Nano has almost the same architecture with TX1, So feel free to use the same config file.
hello, im having a hard time trying to run Darknet tiny-yolo in the jetson nano, if i set the Flags to GPU=1 and OPENCV=1 and run the webcam detection sample the system just crash and freeze.
without GPU (GPU=0) I can run the pictures detection without a problem and webcam seems to open but take like 10 min to show a frame from the webcam.
I’ll appreciate any advice or Makefile example of how to make this run.
thank you
Could you try make clean && make again.
If there are something wrong, it should root from the pre-process part.
Read image/decode from webcamera -> resize/channel transform -> cudamemcpy() -> inference(forward) -> result process.
jetbot@jetbot:~/darknet$ head -n 10 Makefile
GPU=1
CUDNN=1
OPENCV=1
OPENMP=0
DEBUG=0
ARCH= -gencode arch=compute_30,code=sm_30 \
-gencode arch=compute_35,code=sm_35 \
-gencode arch=compute_50,code=[sm_50,compute_50] \
-gencode arch=compute_52,code=[sm_52,compute_52]
jetbot@jetbot:~/darknet$ make
make: Nothing to be done for 'all'.
jetbot@jetbot:~/darknet$ time ./darknet detector test cfg/voc.data cfg/yolov3-tiny.cfg yolov3-tiny.weights data/dog.jpg
layer filters size input output
0 conv 16 3 x 3 / 1 416 x 416 x 3 -> 416 x 416 x 16 0.150 BFLOPs
1 max 2 x 2 / 2 416 x 416 x 16 -> 208 x 208 x 16
2 conv 32 3 x 3 / 1 208 x 208 x 16 -> 208 x 208 x 32 0.399 BFLOPs
3 max 2 x 2 / 2 208 x 208 x 32 -> 104 x 104 x 32
4 conv 64 3 x 3 / 1 104 x 104 x 32 -> 104 x 104 x 64 0.399 BFLOPs
5 max 2 x 2 / 2 104 x 104 x 64 -> 52 x 52 x 64
6 conv 128 3 x 3 / 1 52 x 52 x 64 -> 52 x 52 x 128 0.399 BFLOPs
7 max 2 x 2 / 2 52 x 52 x 128 -> 26 x 26 x 128
8 conv 256 3 x 3 / 1 26 x 26 x 128 -> 26 x 26 x 256 0.399 BFLOPs
9 max 2 x 2 / 2 26 x 26 x 256 -> 13 x 13 x 256
10 conv 512 3 x 3 / 1 13 x 13 x 256 -> 13 x 13 x 512 0.399 BFLOPs
11 max 2 x 2 / 1 13 x 13 x 512 -> 13 x 13 x 512
12 conv 1024 3 x 3 / 1 13 x 13 x 512 -> 13 x 13 x1024 1.595 BFLOPs
13 conv 256 1 x 1 / 1 13 x 13 x1024 -> 13 x 13 x 256 0.089 BFLOPs
14 conv 512 3 x 3 / 1 13 x 13 x 256 -> 13 x 13 x 512 0.399 BFLOPs
15 conv 255 1 x 1 / 1 13 x 13 x 512 -> 13 x 13 x 255 0.044 BFLOPs
16 yolo
17 route 13
18 conv 128 1 x 1 / 1 13 x 13 x 256 -> 13 x 13 x 128 0.011 BFLOPs
19 upsample 2x 13 x 13 x 128 -> 26 x 26 x 128
20 route 19 8
21 conv 256 3 x 3 / 1 26 x 26 x 384 -> 26 x 26 x 256 1.196 BFLOPs
22 conv 255 1 x 1 / 1 26 x 26 x 256 -> 26 x 26 x 255 0.088 BFLOPs
23 yolo
Loading weights from yolov3-tiny.weights...Done!
data/dog.jpg: Predicted in 0.079204 seconds.
sheep: 56%
bird: 52%
cat: 56%
bird: 62%
bicycle: 58%
Gtk-Message: 22:16:26.889: Failed to load module "canberra-gtk-module"
^C
real 0m11.218s
user 0m4.176s
sys 0m1.524s
I run tiny-yolo on jetson nano with Tensorrt5.0 ,the model used lightweight-yolov3 .
Using previously generated plan file located at data/yolov3-1-kFLOAT-kGPU-batch1.engine
Loading TRT Engine…
Loading Complete!
trt-yolo-app: /home/ai/TensorRT_yolo3_module/deepstream_reference_apps/yolo/lib/yolo.cpp:646: bool Yolo::verifyYoloEngine(): Assertion `get3DTensorVolume(m_Engine->getBindingDimensions(tensor.bindingIndex)) == tensor.volume && “Tensor volumes dont match between cfg and engine file \n”’ failed.
Aborted (core dumped)
