Jetson Nano freezes after boot, says tegradc.1 error
If the headless configuration really not appears in the end, you can try the debug script I shared long time ago…
A forum user verified this script still works last week.
Hello, again.
I did use user creation script, here is log file. :-)
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.04.14 14:14:05 =~=~=~=~=~=~=~=~=~=~=~=
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1416e9
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI …
[0000.281] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.302] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI …
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.525] Bootloader DTB Load Address: 0x83000000
[0000.530] BoardID = 3448, SKU = 0x0
[0000.533] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.537] Nano-SD: checking PT table on QSPI …
[0000.541] Loading NvTbootKernelDTB
[0000.607] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.680] Kernel DTB Load Address: 0x83100000
[0000.684] BoardID = 3448, SKU = 0x0
[0000.688] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.692] Nano-SD: checking PT table on QSPI …
[0000.698] Loading cboot binary
[0000.814] Verifying EBT in OdmNonSecureSBK mode
[0000.855] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.862] Bootloader downloaded successfully.
[0000.866] BoardID = 3448, SKU = 0x0
[0000.870] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.873] Nano-SD: checking PT table on QSPI …
[0000.878] PT: Partition NCT NOT found !
[0000.882] Warning: Find Partition via PT Failed
[0000.886] Next binary entry address: 0x92c00258
[0000.891] BoardId: 3448
[0000.895] Overriding pmu board id with proc board id
[0000.900] Display board id is not available
[0000.904] BoardID = 3448, SKU = 0x0
[0000.907] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.911] Nano-SD: checking PT table on QSPI …
[0001.016] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.073] /bpmp deleted
[0001.075] SC7EntryFw header found loaded at 0xff700000
[0001.271] OVR2 PMIC
[0001.272] Bpmp FW successfully loaded
[0001.276] BoardID = 3448, SKU = 0x0
[0001.279] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.283] Nano-SD: checking PT table on QSPI …
[0001.288] WB0 init successfully at 0xff780000
[0001.293] Set NvDecSticky Bits
[0001.296] GSC2 address ff53fffc value c0edbbcc
[0001.302] GSC MC Settings done
[0001.305] BoardID = 3448, SKU = 0x0
[0001.309] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.312] Nano-SD: checking PT table on QSPI …
[0001.318] TOS Image length 53680
[0001.321] Monitor size 53680
[0001.324] OS size 0
[0001.339] Secure Os AES-CMAC Verification Success!
[0001.343] TOS image cipher info: plaintext
[0001.347] Loading and Validation of Secure OS Successful
[0001.363] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.368] NvTbootPackSdramParams: start.
[0001.373] NvTbootPackSdramParams: done.
[0001.377] Tegraboot started after 51828 us
[0001.381] Basic modules init took 886482 us
[0001.385] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.390] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.396] Next stage binary read took 102859 us
[0001.400] Carveout took -126356 us
[0001.403] CPU initialization took 495390 us
[0001.407] Total time taken by TegraBoot 1358375 us
[0001.412] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:37:40, Feb 19 2021
ERROR: Error initializing runtime service trusty_fast
[0001.534] RamCode = 0
[0001.539] LPDDR4 Training: Read DT: Number of tables = 2
[0001.544] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.557] EMC Training Successful
[0001.560] 408000 not found in DVFS table
[0001.566] RamCode = 0
[0001.570] DT Write: emc-table@204000 succeeded
[0001.575] DT Write: emc-table@1600000 succeeded
[0001.579] LPDDR4 Training: Write DT: Number of tables = 2
[0001.626]
[0001.627] Debug Init done
[0001.630] Marked DTB cacheable
[0001.633] Bootloader DTB loaded at 0x83000000
[0001.638] Marked DTB cacheable
[0001.640] Kernel DTB loaded at 0x83100000
[0001.644] DeviceTree Init done
[0001.657] Pinmux applied successfully
[0001.662] gicd_base: 0x50041000
[0001.665] gicc_base: 0x50042000
[0001.668] Interrupts Init done
[0001.672] Using base:0x60005090 & irq:208 for tick-timer
[0001.678] Using base:0x60005098 for delay-timer
[0001.682] platform_init_timer: DONE
[0001.685] Timer(tick) Init done
[0001.689] osc freq = 38400 khz
[0001.693]
[0001.694] Welcome to L4T Cboot
[0001.697]
