Jetson nano flash failed
I’m using a jetson nano, I would like to upgrade this to jetson pack, however it can’t be done.
I’m sure I followed all the instructions.
All logs exported are attached here, looking for your advice.
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_Orin_Nano_4GB_2024-10-29_15-44-04.zip (182.1 KB)
Hi yc14
I would like to ask you some questions for more information:
  1. Are you using a NV devkit or custom board? Or you are not sure about the question here?
  2. Are you using the correct port to flash? Only one specific type C port is the flash port.
  3. The board needs to be in recovery mode before flash starts. Did you put the board into recovery mode?
  4. Are you sure the usb cable is able to transfer data? As some cheap cable only has charging function.’
  5. Is the host machine a native ubuntu PC?
Thanks for your reply!
  1. It’s not a custom board, it’s NV board;
  2. I think it’s the right port, as when this port is plugged in, the board could be detected by SDK manager;
  3. When the board is detected by SDK manager, it means that it’s in recovery mode, right?
  4. I tried with a few cables, I’m sure this one works;
  5. Yes it’s a ubuntu 20;
Hi yc14,
To change to Force Recovery Mode, you can refer to this website Jetson Orin Nano Developer Kit User Guide - How-to.
To determine whether the dev kit is in recovery mode, please refer Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
Hello David,
I tried forced recovery mode as indicated in the first link, and checked with method mentioned in the second one, which showed:
Bus 001 Device 048: ID 0955:7623 NVIDIA Corp. APX
Thus I’m pretty sure it’s in the recovery mode, however the error information remains unchanged.
Here’s the new log:
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_Orin_Nano_4GB_2024-10-30_11-02-44.zip (145.4 KB)
Just to clarify the naming here… Are you using Jetson Nano or Jetson Orin nano…?
These two are totally different. I guess you are using Orin Nano… but you filed in the old Jetson nano forum.
It’s Jetson Orin Nano, sorry for this misleading, I’m new here.
Ok. I just moved the post to Orin Nano forum.
vThere is no update from you for a period, assuming this is not an issue anymore.
please enable serial console log and share the log during flash failure happened.
