Hello there,
EDIT:
Before all, the Nano is booting again from previously working SD-Card, so it can not be called bricked anymore. This is new since starting the topic, but I can not change the name of the topic anymore.
So the topic name should be something like “Jetson Nano not booting despite seemingly successful flashing”.
I have the following situation:
First I got the Nano Developer Kit for developing purposes. I flashed the SD-Card with the given SD-Card-Image using dd, inserted it into the Developer Kit, booted. Worked well, no problems. I worked quite some time on this setup.
Now we want to use the Jetson Nano Production Module (emmc) soon. So I was given the task to experiment flashing the nano SD-Card the same way one would flash the module with emmc later.
So I used the SDKManager to flash the Developer Kit with inserted SD-Card.
After one hour and many warnings from SDKM that flashing takes way too much time and being stuck at 100% percent of writing APP partition really long, I aborted using Ctrl-C. See the log:
DETAILS TERMINAL
Component Name: All
Message Type: All
Filter text here...
14:59:21 INFO : Flash Jetson Nano : [ 0.0200 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
14:59:21 INFO : Flash Jetson Nano : [ 0.0220 ] Assuming zero filled SBK key
14:59:21 INFO : Flash Jetson Nano : [ 0.0489 ]
14:59:21 INFO : Flash Jetson Nano : [ 0.0489 ] Copying signature to RCM mesages
14:59:21 INFO : Flash Jetson Nano : [ 0.0514 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
14:59:21 INFO : Flash Jetson Nano : [ 0.0612 ]
14:59:21 INFO : Flash Jetson Nano : [ 0.0612 ] Boot Rom communication
14:59:21 INFO : Flash Jetson Nano : [ 0.0659 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
14:59:21 INFO : Flash Jetson Nano : [ 0.0689 ] RCM version 0X210001
14:59:22 INFO : Flash Jetson Nano : [ 0.3940 ] Boot Rom communication completed
14:59:23 INFO : Flash Jetson Nano : [ 1.4119 ]
14:59:23 INFO : Flash Jetson Nano : [ 1.4120 ] dump EEPROM info
14:59:23 INFO : Flash Jetson Nano : [ 1.4180 ] tegrarcm --oem platformdetails eeprom /home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
14:59:23 INFO : Flash Jetson Nano : [ 1.4203 ] Applet version 00.01.0000
14:59:23 INFO : Flash Jetson Nano : [ 1.7016 ] Saved platform info in /home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
14:59:23 INFO : Flash Jetson Nano : [ 1.7896 ]
14:59:23 ERROR : Flash Jetson Nano : Board ID(3448) version(200)
14:59:23 INFO : Flash Jetson Nano : creating dummy /home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin
14:59:23 ERROR : Flash Jetson Nano : 1+0 records in
14:59:23 INFO : Flash Jetson Nano : 1+0 records out
14:59:23 ERROR : Flash Jetson Nano : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000197652 s, 20.7 MB/s
14:59:23 INFO : Flash Jetson Nano : copying bctfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
14:59:23 INFO : Flash Jetson Nano : copying bootloader(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
14:59:23 INFO : Flash Jetson Nano : copying initrd(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
14:59:23 INFO : Flash Jetson Nano : populating kernel to rootfs... done.
14:59:23 INFO : Flash Jetson Nano : populating initrd to rootfs... done.
14:59:23 INFO : Flash Jetson Nano : populating /home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
14:59:23 INFO : Flash Jetson Nano : Making Boot image... done.
14:59:23 INFO : Flash Jetson Nano : Existing sosfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
14:59:23 INFO : Flash Jetson Nano : copying tegraboot(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
14:59:23 INFO : Flash Jetson Nano : copying cpu_bootloader(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
14:59:23 INFO : Flash Jetson Nano : copying bpffile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
14:59:23 INFO : Flash Jetson Nano : Existing badpagefile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin) reused.
14:59:23 INFO : Flash Jetson Nano : copying wb0boot(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
14:59:23 INFO : Flash Jetson Nano : Existing tosfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
14:59:23 INFO : Flash Jetson Nano : Existing eksfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/eks.img) reused.
14:59:23 INFO : Flash Jetson Nano : copying dtbfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
14:59:24 INFO : Flash Jetson Nano : Copying nv_boot_control.conf to rootfs
14:59:24 INFO : Flash Jetson Nano : Making system.img...
