Are the Jetson Nano DLI courses going to be updated? The videos reference things that no longer work.
8-Dale
8-Dale
Hi @HybridRobotics, the ‘Getting Started With AI on Jetson Nano’ DLI course should still run on Nano, using the nvcr.io/nvidia/dli/dli-nano-ai:v2.0.2-r32.7.1
container from NGC on JetPack 4.6 (or an older version of the container if you’re still running an older version of JetPack-L4T). Is there a particular issue that you’re having?
The tutorial video shows a much older tag for the docker image. I fixed that.
Now, I get
docker: Error response from daemon: unauthorized: authentication required
which I do not understand. I am in the docker group.
My current run file:
docker run --runtime nvidia -it --rm --network host \ --volume -v /home/hybotics/NVIDIA_Deep-Learning-Institute/dli-data:/nvidia-dli-nano/data \ --device /dev/video0 \ nvcr.io/nvidia/dli-nano-ai:v2.0.2-r32.7.1
8-Dale
Do you get the same ‘authentication required’ error if you run sudo docker pull nvcr.io/nvidia/dli/dli-nano-ai:v2.0.2-r32.7.1
If so, you may need to login to the nvcr.io registry. First, login to NGC and create an API key, as shown under the Get a New API Key for the NGC Registry
section of this page: NGC Container Registry for DGX User Guide :: DGX Systems Documentation
Then run sudo docker login nvcr.io
on your Jetson and enter the following credentials:
Username: $oauthtoken
Password: YOUR_NGC_API_KEY
Then try running sudo docker pull nvcr.io/nvidia/dli/dli-nano-ai:v2.0.2-r32.7.1
again.
I am logged into NGC with my API key as directed in the instructions.
Yes, I still get an error.
I got my API key and got logged into nvcr.io. Big progress! This entire procedure is not intuitive at all and needs to be simplified for people like me. I am not a corporate entity. I am just one guy with a dream, using now outdated NVIDIA hardware to build robots.
Now, I get:
docker: Error response from daemon: pull access denied for nvcr.io/nvidia/dli-nano-ai, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
8-Dale
Sorry, I got my URLs confused between my first and second reply - can you try sudo docker pull nvcr.io/nvidia/dli/dli-nano-ai:v2.0.2-r32.7.1
instead? (note the /dli
in there - corrected this above)
You should not actually need authentication to pull this container, and so I wonder if what actually happen is that we had the URL mixed up here.
It is working with the updated URL! Thank you, Dusty!
Now, I just have to figure out how to get my camera working.
8-Dale
