Jetson Nano does not boot after flash
I want to enable PWM on the GPIO pins of my Jetson Nano. For that I exactly followed these instructions: https://developer.download.nvidia.com/assets/embedded/secure/jetson/Nano/docs/customizing_the_jetson_nano_40-pin_expansion_header_v1.2.pdf?2MqObKUvEPNy8PXMT53MWhp6RbVQW0uqdQRYO7WCqK8xoOm5Uq3Gq4oZHnBdHi60Q1nd3MPi6128RxknmpHJYuEjHvvi5l-usFJzAd052aOw6M8riLCLVDs51jZ8nogbLyLEjKj337s5Gsbp71GcTkHT7x8j-whYdf3l-4O9f_gHwN3Nds6pM2OMQOGL9KnFsl14MWkKJGB-k9hlxUtgnBX9zg
Now I am trying to boot my Nano. The yellow power indication light goes on, but apart from that nothing happens. I connected my laptop to the serial port, and it gave me the below output. I removed some lines that seemed not interesting. So I can see two lines that seem to tell me there is an error:
e[23;80H e[24;1HCard did not respond to voltage select!
e[23;80H e[24;1H** Bad device mmc 1 **
I am using a 16 GB raspberry PI SD card to boot from, can this be the issue? Or is there some other reason that it won’t boot?
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
e[23;80H e[24;1H[0001.534] Pinmux applied successfully
e[23;80H e[24;1H[0001.538] gicd_base: 0x50041000
e[23;80H e[24;1H[0001.542] gicc_base: 0x50042000
e[23;80H e[24;1H[0001.545] Interrupts Init done
e[23;80H e[24;1H[0001.549] Using base:0x60005090 & irq:208 for tick-timer
e[23;80H e[24;1H[0001.554] Using base:0x60005098 for delay-timer
e[23;80H e[24;1H[0001.559] platform_init_timer: DONE
e[23;80H e[24;1H[0001.562] Timer(tick) Init done
e[23;80H e[24;1H[0001.566] osc freq = 38400 khz
e[23;80H e[24;1H[0001.570]
e[23;80H e[24;1H[0001.571] welcome to cboot
e[23;80H e[24;1H[0001.574]
e[23;80H e[24;1H[0001.575] Cboot Version: 00.00.2018.01-t210-3a168c35
e[23;80H e[24;1H[0001.580] calling constructors
e[23;80H e[24;1H[0001.583] initializing heap
e[23;80H e[24;1H[0001.585] initializing threads
e[23;80H e[24;1H[0001.588] initializing timers
e[23;80H e[24;1H[0001.591] creating bootstrap completion thread
e[23;80H e[24;1H[0001.595] top of bootstrap2()
e[23;80H e[24;1H[0001.598] CPU: ARM Cortex A57
e[23;80H e[24;1H[0001.601] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
e[23;80H e[24;1H[0001.606] initializing platform
e[23;80H e[24;1H[0001.609] Scratch reg 37 & 271 initial value set…
e[23;80H e[24;1H[0001.615] cboot:secure-pmc present
e[23;80H e[24;1H[0001.619] Manufacturer: MF = 0xc2, ID MSB = 0x25
e[23;80H e[24;1H[0001.623] ID LSB = 0x36, ID-CFI len = 194 bytes
e[23;80H e[24;1H[0001.628] Macronix QSPI chip present
e[23;80H e[24;1H[0001.631] SPI device register
e[23;80H e[24;1H[0001.634] init boot device
e[23;80H e[24;1H[0001.637] allocating memory for boot device(SPI)
e[23;80H e[24;1H[0001.641] registering boot device
e[23;80H e[24;1H[0001.651] sdmmc node status = okay
e[23;80H e[24;1H[0001.654] sdcard instance = 0
e[23;80H e[24;1H[0001.657] sdcard gpio handle 0x56
e[23;80H e[24;1H[0001.660] sdcard gpio pin 0xc9
e[23;80H e[24;1H[0001.663] sdcard gpio flags 0x0
e[23;80H e[24;1H[0001.666] vmmc-supply 0x99
e[23;80H e[24;1H[0001.668] Instance: 0
e[23;80H e[24;1H[0001.671] Allocating memory for context
e[23;80H e[24;1H[0001.674] enabling clock
e[23;80H e[24;1H[0001.677] sd card init
e[23;80H e[24;1H[0001.679] Check card present and stable
e[23;80H e[24;1H[0001.683] Send command 0
e[23;80H e[24;1H[0001.699] Send command 3
e[23;80H e[24;1H[0001.704] Set RCA for the card
e[23;80H e[24;1H[0001.706] Query card specific data by command 9
e[23;80H e[24;1H[0001.713] Parse CSD data
e[23;80H e[24;1H[0001.715] Send command 7
