Jetson Nano : factory recovery method?
Hello there,
My Jetson nano devkit(P3448-0000, 4GB) is same problem with https://forums.developer.nvidia.com/t/production-mode-unfused-solution-needed/181372/8
And boot log
[0002.039] Find /i2c@7000c000's alias i2c0
[0002.043] get eeprom at 1-a0, size 256, type 0
[0002.052] Find /i2c@7000c500's alias i2c2
[0002.056] get eeprom at 3-a0, size 256, type 0
[0002.060] get eeprom at 3-ae, size 256, type 0
[0002.065] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.070] I2C slave not started
[0002.073] I2C write failed
[0002.076] Writing offset failed
[0002.079] eeprom_init: EEPROM read failed
[0002.083] pm_ids_update: eeprom init failed
[0002.087] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.117] pm_ids_update: The pm board id is 3448-0000-402
[0002.124] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.132] pm_ids_update: pm id update successful
[0002.137] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.167] pm_ids_update: The pm board id is 3449-0000-400
[0002.173] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.181] pm_ids_update: pm id update successful
[0002.211] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.217] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.225] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.231] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.239] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:a1:e0
[0002.245] Plugin Manager: Parse ODM data 0x000a4000
[0002.258] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.273] Find /i2c@7000c000's alias i2c0
[0002.276] get eeprom at 1-a0, size 256, type 0
[0002.285] Find /i2c@7000c500's alias i2c2
[0002.289] get eeprom at 3-a0, size 256, type 0
[0002.294] get eeprom at 3-ae, size 256, type 0
[0002.298] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.303] I2C slave not started
[0002.306] I2C write failed
[0002.309] Writing offset failed
[0002.312] eeprom_init: EEPROM read failed
[0002.316] pm_ids_update: eeprom init failed
[0002.320] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.350] pm_ids_update: The pm board id is 3448-0000-402
[0002.356] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.363] pm_ids_update: pm id update successful
[0002.368] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.398] pm_ids_update: The pm board id is 3449-0000-400
[0002.404] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.411] pm_ids_update: pm id update successful
[0002.442] Add serial number:1421321020479 as DT property
[0002.449] Applying platform configs
[0002.456] platform-init is not present. Skipping
[0002.461] calling apps_init()
[0002.466] Couldn't find GPT header
[0002.471] Proceeding to Cold Boot
[0002.474] starting app android_boot_app
[0002.478] Device state: unlocked
[0002.481] display console init
[0002.489] could not find regulator
[0002.493] hdmi cable connected
[0002.508] edid read success
[0002.523] edidDT entry for leds-pwm not found
 [0002.531] read success
[0002.533] width = 640, height = 480, frequency = 25174825
[0002.539] width = 640, height = 480, frequency = 25174825
[0002.544] width = 2560, height = 1440, frequency = 241500000
[0002.550] width = 1920, height = 1080, frequency = 148500000
[0002.555] width = 640, height = 480, frequency = 25174825
[0002.561] width = 720, height = 480, frequency = 26973026
[0002.566] width = 1280, height = 720, frequency = 74175824
[0002.571] width = 1920, height = 1080, frequency = 148351648
[0002.577] width = 720, height = 576, frequency = 26973026
[0002.583] width = 1280, height = 720, frequency = 74175824
[0002.588] width = 1920, height = 1080, frequency = 148351648
[0002.594] width = 1920, height = 1080, frequency = 74175824
[0002.599] width = 3840, height = 2160, frequency = 296703296
[0002.605] width = 3840, height = 2160, frequency = 296703296
[0002.610] width = 3840, height = 2160, frequency = 296703296
[0002.616] width = 3840, height = 2160, frequency = 296703296
[0002.622] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.630] tmds-config node not found
[0002.634] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.648] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.656] could not find regulator
[0002.659] could not find regulator
[0002.663] could not find regulator
[0002.691] using default cmu settings
[0002.694] dc_hdmi_enable, starting HDMI initialisation
[0002.701] dc_hdmi_enable, HDMI initialisation complete
[0002.706] list and configure display window
[0002.714] display console init completed
[0002.726] subnode volume_up is not found !
