Hello, on jetson nano how can i modify the carrier board eeprom data with my custom carrier board name
what are the files do i need to change for that
hello srikanth.reddy1,
may I know what’s your use-case for writing your customize carrier board eeprom?
according to developer guide, you may check Board Configuration session, an EEPROM ID for your custom board is not required.
I think SoM module detects carrier board based on the board-id written in carrier board’s eeprom right? , if i am wrong please correct me.
If SoM module detects carrier board based on carrier board’s eeprom then In order to detect my custom carrier board, i need to write my custom carrier board id to carrier board’s eeprom, how can i write?
please check Jetson Nano Platform Adaptation and Bring-Up for the steps to have board customization.
thanks
