Jetson nano crashed when using gstreamer to display an imx219 camera
I am using commands from this page Nvidia Nano IMX219 camera messages - RidgeRun Developer Connection
dmesg | grep -iw -e imx219 -e vi
and the output
[ 0.439825] iommu: Adding device 54080000.vi to group 11
[ 1.765169] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.788600] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.796180] imx219 7-0010: board setup failed
[ 1.800645] imx219: probe of 7-0010 failed with error -121
[ 1.801166] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.974602] vi 54080000.vi: vi_probe: ++
[ 1.991250] vi 54080000.vi: initialized
[ 1.996601] vi 54080000.vi: subdev nvcsi–2 bound
[ 1.996702] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.996711] vi 54080000.vi: subdev imx219 8-0010 bound
and after i used this command to show this camera
DISPLAY=:0 gst-launch-1.0 nvarguscamerasrc sensor-id=0 num-buffers=300 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! nvvidconv ! queue ! xvimagesink
output:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: PowerService: requested_clock_Hz=13608000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Then nano crashed, with no output and no windows popup.
Could you tell me how i can fix this problem, or could you tell me some methods to diagnose the error.
Thank you so mush!!
This is the wrong forum, moving this to the Jetson Nano section.
hello wy430421,
is there an application hang or system restart failure,
could you please also share logs for checking, you may refer to Serial Console for the wiring to gather debug logs.
BTW,
you may check Applications Using V4L2 IOCTL Directly, please enable V4L2 standard controls to verify basic camera functionality.
thanks