[0002.730] subnode back is not found !
[0002.733] subnode volume_down is not found !
[0002.737] subnode menu is not found !
[0002.741] Gpio keyboard init success
[0002.822] found decompressor handler: lz4-legacy
[0002.836] decompressing blob (type 1)...
[0002.906] load_bmp_blob: panelresolution=1080 type=3
[0002.981] decompressor handler not found
[0002.984] load_firmware_blob: Firmware blob loaded, entries=2
[0002.990] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.996] -------> se_aes_verify_sbk_clear: 747
[0003.001] se_aes_verify_sbk_clear: Error
[0003.004] SE operation failed
[0003.007] bl_battery_charging: connected to external power supply
[0003.020] device_query_partition_size: failed to open partition spiflash0:MSC !
[0003.027] MSC Partition not found
[0003.033] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.040] USP partition read failed!
[0003.044] blob_init: blob-partition USP header read failed
[0003.049] android_boot Unable to update recovery partition
[0003.055] kfs_getpartname: name = LNX
[0003.058] Loading kernel from LNX
[0003.068] Found 19 BFS partitions in "spiflash0"
[0003.391] Failed to validate boot-image
[0003.395] Failed while loading kernel and ramdisk images
[0003.400] Failed to boot Android
[0003.403] starting fastboot mode
[0003.408] fastboot cmd_init done.
[0003.411] platform does not support off-mode-charge
[0003.416] usbdcd_init Initialize USBF driver
[0003.420]  usbdcd_phy_open oscfreq = 5
[0003.429] usbdcd_start Start the initialized controller
[0003.435] get_fastboot-- suspend --
_[0003.438] instructions: Error -2 finding instructions in /chosen
[0003.543] portspeed = 2
[0014.121] -- suspend --
I trying to download 2 method.
1st method: sdk manager
After booting Jetson nano to factory recovery mode, if I download it using sdk manager, the following error message appears at sdk manager.
and Jetson nano console message is
[0183.338] Enabled early print
[0183.341] [L4T TegraBoot] (version ??B)
[0183.345] Processing in recovery mode
[0183.348] A02 Bootrom Patch rev = 1023
[0183.352] Power-up reason: pmc por
[0183.355] Established communication link with host
[0184.548] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0184.556] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0184.565] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
2nd method : flash.sh
After booting Jetson nano to factory recovery mode, if I download it using flash.sh script message is below
cavo@nanoVB:~/nano/Linux_for_Tegra$ sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 5.1
# Target Board Information:
# Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet "/home/cavo/nano/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0012 ] Generating RCM messages
[   0.0017 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/cavo/nano/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[   0.0021 ] RCM 0 is saved as rcm_0.rcm
[   0.0023 ] RCM 1 is saved as rcm_1.rcm
[   0.0023 ] List of rcm files are saved in rcm_list.xml
[   0.0024 ]
[   0.0024 ] Signing RCM messages
[   0.0028 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0032 ] Assuming zero filled SBK key
[   0.0065 ]
[   0.0065 ] Copying signature to RCM mesages
[   0.0070 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[   0.0077 ]
[   0.0077 ] Boot Rom communication
[   0.0081 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[   0.0085 ] RCM version 0X210001
[   0.0740 ] Boot Rom communication completed
[   1.1490 ]
[   1.1490 ] dump EEPROM info
[   1.1498 ] tegrarcm --oem platformdetails eeprom /home/cavo/nano/Linux_for_Tegra/bootloader/cvm.bin
[   1.1503 ] Applet version 00.01.0000
[   1.3412 ] Saved platform info in /home/cavo/nano/Linux_for_Tegra/bootloader/cvm.bin
[   1.5895 ]
[   1.5902 ] tegrarcm --reboot recovery
[   1.5906 ] Applet version 00.01.0000
[   1.8358 ]
Board ID(3448) version(402)
copying bctfile(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/cavo/nano/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating /home/cavo/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/cavo/nano/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/cavo/nano/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/cavo/nano/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/cavo/nano/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/cavo/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)... done.
