Jetson nano developer kit jumper question
hi,
i just purchase the following item:
945-13450-0000-100 , and found that there are some discrepancy on the jumper area.
like to check by default when open from brand new package. what is the correct position of the jumper?
by default, should the jumper be completely covered or covered half way?
It is J48.
[J48] Enables either J28 Micro-USB connector or J25 power jack as power source for the developer kit. Without a jumper, the developer kit can be powered by J28 Micro-USB connector. With a jumper, no power is drawn from J28, and the developer kit can be powered via J25 power jack.
hi Sir,
from original condition, what is the jumper default positioning? should it be placed at J28 or J25?
With or without jumper, both are ok.
