I would like to ask for help:
I have a Jetson Nano devkit module with an SD card (P3448-0000) and a custom board instead of the NVIDIA board (P3449-0000).
The module works perfectly in my custom board and L4T32.7.2. Also, the module with emmc (p3448-0002) works perfectly with my custom board and L4T32.7.6. But when I want to use P3448-0000 with L4T32.7.6, it does not want to boot on my custom board
I tried to flash it with several variants of params for flash.sh script, e.g.:
- `./flash.sh jetson-nano-devkiti mmcblk0p1`
- `sudo BOARDID=3448 FAB=300 BOARDSKU=0000 BOARDREV=B00 PYTHON=python2 ./flash.sh p3448-0000-max-spi mmcblk0p1`
- `sudo BOARDID=3448 FAB=300 BOARDSKU=0002 BOARDREV=B00 PYTHON=python2 ./flash.sh p3448-0000-max-spi mmcblk0p1`
- and several other
can you help me? here is output from minicom
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x10
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0xd06ae
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.273] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.277] Nano-SD: checking PT table on QSPI ...
[0000.281] Initialize FailControl
[0000.284] Read PT from (2:0)
[0000.314] PT crc32 and magic check passed.
[0000.318] Using BFS PT to query partitions
[0000.324] Loading Tboot-CPU binary
[0000.352] Verifying TBC in OdmNonSecureSBK mode
[0000.363] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.370] Bootloader downloaded successfully.
[0000.375] Downloaded Tboot-CPU binary to 0xa0000258
[0000.380] MAX77620_GPIO5 configured
[0000.383] CPU power rail is up
[0000.386] CPU clock enabled
[0000.390] Performing RAM repair
[0000.392] Updating A64 Warmreset Address to 0xa00002e9
[0000.397] BoardID = 3448, SKU = 0x0
[0000.401] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.405] Nano-SD: checking PT table on QSPI ...
[0000.409] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.415] Loading NvTbootBootloaderDTB
[0000.481] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.553] Bootloader DTB Load Address: 0x83000000
[0000.558] BoardID = 3448, SKU = 0x0
[0000.561] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.565] Nano-SD: checking PT table on QSPI ...
[0000.569] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.575] Loading NvTbootKernelDTB
[0000.641] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.712] Kernel DTB Load Address: 0x83100000
[0000.717] BoardID = 3448, SKU = 0x0
[0000.720] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.724] Nano-SD: checking PT table on QSPI ...
[0000.728] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.736] Loading cboot binary
[0000.852] Verifying EBT in OdmNonSecureSBK mode
[0000.893] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.900] Bootloader downloaded successfully.
[0000.905] BoardID = 3448, SKU = 0x0
[0000.908] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.912] Nano-SD: checking PT table on QSPI ...
[0000.916] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.922] PT: Partition NCT NOT found !
[0000.926] Warning: Find Partition via PT Failed
[0000.930] Next binary entry address: 0x92c00258
[0000.935] BoardId: 3448
[0000.939] Overriding pmu board id with proc board id
[0000.944] Display board id is not available
[0000.948] BoardID = 3448, SKU = 0x0
[0000.952] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.955] Nano-SD: checking PT table on QSPI ...
[0000.960] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.066] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.156] /bpmp deleted
[0001.159] SC7EntryFw header found loaded at 0xff700000
[0001.566] OVR2 PMIC
[0001.568] Bpmp FW successfully loaded
[0001.571] BoardID = 3448, SKU = 0x0
[0001.575] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.578] Nano-SD: checking PT table on QSPI ...
[0001.583] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.590] WB0 init successfully at 0xff780000
[0001.594] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.599] Set NvDecSticky Bits
[0001.603] GSC2 address ff53fffc value c0edbbcc
[0001.609] GSC MC Settings done
[0001.612] BoardID = 3448, SKU = 0x0
[0001.615] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.619] Nano-SD: checking PT table on QSPI ...
