Hi everyone! I’m building robot from scratch with jetson nano and a usb webcam. When that webcam plugged in the jetson nano stop responding until I unplug the webcam. I checked to dmesg and gives the following message?
[ 506.374532] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 506.381649] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
[ 506.388683] tegra-xusb 70090000.xusb: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 4 comp_code 31
[ 506.399270] tegra-xusb 70090000.xusb: Looking for event-dma 00000000ffca28a0 trb-start 00000000ffca28f0 trb-end 00000000ffca28f0 seg-start 00000000ffca2000 seg-end 00000000ffca2ff0
[ 506.415314] tegra-xusb 70090000.xusb: WARN: buffer overrun event on endpoint
What I can do to resolve that issue?
I decided to go with usb webcam is because the csi camera failed ( imx219 board setup faield )