e[23;80H e[24;1H[0001.726] Calling sd device register
e[23;80H e[24;1H[0001.729] Init sdcard
e[23;80H e[24;1H[0001.731] Allocating memory for boot device
e[23;80H e[24;1H[0001.735] Registering user device
e[23;80H e[24;1H[0001.749] Enable APE clock
e[23;80H e[24;1H[0001.751] Un-powergate APE partition
e[23;80H e[24;1H[0001.755] of_register: registering tegra_udc to of_hal
e[23;80H e[24;1H[0001.760] of_register: registering tegra_udc to of_hal
e[23;80H e[24;1H[0001.765] of_register: registering inv20628-driver to of_hal
e[23;80H e[24;1H[0001.771] of_register: registering ads1015-driver to of_hal
e[23;80H e[24;1H[0001.776] of_register: registering lp8557-bl-driver to of_hal
e[23;80H e[24;1H[0001.782] of_register: registering bq2419x_charger to of_hal
e[23;80H e[24;1H[0001.787] of_register: registering cpc to of_hal
e[23;80H e[24;1H[0001.792] of_register: registering bq27441_fuel_gauge to of_hal
e[23;80H e[24;1H[0001.803] gpio framework initialized
e[23;80H e[24;1H[0001.807] of_register: registering tca9539_gpio to of_hal
e[23;80H e[24;1H[0001.812] of_register: registering tca9539_gpio to of_hal
e[23;80H e[24;1H[0001.818] of_register: registering i2c_bus_driver to of_hal
e[23;80H e[24;1H[0001.823] of_register: registering i2c_bus_driver to of_hal
e[23;80H e[24;1H[0001.829] of_register: registering i2c_bus_driver to of_hal
e[23;80H e[24;1H[0001.834] of_register: registering i2c_bus_driver to of_hal
e[23;80H e[24;1H[0001.840] pmic framework initialized
e[23;80H e[24;1H[0001.843] of_register: registering max77620_pmic to of_hal
e[23;80H e[24;1H[0001.849] regulator framework initialized
e[23;80H e[24;1H[0001.853] of_register: registering tps65132_bl_driver to of_hal
e[23;80H e[24;1H[0001.859] initializing target
e[23;80H e[24;1H[0001.864] gpio_driver_register: register ‘tegra_gpio_driver’ driver
e[23;80H e[24;1H[0001.873] fixed regulator driver initialized
e[23;80H e[24;1H[0001.890] initializing OF layer
e[23;80H e[24;1H[0001.893] NCK carveout not present
e[23;80H e[24;1H[0001.896] Skipping dts_overrides
e[23;80H e[24;1H[0001.900] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0001.917] I2C Bus Init done
e[23;80H e[24;1H[0001.919] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0001.930] I2C Bus Init done
e[23;80H e[24;1H[0001.932] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0001.942] I2C Bus Init done
e[23;80H e[24;1H[0001.945] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0001.955] I2C Bus Init done
e[23;80H e[24;1H[0001.958] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0001.968] I2C Bus Init done
e[23;80H e[24;1H[0001.971] of_children_init: Ops found for compatible string maxim,max77620
e[23;80H e[24;1H[0001.981] max77620_init using irq 118
e[23;80H e[24;1H[0001.986] register ‘maxim,max77620’ pmic
e[23;80H e[24;1H[0001.990] gpio_driver_register: register ‘max77620-gpio’ driver
e[23;80H e[24;1H[0001.997] of_children_init: Ops found for compatible string nvidia,tegra210-i2e[24;80H
e[23;80Hce[24;1H[0002.007] I2C Bus Init done
e[23;80H e[24;1H[0002.010] NCK carveout not present
e[23;80H e[24;1H[0002.014] shim_invoke: No NCT, Calling dts updates
e[23;80H e[24;1H[0002.025] Find /i2c@7000c000’s alias i2c0
e[23;80H e[24;1H[0002.029] get eeprom at 1-a0, size 256, type 0
e[23;80H e[24;1H[0002.038] Find /i2c@7000c500’s alias i2c2
e[23;80H e[24;1H[0002.041] get eeprom at 3-a0, size 256, type 0
e[23;80H e[24;1H[0002.046] get eeprom at 3-ae, size 256, type 0
e[23;80H e[24;1H[0002.050] pm_ids_update: Updating 1,a0, size 256, type 0
e[23;80H e[24;1H[0002.056] I2C slave not started
