Hey guys
I am trying to reconfigure “Jetson Nano Developer Kit 40-Pin Expansion Header” following the document “DA_09565-001” step by step carefully. Everything was ok until I rebooted Nano which was flashed with new u-boot.bin and dtb files. Something seems to be wrong, the u-boot was stopped by some error as follows:
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.140] Power-up reason: pmc por
[0000.143] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.149] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.158] max77620 disabling SD1 Remote Sense
[0000.162] Setting DDR voltage to 1125mv
[0000.166] Serial Number of Pmic Max77663: 0x1b10f0
[0000.174] Entering ramdump check
[0000.177] Get RamDumpCarveOut = 0x0
[0000.180] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.185] Last reboot was clean, booting normally!
[0000.190] Sdram initialization is successful
[0000.194] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.200] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.206] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.229] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.235] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.251] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.396] Csd NumOfBlocks=31116288
[0000.401] Set High speed to 1
[0000.404] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.414] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.421] Number of retries left 4
[0000.429] Using GPT Primary to query partitions
[0000.434] Loading Tboot-CPU binary
[0000.446] Verifying TBC in OdmNonSecureSBK mode
[0000.456] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.463] Bootloader downloaded successfully.
[0000.467] Downloaded Tboot-CPU binary to 0xa0000258
[0000.472] MAX77620_GPIO5 configured
[0000.476] CPU power rail is up
[0000.478] CPU clock enabled
[0000.482] Performing RAM repair
[0000.485] Updating A64 Warmreset Address to 0xa00002e9
[0000.490] Loading NvTbootBootloaderDTB
[0000.528] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.593] Bootloader DTB Load Address: 0x83000000
[0000.597] Loading NvTbootKernelDTB
[0000.635] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.699] Kernel DTB Load Address: 0x83100000
[0000.706] Loading cboot binary
[0000.750] Verifying EBT in OdmNonSecureSBK mode
[0000.792] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.799] Bootloader downloaded successfully.
[0000.804] Next binary entry address: 0x92c00258
[0000.808] BoardId: 3448
[0000.813] Overriding pmu board id with proc board id
[0000.817] Display board id is not available
[0000.860] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.912] /bpmp deleted
[0000.914] SC7EntryFw header found loaded at 0xff700000
[0001.102] OVR2 PMIC
[0001.104] Bpmp FW successfully loaded
[0001.110] WB0 init successfully at 0xff780000
[0001.115] Set NvDecSticky Bits
[0001.118] GSC2 address ff53fffc value c0edbbcc
[0001.124] GSC MC Settings done
[0001.130] TOS Image length 53680
[0001.133] Monitor size 53680
[0001.135] OS size 0
[0001.146] Secure Os AES-CMAC Verification Success!
[0001.150] TOS image cipher info: plaintext
[0001.154] Loading and Validation of Secure OS Successful
[0001.170] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.175] NvTbootPackSdramParams: start.
[0001.180] NvTbootPackSdramParams: done.
[0001.183] Tegraboot started after 53761 us
[0001.187] Basic modules init took 788207 us
[0001.191] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.197] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.203] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.209] Storage Device Read Time = 178 ms, Read Size = 2226 KB
[0001.215] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.220] Next stage binary read took 39335 us
[0001.224] Carveout took -51000 us
[0001.228] CPU initialization took 381952 us
[0001.232] Total time taken by TegraBoot 1158494 us
[0001.236] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 21:10:01, Aug 12 2019
ERROR: Error initializing runtime service trusty_fast
[0001.359] RamCode = 0
[0001.363] LPDDR4 Training: Read DT: Number of tables = 2
[0001.368] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.381] EMC Training Successful
[0001.384] 408000 not found in DVFS table
[0001.391] RamCode = 0
[0001.394] DT Write: emc-table@204000 succeeded
[0001.399] DT Write: emc-table@1600000 succeeded
[0001.404] LPDDR4 Training: Write DT: Number of tables = 2
[0001.446]
[0001.447] Debug Init done
[0001.450] Marked DTB cacheable
[0001.453] Bootloader DTB loaded at 0x83000000
[0001.458] Marked DTB cacheable
[0001.461] Kernel DTB loaded at 0x83100000
[0001.464] DeviceTree Init done
[0001.476] Pinmux applied successfully
[0001.480] gicd_base: 0x50041000
