My Jetson Nano gets stuck here while trying to flash it using ./flash. Any ideas about why? Thanks in advance
[ 2.8766 ] Retrieving storage infomation
[ 2.8880 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 2.8902 ] Applet is not running on device. Continue with Bootloader
[ 3.5821 ]
[ 3.5879 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 3.5897 ] Cboot version 00.01.0000
[ 3.6471 ] Saved platform info in storage_info.bin
c^CTraceback (most recent call last):
File “/home/yahboom/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2502, in tegraflash_get_storage_info
run_command(command)
File “/home/yahboom/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 207, in run_command
'\nCommand ’ + ’ '.join(cmd))
tegraflash_internal.tegraflash_exception: ‘Return value 8\nCommand tegrarcm --oem platformdetails storage storage_info.bin’
During handling of the above exception, another exception occurred:
File “./tegraflash.py”, line 1296, in
tegraflash_run_commands()
File “./tegraflash.py”, line 1155, in tegraflash_run_commands
interpreter.onecmd(command)
File “/usr/lib/python3.6/cmd.py”, line 217, in onecmd
return func(arg)
File “./tegraflash.py”, line 216, in do_flash
tegraflash_flash(exports)
File “/home/yahboom/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 274, in tegraflash_flash
tegraflash_get_storage_info()
File “/home/yahboom/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2506, in tegraflash_get_storage_info
File “/home/yahboom/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 202, in run_command
log = print_process(process, enable_print)
File “/home/yahboom/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 161, in print_process
output = process.stdout.read(1)
KeyboardInterrupt
Failed flashing t210ref.