e[23;80H e[24;1H[0002.059] I2C write failed
e[23;80H e[24;1H[0002.061] Writing offset failed
e[23;80H e[24;1H[0002.064] eeprom_init: EEPROM read failed
e[23;80H e[24;1H[0002.068] pm_ids_update: eeprom init failed
e[23;80H e[24;1H[0002.072] pm_ids_update: Updating 3,a0, size 256, type 0
e[23;80H e[24;1H[0002.102] pm_ids_update: The pm board id is 3448-0000-200
e[23;80H e[24;1H[0002.109] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
e[23;80H e[24;1H[0002.117] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.121] pm_ids_update: Updating 3,ae, size 256, type 0
e[23;80H e[24;1H[0002.151] pm_ids_update: The pm board id is 3449-0000-200
e[23;80H e[24;1H[0002.158] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
e[23;80H e[24;1H[0002.165] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.196] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0002.202] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
e[23;80H e[24;1H[0002.210] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0002.216] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
e[23;80H e[24;1H[0002.224] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:08:28
e[23;80H e[24;1H[0002.230] Plugin Manager: Parse ODM data 0x00094000
e[23;80H e[24;1H[0002.262] Find /i2c@7000c000’s alias i2c0
e[23;80H e[24;1H[0002.266] get eeprom at 1-a0, size 256, type 0
e[23;80H e[24;1H[0002.274] Find /i2c@7000c500’s alias i2c2
e[23;80H e[24;1H[0002.278] get eeprom at 3-a0, size 256, type 0
e[23;80H e[24;1H[0002.282] get eeprom at 3-ae, size 256, type 0
e[23;80H e[24;1H[0002.287] pm_ids_update: Updating 1,a0, size 256, type 0
e[23;80H e[24;1H[0002.292] I2C slave not started
e[23;80H e[24;1H[0002.295] I2C write failed
e[23;80H e[24;1H[0002.298] Writing offset failed
e[23;80H e[24;1H[0002.301] eeprom_init: EEPROM read failed
e[23;80H e[24;1H[0002.305] pm_ids_update: eeprom init failed
e[23;80H e[24;1H[0002.309] pm_ids_update: Updating 3,a0, size 256, type 0
e[23;80H e[24;1H[0002.339] pm_ids_update: The pm board id is 3448-0000-200
e[23;80H e[24;1H[0002.346] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
e[23;80H e[24;1H[0002.352] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.357] pm_ids_update: Updating 3,ae, size 256, type 0
e[23;80H e[24;1H[0002.387] pm_ids_update: The pm board id is 3449-0000-200
e[23;80H e[24;1H[0002.394] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
e[23;80H e[24;1H[0002.401] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0002.431] Chip UID is 0000000164449449080000000b058300
e[23;80H e[24;1H[0002.436] Add serial number:14221190912280008305 as DT property
e[23;80H e[24;1H[0002.444] Applying platform configs
e[23;80H e[24;1H[0002.451] platform-init is not present. Skipping
e[23;80H e[24;1H[0002.455] calling apps_init()
e[23;80H e[24;1H[0002.475] Found 14 GPT partitions in “sd0”
e[23;80H e[24;1H[0002.479] Proceeding to Cold Boot
e[23;80H e[24;1H[0002.482] starting app android_boot_app
e[23;80H e[24;1H[0002.486] Device state: unlocked
e[23;80H e[24;1H[0002.489] display console init
e[23;80H e[24;1H[0002.498] could not find regulator
e[23;80H e[24;1H[0002.521] hdmi cable not connected
e[23;80H e[24;1H[0002.524] is_hdmi_needed: HDMI not connected, returning false
e[23;80H e[24;1H[0002.530][0002.534] DT entry for leds-pwm not found
e[23;80H e[24;1H hdmi is not connected
e[23;80H e[24;1H[0002.540] sor0 is not supported
e[23;80H e[24;1H[0002.543] display_console_init: no valid display out_type
e[23;80H e[24;1H[0002.551] subnode volume_up is not found !
