I have jetson nano model with 16 gb internal memory. This memory cannot be installed because it is not enough when installing deepstream with sdk manager. Could you suggest a solution for this?
Is the 16GB a memory size or storage size?
The model I use, jetson j1020 has its own memory and the memory size is 16GB. That’s why I can’t do the necessary installations. I am using ssd as external memory, but I cannot perform memory selection with sdk manager during installation.
how do you attach the SSD onto your Jetson Nano?
I think you can also use a USB drive for larger storage.