[0001.698] Cboot Version: 00.00.2018.01-t210-39562017
[0001.703] calling constructors
[0001.706] initializing heap
[0001.709] initializing threads
[0001.712] initializing timers
[0001.715] creating bootstrap completion thread
[0001.719] top of bootstrap2()
[0001.722] CPU: ARM Cortex A57
[0001.725] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.730] initializing platform
[0001.737] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.742] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.746] Macronix QSPI chip present
[0001.750] SPI device register
[0001.752] init boot device
[0001.755] allocating memory for boot device(SPI)
[0001.760] registering boot device
[0001.768] QSPI bdev is already initialized
[0001.772] Enable APE clock
[0001.775] Un-powergate APE partition
[0001.778] of_register: registering tegra_udc to of_hal
[0001.783] of_register: registering inv20628-driver to of_hal
[0001.789] of_register: registering ads1015-driver to of_hal
[0001.794] of_register: registering lp8557-bl-driver to of_hal
[0001.800] of_register: registering bq2419x_charger to of_hal
[0001.806] of_register: registering bq27441_fuel_gauge to of_hal
[0001.817] gpio framework initialized
[0001.821] of_register: registering tca9539_gpio to of_hal
[0001.826] of_register: registering tca9539_gpio to of_hal
[0001.832] of_register: registering i2c_bus_driver to of_hal
[0001.837] of_register: registering i2c_bus_driver to of_hal
[0001.843] of_register: registering i2c_bus_driver to of_hal
[0001.848] pmic framework initialized
[0001.852] of_register: registering max77620_pmic to of_hal
[0001.857] regulator framework initialized
[0001.861] of_register: registering tps65132_bl_driver to of_hal
[0001.867] initializing target
[0001.873] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.881] board ID = D78, board SKU = 0
[0001.885] Skipping Z3!
[0001.889] fixed regulator driver initialized
[0001.907] initializing OF layer
[0001.910] NCK carveout not present
[0001.914] Skipping dts_overrides
[0001.918] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.935] I2C Bus Init done
[0001.937] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.948] I2C Bus Init done
[0001.950] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.961] I2C Bus Init done
[0001.963] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.974] I2C Bus Init done
[0001.976] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.987] I2C Bus Init done
[0001.989] of_children_init: Ops found for compatible string maxim,max77620
[0002.000] max77620_init using irq 118
[0002.005] register ‘maxim,max77620’ pmic
[0002.009] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.015] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.026] I2C Bus Init done
[0002.029] NCK carveout not present
[0002.039] Find /i2c@7000c000’s alias i2c0
[0002.043] get eeprom at 1-a0, size 256, type 0
[0002.052] Find /i2c@7000c500’s alias i2c2
[0002.056] get eeprom at 3-a0, size 256, type 0
[0002.060] get eeprom at 3-ae, size 256, type 0
[0002.065] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.070] I2C slave not started
[0002.073] I2C write failed
[0002.075] Writing offset failed
[0002.079] eeprom_init: EEPROM read failed
[0002.082] pm_ids_update: eeprom init failed
[0002.087] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.117] pm_ids_update: The pm board id is 3448-0000-200
[0002.123] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.132] pm_ids_update: pm id update successful
[0002.136] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.167] pm_ids_update: The pm board id is 3449-0000-200
[0002.173] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.181] pm_ids_update: pm id update successful
[0002.211] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.217] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.225] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.231] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.239] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:c8:6b
[0002.245] Plugin Manager: Parse ODM data 0x000a4000
[0002.258] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.273] Find /i2c@7000c000’s alias i2c0
[0002.276] get eeprom at 1-a0, size 256, type 0
[0002.285] Find /i2c@7000c500’s alias i2c2
[0002.289] get eeprom at 3-a0, size 256, type 0
[0002.294] get eeprom at 3-ae, size 256, type 0
[0002.298] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.303] I2C slave not started
[0002.306] I2C write failed
[0002.309] Writing offset failed
