I’ll start out by saying that I am not an electrical engineer, and device trees are still new to me.
On our carrier board we have an Infineon slb9672 TPM. We have it connected to SPI2 (SPI2A_DOUT, SPI2A_DIN, SPI2A_SCK, and SPI2A_CS0 are connected). PBB.00 is also connected for PIRQ.
I added a dtsi file with the following content:
#include <dt-bindings/platform/t210/t210.h>
spi@7000d600 {
status = "okay";
spi@0 {
status = "disabled";
spi@1 {
slb9670: slb9670@0{
compatible = "infineon,slb9670";
reg = <0>;
spi-max-frequency = <32000000>;
status = "okay";
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <7>;
In addition we are adding the following to the kernel .config file:
CONFIG_TCG_TPM=y
CONFIG_TCG_TIS_CORE=y
CONFIG_TCG_TIS_SPI=y
# CONFIG_TCG_TIS_I2C_ATMEL is not set
# CONFIG_TCG_TIS_I2C_INFINEON is not set
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_ATMEL is not set
# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
CONFIG_DEVPORT=y
# CONFIG_XILLYBUS is not set
# CONFIG_HMM_DMIRROR is not set
CONFIG_HW_RANDOM=m
CONFIG_HW_RANDOM_TPM=m
# CONFIG_TRUSTED_KEYS is not set
When we build/flash/boot the Jetson Nano we don’t see any tpm in /dev as we would expect.
If we grep dmesg for “TPM, tpm, tis, TIS or SPI” nothing is there. If we grep “spi” we only see:
dmesg | grep spi
[ 0.428153] iommu: Adding device 7000d400.spi to group 7
[ 0.428412] iommu: Adding device 7000d600.spi to group 8
I do see this in sysfs:
sudo cat /sys/bus/spi/devices/spi1.0/uevent
OF_NAME=slb9670
OF_FULLNAME=/spi@7000d600/slb9670@0
OF_COMPATIBLE_0=infineon,slb9670
OF_COMPATIBLE_N=1
MODALIAS=spi:slb9670
I also added tpm2-tss and tpm2-tools to the rootfs to help in testing, but since we dont see a /dev/tpmrm0 they are not being used.
Has anyone else put a Infineon TPM on a Jetson Nano carrier board?
