Anyone met this before ? Withe the official root system, the boot hang after below logs from console, the green led
is on , seems not the power issue mentioned in the forum before .
[ 4.909025] clk_cbus_recalc_rate: no gbus parent
[ 4.909127] clk_cbus_recalc_rate: no gbus parent
[ 4.909129] clk_cbus_round_rate: no gbus parent
[ 4.909131] clk_cbus_round_rate: no gbus parent
[ 4.909133] clk_cbus_recalc_rate: no gbus parent
[ 4.909147] tegra_dvfs: GPU-cap: registered
[ 4.909207] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.909209] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.909211] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.911288] tegra_dvfs: vdd-gpu-vts: registered
[ 4.912292] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 4.912900] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 4.913433] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.954759] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:26 UTC (946688426)
[ 4.955696] vi 54080000.vi: vi_probe: ++
[ 4.959542] vi 54080000.vi: initialized
[ 4.961807] vi 54080000.vi: subdev nvcsi--1 bound
[ 4.962060] mmcblk mmc0:aaaa: Card claimed for testing.
[ 4.963200] Disable partitions left on by BL
[ 4.963203] disb
[ 4.963253] bwmgr: missing cdev-type property
[ 4.963351] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.963356] DRAM derating cdev registered.
[ 4.964351] vdd-1v8: disabling
[ 4.964353] vdd-fan: disabling
[ 4.964355] vdd-usb-vbus: disabling
[ 4.964356] vdd-usb-vbus2: disabling
[ 4.964366] avdd-io-edp-1v05: disabling
[ 4.964367] vdd-usb-hub-en: disabling
[ 4.964515] ALSA device list:
[ 4.964517] #0: tegra-hda at 0x70038000 irq 83
[ 4.964518] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.092798] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.098304] tegradc tegradc.1: blank - powerdown
[ 5.102933] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 5.110186] Extcon DP: HPD disabled
[ 5.113676] hpd: hpd_switch 0
[ 5.116643] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.123262] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.129182] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.562073] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 5.567415] EXT4-fs (mmcblk0p1): recovery complete
[ 5.582827] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.590948] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.600554] devtmpfs: mounted
[ 5.606603] Freeing unused kernel memory: 8512K
[ 5.752231] systemd[1]: System time before build time, advancing clock.
[ 5.779917] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.796309] cgroup: cgroup2: unknown option "nsdelegate"
[ 5.812550] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.834691] systemd[1]: Detected architecture arm64.
[ 5.865336] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 5.944227] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.961373] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.076664] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.083327] systemd[1]: Reached target Swap.
[ 6.087930] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.096313] systemd[1]: Created slice System Slice.
[ 6.101402] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.108214] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.115050] systemd[1]: Reached target Slices.
[ 6.121588] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.191607] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.284184] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 7.308640] random: crng init done
[ 7.312047] random: 7 urandom warning(s) missed due to ratelimiting
