I have tried setting up hotspot in my Jetson Nano having Intel AC8265 for wifi module by following below link
https://couka.de/2020/10/26/jetson-nano-as-access-point/
Once done with all steps, my nano stopped working. It start boot in, but giving error and eventually stops boot in process. Find attached screenshot for reference, please suggest way forward
Please use below method to dump the boot log, capture them all and attach it as a file here.
Do not use the screen or photo to share log, especially a partial log.
Hi @WayneWWW,
Thanks for quick response. When this issue happens, nano not getting boot in. Because of this reason, I have removed Wifi module from nano. Do you think, I have to add this again to collect the logs
If you want us to help check your issue, then yes. That is the reason you filed this topic, isn’t it?
