I have tried android on jetson nano board via Install Jedroid onto SD card - NVIDIA Jetson TK1 · GitHub, but when I restart jetson nano, Nvidia Splash Screen Frozen and can’t read SD card (I tried many SD Card). So I try to reccomputer the jetson nano j1010 using sdkmanager but it always freezes at 99%.
On host PC, please remove the folder in
~/nvidia/nvidia_sdk
And then try again. This will force SDKmanager to re-download the whole package. See if it can flash and boot after re-dowloading. Please also make sure Jetson Nano is in recovery mode before flashing.
Thanks for your reply, I tried deleting the nvidia sdk folder, but it didn’t work. It still freezes at 99%.Below is a video of what I did.
Hi ericjjkkhandsome,
Are you using Nano-SD?
If yes, please select Jetson Nano [developer kit version]
to flash image.
This one is for Nano-SD module.
The Jetson Nano
is for Nano-emmc modue.
Sdkmanager does not support VM.
Thanks for your help. I will try the SDK manager on the host