[0002.312] eeprom_init: EEPROM read failed
[0002.316] pm_ids_update: eeprom init failed
[0002.320] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.350] pm_ids_update: The pm board id is 3448-0000-200
[0002.356] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.363] pm_ids_update: pm id update successful
[0002.368] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.398] pm_ids_update: The pm board id is 3449-0000-200
[0002.404] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.411] pm_ids_update: pm id update successful
[0002.442] Add serial number:1422619039096 as DT property
[0002.449] Applying platform configs
[0002.456] platform-init is not present. Skipping
[0002.460] calling apps_init()
[0002.466] Couldn’t find GPT header
[0002.471] Proceeding to Cold Boot
[0002.474] starting app android_boot_app
[0002.478] Device state: unlocked
[0002.481] display console init
[0002.489] could not find regulator
[0002.493] hdmi cable connected
[0002.508] edid read success
[0002.511] width = 1024, height = 600, frequency = 49000000
[0002.516] Best mode Width = 640, Height = 480, freq = 25174825
[0002.524] tmDT entry for leds-pwm not found
d[0002.531] s-config node not found
[0002.535] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.550] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.557] could not find regulator
[0002.561] could not find regulator
[0002.564] could not find regulator
[0002.592] using default cmu settings
[0002.596] dc_hdmi_enable, starting HDMI initialisation
[0002.602] dc_hdmi_enable, HDMI initialisation complete
[0002.607] list and configure display window
[0002.612] display console init completed
[0002.620] subnode volume_up is not found !
[0002.624] subnode back is not found !
[0002.627] subnode volume_down is not found !
[0002.631] subnode menu is not found !
[0002.635] Gpio keyboard init success
[0002.715] found decompressor handler: lz4-legacy
[0002.730] decompressing blob (type 1)…
[0002.797] load_bmp_blob: panelresolution=480 type=0
[0002.871] decompressor handler not found
[0002.875] load_firmware_blob: Firmware blob loaded, entries=2
[0002.881] XUSB blob version 0 size 124416 @ 0x92dee28c
[0002.887] -------> se_aes_verify_sbk_clear: 747
[0002.891] se_aes_verify_sbk_clear: Error
[0002.895] SE operation failed
[0002.898] bl_battery_charging: connected to external power supply
[0002.910] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.918] MSC Partition not found
[0002.924] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.931] USP partition read failed!
[0002.935] blob_init: blob-partition USP header read failed
[0002.940] android_boot Unable to update recovery partition
[0002.946] kfs_getpartname: name = LNX
[0002.949] Loading kernel from LNX
[0002.958] Found 19 BFS partitions in “spiflash0”
[0003.281] load kernel from storage
[0003.286] decompressor handler not found
[0003.554] Successfully loaded kernel and ramdisk images
[0003.559] board ID = D78, board SKU = 0
[0003.564] sdmmc node status = okay
[0003.567] sdcard instance = 0
[0003.570] sdcard gpio handle 0x5b
[0003.573] sdcard gpio pin 0xc9
[0003.576] sdcard gpio flags 0x0
[0003.579] vmmc-supply 0x9e
[0003.582] cd_gpio_pin = 201
[0003.584] pin_state = 0
[0003.587] Found sdcard
[0003.589] SD-card IS present …
[0003.592] load_and_boot_kernel: SD card detected OK
[0003.598] load_bmp_blob: panelresolution=480 type=0
[0003.671] display bmp image done
[0003.674] NCK carveout not present
[0003.678] Skipping dts_overrides
[0003.681] NCK carveout not present
[0003.691] Find /i2c@7000c000’s alias i2c0
[0003.695] get eeprom at 1-a0, size 256, type 0
[0003.704] Find /i2c@7000c500’s alias i2c2
[0003.708] get eeprom at 3-a0, size 256, type 0
[0003.712] get eeprom at 3-ae, size 256, type 0
[0003.716] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.722] I2C slave not started
[0003.725] I2C write failed
[0003.727] Writing offset failed
[0003.730] eeprom_init: EEPROM read failed
[0003.734] pm_ids_update: eeprom init failed
[0003.738] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.769] pm_ids_update: The pm board id is 3448-0000-200
[0003.775] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0003.784] pm_ids_update: pm id update successful
[0003.788] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.818] pm_ids_update: The pm board id is 3449-0000-200
[0003.825] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0003.833] pm_ids_update: pm id update successful