[0001.484] gicc_base: 0x50042000
[0001.487] Interrupts Init done
[0001.491] Using base:0x60005090 & irq:208 for tick-timer
[0001.496] Using base:0x60005098 for delay-timer
[0001.501] platform_init_timer: DONE
[0001.504] Timer(tick) Init done
[0001.508] osc freq = 38400 khz
[0001.512]
[0001.513] welcome to cboot
[0001.516]
[0001.517] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.522] calling constructors
[0001.525] initializing heap
[0001.527] initializing threads
[0001.530] initializing timers
[0001.533] creating bootstrap completion thread
[0001.538] top of bootstrap2()
[0001.540] CPU: ARM Cortex A57
[0001.543] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.548] initializing platform
[0001.551] Scratch reg 37 & 271 initial value set…
[0001.557] cboot:secure-pmc present
[0001.561] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.565] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.570] Macronix QSPI chip present
[0001.573] SPI device register
[0001.576] init boot device
[0001.579] allocating memory for boot device(SPI)
[0001.583] registering boot device
[0001.593] sdmmc node status = okay
[0001.596] sdcard instance = 0
[0001.599] sdcard gpio handle 0x56
[0001.602] sdcard gpio pin 0xc9
[0001.605] sdcard gpio flags 0x0
[0001.608] vmmc-supply 0x99
[0001.610] Instance: 0
[0001.613] Allocating memory for context
[0001.616] enabling clock
[0001.619] sd card init
[0001.621] Check card present and stable
[0001.625] Send command 0
[0001.645] Send command 3
[0001.650] Set RCA for the card
[0001.653] Query card specific data by command 9
[0001.659] Parse CSD data
[0001.661] Send command 7
[0001.672] Calling sd device register
[0001.675] Init sdcard
[0001.677] Allocating memory for boot device
[0001.682] Registering user device
[0001.695] Enable APE clock
[0001.697] Un-powergate APE partition
[0001.701] of_register: registering tegra_udc to of_hal
[0001.706] of_register: registering tegra_udc to of_hal
[0001.711] of_register: registering inv20628-driver to of_hal
[0001.717] of_register: registering ads1015-driver to of_hal
[0001.722] of_register: registering lp8557-bl-driver to of_hal
[0001.728] of_register: registering bq2419x_charger to of_hal
[0001.734] of_register: registering cpc to of_hal
[0001.738] of_register: registering bq27441_fuel_gauge to of_hal
[0001.750] gpio framework initialized
[0001.753] of_register: registering tca9539_gpio to of_hal
[0001.758] of_register: registering tca9539_gpio to of_hal
[0001.764] of_register: registering i2c_bus_driver to of_hal
[0001.769] of_register: registering i2c_bus_driver to of_hal
[0001.775] of_register: registering i2c_bus_driver to of_hal
[0001.780] of_register: registering i2c_bus_driver to of_hal
[0001.786] pmic framework initialized
[0001.789] of_register: registering max77620_pmic to of_hal
[0001.795] regulator framework initialized
[0001.799] of_register: registering tps65132_bl_driver to of_hal
[0001.805] initializing target
[0001.810] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.819] fixed regulator driver initialized
[0001.836] initializing OF layer
[0001.839] NCK carveout not present
[0001.842] Skipping dts_overrides
[0001.846] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.863] I2C Bus Init done
[0001.866] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.876] I2C Bus Init done
[0001.878] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.889] I2C Bus Init done
[0001.891] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.902] I2C Bus Init done
[0001.904] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.914] I2C Bus Init done
[0001.917] of_children_init: Ops found for compatible string maxim,max77620
[0001.927] max77620_init using irq 118
[0001.932] register ‘maxim,max77620’ pmic
[0001.936] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.943] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.953] I2C Bus Init done
[0001.957] NCK carveout not present
[0001.960] shim_invoke: No NCT, Calling dts updates
[0001.971] Find /i2c@7000c000’s alias i2c0
[0001.975] get eeprom at 1-a0, size 256, type 0
[0001.984] Find /i2c@7000c500’s alias i2c2
[0001.988] get eeprom at 3-a0, size 256, type 0
[0001.992] get eeprom at 3-ae, size 256, type 0
[0001.997] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.002] I2C slave not started
[0002.005] I2C write failed
[0002.007] Writing offset failed
[0002.010] eeprom_init: EEPROM read failed
[0002.014] pm_ids_update: eeprom init failed
[0002.019] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.049] pm_ids_update: The pm board id is 3448-0000-200
[0002.055] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.063] pm_ids_update: pm id update successful
[0002.067] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.098] pm_ids_update: The pm board id is 3449-0000-200
