Jetson Nano GbE port AC coupling to ethernet switch IC
What is the proper way to ac couple the jetson nano GbE port with an ethernet switch IC KSZ9897’s PHY port? For example, what value coupling caps are needed, and are bias resistors required on either side of the ac coupling caps and if so, which side?
Hi, please check PHY switch datasheet or vendor for that. For nano side, please follow the nano Design Guide in DLC. Jetson Download Center | NVIDIA Developer
