.962826] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 2.962834] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
[ 2.962839] dp lt: tx_pu: 0x20
[ 2.963739] dp lt: CR done
[ 2.963742] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[ 2.963746] dp lt: state 3 (channel equalization), pending_lt_evt 0
[ 2.966115] dp lt: CE done
[ 2.966117] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[ 2.966351] tegradc tegradc.1: sync windows ret = 250
[ 2.966482] extcon-disp-state extcon:disp-state: cable 44 state 1
[ 2.966484] Extcon DP: HPD enabled
[ 2.966495] hpd: Display connected, hpd_switch 1
[ 2.966498] hpd: switching from state 2 (Check EDID) to state 4 (Enabled)
[ 2.969509] Freeing unused kernel memory: 8576K
[ 2.993525] Root device found: mmcblk0p1
[ 2.994586] Found dev node: /dev/mmcblk0p1
[ 5.791641] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.791646] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 6.120061] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.154967] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 6.154971] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.154975] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 6.154977] usb 2-1: Manufacturer: Generic
[ 6.160563] hub 2-1:1.0: USB hub found
[ 6.161964] hub 2-1:1.0: 4 ports detected
[ 6.319099] usb 2-1: usb_suspend_both: status 0
[ 6.319213] usb usb2: usb_suspend_both: status 0
[ 7.829615] EXT4-fs (mmcblk0p1): recovery complete
[ 7.830669] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.831462] Rootfs mounted over mmcblk0p1
[ 7.846672] Switching from initrd to actual rootfs
[ 8.146741] systemd[1]: System time before build time, advancing clock.
[ 8.192230] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.205422] cgroup: cgroup2: unknown option "nsdelegate"
[ 8.224878] systemd[1]: systemd 245.4-4ubuntu3.3 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 8.225703] systemd[1]: Detected architecture arm64.
[ 8.249624] systemd[1]: Set hostname to <nano-desktop>.
[ 8.667696] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[ 8.792777] systemd[1]: /lib/systemd/system/rpc-statd.service:16: PIDFile= references a path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
[ 8.803534] systemd[1]: /lib/systemd/system/gpsd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/gpsd.sock → /run/gpsd.sock; please update the unit file accordingly.
[ 8.867938] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 8.879168] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.879314] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 8.879324] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 8.881636] systemd[1]: Created slice system-modprobe.slice.
[ 8.881758] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.882598] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 8.882630] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.883485] systemd[1]: Created slice system-vncserver.slice.
[ 8.884367] systemd[1]: Created slice User and Session Slice.
[ 8.884549] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.886568] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.886720] systemd[1]: Reached target User and Group Name Lookups.
[ 8.886779] systemd[1]: Reached target Slices.
[ 8.887248] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 8.888280] systemd[1]: Listening on Syslog Socket.
[ 8.890084] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.890210] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.890620] systemd[1]: Listening on Journal Audit Socket.
[ 8.890825] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.891148] systemd[1]: Listening on Journal Socket.
[ 8.891397] systemd[1]: Listening on udev Control Socket.
[ 8.891546] systemd[1]: Listening on udev Kernel Socket.
[ 8.894056] systemd[1]: Mounting Huge Pages File System...
[ 8.897081] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.899903] systemd[1]: Mounting NFSD configuration filesystem...
[ 8.902714] systemd[1]: Mounting RPC Pipe File System...
[ 8.906062] systemd[1]: Mounting Kernel Debug File System...
[ 8.909555] systemd[1]: Mounting Kernel Trace File System...
[ 8.913128] systemd[1]: Starting Journal Service...
[ 8.913359] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 8.916524] systemd[1]: Starting Set the console keyboard layout...
[ 8.919635] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 8.919767] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 8.922872] systemd[1]: Started Nameserver information manager.
[ 8.923476] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 8.924832] systemd[1]: Reached target Network (Pre).
[ 8.931705] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 8.931826] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.940342] systemd[1]: Starting Load Kernel Modules...
[ 8.943585] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.946632] systemd[1]: Starting udev Coldplug all Devices...