15:00:49 INFO : Flash Jetson Nano : populating rootfs from /home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/rootfs ... done.
15:00:56 INFO : Flash Jetson Nano : Sync'ing system.img ... done.
15:00:56 INFO : Flash Jetson Nano : Converting RAW image to Sparse image...
15:00:56 ERROR : Flash Jetson Nano :
15:00:56 INFO : Flash Jetson Nano : ---- Raw to Sparse Image Converter v1.0
15:00:56 ERROR : Flash Jetson Nano : ----------------------------
15:00:56 ERROR : Flash Jetson Nano : 0: RAW: 4194304( 4 blks) ==> 28:4194316
15:00:56 ERROR : Flash Jetson Nano : 1: SKP: 32505856( 31 blks) ==> 4194344:12
15:00:56 ERROR : Flash Jetson Nano : 2: RAW: 2097152( 2 blks) ==> 4194356:2097164
15:00:57 ERROR : Flash Jetson Nano : 3: SKP: 95420416( 91 blks) ==> 6291520:12
15:00:57 ERROR : Flash Jetson Nano : 4: RAW: 1048576( 1 blks) ==> 6291532:1048588
15:00:57 ERROR : Flash Jetson Nano : 5: SKP: 2097152( 2 blks) ==> 7340120:12
15:00:57 ERROR : Flash Jetson Nano : 6: RAW: 28311552( 27 blks) ==> 7340132:28311564
15:00:57 ERROR : Flash Jetson Nano : 7: SKP: 1048576( 1 blks) ==> 35651696:12
15:00:57 ERROR : Flash Jetson Nano : 8: RAW: 77594624( 74 blks) ==> 35651708:77594636
15:00:57 ERROR : Flash Jetson Nano : 9: SKP: 24117248( 23 blks) ==> 113246344:12
15:00:58 ERROR : Flash Jetson Nano : 10: RAW: 59768832( 57 blks) ==> 113246356:59768844
15:00:58 ERROR : Flash Jetson Nano : 11: SKP: 15728640( 15 blks) ==> 173015200:12
15:00:58 ERROR : Flash Jetson Nano : 12: RAW: 49283072( 47 blks) ==> 173015212:49283084
15:00:58 ERROR : Flash Jetson Nano : 13: SKP: 9437184( 9 blks) ==> 222298296:12
15:00:58 ERROR : Flash Jetson Nano : 14: RAW: 1048576( 1 blks) ==> 222298308:1048588
15:00:58 ERROR : Flash Jetson Nano : 15: SKP: 2097152( 2 blks) ==> 223346896:12
15:00:58 ERROR : Flash Jetson Nano : 16: RAW: 12582912( 12 blks) ==> 223346908:12582924
15:00:58 ERROR : Flash Jetson Nano : 17: SKP: 1048576( 1 blks) ==> 235929832:12
15:00:59 ERROR : Flash Jetson Nano : 18: RAW: 252706816( 241 blks) ==> 235929844:252706828
15:00:59 ERROR : Flash Jetson Nano : 19: SKP: 2097152( 2 blks) ==> 488636672:12
15:01:00 ERROR : Flash Jetson Nano : 20: RAW: 117440512( 112 blks) ==> 488636684:117440524
15:01:00 ERROR : Flash Jetson Nano : 21: SKP: 13631488( 13 blks) ==> 606077208:12
15:01:01 ERROR : Flash Jetson Nano : 22: RAW: 26214400( 25 blks) ==> 606077220:26214412
15:01:01 ERROR : Flash Jetson Nano : 23: SKP: 1048576( 1 blks) ==> 632291632:12
15:01:01 ERROR : Flash Jetson Nano : 24: RAW: 1048576( 1 blks) ==> 632291644:1048588
15:01:01 ERROR : Flash Jetson Nano : 25: SKP: 1048576( 1 blks) ==> 633340232:12
15:01:01 ERROR : Flash Jetson Nano : 26: RAW: 97517568( 93 blks) ==> 633340244:97517580
