To verify that the I/O pins work, you need a hardware fixture that can provide and sense expected signals, and/or loop back outputs to inputs.
The CSI control circuitry can work just fine, but if you’re having problems talking to a camera module, it’s either a configuration problem in the device tree, or it’s a physical connection hardware problem, which the CSI interface hardware wouldn’t be able to sense on its own.
