I’m trying to run a face recognition model on Jetson Nano with Open-CV Fast Math Enabled the range of the metric that is calculated using face distance is 0 to 1 but with Fast Math On the values are off by large number which is returning -835.66 e^34
With Open-CV Fast Math disabled it’s getting killed
Do you use OpenCV or the face recognition python module, which is simply based on the dlib library?
There is a known issue in dlib that generate NAN or very small number, similar to your description.