[0003.863] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.869] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.877] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.883] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.891] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:c8:6b
[0003.897] Plugin Manager: Parse ODM data 0x000a4000
[0003.910] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.918] Add serial number:1422619039096 as DT property
[0003.927] “bpmp” doesn’t exist, creating
[0003.933] Updated bpmp info to DTB
[0003.937] Updated initrd info to DTB
[0003.941] “proc-board” doesn’t exist, creating
[0003.947] Updated board info to DTB
[0003.950] “pmu-board” doesn’t exist, creating
[0003.956] Updated board info to DTB
[0003.960] “display-board” doesn’t exist, creating
[0003.966] Updated board info to DTB
[0003.969] “reset” doesn’t exist, creating
[0003.974] Updated reset info to DTB
[0003.977] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1
[0004.016] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.022] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.035] Updated bootarg info to DTB
[0004.039] Adding uuid 0000000164449584040000000e078380 to DT
[0004.044] Adding eks info 0 to DT
[0004.050] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.056] Updated memory info to DTB
[0004.062] Updated system-lp0-disable info to DTB
[0004.069] set vdd_core voltage to 1125 mv
[0004.073] setting ‘vdd-core’ regulator to 1125000 micro volts
[0004.079] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:46 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 27 ms (30.3 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 327 ms (20.9 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1503 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317e68d
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.131596] tegradc tegradc.1: dpd enable lookup fail:-19
Looks like “quiet” is still there. Could you remove it?
How can you found? I did deleted it. Please show where it is found in log, please.
  1. Because the kernel log is still short here so I just scroll back few lines and it is there.
  2. You can use the browser to search “quiet” here and you will see.
  1. If you do delete, then tell me how was your step to do so. Maybe there is something wrong.
OK, my bad.
Did long log:
All before is same
Starting kernel …
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29360(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568568K/4159488K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 115784K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.010030] Console: colour dummy device 80x25
[ 0.014677] console [tty0] enabled
[ 0.018184] bootconsole [uart8250] disabled
[ 0.022511] kmemleak: Kernel memory leak detector disabled
[ 0.022537] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.022560] pid_max: default: 32768 minimum: 301
[ 0.023027] Security Framework initialized
[ 0.023250] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023266] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.024380] ftrace: allocating 47208 entries in 185 pages
[ 0.193059] ASID allocator initialised with 65536 entries
[ 0.232186] tegra-id: chipid=22117.
[ 0.232216] tegra-id: opt_subrevision=0.
[ 0.232238] Tegra Speedo/IDDQ fuse revision 4
[ 0.232247] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.232257] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.232268] Tegra: CPU Speedo Value 2008, SoC Speedo Value 1919, GPU Speedo Value 1992
[ 0.232279] Tegra: CPU IDDQ Value 1856, SoC IDDQ Value 1964, GPU IDDQ Value 2250
[ 0.232304] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.232325] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.232346] DTB Build time: Feb 19 2021 08:42:41
[ 0.281287] CPU1: Booted secondary processor [411fd071]
[ 0.313193] CPU2: Booted secondary processor [411fd071]
[ 0.345145] CPU3: Booted secondary processor [411fd071]
[ 0.345238] Brought up 4 CPUs
[ 0.345289] SMP: Total of 4 processors activated.
[ 0.345307] CPU features: detected feature: 32-bit EL0 Support
[ 0.345580] CPU: All CPU(s) started at EL2
[ 0.345608] alternatives: patching kernel code
[ 0.353767] devtmpfs: initialized
[ 0.392341] Initilizing CustomIPI irq domain
[ 0.392774] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.392819] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.403362] pinctrl core: initialized pinctrl subsystem
[ 0.403981] OS set in device tree is not L4T.