e[23;80H e[24;1H[0002.555] subnode back is not found !
e[23;80H e[24;1H[0002.559] subnode volume_down is not found !
e[23;80H e[24;1H[0002.563] subnode menu is not found !
e[23;80H e[24;1H[0002.567] Gpio keyboard init success
e[23;80H e[24;1H[0002.611] found decompressor handler: lz4-legacy
e[23;80H e[24;1H[0002.625] decompressing blob (type 1)…
e[23;80H e[24;1H[0002.659] display_resolution: No display init
e[23;80H e[24;1H[0002.663] Failed to retrieve display resolution
e[23;80H e[24;1H[0002.667] Could not load/initialize BMP blob…ignoring
e[23;80H e[24;1H[0002.718] decompressor handler not found
e[23;80H e[24;1H[0002.722] load_firmware_blob: Firmware blob loaded, entries=2
e[23;80H e[24;1H[0002.728] se_aes_verify_sbk_clear: Error
e[23;80H e[24;1H[0002.732] bl_battery_charging: connected to external power supply
e[23;80H e[24;1H[0002.739] xusb is supported
e[23;80H e[24;1H[0002.745] error while finding nvidia,portmap
e[23;80H e[24;1H[0002.750] could not find regulator
e[23;80H e[24;1H[0003.254] xusb blob version 0 size 124416
e[23;80H e[24;1H[0003.258] firmware size 124416
e[23;80H e[24;1H[0003.262] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
e[23;80H e[24;1H[0003.271] xhci0: 64 bytes context size, 32-bit DMA
e[23;80H e[24;1H[0003.311] usbus0: 5.0Gbps Super Speed USB v3.0
e[23;80H e[24;1H[0003.331] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on ue[24;80He[24;80He[24;80He[24;80He[24;80H
e[23;80H0e[24;1H[0003.981] uhub0: 9 ports with 9 removable, self powered
e[23;80H e[24;1H[0004.981] failed to get HID devices
e[23;80H e[24;1H[0004.984] failed to init xhci or no usb device attached
e[23;80H e[24;1H[0004.992] display_console_ioctl: No display init
e[23;80H e[24;1H[0004.996] switch_backlight failed
e[23;80H e[24;1H[0005.003] device_query_partition_size: failed to open partition sd0:MSC !
e[23;80H e[24;1H[0005.009] MSC Partition not found
e[23;80H e[24;1H[0005.016] device_query_partition_size: failed to open partition sd0:USP !
e[23;80H e[24;1H[0005.022] USP partition read failed!
