Jetson Nano developer kit doesn't work with Waveshare Jetracer
I’m new to Jetsons, and I recently bought Waveshare’s JetRacer AI Racer Kit. I reset it using SDK Manager with Ubuntu, but now I want to flash JetRacer’s own image with SD card. However, no matter when I insert the SD card into the Jetson, it doesn’t recognize it. Even when the SD card is empty, it still doesn’t show up. As I mentioned, I’m new to robotics.
Guessing that’s the bootloader mismatch issue.
You may need to flash the same JetPack SW version as the JetRacer image.
Thanks I will try that now and notify you. I found out I flashed my jetson with Jetpack 4.6 but image supports 4.5.
so I flashed the Jetson Nano with Jetpack 4.5 and suddenly my wifi module started to overheat and I could not fix it. I ordered new one thanks for the help!
What’s wifi module your are using?
Please record the serial console log for us to review.