[ 0.404418] regulator-dummy: no parameters
[ 0.404706] Initializing plugin-manager
[ 0.404888] Plugin module not found
[ 0.405089] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.405652] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.406383] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.406925] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.407145] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.407511] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.412295] NET: Registered protocol family 16
[ 0.413705] pstore: using zlib compression
[ 0.414206] console [pstore-1] enabled
[ 0.414221] pstore: Registered ramoops as persistent store backend
[ 0.414239] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.429306] cpuidle: using governor menu
[ 0.433792] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.435566] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.435609] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.437770] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.440247] Serial: AMBA PL011 UART driver
[ 0.440772] tegra_powergate_init: DONE
[ 0.440805] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.440839] DTB Build time: Feb 19 2021 08:42:41
[ 0.442906] Tegra reboot handler registered.
[ 0.447537] iommu: Adding device tegra-carveouts to group 0
[ 0.447706] platform tegra-carveouts: domain=ffffffc0f94423d8 allocates as[0]=ffffffc0f94540a8
[ 0.448082] iommu: Adding device smmu_test to group 1
[ 0.448144] platform smmu_test: domain=ffffffc0f9442618 allocates as[0]=ffffffc0f9454110
[ 0.448969] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.449040] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.449110] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.449131] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.449168] mc-err: mcerr ops are set to t21x
[ 0.459719] iommu: Adding device 70090000.xusb to group 2
[ 0.460029] iommu: Adding device 70006000.serial to group 3
[ 0.460114] platform 70006000.serial: domain=ffffffc0f94e96d8 allocates as[0]=ffffffc0f9454178
[ 0.460553] iommu: Adding device 70006040.serial to group 4
[ 0.460845] iommu: Adding device 70006200.serial to group 5
[ 0.461077] iommu: Adding device sound to group 6
[ 0.461139] platform sound: domain=ffffffc0f94e9c18 allocates as[0]=ffffffc0f94541e0
[ 0.461864] iommu: Adding device 7000d400.spi to group 7
[ 0.462144] iommu: Adding device 7000d600.spi to group 8
[ 0.462424] iommu: Adding device 70410000.spi to group 9
[ 0.462745] iommu: Adding device 50000000.host1x to group 10
[ 0.463034] iommu: Adding device 54080000.vi to group 11
[ 0.463435] iommu: Adding device 54600000.isp to group 12
[ 0.463710] iommu: Adding device 54680000.isp to group 13
[ 0.464034] iommu: Adding device tegradc.0 to group 14
[ 0.464097] platform tegradc.0: domain=ffffffc0f94f6b58 allocates as[0]=ffffffc0f9454248
[ 0.464634] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.464978] iommu: Adding device tegradc.1 to group 15
[ 0.465037] platform tegradc.1: domain=ffffffc0f94f6d98 allocates as[0]=ffffffc0f94542b0
[ 0.465600] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.465865] iommu: Adding device 54340000.vic to group 16
[ 0.466092] iommu: Adding device 544c0000.nvenc to group 17
[ 0.466309] iommu: Adding device 54500000.tsec to group 18
[ 0.466525] iommu: Adding device 54100000.tsecb to group 19
[ 0.466731] iommu: Adding device 54480000.nvdec to group 20
[ 0.466957] iommu: Adding device 54380000.nvjpg to group 21
[ 0.468014] iommu: Adding device 546c0000.i2c to group 22
[ 0.468368] iommu: Adding device 57000000.gpu to group 23
[ 0.468432] platform 57000000.gpu: domain=ffffffc0f9500d98 allocates as[0]=ffffffc0f9454318
[ 0.468488] platform 57000000.gpu: domain=ffffffc0f9500d98 allocates as[1]=ffffffc0f9454380
[ 0.468543] platform 57000000.gpu: domain=ffffffc0f9500d98 allocates as[2]=ffffffc0f94543e8
[ 0.468598] platform 57000000.gpu: domain=ffffffc0f9500d98 allocates as[3]=ffffffc0f9454450
[ 0.469543] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.469584] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.469611] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.469630] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.469645] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.521378] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.521408] tegra-pmc: Clear bootloader IO dpd settings
[ 0.521443] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.521517] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.521824] iommu: Adding device 70012000.se to group 24
[ 0.522621] iommu: Adding device 7000c000.i2c to group 25
[ 0.522886] iommu: Adding device 7000c400.i2c to group 26
[ 0.523156] iommu: Adding device 7000c500.i2c to group 27
[ 0.523420] iommu: Adding device 7000c700.i2c to group 28
[ 0.523723] iommu: Adding device 7000d000.i2c to group 29
[ 0.523989] iommu: Adding device 7000d100.i2c to group 30
[ 0.524298] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.524360] platform sdhci-tegra.0: domain=ffffffc0f95a6f18 allocates as[0]=ffffffc0f94544b8
[ 0.525230] iommu: Adding device 700d0000.xudc to group 32
[ 0.528433] vdd-ac-bat: 5000 mV
[ 0.528808] vdd-5v0-sys: 5000 mV
[ 0.529821] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.529908] vdd-5v0-hdmi: 5000 mV