15:01:01 ERROR : Flash Jetson Nano : 27: SKP: 7340032( 7 blks) ==> 730857824:12
15:01:01 ERROR : Flash Jetson Nano : 28: RAW: 1048576( 1 blks) ==> 730857836:1048588
15:01:01 ERROR : Flash Jetson Nano : 29: SKP: 2097152( 2 blks) ==> 731906424:12
15:01:02 ERROR : Flash Jetson Nano : 30: RAW: 126877696( 121 blks) ==> 731906436:126877708
15:01:02 ERROR : Flash Jetson Nano : 31: SKP: 4194304( 4 blks) ==> 858784144:12
15:01:03 ERROR : Flash Jetson Nano : 32: RAW: 65011712( 62 blks) ==> 858784156:65011724
15:01:03 ERROR : Flash Jetson Nano : 33: SKP: 2097152( 2 blks) ==> 923795880:12
15:01:03 ERROR : Flash Jetson Nano : 34: RAW: 68157440( 65 blks) ==> 923795892:68157452
15:01:03 ERROR : Flash Jetson Nano : 35: SKP: 2097152( 2 blks) ==> 991953344:12
15:01:04 ERROR : Flash Jetson Nano : 36: RAW: 124780544( 119 blks) ==> 991953356:124780556
15:01:05 ERROR : Flash Jetson Nano : 37: SKP: 6291456( 6 blks) ==> 1116733912:12
15:01:05 ERROR : Flash Jetson Nano : 38: RAW: 127926272( 122 blks) ==> 1116733924:127926284
15:01:05 ERROR : Flash Jetson Nano : 39: SKP: 6291456( 6 blks) ==> 1244660208:12
15:01:06 ERROR : Flash Jetson Nano : 40: RAW: 127926272( 122 blks) ==> 1244660220:127926284
15:01:07 ERROR : Flash Jetson Nano : 41: SKP: 6291456( 6 blks) ==> 1372586504:12
15:01:07 ERROR : Flash Jetson Nano : 42: RAW: 23068672( 22 blks) ==> 1372586516:23068684
15:01:07 ERROR : Flash Jetson Nano : 43: SKP: 2097152( 2 blks) ==> 1395655200:12
15:01:07 ERROR : Flash Jetson Nano : 44: RAW: 39845888( 38 blks) ==> 1395655212:39845900
15:01:07 ERROR : Flash Jetson Nano : 45: SKP: 1048576( 1 blks) ==> 1435501112:12
15:01:07 ERROR : Flash Jetson Nano : 46: RAW: 27262976( 26 blks) ==> 1435501124:27262988
15:01:07 ERROR : Flash Jetson Nano : 47: SKP: 7340032( 7 blks) ==> 1462764112:12
15:01:08 ERROR : Flash Jetson Nano : 48: RAW: 78643200( 75 blks) ==> 1462764124:78643212
15:01:08 ERROR : Flash Jetson Nano : 49: SKP: 1048576( 1 blks) ==> 1541407336:12
15:01:09 ERROR : Flash Jetson Nano : 50: RAW: 63963136( 61 blks) ==> 1541407348:63963148
15:01:09 ERROR : Flash Jetson Nano : 51: SKP: 7340032( 7 blks) ==> 1605370496:12
15:01:09 ERROR : Flash Jetson Nano : 52: RAW: 30408704( 29 blks) ==> 1605370508:30408716
15:01:09 ERROR : Flash Jetson Nano : 53: SKP: 3145728( 3 blks) ==> 1635779224:12
15:01:09 ERROR : Flash Jetson Nano : 54: RAW: 15728640( 15 blks) ==> 1635779236:15728652
15:01:09 ERROR : Flash Jetson Nano : 55: SKP: 1048576( 1 blks) ==> 1651507888:12
15:01:09 ERROR : Flash Jetson Nano : 56: RAW: 15728640( 15 blks) ==> 1651507900:15728652
15:01:10 ERROR : Flash Jetson Nano : 57: SKP: 219152384( 209 blks) ==> 1667236552:12
