Jetson nano cant complete booting
Hello everyone
I juat finished setting up my jetson nano last night. This morning i unplugged it and took it to work but i cant seem to get it to fully boot
I get the following
1.0961251 tegradc tegradc.1: dpd enable lookup fail:-19
1.2875591 imx 219 6-0010 : inx219 board setup: error during 12c read probe (-121)
1.2875911 imx 219 6-0010 : board setup failed
cp: not writing through dangling symlink ‘etc/resolv.conf’
/sbin/init: error while loading shared libraries: libip4tc.so.0: cannot open shared object file: No such file or director
2.052038 Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
2.052038
2.061218 CPU: 2 PID: 1 Comm: init Not tainted 4.9.140-tegra #1
2.0673371 Hardware name: NVIDIA Jetson nano Developer Kit (DT)
2.0733661 Call trace:
2.075828 dump backtrace+0X/0x198
2.081251 show stack+ 0x24/0x30
2.086323 dump stack+0X98/0xc0
2.0913951 panic+0x11c/0x298
2.0962081 1 do_exit 0xa04/0xa08
2.1011931 1 do group exit 0x40/0xa8
2.1065271 1 wake up parent +0x0/0x40
2.1120341 1 el0 Svc naked 0x34/0x38
2.117369 SMP: stopping secondary CPUs
2.1213601 Kernel Offset: disabled
2.124865 Memory Limit: none
2.1336501 Rebooting in 5 seconds
Your support is really appreciated
I think the flash process had some problems. Could you share how you flashed your jetson nano?
I’m getting this same error. Everything was working fine until this morning. I clicked the “shutdown” button and everything froze, nothing shut down, I had to unplug manually. Now, I’m getting this message over and over again.
Did you solve the problem? havin the same issue right now
Hi marco.buob,
Please help to open a new topic with more details of your boot issue. Thanks