[ 0.530332] vdd-1v8-sys: 1800 mV
[ 0.530736] vdd-fan: supplied by vdd-5v0-sys
[ 0.530790] vdd-fan: 5000 mV
[ 0.531184] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.531252] vdd-usb-vbus: 5000 mV
[ 0.531802] vdd-usb-vbus2: 5000 mV
[ 0.562343] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.564959] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.566224] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.566261] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.566640] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.574684] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.575069] SCSI subsystem initialized
[ 0.575646] usbcore: registered new interface driver usbfs
[ 0.575723] usbcore: registered new interface driver hub
[ 0.575810] usbcore: registered new device driver usb
[ 0.579794] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.584456] random: fast init done
[ 0.585413] vdd-core: 600 <–> 1162 mV at 1125 mV
[ 0.586493] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.589307] vdd-ddr-1v1: 1150 mV
[ 0.593164] vdd-pre-reg-1v35: 1350 mV
[ 0.597162] vdd-1v8: 1800 mV
[ 0.601165] avdd-sys-1v2: 1200 mV
[ 0.605163] vdd-pex-1v0: 1050 mV
[ 0.605849] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.606409] max77620-ldo3: at 3100 mV
[ 0.609165] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.609731] max77620-ldo5: at 3100 mV
[ 0.610287] max77620-ldo6: at 2800 mV
[ 0.613167] avdd-1v05-pll: 1050 mV
[ 0.617162] avdd-io-hdmi-dp: 1050 mV
[ 0.619846] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.620139] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.620438] max77620 4-003c: max77620 probe successful
[ 0.623191] media: Linux media interface: v0.10
[ 0.623269] Linux video capture interface: v2.00
[ 0.624229] pps_core: LinuxPPS API ver. 1 registered
[ 0.624255] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.624293] PTP clock support registered
[ 0.627537] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.628535] Advanced Linux Sound Architecture Driver Initialized.
[ 0.629220] Bluetooth: Core ver 2.22
[ 0.629288] NET: Registered protocol family 31
[ 0.629306] Bluetooth: HCI device and connection manager initialized
[ 0.629334] Bluetooth: HCI socket layer initialized
[ 0.629354] Bluetooth: L2CAP socket layer initialized
[ 0.629414] Bluetooth: SCO socket layer initialized
[ 0.631224] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.631261] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.631322] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.631350] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.635136] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.636401] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.636484] vdd-3v3-sys: 3300 mV
[ 0.636787] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.641448] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.641960] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.642048] vdd-3v3-sd: 3300 mV
[ 0.643146] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.643201] avdd-io-edp-1v05: 1050 mV
[ 0.643704] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.643754] vdd-usb-hub-en: 5000 mV
[ 0.645232] camchar: rtcpu character device driver loaded
[ 0.645964] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.647323] clocksource: Switched to clocksource arch_sys_counter
[ 0.687903] VFS: Disk quotas dquot_6.6.0
[ 0.688080] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.688562] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.688992] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.689038] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.689259] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.689280] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.689307] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.689353] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.689378] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.689407] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.689428] nvmap_page_pool_init: Total RAM pages: 1010926
[ 0.689446] nvmap_page_pool_init: nvmap page pool size: 126365 pages (493 MB)
[ 0.689547] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.690024] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.690933] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.699129] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.699659] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.700058] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.700359] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.700557] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.700854] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.700872] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.701318] NET: Registered protocol family 2
[ 0.702301] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.702537] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.703044] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.703212] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.703358] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.703785] NET: Registered protocol family 1
[ 0.704508] RPC: Registered named UNIX socket transport module.