[0002.104] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.112] pm_ids_update: pm id update successful
[0002.142] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.148] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.156] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.162] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.170] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:4f:10
[0002.177] Plugin Manager: Parse ODM data 0x00094000
[0002.187] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.208] Find /i2c@7000c000’s alias i2c0
[0002.212] get eeprom at 1-a0, size 256, type 0
[0002.221] Find /i2c@7000c500’s alias i2c2
[0002.224] get eeprom at 3-a0, size 256, type 0
[0002.229] get eeprom at 3-ae, size 256, type 0
[0002.233] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.239] I2C slave not started
[0002.242] I2C write failed
[0002.244] Writing offset failed
[0002.247] eeprom_init: EEPROM read failed
[0002.251] pm_ids_update: eeprom init failed
[0002.255] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.285] pm_ids_update: The pm board id is 3448-0000-200
[0002.292] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.299] pm_ids_update: pm id update successful
[0002.303] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.333] pm_ids_update: The pm board id is 3449-0000-200
[0002.340] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.347] pm_ids_update: pm id update successful
[0002.377] Chip UID is 00000001644495812000000018060200
[0002.383] Add serial number:14224190463130000206 as DT property
[0002.391] Applying platform configs
[0002.397] platform-init is not present. Skipping
[0002.402] calling apps_init()
[0002.422] Found 14 GPT partitions in “sd0”
[0002.426] Proceeding to Cold Boot
[0002.429] starting app android_boot_app
[0002.433] Device state: unlocked
[0002.436] display console init
[0002.444] could not find regulator
[0002.447] hdmi cable connected
[0002.463] edid read success
[0002.476] DT entry for leds-pwm not found
[0002.482] edid read success
[0002.484] width = 640, height = 480, frequency = 25174825
[0002.490] width = 640, height = 480, frequency = 25174825
[0002.495] width = 640, height = 480, frequency = 25174825
[0002.500] width = 640, height = 480, frequency = 25174825
[0002.506] width = 2560, height = 1440, frequency = 241500000
[0002.512] width = 1920, height = 1080, frequency = 148500000
[0002.517] width = 1920, height = 1080, frequency = 148351648
[0002.523] width = 1920, height = 1080, frequency = 148351648
[0002.528] width = 1280, height = 720, frequency = 74175824
[0002.534] width = 1280, height = 720, frequency = 74175824
[0002.539] width = 720, height = 480, frequency = 26973026
[0002.545] width = 720, height = 576, frequency = 26973026
[0002.550] width = 720, height = 480, frequency = 26973026
[0002.555] width = 720, height = 576, frequency = 26973026
[0002.561] width = 640, height = 480, frequency = 25174825
[0002.566] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.574] tmds-config node not found
[0002.578] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.593] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.600] could not find regulator
[0002.604] could not find regulator
[0002.607] could not find regulator
[0002.635] using default cmu settings
[0002.639] dc_hdmi_enable, starting HDMI initialisation
[0002.645] dc_hdmi_enable, HDMI initialisation complete
[0002.650] list and configure display window
[0002.659] display console init completed
[0002.670] subnode volume_up is not found !
[0002.674] subnode back is not found !
[0002.677] subnode volume_down is not found !
[0002.682] subnode menu is not found !
[0002.685] Gpio keyboard init success
[0002.731] found decompressor handler: lz4-legacy
[0002.745] decompressing blob (type 1)…
[0002.781] load_bmp_blob: panelresolution=1080 type=3
[0002.833] decompressor handler not found
[0002.837] load_firmware_blob: Firmware blob loaded, entries=2
[0002.843] se_aes_verify_sbk_clear: Error
[0002.847] bl_battery_charging: connected to external power supply
[0002.854] xusb is supported
[0002.860] error while finding nvidia,portmap
[0002.865] could not find regulator
[0003.369] xusb blob version 0 size 124416
[0003.372] firmware size 124416
[0003.377] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.393] xhci0: 64 bytes context size, 32-bit DMA
[0003.433] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.453] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.103] uhub0: 9 ports with 9 removable, self powered
[0005.103] failed to get HID devices
[0005.106] failed to init xhci or no usb device attached
[0005.117] device_query_partition_size: failed to open partition sd0:MSC !
