Well, do you have the file ‘ssd_mobilenet_v2_coco.engine’ ?
(This is presumably a pre-trained model file you can download.)
Is the file available in the current working directory for the program?
Thanks for the reply, snarky. It’s there… but to your point, I may not have it in the working directory for the program. My dev machine is at the house. Will take a look at it tonight and report back.
Slow reply… but worth updating. I am using a Jupyter notebook to run the packages. To Snarky’s point, I needed to move the ‘ssd_mobilenet_v2_coco.engine’ into the same directory as the notebook. Worked like a champ.
Is there a way to create my own ‘.engine’ file with my .weights and .cfg file?
I have used Yolov3 with Darknet framework… according to Darknet documentation it is supported TensorRT.
