Jetson nano bo1 pin9 and pin10 forced recovery also cannot be swiped
我将pin10和pin9短接的,需要强制恢复才能进行刷机,但是我通过usb识别到的不是7f21,而是一个7020 ,通过看那个表没有与之对应的,我不知道为啥短接了,识别到是错的
I short-connected pin10 and pin9, and forced recovery was required before I could refresh the machine. However, what I identified through usb was not 7f21, but a 7020. After looking at the watch, I did not know why I short-connected it, and I recognized that it was wrong
然后通过guide输入刷机指令
Then enter the brush command through guide
下面错误
L4T BSP Information:
R32 , REVISION: 7.3
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
Hi, are you testing on nano devkit or custom board? Is USB0 port that you are using to flash?
Ha ha, I’m fine now