[ 0.704537] RPC: Registered udp transport module.
[ 0.704553] RPC: Registered tcp transport module.
[ 0.704569] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.704856] Trying to unpack rootfs image as initramfs…
[ 1.008556] Freeing initrd memory: 6992K
[ 1.018405] host1x 50000000.host1x: initialized
[ 1.020388] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.023635] audit: initializing netlink subsys (disabled)
[ 1.023729] audit: type=2000 audit(0.867:1): initialized
[ 1.024477] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.034305] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.035855] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.036656] 9p: Installing v9fs 9p2000 file system support
[ 1.039967] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.040135] io scheduler noop registered
[ 1.040443] io scheduler cfq registered (default)
[ 1.043072] gic 702f9000.agic: GIC IRQ controller registered
[ 1.046085] iommu: Adding device 702ef000.adsp to group 33
[ 1.055428] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.055626] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.056262] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8207c10
[ 1.056290] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.057919] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.058053] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.058193] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.058409] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.058524] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.058626] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.058732] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.058836] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.058943] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.059045] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.065213] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.066917] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.068844] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.070122] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.070492] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.071858] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.072113] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 1.072386] Adding domain tsec-pd to PM domain host1x-pd
[ 1.074832] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.075819] tsec 54500000.tsec: initialized
[ 1.077386] tsec 54100000.tsecb: initialized
[ 1.078110] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.081769] nvdec 54480000.nvdec: initialized
[ 1.082853] Adding domain vic03-pd to PM domain host1x-pd
[ 1.083052] Adding domain msenc-pd to PM domain host1x-pd
[ 1.083224] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.087392] falcon 54340000.vic: initialized
[ 1.088709] falcon 544c0000.nvenc: initialized
[ 1.090027] falcon 54380000.nvjpg: initialized
[ 1.094439] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.094531] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.094579] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.094686] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.094793] display board info: id 0x0, fab 0x0
[ 1.094860] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.094863] generic_infoframe_type: 0x87
[ 1.094894] tegra_cec 70015000.tegra_cec: probed
[ 1.095006] tegradc tegradc.0: DT parsed successfully
[ 1.095067] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.102950] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.103019] tegradc tegradc.0: probed
[ 1.103800] Console: switching to colour frame buffer device 80x30
[ 1.103846] tegradc tegradc.0: fb registered
[ 1.105154] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.105255] tegradc tegradc.1: No lt-data, using default setting
[ 1.105297] tegradc tegradc.1: No hpd-gpio in DT
[ 1.105351] tegradc tegradc.1: DT parsed successfully
[ 1.105415] tegradc tegradc.1: Display dc.ffffff800ad00000 registered with id=1
[ 1.106918] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.109310] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.110098] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.110121] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.110452] kfuse 7000fc00.kfuse: initialized
[ 1.612647] Host read timeout at address 545c00c4
[ 1.612913] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.613819] tegradc tegradc.1: probed
[ 1.613876] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.614156] tegradc tegradc.1: fb registered
[ 1.615052] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.615079] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.615515] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.616853] vdd-gpu: applied init 1000000uV constraint
[ 1.616873] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.617273] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.617372] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.617391] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.617410] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.617433] tegradc tegradc.1: blank - powerdown
[ 1.617462] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.617477] Extcon DP: HPD disabled
[ 1.617488] hpd: hpd_switch 0
[ 1.617499] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.617517] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.617532] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.621078] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.621200] No Device Node present for smmu client: serial8250 !!
