Jetson nano dev kit B01 Booting time to time
Ubuntu 20.04 OS is installed in the SD card. The board and the OS worked perfectly for few weeks. After I bought a power adapter which powers the board through the barrel connector and in the same day I powered up using a Li-Po battery also which connected to the barrel connector too. From that day onwards my jetson nano behaviors weirdly. All the time green LED is light up no problem with the powering up but OS not booting up most of the time once I detach the jetson nano from the dev board or remove and re-insert the SD card allows the OS running again. However sometimes this also not gonna work for days but after some days it works again. Its behavior is totally un predictable but the interesting thing is till now it never stopped working while we working with the board. I think you got my point. Please give me some solution and some instructions.
Hi prabashwara21,
What is that power supply?
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
And also share the serial console log when you hit the boot issue.
