Jetson Nano Hangs Frequently (checked power and fan)
My nano hangs frequently when try to play video or even a few extra tabs in the browser. By hang I mean the screen freezes, and the mouse pointer is stuck. If a video is playing - it is stuck and random audio sound plays in the speaker in a very short loop (basically, noise). If I leave the nano for about 30 mins - it eventually will recover.
Here are the things I have tried:
  • I replaced the USB power with a recommended barrel power suppply
  • I thought this was a temperature issue, so I installed a FAN
I’ve run apt update and apt upgrade fairly regularly. Now I am running out of ideas. How can I fix this. From a hardware angle the device should be able to handle this workload.
hello nvidiac0stz,
may I know which JetPack release you’re working with.
could you please gather failure logs for investigation, you might also check both kernel side and user-space.
for example,
dmesg cat /var/log/syslog
BTW,
please also monitor tegrastats to check the system resources.
thanks
You may run out of memory.
Create swap on SD card to fix the problem
Both the logs have the following message over and over again:
<timestamp> xxxxx kernel: [114793.784301] tegra_i2c_handle_xfer_error: 2 callbacks suppressed
<timestamp> xxxxx kernel: [114793.784339] tegra-i2c 7000c700.i2c: no acknowledge from address 0x54
<timestamp> xxxxx kernel: [114793.797731] tegradc tegradc.0: hdmi: scdc scrambling status is reset, trying to reconfigure.
Here is the details from tegrastats while the screen is frozen (ran ssh on remote machine and issued the command before trying to run a video).
RAM 3445/3957MB (lfb 9x4MB) CPU [20%@1428,11%@1428,14%@1428,12%@1428] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@28C PMIC@100C GPU@27C AO@31C thermal@26.75C POM_5V_IN 3826/3626 POM_5V_GPU 0/16 POM_5V_CPU 967/788
RAM 3447/3957MB (lfb 9x4MB) CPU [16%@518,10%@518,30%@518,10%@518] EMC_FREQ 0% GR3D_FREQ 0% PLL@24C CPU@27C PMIC@100C GPU@27C AO@31C thermal@27.25C POM_5V_IN 3163/3625 POM_5V_GPU 0/16 POM_5V_CPU 379/787
RAM 3446/3957MB (lfb 9x4MB) CPU [14%@403,10%@403,23%@403,7%@403] EMC_FREQ 0% GR3D_FREQ 0% PLL@24C CPU@26.5C PMIC@100C GPU@27C AO@31C thermal@26.75C POM_5V_IN 3083/3624 POM_5V_GPU 0/16 POM_5V_CPU 295/786
RAM 3446/3957MB (lfb 9x4MB) CPU [19%@518,7%@518,23%@518,9%@518] EMC_FREQ 0% GR3D_FREQ 0% PLL@24C CPU@27C PMIC@100C GPU@27C AO@30.5C thermal@26.75C POM_5V_IN 3121/3623 POM_5V_GPU 0/15 POM_5V_CPU 337/785
RAM 3446/3957MB (lfb 9x4MB) CPU [17%@518,11%@518,25%@518,9%@518] EMC_FREQ 0% GR3D_FREQ 0% PLL@24.5C CPU@26.5C PMIC@100C GPU@27C AO@31C thermal@27C POM_5V_IN 3247/3623 POM_5V_GPU 0/15 POM_5V_CPU 421/784
RAM 3446/3957MB (lfb 9x4MB) CPU [16%@204,11%@204,18%@204,5%@204] EMC_FREQ 0% GR3D_FREQ 0% PLL@24C CPU@26.5C PMIC@100C GPU@27C AO@31C thermal@26.75C POM_5V_IN 2999/3621 POM_5V_GPU 0/15 POM_5V_CPU 253/783
Thanks for the tip on the swap. I created and turned on swap - that helped materially!