15:01:10 ERROR : Flash Jetson Nano : 58: RAW: 6291456( 6 blks) ==> 1667236564:6291468
15:01:10 ERROR : Flash Jetson Nano : 59: SKP: 27262976( 26 blks) ==> 1673528032:12
15:01:10 ERROR : Flash Jetson Nano : 60: RAW: 15728640( 15 blks) ==> 1673528044:15728652
15:01:10 ERROR : Flash Jetson Nano : 61: SKP: 84934656( 81 blks) ==> 1689256696:12
15:01:12 ERROR : Flash Jetson Nano : 62: RAW: 256901120( 245 blks) ==> 1689256708:256901132
15:01:12 ERROR : Flash Jetson Nano : 63: SKP: 2097152( 2 blks) ==> 1946157840:12
15:01:13 ERROR : Flash Jetson Nano : 64: RAW: 190840832( 182 blks) ==> 1946157852:190840844
15:01:14 ERROR : Flash Jetson Nano : 65: SKP: 19922944( 19 blks) ==> 2136998696:12
15:01:14 ERROR : Flash Jetson Nano : 66: RAW: 33554432( 32 blks) ==> 2136998708:33554444
15:01:15 ERROR : Flash Jetson Nano : 67: SKP: 570425344( 544 blks) ==> 2170553152:12
15:01:15 ERROR : Flash Jetson Nano : 68: RAW: 1048576( 1 blks) ==> 2170553164:1048588
15:01:15 ERROR : Flash Jetson Nano : 69: SKP: 267386880( 255 blks) ==> 2171601752:12
15:01:15 ERROR : Flash Jetson Nano : 70: RAW: 1048576( 1 blks) ==> 2171601764:1048588
15:01:17 ERROR : Flash Jetson Nano : 71: SKP: 670040064( 639 blks) ==> 2172650352:12
15:01:17 ERROR : Flash Jetson Nano : 72: RAW: 7340032( 7 blks) ==> 2172650364:7340044
15:01:17 ERROR : Flash Jetson Nano : 73: SKP: 26214400( 25 blks) ==> 2179990408:12
15:01:17 ERROR : Flash Jetson Nano : 74: RAW: 13631488( 13 blks) ==> 2179990420:13631500
15:01:17 ERROR : Flash Jetson Nano : 75: SKP: 87031808( 83 blks) ==> 2193621920:12
15:01:19 ERROR : Flash Jetson Nano : 76: RAW: 436207616( 416 blks) ==> 2193621932:436207628
15:01:19 ERROR : Flash Jetson Nano : 77: SKP: 33554432( 32 blks) ==> 2629829560:12
15:01:19 ERROR : Flash Jetson Nano : 78: RAW: 5242880( 5 blks) ==> 2629829572:5242892
15:01:22 ERROR : Flash Jetson Nano : 79: SKP: 1538260992( 1467 blks) ==> 2635072464:12
15:01:22 ERROR : Flash Jetson Nano : 80: RAW: 9437184( 9 blks) ==> 2635072476:9437196
15:01:22 ERROR : Flash Jetson Nano : 81: SKP: 24117248( 23 blks) ==> 2644509672:12
15:01:22 ERROR : Flash Jetson Nano : 82: RAW: 14680064( 14 blks) ==> 2644509684:14680076
15:01:23 ERROR : Flash Jetson Nano : 83: SKP: 85983232( 82 blks) ==> 2659189760:12
15:01:23 ERROR : Flash Jetson Nano : 84: RAW: 1048576( 1 blks) ==> 2659189772:1048588
15:01:23 ERROR : Flash Jetson Nano : 85: SKP: 2097152( 2 blks) ==> 2660238360:12
15:01:24 ERROR : Flash Jetson Nano : 86: RAW: 320864256( 306 blks) ==> 2660238372:320864268
15:01:25 ERROR : Flash Jetson Nano : 87: SKP: 11534336( 11 blks) ==> 2981102640:12
15:01:25 ERROR : Flash Jetson Nano : 88: RAW: 33554432( 32 blks) ==> 2981102652:33554444