[0005.124] MSC Partition not found
[0005.130] device_query_partition_size: failed to open partition sd0:USP !
[0005.137] USP partition read failed!
[0005.140] blob_init: blob-partition USP header read failed
[0005.146] android_boot Unable to update recovery partition
[0005.151] kfs_getpartname: name = LNX
[0005.155] Loading kernel from LNX
[0005.214] Verifying boot image in OdmNonSecureSBK mode
[0005.258] kernel load address: 0x80080000, size: 481226 bytes
[0005.263] ramdisk load address: 0x84100000, size: 0 bytes
[0005.269] load kernel from storage
[0005.280] decompressor handler not found
[0005.337] Successfully loaded kernel and ramdisk images
[0005.344] load_bmp_blob: panelresolution=1080 type=3
[0005.842] display bmp image done
[0005.845] NCK carveout not present
[0005.848] Skipping dts_overrides
[0005.851] NCK carveout not present
[0005.854] shim_invoke: No NCT, Calling dts updates
[0005.866] Find /i2c@7000c000’s alias i2c0
[0005.869] get eeprom at 1-a0, size 256, type 0
[0005.878] Find /i2c@7000c500’s alias i2c2
[0005.882] get eeprom at 3-a0, size 256, type 0
[0005.887] get eeprom at 3-ae, size 256, type 0
[0005.891] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.896] I2C slave not started
[0005.899] I2C write failed
[0005.902] Writing offset failed
[0005.905] eeprom_init: EEPROM read failed
[0005.909] pm_ids_update: eeprom init failed
[0005.913] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.943] pm_ids_update: The pm board id is 3448-0000-200
[0005.950] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.957] pm_ids_update: pm id update successful
[0005.962] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.992] pm_ids_update: The pm board id is 3449-0000-200
[0005.998] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0006.006] pm_ids_update: pm id update successful
[0006.036] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.042] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0006.050] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.056] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0006.065] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:4f:10
[0006.071] Plugin Manager: Parse ODM data 0x00094000
[0006.081] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.096] Add serial number:14224190463130000206 as DT property
[0006.105] “bpmp” doesn’t exist, creating
[0006.111] Updated bpmp info to DTB
[0006.116] Updated initrd info to DTB
[0006.119] “proc-board” doesn’t exist, creating
[0006.125] Updated board info to DTB
[0006.128] “pmu-board” doesn’t exist, creating
[0006.133] Updated board info to DTB
[0006.137] “display-board” doesn’t exist, creating
[0006.142] Updated board info to DTB
[0006.146] “reset” doesn’t exist, creating
[0006.150] Updated reset info to DTB
[0006.154] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb3000 is_hdmi_initialised=1
[0006.192] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.205] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.218] Updated bootarg info to DTB
[0006.222] Adding uuid 00000001644495812000000018060200 to DT
[0006.227] Adding eks info 0 to DT
[0006.233] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.239] Updated memory info to DTB
[0006.244] Updated system-lp0-disable info to DTB
[0006.253] set vdd_core voltage to 1075 mv
[0006.256] setting ‘vdd-core’ regulator to 1075000 micro volts
[0006.273] could not find regulator
[0006.277] Found secure-pmc; disable BPMP
U-Boot 2016.07 (Nov 22 2019 - 17:26:21 +0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Card did not respond to voltage select!
** Bad device mmc 1 **
Hit any key to stop autoboot: 0
starting USB…
USB0: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
USB error: all controllers failed lowlevel init
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-00-04-4b-e6-4f-10
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 *** ERROR:
serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 *** ERROR:
serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 *** ERROR:
serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 *** ERROR:
serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-tegra210 *** ERROR:
serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default *** ERROR:
serverip’ not set
Config file not found
starting USB…
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Tegra210 (P3450-Porg) #
The name of the document “DA_09565-001” is “Jetson Nano Developer Kit 40-Pin Expansion Header Configuration Application Note”, with partnumber “DA_09565-001 | August 2019”
The spreadsheet I was using is “Jetson_Nano_Module_Pinmux_Config_Template.xlsm”, which was download from the follwing url.
https://developer.nvidia.com/embedded/downloads#?tx=$product,jetson_nano
But I modified only one GPIO in the spreadsheet “Jetson_Nano_Module_Pinmux_Config_Template.xlsm” like the following picture.
And there is not other modification to the spreadsheet “Jetson_Nano_Module_Pinmux_Config_Template.xlsm” .