[ 1.621221] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.621272] iommu: Adding device serial8250 to group 35
[ 1.623545] console [ttyS0] disabled
[ 1.623633] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 2.001033] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.108553] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.108558] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.707142] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 3.111572] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 3.113590] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 3.219841] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 3.219851] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 3.219855] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 3.219860] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 3.219865] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.220255] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.231489] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 3.231494] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.231503] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 3.231525] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 3.231543] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 3.231553] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 3.231558] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 3.231565] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 3.231948] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 3.231953] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 4.171626] console [ttyS0] enabled
[ 4.176393] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 4.185590] serial-tegra 70006200.serial: RX in PIO mode
[ 4.191021] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 4.200873] [drm] Initialized
[ 4.214320] brd: module loaded
[ 4.222780] loop: module loaded
[ 4.226190] tegra_profiler: version: 1.143, samples/io: 48/28
[ 4.232083] tegra_profiler: auth: init
[ 4.237257] THERMAL EST: found 2 subdevs
[ 4.241223] THERMAL EST num_resources: 0
[ 4.245162] [THERMAL EST subdev 0]
[ 4.248627] [THERMAL EST subdev 1]
[ 4.252498] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 4.261477] THERMAL EST: thz register success.
[ 4.266094] THERMAL EST: end of probe, return err: 0
[ 4.272321] sd: No Scsi addr parsed to reserve index
[ 4.277352] hisi_sas: driver version v1.6
[ 4.286060] tegra-qspi 70410000.spi: Prod settings list not found
[ 4.293327] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 4.298758] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 4.313706] libphy: Fixed MDIO Bus: probed
[ 4.318776] tun: Universal TUN/TAP device driver, 1.6
[ 4.323865] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.331036] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.336892] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.342881] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.349854] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.355491] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.363328] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.369301] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.376271] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.382518] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 4.388406] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 4.408386] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 4.420776] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:c8:6b from device tree
[ 4.433259] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 4.444713] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
[ 4.444713] This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
[ 4.444713] This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 4.476059] PPP generic driver version 2.4.2
[ 4.480550] PPP BSD Compression module registered
[ 4.485267] PPP Deflate Compression module registered
[ 4.490363] PPP MPPE Compression module registered
[ 4.495163] NET: Registered protocol family 24
[ 4.499682] usbcore: registered new interface driver r8152
[ 4.505218] usbcore: registered new interface driver asix
[ 4.510692] usbcore: registered new interface driver ax88179_178a
[ 4.516826] usbcore: registered new interface driver cdc_ether
[ 4.522701] usbcore: registered new interface driver net1080
[ 4.528406] usbcore: registered new interface driver cdc_subset
[ 4.534368] usbcore: registered new interface driver zaurus
[ 4.540005] usbcore: registered new interface driver cdc_ncm
[ 4.545845] VFIO - User Level meta-driver version: 0.3
[ 4.552236] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.558795] ehci-pci: EHCI PCI platform driver
[ 4.563294] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.569489] ohci-pci: OHCI PCI platform driver
[ 4.573982] ohci-platform: OHCI generic platform driver
[ 4.581979] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 4.588376] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 4.596710] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f91e8400 id
[ 4.605383] usbcore: registered new interface driver uas
[ 4.610750] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 4.610821] tegra-xu
Maybe you should attach it as a text file. The log is truncated by forum system due to length.
Trying, but cannot.
Error: undefined method `hostname’ for nil:NilClass
While downloading logfile.
Not sure about such error. Where did you see it?
When pressing “Upload” button at forum in “Upload” menu.
Update, used another jetson with flashed SD card - it cannot find any partitions.
Flashing new SD card right now.
Installed on same devboard another Jetson, flashed and here is log file.
Maybe the forum system has some problem. How about paste it to some google doc and share the link ?
Hello.
Sorry, it was all my fault.
I did used 5V/10A DC power source which were VERY good at all times.
But it was good. Basically, when i did watched non-quiet log, i did saw that Jetson were stopped at some strange place, right in initialization.
So, i did used 5V/45A power source to check and it all worked.
I am very sorry for this small but big problem for me.
Alas, i did found, that modifying “quiet” in extlinux.conf is not always answer. I did erased “quiet” in extlinux.conf.backup and then got full log.
Thank you for patience and sorry again. Feel myself very ashamed that not checked it before. So much time is lost.