15:01:28 ERROR : Flash Jetson Nano : 89: SKP: 1644167168( 1568 blks) ==> 3014657096:12
15:01:28 ERROR : Flash Jetson Nano : 90: RAW: 7340032( 7 blks) ==> 3014657108:7340044
15:01:28 ERROR : Flash Jetson Nano : 91: SKP: 26214400( 25 blks) ==> 3021997152:12
15:01:28 ERROR : Flash Jetson Nano : 92: RAW: 13631488( 13 blks) ==> 3021997164:13631500
15:01:28 ERROR : Flash Jetson Nano : 93: SKP: 87031808( 83 blks) ==> 3035628664:12
15:01:29 ERROR : Flash Jetson Nano : 94: RAW: 315621376( 301 blks) ==> 3035628676:315621388
15:01:33 ERROR : Flash Jetson Nano : 95: SKP: 1697644544( 1619 blks) ==> 3351250064:12
15:01:33 ERROR : Flash Jetson Nano : 96: RAW: 7340032( 7 blks) ==> 3351250076:7340044
15:01:33 ERROR : Flash Jetson Nano : 97: SKP: 26214400( 25 blks) ==> 3358590120:12
15:01:33 ERROR : Flash Jetson Nano : 98: RAW: 16777216( 16 blks) ==> 3358590132:16777228
15:01:33 ERROR : Flash Jetson Nano : 99: SKP: 83886080( 80 blks) ==> 3375367360:12
15:01:33 ERROR : Flash Jetson Nano : 100: RAW: 1048576( 1 blks) ==> 3375367372:1048588
15:01:33 ERROR : Flash Jetson Nano : 101: SKP: 2097152( 2 blks) ==> 3376415960:12
15:01:34 ERROR : Flash Jetson Nano : 102: RAW: 249561088( 238 blks) ==> 3376415972:249561100
15:01:37 ERROR : Flash Jetson Nano : 103: SKP: 1760559104( 1679 blks) ==> 3625977072:12
15:01:37 ERROR : Flash Jetson Nano : 104: RAW: 7340032( 7 blks) ==> 3625977084:7340044
15:01:37 ERROR : Flash Jetson Nano : 105: SKP: 26214400( 25 blks) ==> 3633317128:12
15:01:38 ERROR : Flash Jetson Nano : 106: RAW: 17825792( 17 blks) ==> 3633317140:17825804
15:01:38 ERROR : Flash Jetson Nano : 107: SKP: 82837504( 79 blks) ==> 3651142944:12
15:01:43 ERROR : Flash Jetson Nano : 108: RAW: 825229312( 787 blks) ==> 3651142956:825229324
15:01:46 ERROR : Flash Jetson Nano : 109: SKP: 1188036608( 1133 blks) ==> 4476372280:12
15:01:46 ERROR : Flash Jetson Nano : -- Total:
15:01:46 ERROR : Flash Jetson Nano : ---------------------------------------------------
15:01:46 ERROR : Flash Jetson Nano : 110 CHUNK 15032385536( 14336 blks) ==> 4476372292(4269 blks)
15:01:46 INFO : Flash Jetson Nano : done.
15:01:46 INFO : Flash Jetson Nano : system.img built successfully.
15:01:46 INFO : Flash Jetson Nano : Existing tbcfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
15:01:46 INFO : Flash Jetson Nano : copying tbcdtbfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
15:01:46 INFO : Flash Jetson Nano : copying cfgfile(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
15:01:46 INFO : Flash Jetson Nano : copying flasher(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
15:01:46 INFO : Flash Jetson Nano : Existing flashapp(/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/tegraflash.py) reused.
