After jetson nano install jetpack 4.4.1, use Deepstream to run yolov3, the pipeline generation is normal, but nano restarts. The terminal output is as follows:
yolov3 is too large for Nano. You may change to some smaller model.
First of all thank you for your reply. I finally solved this problem. The reason for this problem was insufficient power supply. After replacing the high power, the nano runs normally.