e[23;80H e[24;1H[0005.026] blob_init: blob-partition USP header read failed
e[23;80H e[24;1H[0005.031] android_boot Unable to update recovery partition
e[23;80H e[24;1H[0005.037] kfs_getpartname: name = LNX
e[23;80H e[24;1H[0005.040] Loading kernel from LNX
e[23;80H e[24;1H[0005.100] Verifying boot image in OdmNonSecureSBK mode
e[23;80H e[24;1H[0005.143] kernel load address: 0x80080000, size: 481226 bytes
e[23;80H e[24;1H[0005.149] ramdisk load address: 0x84100000, size: 0 bytes
e[23;80H e[24;1H[0005.154] load kernel from storage
e[23;80H e[24;1H[0005.166] decompressor handler not found
e[23;80H e[24;1H[0005.223] Successfully loaded kernel and ramdisk images
e[23;80H e[24;1H[0005.229] display_resolution: No display init
e[23;80H e[24;1H[0005.234] Failed to retrieve display resolution
e[23;80H e[24;1H[0005.238] bmp blob is not loaded and initialized
e[23;80H e[24;1H[0005.243] Failed to display boot-logo
e[23;80H e[24;1H[0005.246] NCK carveout not present
e[23;80H e[24;1H[0005.249] Skipping dts_overrides
e[23;80H e[24;1H[0005.253] NCK carveout not present
e[23;80H e[24;1H[0005.256] shim_invoke: No NCT, Calling dts updates
e[23;80H e[24;1H[0005.267] Find /i2c@7000c000’s alias i2c0
e[23;80H e[24;1H[0005.271] get eeprom at 1-a0, size 256, type 0
e[23;80H e[24;1H[0005.280] Find /i2c@7000c500’s alias i2c2
e[23;80H e[24;1H[0005.284] get eeprom at 3-a0, size 256, type 0
e[23;80H e[24;1H[0005.288] get eeprom at 3-ae, size 256, type 0
e[23;80H e[24;1H[0005.292] pm_ids_update: Updating 1,a0, size 256, type 0
e[23;80H e[24;1H[0005.298] I2C slave not started
e[23;80H e[24;1H[0005.301] I2C write failed
e[23;80H e[24;1H[0005.303] Writing offset failed
e[23;80H e[24;1H[0005.306] eeprom_init: EEPROM read failed
e[23;80H e[24;1H[0005.310] pm_ids_update: eeprom init failed
e[23;80H e[24;1H[0005.314] pm_ids_update: Updating 3,a0, size 256, type 0
e[23;80H e[24;1H[0005.345] pm_ids_update: The pm board id is 3448-0000-200
e[23;80H e[24;1H[0005.351] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
e[23;80H e[24;1H[0005.359] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0005.363] pm_ids_update: Updating 3,ae, size 256, type 0
e[23;80H e[24;1H[0005.393] pm_ids_update: The pm board id is 3449-0000-200
e[23;80H e[24;1H[0005.400] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
e[23;80H e[24;1H[0005.407] pm_ids_update: pm id update successful
e[23;80H e[24;1H[0005.438] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0005.444] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
e[23;80H e[24;1H[0005.452] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
e[23;80H e[24;1H[0005.458] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
e[23;80H e[24;1H[0005.466] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:08:28
e[23;80H e[24;1H[0005.473] Plugin Manager: Parse ODM data 0x00094000
e[23;80H e[24;1H[0005.483] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw
e[23;80H e[24;1H[0005.497] Add serial number:14221190912280008305 as DT property
e[23;80H e[24;1H[0005.507] “bpmp” doesn’t exist, creating
e[23;80H e[24;1H[0005.512] Updated bpmp info to DTB
e[23;80H e[24;1H[0005.517] Updated initrd info to DTB
e[23;80H e[24;1H[0005.521] “proc-board” doesn’t exist, creating
e[23;80H e[24;1H[0005.526] Updated board info to DTB
e[23;80H e[24;1H[0005.529] “pmu-board” doesn’t exist, creating
e[23;80H e[24;1H[0005.535] Updated board info to DTB
e[23;80H e[24;1H[0005.538] “display-board” doesn’t exist, creating
e[23;80H e[24;1H[0005.544] Updated board info to DTB