15:01:46 INFO : Flash Jetson Nano : ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb"
15:01:46 INFO : Flash Jetson Nano : saving flash command in /home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/flashcmd.txt
15:01:46 INFO : Flash Jetson Nano : saving Windows flash command to /home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448/Linux_for_Tegra/bootloader/flash_win.bat
15:01:46 INFO : Flash Jetson Nano : *** Flashing target device started. ***
15:01:46 INFO : Flash Jetson Nano : Welcome to Tegra Flash
15:01:46 INFO : Flash Jetson Nano : version 1.0.0
15:01:46 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
15:01:46 INFO : Flash Jetson Nano : Use ! to execute system commands
15:01:46 INFO : Flash Jetson Nano : [ 0.0028 ] tegrasign --key None --getmode mode.txt
15:01:46 INFO : Flash Jetson Nano : [ 0.0043 ] Assuming zero filled SBK key
15:01:46 INFO : Flash Jetson Nano : [ 0.0186 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.0187 ] Generating RCM messages
15:01:46 INFO : Flash Jetson Nano : [ 0.0217 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
15:01:46 INFO : Flash Jetson Nano : [ 0.0232 ] RCM 0 is saved as rcm_0.rcm
15:01:46 INFO : Flash Jetson Nano : [ 0.0287 ] RCM 1 is saved as rcm_1.rcm
15:01:46 INFO : Flash Jetson Nano : [ 0.0294 ] List of rcm files are saved in rcm_list.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.0372 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.0373 ] Signing RCM messages
15:01:46 INFO : Flash Jetson Nano : [ 0.0392 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
15:01:46 INFO : Flash Jetson Nano : [ 0.0408 ] Assuming zero filled SBK key
15:01:46 INFO : Flash Jetson Nano : [ 0.0626 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.0626 ] Copying signature to RCM mesages
15:01:46 INFO : Flash Jetson Nano : [ 0.0646 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.0745 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.0746 ] Parsing partition layout
15:01:46 INFO : Flash Jetson Nano : [ 0.0786 ] tegraparser --pt flash.xml.tmp
15:01:46 INFO : Flash Jetson Nano : [ 0.0936 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.0937 ] Creating list of images to be signed
15:01:46 INFO : Flash Jetson Nano : [ 0.0979 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.1211 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.1212 ] Generating signatures
15:01:46 INFO : Flash Jetson Nano : [ 0.1231 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
15:01:46 INFO : Flash Jetson Nano : [ 0.1245 ] Assuming zero filled SBK key
15:01:46 INFO : Flash Jetson Nano : [ 0.2746 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.2747 ] Generating br-bct
15:01:46 INFO : Flash Jetson Nano : [ 0.2780 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
15:01:46 INFO : Flash Jetson Nano : [ 0.2799 ] Copying Sdram info from 0 to 1 set
15:01:46 INFO : Flash Jetson Nano : [ 0.2855 ] Copying Sdram info from 1 to 2 set
15:01:46 INFO : Flash Jetson Nano : [ 0.2860 ] Copying Sdram info from 2 to 3 set
15:01:46 INFO : Flash Jetson Nano : [ 0.2934 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.2935 ] Updating boot device parameters
15:01:46 INFO : Flash Jetson Nano : [ 0.2969 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
15:01:46 INFO : Flash Jetson Nano : [ 0.2985 ] Warning: No sdram params
15:01:46 INFO : Flash Jetson Nano : [ 0.3065 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3065 ] Updating bl info
15:01:46 INFO : Flash Jetson Nano : [ 0.3082 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.3188 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3189 ] Updating secondary storage information into bct
15:01:46 INFO : Flash Jetson Nano : [ 0.3207 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
15:01:46 INFO : Flash Jetson Nano : [ 0.3306 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3306 ] Updating Odmdata
15:01:46 INFO : Flash Jetson Nano : [ 0.3324 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
15:01:46 INFO : Flash Jetson Nano : [ 0.3338 ] Warning: No sdram params
15:01:46 INFO : Flash Jetson Nano : [ 0.3425 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3426 ] Get Signed section of bct
15:01:46 INFO : Flash Jetson Nano : [ 0.3451 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.3547 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3547 ] Signing BCT
15:01:46 INFO : Flash Jetson Nano : [ 0.3582 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
15:01:46 INFO : Flash Jetson Nano : [ 0.3600 ] Assuming zero filled SBK key
15:01:46 INFO : Flash Jetson Nano : [ 0.3619 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3620 ] Updating BCT with signature
15:01:46 INFO : Flash Jetson Nano : [ 0.3639 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.3766 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3767 ] Copying signatures
15:01:46 INFO : Flash Jetson Nano : [ 0.3790 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.3986 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.3986 ] Updating BFS information on BCT