Copying nv_boot_control.conf to rootfs
sed: can't read /home/cavo/nano/Linux_for_Tegra/rootfs/etc/nv_boot_control.conf: Not a directory
Making system.img...
/home/cavo/nano/Linux_for_Tegra/rootfs/boot/extlinux/extlinux.conf is not found, exiting...
After I copy extlinux.conf file form another jetson nano, and then download it using flash.sh script. message is below
version 1.0.0
[   0.0011 ] Generating RCM messages
[   0.0019 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/cavo/nano/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[   0.0024 ] RCM 0 is saved as rcm_0.rcm
[   0.0026 ] RCM 1 is saved as rcm_1.rcm
[   0.0027 ] List of rcm files are saved in rcm_list.xml
[   0.0027 ]
[   0.0027 ] Signing RCM messages
[   0.0032 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0037 ] Assuming zero filled SBK key
[   0.0069 ]
[   0.0069 ] Copying signature to RCM mesages
[   0.0074 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[   0.0080 ]
[   0.0080 ] Boot Rom communication
[   0.0084 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[   0.0088 ] RCM version 0X210001
[   0.0646 ] Boot Rom communication completed
[   1.1449 ]
[   1.1449 ] dump EEPROM info
[   1.1458 ] tegrarcm --oem platformdetails eeprom /home/cavo/nano/Linux_for_Tegra/bootloader/cvm.bin
[   1.1463 ] Applet version 00.01.0000
[   1.3306 ] Saved platform info in /home/cavo/nano/Linux_for_Tegra/bootloader/cvm.bin
[   1.5812 ]
[   1.5820 ] tegrarcm --reboot recovery
[   1.5824 ] Applet version 00.01.0000
[   1.8278 ]
	populating rootfs from /home/cavo/nano/Linux_for_Tegra/rootfs ... done.
	populating /boot/extlinux/extlinux.conf ... 	Sync'ing system.img ... done.
	Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/cavo/nano/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/cavo/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)... done.
copying cfgfile(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/home/cavo/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/cavo/nano/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct  P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0000-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x21    --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-b00.dtb"
saving flash command in /home/cavo/nano/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/cavo/nano/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0088 ] tegrasign --key None --getmode mode.txt
[   0.0093 ] Assuming zero filled SBK key
[   0.0094 ]
[   0.0094 ] Generating RCM messages
[   0.0141 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[   0.0147 ] RCM 0 is saved as rcm_0.rcm
[   0.0149 ] RCM 1 is saved as rcm_1.rcm
[   0.0149 ] List of rcm files are saved in rcm_list.xml
[   0.0149 ]
[   0.0149 ] Signing RCM messages
[   0.0153 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0157 ] Assuming zero filled SBK key
[   0.0189 ]
[   0.0189 ] Copying signature to RCM mesages
[   0.0194 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[   0.0200 ]
[   0.0200 ] Parsing partition layout
[   0.0289 ] tegraparser --pt flash.xml.tmp
[   0.0405 ]
[   0.0405 ] Creating list of images to be signed
[   0.0417 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[   0.0660 ]
[   0.0660 ] Generating signatures
[   0.0667 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[   0.0671 ] Assuming zero filled SBK key
[   0.1056 ]
[   0.1056 ] Generating br-bct
[   0.1072 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[   0.1077 ] Copying Sdram info from 2 to 3 set
[   0.1325 ]
[   0.1325 ] Updating boot device parameters
[   0.1331 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[   0.1337 ] Warning: No sdram params
[   0.1338 ]
[   0.1338 ] Updating bl info
[   0.1342 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   0.1349 ]
[   0.1349 ] Updating secondary storage information into bct
[   0.1354 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[   0.1359 ]
[   0.1359 ] Updating Odmdata
[   0.1364 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[   0.1368 ] Warning: No sdram params
[   0.1369 ]
[   0.1369 ] Get Signed section of bct