e[23;80H e[24;1H[0005.547] “reset” doesn’t exist, creating
e[23;80H e[24;1H[0005.552] Updated reset info to DTB
e[23;80H e[24;1H[0005.555] display_console_ioctl: No display init
e[23;80H e[24;1H[0005.560] display_console_ioctl: No display init
e[23;80H e[24;1H[0005.564] display_console_ioctl: No display init
e[23;80H e[24;1H[0005.628] Updated bootarg info to DTB
e[23;80H e[24;1H[0005.632] Adding uuid 0000000164449449080000000b058300 to DT
e[23;80H e[24;1H[0005.638] Adding eks info 0 to DT
e[23;80H e[24;1H[0005.643] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
e[23;80H e[24;1H[0005.649] Updated memory info to DTB
e[23;80H e[24;1H[0005.655] Updated system-lp0-disable info to DTB
e[23;80H e[24;1H[0005.663] set vdd_core voltage to 1075 mv
e[23;80H e[24;1H[0005.667] setting ‘vdd-core’ regulator to 1075000 micro volts
e[23;80H e[24;1H[0005.691] could not find regulator
e[23;80H e[24;1H[0005.695] Found secure-pmc; disable BPMP
e[23;80H e[24;1H
e[23;80H e[24;1H
e[23;80H e[24;1HU-Boot 2016.07-dirty (Sep 18 2019 - 11:12:36 +0200)
e[23;80H e[24;1H
e[23;80H e[24;1HTEGRA210
e[23;80H e[24;1HModel: NVIDIA P3450-Porg
e[23;80H e[24;1HBoard: NVIDIA P3450-PORG
e[23;80H e[24;1HDRAM: 4 GiB
e[23;80H e[24;1HMMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
e[23;80H e[24;1HUsing default environment
e[23;80H e[24;1H
e[23;80H e[24;1HIn: serial
e[23;80H e[24;1HOut: serial
e[23;80H e[24;1HErr: serial
e[23;80H e[24;1HNet: No ethernet found.
e[23;80H e[24;1HHit any key to stop autoboot: 1 0
e[23;80H e[24;1Hstarting USB…
e[23;80H e[24;1HUSB0: tegrausb: Invalid dr_mode 2 for host mode
e[23;80H e[24;1Hprobe failed, error -1
e[23;80H e[24;1HUSB error: all controllers failed lowlevel init
e[23;80H e[24;1HBOOTP broadcast 1
e[23;80H e[24;1HBOOTP broadcast 2
e[23;80H e[24;1HBOOTP broadcast 3
e[23;80H e[24;1HBOOTP broadcast 4
e[23;80H e[24;1HBOOTP broadcast 5
e[23;80H e[24;1HBOOTP broadcast 6
e[23;80H e[24;1HBOOTP broadcast 7
e[23;80H e[24;1HBOOTP broadcast 8
e[23;80H e[24;1HBOOTP broadcast 9
e[23;80H e[24;1HBOOTP broadcast 10
e[23;80H e[24;1HBOOTP broadcast 11
e[23;80H e[24;1HBOOTP broadcast 12
e[23;80H e[24;1HBOOTP broadcast 13
e[23;80H e[24;1HBOOTP broadcast 14
e[23;80H e[24;1HBOOTP broadcast 15
e[23;80H e[24;1HBOOTP broadcast 16
e[23;80H e[24;1HBOOTP broadcast 17
e[23;80H e[24;1H
e[23;80H e[24;1HRetry time exceeded; starting again
There seems to be an issue with the spreadsheets not producing good dts/dtsi files. They seem to mess with the qspi definition which makes it impossible to boot from the sd card.
Try the suggestions here…
https://devtalk.nvidia.com/default/topic/1063105/can-t-get-jetson-nano-to-boot-with-custom-pinmux-configuration-per-nvidia-instructions/?offset=2#5383572
I am checking this issue. Thanks for your report.
Hi SimonDahrs,
Are you update CBoot pinmux and U-boot pinmux?
Which configure are you modify in pinmux spreadsheet?
Hi carolyuu,
I am not sure what you mean by your first question. As I said, I exactly followed all the instructions found at the url I mentioned in my post.
I modified pin GPIO13 to PM3_PWM2 Output and GPIO07 to PM3_PWM0 Output.
SimonDahrs,
What @carolyuu wanted to ask is if you change the pinmux in both bootloader and kernel. If you just follow all the steps, I think that means you replace them all.
We got your info now and will start to investigate. Thanks.
@WayneWWW, I followed all the steps, so yes I replaced them all!
Thanks for looking into it and I’m hoping that you’ll fix it!
i have the same problem as SimonDahrs