15:01:46 INFO : Flash Jetson Nano : [ 0.4006 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
15:01:46 INFO : Flash Jetson Nano : [ 0.4101 ]
15:01:46 INFO : Flash Jetson Nano : [ 0.4101 ] Boot Rom communication
15:01:46 INFO : Flash Jetson Nano : [ 0.4124 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
15:01:46 INFO : Flash Jetson Nano : [ 0.4145 ] BootRom is not running
15:01:47 INFO : Flash Jetson Nano : [ 0.6104 ]
15:01:47 INFO : Flash Jetson Nano : [ 0.6109 ] Sending BCTs
15:01:47 INFO : Flash Jetson Nano : [ 0.6127 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
15:01:47 INFO : Flash Jetson Nano : [ 0.6168 ] Applet version 00.01.0000
15:01:47 INFO : Flash Jetson Nano : [ 0.8988 ] Sending bct
15:01:47 INFO : Flash Jetson Nano : [ 0.8991 ] [...] 100%
15:01:47 INFO : Flash Jetson Nano : [ 1.0851 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.0871 ] tegrahost --chip 0x21 --align cboot.bin
15:01:47 INFO : Flash Jetson Nano : [ 1.1049 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.1068 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
15:01:47 INFO : Flash Jetson Nano : [ 1.1213 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.1236 ] tegrasign --key None --list cboot.bin_list.xml
15:01:47 INFO : Flash Jetson Nano : [ 1.1250 ] Assuming zero filled SBK key
15:01:47 INFO : Flash Jetson Nano : [ 1.1713 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.1738 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
15:01:47 INFO : Flash Jetson Nano : [ 1.1865 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.1923 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
15:01:47 INFO : Flash Jetson Nano : [ 1.2047 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.2068 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
15:01:47 INFO : Flash Jetson Nano : [ 1.2145 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.2176 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
15:01:47 INFO : Flash Jetson Nano : [ 1.2191 ] Assuming zero filled SBK key
15:01:47 INFO : Flash Jetson Nano : [ 1.2425 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.2480 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
15:01:47 INFO : Flash Jetson Nano : [ 1.2585 ]
15:01:47 INFO : Flash Jetson Nano : [ 1.2595 ] Sending bootloader and pre-requisite binaries
15:01:47 INFO : Flash Jetson Nano : [ 1.2643 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
15:01:47 INFO : Flash Jetson Nano : [ 1.2667 ] Applet version 00.01.0000
15:01:47 INFO : Flash Jetson Nano : [ 1.5508 ] Sending ebt
15:01:47 INFO : Flash Jetson Nano : [ 1.5518 ] [...] 100%
15:01:47 INFO : Flash Jetson Nano : [ 1.6648 ] Sending rp1
15:01:48 INFO : Flash Jetson Nano : [ 1.6701 ] [...] 100%
15:01:48 INFO : Flash Jetson Nano : [ 1.7346 ]
15:01:48 INFO : Flash Jetson Nano : [ 1.7369 ] tegrarcm --boot recovery
15:01:48 INFO : Flash Jetson Nano : [ 1.7389 ] Applet version 00.01.0000
15:01:49 INFO : Flash Jetson Nano : [ 2.0368 ]
15:01:49 INFO : Flash Jetson Nano : [ 2.0368 ] Retrieving storage infomation
15:01:49 INFO : Flash Jetson Nano : [ 2.0402 ] tegrarcm --oem platformdetails storage storage_info.bin
15:01:49 INFO : Flash Jetson Nano : [ 2.0419 ] Applet is not running on device. Continue with Bootloader
15:01:49 INFO : Flash Jetson Nano : [ 2.7542 ]
15:01:49 INFO : Flash Jetson Nano : [ 2.7598 ] tegradevflash --oem platformdetails storage storage_info.bin
15:01:49 INFO : Flash Jetson Nano : [ 2.7617 ] Cboot version 00.01.0000
15:01:49 INFO : Flash Jetson Nano : [ 2.9075 ] Saved platform info in storage_info.bin
15:01:49 INFO : Flash Jetson Nano : [ 2.9145 ]
15:01:49 INFO : Flash Jetson Nano : [ 2.9146 ] Flashing the device
15:01:49 INFO : Flash Jetson Nano : [ 2.9163 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
15:01:49 INFO : Flash Jetson Nano : [ 2.9180 ] Cboot version 00.01.0000
15:01:49 INFO : Flash Jetson Nano : [ 3.0594 ] Writing partition GPT with gpt.bin
15:01:49 INFO : Flash Jetson Nano : [ 3.0600 ] [...] 100%
15:02:03 INFO : Flash Jetson Nano : [ 3.0662 ] Writing partition NVC with nvtboot.bin.encrypt
15:02:03 INFO : Flash Jetson Nano : [ 17.2214 ] [...] 100%
15:02:14 INFO : Flash Jetson Nano : [ 17.2354 ] Writing partition PT with flash.xml.bin
15:02:14 INFO : Flash Jetson Nano : [ 27.7342 ] [...] 100%
15:02:14 INFO : Flash Jetson Nano : [ 27.7428 ] Writing partition NVC_R with nvtboot.bin.encrypt
15:02:14 INFO : Flash Jetson Nano : [ 27.9919 ] [...] 100%
15:02:24 INFO : Flash Jetson Nano : [ 28.0112 ] Writing partition VER with qspi_bootblob_ver.txt
15:02:24 INFO : Flash Jetson Nano : [ 38.5219 ] [...] 100%
15:02:25 INFO : Flash Jetson Nano : [ 38.5347 ] Writing partition APP with system.img
15:06:21 INFO : Flash Jetson Nano : [ 38.7970 ] [ ] 000%
100%
<<<<<Flashing stopped right here at 100%, aborted using Ctrl-C>>>>>>>>
15:59:16 INFO : Flash Jetson Nano : [ 3450.0386 ]
15:59:16 INFO : Flash Jetson Nano : Error: Return value 8
15:59:16 INFO : Flash Jetson Nano : Command tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
15:59:16 INFO : Flash Jetson Nano : Failed flashing t210ref.