[ 8.950098] systemd[1]: Starting Uncomplicated firewall...
[ 8.956724] systemd[1]: Mounted Huge Pages File System.
[ 8.957221] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.957665] systemd[1]: Mounted NFSD configuration filesystem.
[ 8.958141] systemd[1]: Mounted RPC Pipe File System.
[ 8.958553] systemd[1]: Mounted Kernel Debug File System.
[ 8.958944] systemd[1]: Mounted Kernel Trace File System.
[ 8.961150] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 8.966575] systemd[1]: Starting pNFS block layout mapping daemon...
[ 8.971477] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.975199] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.978150] systemd[1]: Activating swap /mnt/4GB.swap...
[ 8.986372] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 9.009847] systemd[1]: Starting Platform Persistent Storage Archival...
[ 9.012848] systemd[1]: Starting Load/Save Random Seed...
[ 9.047716] systemd[1]: Starting Create System Users...
[ 9.051477] systemd[1]: Finished Uncomplicated firewall.
[ 9.052412] systemd[1]: Started pNFS block layout mapping daemon.
[ 9.090342] systemd[1]: Finished Platform Persistent Storage Archival.
[ 9.100113] systemd[1]: Finished Create System Users.
[ 9.136274] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 9.150034] systemd[1]: Finished Set the console keyboard layout.
[ 9.164658] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 9.169445] systemd[1]: Finished Load Kernel Modules.
[ 9.170061] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 9.199536] systemd[1]: Mounting Kernel Configuration File System...
[ 9.202339] systemd[1]: Starting Apply Kernel Variables...
[ 9.205132] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 9.205730] systemd[1]: Reached target Local File Systems (Pre).
[ 9.214002] systemd[1]: Mounting Mount unit for core18, revision 1888...
[ 9.241912] systemd[1]: Mounting Mount unit for core18, revision 1936...
[ 9.245840] systemd[1]: Mounting Mount unit for gnome-3-34-1804, revision 61...
[ 9.249879] systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1506...
[ 9.257862] systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1513...
[ 9.265752] systemd[1]: Mounting Mount unit for snap-store, revision 476...
[ 9.269354] systemd[1]: Mounting Mount unit for snap-store, revision 499...
[ 9.273306] systemd[1]: Mounting Mount unit for snapd, revision 9287...
[ 9.276938] systemd[1]: Mounting Mount unit for snapd, revision 9730...
[ 9.279852] systemd[1]: Starting udev Kernel Device Manager...
[ 9.284428] systemd[1]: Started Journal Service.
[ 9.320745] systemd-journald[2002]: Received client request to flush runtime journal.
[ 9.355566] random: crng init done
[ 9.358973] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.432461] Adding 4194300k swap on /mnt/4GB.swap. Priority:-1 extents:612 across:31102728k SS
[ 10.571920] using random self ethernet address
[ 10.576573] using random host ethernet address
[ 12.180705] Intel(R) Wireless WiFi driver for Linux
[ 12.180709] Copyright(c) 2003- 2015 Intel Corporation
[ 12.181073] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 12.195327] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 12.214668] iwlwifi 0000:01:00.0: Falling back to user helper
[ 12.493801] Mass Storage Function, version: 2009/09/11
[ 12.493807] LUN: removable file: (no medium)
[ 12.500975] using random self ethernet address
[ 12.507456] using random host ethernet address
[ 12.640159] usbcore: registered new interface driver btusb
[ 12.645867] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 12.646854] Bluetooth: hci0: Device revision is 16
[ 12.646859] Bluetooth: hci0: Secure boot is enabled
[ 12.646861] Bluetooth: hci0: OTP lock is enabled
[ 12.646863] Bluetooth: hci0: API lock is enabled
[ 12.646865] Bluetooth: hci0: Debug lock is disabled
[ 12.646868] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 12.679318] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 12.855829] rndis0: HOST MAC ca:41:83:76:33:bc
[ 12.856226] rndis0: MAC ca:41:83:76:33:bd
[ 12.858505] usb0: HOST MAC ca:41:83:76:33:be
[ 12.858542] usb0: MAC ca:41:83:76:33:bf
