How can I change at runtime the values of the Gst-nvinfer properties and class attributes (such as ‘Interval’ and ‘pre-cluster-threshold’) in our Python DeepStream application?
We don’t support changing the values dynamically. You would need to terminate and re-launch the pipeline with new values.
You could modify nvinfer plugin code to support on the fly updates, nvinfer plugin code is open source + see example of add remove streams on the fly on https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/runtime_source_add_delete