15:59:16 INFO : Flash Jetson Nano : exit status 1
15:59:16 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
15:59:16 INFO : Flash Jetson Nano : [ 5.94 GB released. Disk Avail: 6.90 GB ]
15:59:16 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP Install took 59m57s ]
15:59:16 ERROR : Flash Jetson Nano : Run commands failed at step Install: command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
15:59:16 ERROR : Flash Jetson Nano : command terminated with error
15:59:16 ERROR : install 'Flash Jetson Nano' failure, command < cd '/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP' -v='32.2' -l='/home/kobold/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3448' -L='/home/kobold/.nvsdkm/logs/JetPack_4.2.2_Linux_GA' -p='5976' -t='P3448-0000' -e='undefined' > terminated with error
15:59:56 INFO : install 'Device Mode Host Setup in Target SDK' Skipped
15:59:56 INFO : install 'DateTime Target Setup' Skipped
15:59:56 INFO : install 'CUDA Toolkit for L4T' Skipped
15:59:56 INFO : install 'cuDNN on Target' Skipped
15:59:56 INFO : install 'TensorRT on Target' Skipped
15:59:56 INFO : install 'OpenCV on Target' Skipped
15:59:56 INFO : install 'VisionWorks on Target' Skipped
15:59:56 INFO : install 'NVIDIA Container Runtime with Docker integration (Beta)' Skipped
15:59:56 INFO : install 'Multimedia API' Skipped
15:59:58 INFO : All done!
FLASHING FAILED
Please review the terminal tab for details. Resolve and RETRY.
Installation of target SDK components was skipped
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2019,
NVIDIA CORPORATION
All rights reserved.
NVIDIA Developer
(I shortened the output at the percentage of APP partition since it messed with the editing here on the board, but it went to 100% and not further.)
So I tried the flash.sh
I used the following commands:
sudo flash.sh jetson-nano-qspi-sd internal
which ran without errors, wrote all the partitions and the GPT-Table. So I restarted the Nano with display and keyboard and it did not boot. It turned on the screen all in black but did not proceed, no log shown.
This may not be the correct command, since it does not specify the SD-Card.
sudo flash.sh jetson-nano-qspi-sd mmcblk1p1
which should be the correct command for the SD-Card. It ran without errors. But again, after unplugging and replugging to power, no boot up, only black lit up screen.
After this my previously working SD-Card did not boot up either, therefore the Name of the topic here. But after the weekend, now it now boots again. Don’t ask me why, some kind of conductivity or memory decharged over the weekend?
For questions that may arise:
Of course the Nano was in recovery mode during flashing. (Jumpered the Recovery pins before plugging the power jack, after that removed the jumper and then flashed the nano)
lsusb showed
Bus 002 Device 002: ID 0955:7f21 NVidia Corp.
So my questions, since I do not understand the exact underlying problems during bootup here:
- What exactly is the QSPI memory used for? Is it some kind of boot vector or the like?
- How can I successfully flash the nano over flash.sh since finding out this was the purpose of this whole endeavour anyways?
With kind regards
Fabian
