But, there is no output signal by default.
I checked the extension header pin with a multimeter, there is no output voltage.
GPIO-14 => extension pin 13
GPIO-15 => extension pin 18
And kernel-gpio isn’t sat, also.
I wonder what i missed?
And how can i read current gpio status?
you may check via sysnode, /sys/class/gpio/.
for example,
SPI1_CS0 / GPIO3_PB.07, it’s gpio15,
you may export the pin manually, # echo 15 > export, then you’ll have gpio15 available.
thanks
it looks those configurations were correct, may I know how you probe the pin,
you may also check applications note of 40-Pin Expansion Header GPIO Usage Considerations about the level shifter.
thanks