[ 12.858566] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 12.859685] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 12.859703] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 12.859732] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 12.859958] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 12.859972] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 12.860468] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 12.860489] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 12.860781] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 12.866504] l4tbr0: port 1(rndis0) entered blocking state
[ 12.866508] l4tbr0: port 1(rndis0) entered disabled state
[ 12.866666] device rndis0 entered promiscuous mode
[ 12.873733] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 12.888826] l4tbr0: port 2(usb0) entered blocking state
[ 12.888854] l4tbr0: port 2(usb0) entered disabled state
[ 12.889027] device usb0 entered promiscuous mode
[ 12.895679] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 13.657702] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.663711] eth0: 0xffffff800a3de000, 00:04:4b:e6:b7:a3, IRQ 406
[ 13.738164] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.144716] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 14.155051] iwlwifi 0000:01:00.0: Falling back to user helper
[ 14.161539] Bluetooth: hci0: Waiting for firmware download to complete
[ 14.161831] Bluetooth: hci0: Firmware loaded in 1486113 usecs
[ 14.161956] Bluetooth: hci0: Waiting for device to boot
[ 14.178836] Bluetooth: hci0: Device booted in 16540 usecs
[ 14.182596] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 14.185866] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 14.719582] zram: Added device: zram0
[ 14.723398] zram: Added device: zram1
[ 14.726736] zram: Added device: zram2
[ 14.729360] zram: Added device: zram3
[ 14.770713] zram0: detected capacity change from 0 to 519589888
[ 14.899520] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 14.909619] iwlwifi 0000:01:00.0: Falling back to user helper
[ 14.936753] Adding 507408k swap on /dev/zram0. Priority:5 extents:1 across:507408k SS
[ 14.942692] zram1: detected capacity change from 0 to 519589888
[ 14.956304] Adding 507408k swap on /dev/zram1. Priority:5 extents:1 across:507408k SS
[ 14.975320] zram2: detected capacity change from 0 to 519589888
[ 14.983735] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.983748] Bluetooth: BNEP socket layer initialized
[ 14.999165] Adding 507408k swap on /dev/zram2. Priority:5 extents:1 across:507408k SS
[ 15.011942] zram3: detected capacity change from 0 to 519589888
[ 15.039917] Adding 507408k swap on /dev/zram3. Priority:5 extents:1 across:507408k SS
[ 15.179672] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 15.191067] iwlwifi 0000:01:00.0: Falling back to user helper
[ 15.278324] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 15.358482] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 15.360935] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 15.362023] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 15.481138] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 15.482017] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 15.488737] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 15.586696] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 15.589108] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 15.589538] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 15.706904] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 15.707399] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 15.765740] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 15.769662] tegradc tegradc.0: blank - powerdown
[ 15.897586] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 16.026610] fuse init (API version 7.26)
[ 18.253769] tegradc tegradc.0: blank - normal
[ 19.317977] wlan0: authenticate with 4c:1b:86:b4:ea:06
[ 19.327757] wlan0: send auth to 4c:1b:86:b4:ea:06 (try 1/3)
[ 19.332599] wlan0: authenticated
[ 19.335113] wlan0: associate with 4c:1b:86:b4:ea:06 (try 1/3)
[ 19.336834] wlan0: RX AssocResp from 4c:1b:86:b4:ea:06 (capab=0x1011 status=0 aid=1)
[ 19.341624] wlan0: associated
[ 19.349361] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.399733] wlan0: Limiting TX power to 19 (20 - 1) dBm as advertised by 4c:1b:86:b4:ea:06
[ 19.518422] tegradc tegradc.0: unblank
[ 19.518436] tegradc tegradc.0: update windows ret = -14
[ 19.518439] tegradc tegradc.0: sync windows ret = -14
[ 319.540750] tegradc tegradc.0: unblank
[ 319.540828] tegradc tegradc.0: blank - normal
[ 319.541026] tegradc tegradc.0: blank - powerdown
