I have the problem that the Jetson Nano B01 Development kit is not recognized over usb.
I’m running Ubuntu 18.04 on my host. I connect the Jetson with the MicroUsb to USB cable. I connect the USB port on my host.I run Jetson into recovery mode
lsusb is not listing the device. If I run dmesg --follow and replug the usb cable, I get
[ 8895.018055] usb 1-1.5: new full-speed USB device number 69 using ehci-pci
[ 8895.098053] usb 1-1.5: device descriptor read/64, error -32
[ 8895.286049] usb 1-1.5: device descriptor read/64, error -32
[ 8895.474016] usb 1-1.5: new full-speed USB device number 70 using ehci-pci
[ 8895.554055] usb 1-1.5: device descriptor read/64, error -32
[ 8895.742037] usb 1-1.5: device descriptor read/64, error -32
[ 8895.850159] usb 1-1-port5: attempt power cycle
[ 8896.454025] usb 1-1.5: new full-speed USB device number 71 using ehci-pci
[ 8896.870039] usb 1-1.5: device not accepting address 71, error -32
[ 8896.950016] usb 1-1.5: new full-speed USB device number 72 using ehci-pci
[ 8897.366006] usb 1-1.5: device not accepting address 72, error -32
[ 8897.366136] usb 1-1-port5: unable to enumerate USB device
[ 9008.171817] usb 1-1.5: new full-speed USB device number 73 using ehci-pci
[ 9008.251835] usb 1-1.5: device descriptor read/64, error -32
[ 9008.439811] usb 1-1.5: device descriptor read/64, error -32
[ 9008.627807] usb 1-1.5: new full-speed USB device number 74 using ehci-pci
[ 9008.707816] usb 1-1.5: device descriptor read/64, error -32
[ 9008.895804] usb 1-1.5: device descriptor read/64, error -32
[ 9009.004024] usb 1-1-port5: attempt power cycle
[ 9009.607788] usb 1-1.5: new full-speed USB device number 75 using ehci-pci
[ 9010.023750] usb 1-1.5: device not accepting address 75, error -32
[ 9010.103750] usb 1-1.5: new full-speed USB device number 76 using ehci-pci
[ 9010.519768] usb 1-1.5: device not accepting address 76, error -32
ubuntu@ubuntu:~$ lsusb
Bus 002 Device 004: ID 8564:1000 Transcend Information, Inc. JetFlash
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 089: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Any hints to what I could do?