[   0.1373 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[   0.1377 ]
[   0.1377 ] Signing BCT
[   0.1386 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[   0.1390 ] Assuming zero filled SBK key
[   0.1392 ]
[   0.1393 ] Updating BCT with signature
[   0.1397 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[   0.1402 ]
[   0.1402 ] Copying signatures
[   0.1407 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   0.1429 ]
[   0.1430 ] Updating BFS information on BCT
[   0.1435 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[   0.1441 ]
[   0.1441 ] Boot Rom communication
[   0.1445 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[   0.1449 ] BootRom is not running
[   0.1648 ]
[   0.1648 ] Sending BCTs
[   0.1654 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[   0.1659 ] Applet is not running on device. Continue with Bootloader
[   0.1707 ]
[   0.1712 ] tegrahost --chip 0x21 --align cboot.bin
[   0.1717 ]
[   0.1722 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[   0.1732 ]
[   0.1738 ] tegrasign --key None --list cboot.bin_list.xml
[   0.1741 ] Assuming zero filled SBK key
[   0.1827 ]
[   0.1833 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[   0.1841 ]
[   0.1850 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-b00.dtb
[   0.1860 ]
[   0.1865 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-b00.dtb tegra210-p3448-0000-p3449-0000-b00.dtb_blheader
[   0.1874 ]
[   0.1879 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-b00.dtb_list.xml
[   0.1883 ] Assuming zero filled SBK key
[   0.1925 ]
[   0.1931 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.hash zerosbk
[   0.1937 ]
[   0.1939 ] Sending bootloader and pre-requisite binaries
[   0.1943 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt 0
[   0.1947 ] Applet is not running on device. Continue with Bootloader
[   0.1990 ]
[   0.1995 ] tegrarcm --boot recovery
[   0.2000 ] Applet is not running on device. Continue with Bootloader
[   0.2048 ]
[   0.2049 ] Retrieving storage infomation
[   0.2053 ] tegrarcm --oem platformdetails storage storage_info.bin
[   0.2058 ] Applet is not running on device. Continue with Bootloader
[   0.2107 ]
[   0.2196 ] tegradevflash --oem platformdetails storage storage_info.bin
[   0.2201 ] Cboot is not running on device.
[   0.2332 ]
Error: Return value 4
Command tegradevflash --oem platformdetails storage storage_info.bin
Failed flashing t210ref.
And I tried second method at https://forums.developer.nvidia.com/t/jetson-tx2-flashing-with-jetpack-4-4/144166/11
it is not improved.
When downloading using sdk-manager or flash script, there is a sound like USB disconnection and re-connection, after which the console message of jetson is as follows:
Hearing that, it seems there is something wrong with the usb, I tried the following. But problem is the same.
echo “-1” > /sys/module/usbcore/parameters/autosuspend
Hoping for your solution…
Sdkmanager and flash.sh are basically the same… sdkm is using flash.sh to flash the board…
Thus, put your board into recovery mode again, run sdkmanager, click on the “export logs” and attach the full log here.
attached sdkmanager logs
SDKM_logs_JetPack_4.5.1_Linux_for_Jetson_Nano_[developer_kit_version]_2021-09-01_09-03-57.zip (117.4 KB)
What is your host environment? Is it a VM?
And are you sure your board is in recovery mode? Your log says it is not.
*** Reading ECID … *** Error: ECID read failed.
Put the target board in RCM mode and retry.
Host environment : Oracle VM VirtualBox6.1.8 + Ubuntu18.04.4 LTS
USB information of VM VBox is below.
Sorry that VM is not supported. We cannot guarantee it would work fine.
I should go buy a new PC.
Thanks your fast reply…
I installed Ubuntu18.4.5 on a new PC(GB-BRi7H-8550) and tried to download it through sdkmanger.
But it’s the same situation.
SDKM_logs_JetPack_4.6_(rev.1)Linux_for_Jetson_Nano[developer_kit_version]_2021-09-02_19-54-33.zip|attachment (185.5 KB)
4.sdk message_in nuc
Jetson nano model : P3448, 180-13448-DAAA-B01
Base board : 180-13449-DAAF-B01, SN:1421321026798
microSD : Samsun EVO Plus 32GB
please run this command on your host
sudo apt-get install libxml2-utils
and flash the board again.
It works…
