Jetson Nano I2C Bind/Unbind
Our custom board, there is a hanging while we use i2c-3(7000c700.i2c)
So, we tried to unbind and bind for i2c-3(7000c700.i2c) but it doesn’t works.
And then Now I’m trying to test same process on Jetson Nano Developer Kit.
I am just testing it as default status. This status has no issue with any i2c bus.
The other i2c buses are working to unbind/bind what I can access.
But there is no result for unbinding i2c-3. Terminal is juststopped.
And I can’t find i2c-3 bus on the other terminal.
And No such devices is out when I try to bind.
Is anyone know why it doesn’t works?
Will update to your for checking internally.
Hello, Could I get any update ??
What’s your BSP version.
I can’t see the problem on my device.
root@tegra-ubuntu:/sys/bus/platform/drivers/tegra-i2c# cat /etc/nv_tegra_release
# R32 (release), REVISION: 7.3, GCID: 31982016, BOARD: t210ref, EABI: aarch64, DATE: Tue Nov 22 17:30:08 UTC 2022
root@tegra-ubuntu:/sys/bus/platform/drivers/tegra-i2c# ll
total 0
drwxr-xr-x   2 root root    0 Dec 23 22:03 ./
drwxr-xr-x 216 root root    0 Dec 23 22:01 ../
lrwxrwxrwx   1 root root    0 Dec 23 22:01 7000c000.i2c -> ../../../../devices/7000c000.i2c/
lrwxrwxrwx   1 root root    0 Dec 23 22:01 7000c400.i2c -> ../../../../devices/7000c400.i2c/
lrwxrwxrwx   1 root root    0 Dec 23 22:01 7000c500.i2c -> ../../../../devices/7000c500.i2c/
lrwxrwxrwx   1 root root    0 Dec 23 22:04 7000c700.i2c -> ../../../../devices/7000c700.i2c/
lrwxrwxrwx   1 root root    0 Dec 23 22:01 7000d000.i2c -> ../../../../devices/7000d000.i2c/
lrwxrwxrwx   1 root root    0 Dec 23 22:01 7000d100.i2c -> ../../../../devices/7000d100.i2c/
--w-------   1 root root 4096 Dec 23 22:03 bind
--w-------   1 root root 4096 Dec 23 22:01 uevent
--w-------   1 root root 4096 Dec 23 22:03 unbind
root@tegra-ubuntu:/sys/bus/platform/drivers/tegra-i2c# echo 7000c700.i2c > unbind
root@tegra-ubuntu:/sys/bus/platform/drivers/tegra-i2c# echo 7000c700.i2c > bind
I tried to test several combinations
But Nothing works.
- Jetson Nano Developer Kit, JetPack 4.6.4
- Jetson Nano Developer Kit, JetPack 4.6.3
- Jetson Nano Production Module + Seeed J101, JetPack 4.6.4
- Jetson Nano Production Module + Seeed J101, JetPack 4.5.1
Is there any other way to reset I2C device about same port (7000c700)??
Do you have any modify for the device tree or have any slave device on this bus?
At beginning of test, we did it on custom board and custom kernel.
Last one, we were flashing just default BSP.
Default BSP on customize board? Could you check on devkit.
Sorry, It means as follow:
Back then, Custom BSP => Custom Board
Now days, Default BSP => Dev Kit (You can see what system I used on the capture images)
I have confirm on two Nano without problem.
Do you have another Nano devkit to confirm.
I tested several boards as following:
  • Jetson Nano A02 Dev Kit
  • Jetson Nano B01 Dev Kit
  • Jetson Nano B01 Production Module.
And Our customer has same problem with their Jetson Nano custom board.
Could you check the dmesg if any error.
I can’t see anything releated to I2C Unbind/Bind error.
nano dev-kit i2c bind error dmesg.txt (57.9 KB)
I’ve got answer.
It can work when HDMI connector is unpluged.
Thank you for the support.
It looks like this i2c is used by display hdmi.
and if you have display connected, it will fail and cause system hang.