[0001.623] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.630] TOS Image length 53680
[0001.633] Monitor size 53680
[0001.636] OS size 0
[0001.651] Secure Os AES-CMAC Verification Success!
[0001.656] TOS image cipher info: plaintext
[0001.660] Loading and Validation of Secure OS Successful
[0001.676] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.680] NvTbootPackSdramParams: start.
[0001.685] NvTbootPackSdramParams: done.
[0001.689] Tegraboot started after 52344 us
[0001.693] Basic modules init took 937234 us
[0001.697] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.703] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.708] Next stage binary read took 102860 us
[0001.712] Carveout took -132462 us
[0001.716] CPU initialization took 770183 us
[0001.720] Total time taken by TegraBoot 1677815 us
[0001.725] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):269577911
NOTICE: BL31: Built : 23:37:38, Nov 4 2024
ERROR: Error initializing runtime service trusty_fast
[0001.847] RamCode = 0
[0001.857] LPDDR4 Training: found 4 entries (2 nominal, 2 derated)
[0001.862] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.875] EMC Training Successful
[0001.878] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.891] EMC Training Successful
[0001.894] 408000 not found in DVFS table
[0001.935] RamCode = 0
[0001.941] DT Write: emc-table@204000 succeeded
[0001.949] DT Write: emc-table@1600000 succeeded
[0001.958] DT Write: emc-table-derated@204000 succeeded
[0001.967] DT Write: emc-table-derated@1600000 succeeded
[0001.972] LPDDR4 Training: Write DT: Number of tables = 4
[0002.028]
[0002.029] Debug Init done
[0002.032] Marked DTB cacheable
[0002.034] Bootloader DTB loaded at 0x83000000
[0002.039] Marked DTB cacheable
[0002.042] Kernel DTB loaded at 0x83100000
[0002.046] DeviceTree Init done
[0002.061] Pinmux applied successfully
[0002.066] gicd_base: 0x50041000
[0002.069] gicc_base: 0x50042000
[0002.072] Interrupts Init done
[0002.077] Using base:0x60005090 & irq:208 for tick-timer
[0002.082] Using base:0x60005098 for delay-timer
[0002.087] platform_init_timer: DONE
[0002.090] Timer(tick) Init done
[0002.094] osc freq = 38400 khz
[0002.098]
[0002.099] Welcome to L4T Cboot
[0002.102]
[0002.103] Cboot Version: 00.00.2018.01-t210-acb23272
[0002.108] calling constructors
[0002.111] initializing heap
[0002.114] initializing threads
[0002.117] initializing timers
[0002.120] creating bootstrap completion thread
[0002.124] top of bootstrap2()
[0002.127] CPU: ARM Cortex A57
[0002.130] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.135] initializing platform
[0002.143] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0002.147] ID LSB = 0x36, ID-CFI len = 194 bytes
[0002.152] Macronix QSPI chip present
[0002.155] SPI device register
[0002.158] init boot device
[0002.161] allocating memory for boot device(SPI)
[0002.165] registering boot device
[0002.174] QSPI bdev is already initialized
[0002.178] Enable APE clock
[0002.180] Un-powergate APE partition
[0002.184] of_register: registering tegra_udc to of_hal
[0002.189] of_register: registering inv20628-driver to of_hal
[0002.195] of_register: registering ads1015-driver to of_hal
[0002.200] of_register: registering lp8557-bl-driver to of_hal
[0002.206] of_register: registering bq2419x_charger to of_hal
[0002.212] of_register: registering bq27441_fuel_gauge to of_hal
[0002.224] gpio framework initialized
[0002.228] of_register: registering tca9539_gpio to of_hal
[0002.233] of_register: registering tca9539_gpio to of_hal
[0002.238] of_register: registering i2[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
minicom output from another attempt:
[0002.239] of_register: registering i2c_bus_driver to of_hal
[0002.244] of_register: registering i2c_bus_driv[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
