Jetson Nano Jetpack 4.2 SoC ID(0x00) mismatches
Below are the logs.
DETAILS TERMINAL
Flash Jetson Nano
Message Type: All
Filter text here...
18:22:34 INFO : Flash Jetson Nano : [ 0.0194 ]
18:22:34 INFO : Flash Jetson Nano : [ 0.0195 ] Copying signature to RCM mesages
18:22:34 INFO : Flash Jetson Nano : [ 0.0209 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
18:22:34 INFO : Flash Jetson Nano : [ 0.0231 ]
18:22:34 INFO : Flash Jetson Nano : [ 0.0231 ] Boot Rom communication
18:22:34 INFO : Flash Jetson Nano : [ 0.0246 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
18:22:34 INFO : Flash Jetson Nano : [ 0.0256 ] RCM version 0X210001
18:22:35 INFO : Flash Jetson Nano : [ 0.0676 ] Boot Rom communication completed
18:22:35 INFO : Flash Jetson Nano : [ 1.0761 ]
18:22:35 INFO : Flash Jetson Nano : [ 1.0764 ] dump EEPROM info
18:22:35 INFO : Flash Jetson Nano : [ 1.0826 ] tegrarcm --oem platformdetails eeprom /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
18:22:35 INFO : Flash Jetson Nano : [ 1.0878 ] Applet version 00.01.0000
18:22:35 INFO : Flash Jetson Nano : [ 1.0930 ] Saved platform info in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
18:22:35 INFO : Flash Jetson Nano : [ 1.1701 ]
18:22:35 ERROR : Flash Jetson Nano : Board ID(3448) version(200)
18:22:35 INFO : Flash Jetson Nano : creating dummy /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/badpage.bin
18:22:35 ERROR : Flash Jetson Nano : 1+0 records in
18:22:35 INFO : Flash Jetson Nano : 1+0 records out
18:22:35 INFO : Flash Jetson Nano : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000107149 s, 38.2 MB/s
18:22:35 INFO : Flash Jetson Nano : copying bctfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
18:22:35 INFO : Flash Jetson Nano : copying bootloader(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
18:22:35 INFO : Flash Jetson Nano : populating kernel to rootfs... done.
18:22:35 INFO : Flash Jetson Nano : populating initrd to rootfs... done.
18:22:35 INFO : Flash Jetson Nano : populating extlinux.conf.emmc to rootfs... done.
18:22:35 INFO : Flash Jetson Nano : populating /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
18:22:35 INFO : Flash Jetson Nano : done.
18:22:35 INFO : Flash Jetson Nano : Making Boot image... done.
18:22:35 INFO : Flash Jetson Nano : Existing sosfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
18:22:35 INFO : Flash Jetson Nano : copying tegraboot(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
18:22:35 INFO : Flash Jetson Nano : copying cpu_bootloader(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
18:22:35 INFO : Flash Jetson Nano : copying bpffile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
18:22:35 INFO : Flash Jetson Nano : Existing badpagefile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/badpage.bin) reused.
18:22:35 INFO : Flash Jetson Nano : copying wb0boot(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
18:22:35 INFO : Flash Jetson Nano : Existing tosfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
18:22:35 INFO : Flash Jetson Nano : Existing eksfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/eks.img) reused.
18:22:35 INFO : Flash Jetson Nano : copying dtbfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
18:22:35 INFO : Flash Jetson Nano : Making system.img...
18:23:23 INFO : Flash Jetson Nano : populating rootfs from /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/rootfs ... done.
18:23:29 INFO : Flash Jetson Nano : Sync'ing system.img ... done.
18:23:31 INFO : Flash Jetson Nano : Converting RAW image to Sparse image...
18:23:31 ERROR : Flash Jetson Nano :
18:23:31 INFO : Flash Jetson Nano : ---- Raw to Sparse Image Converter v1.0
18:23:31 ERROR : Flash Jetson Nano : ----------------------------
18:23:31 ERROR : Flash Jetson Nano : 0: RAW: 9437184( 9 blks) ==> 28:9437196
18:23:31 ERROR : Flash Jetson Nano : 1: SKP: 28311552( 27 blks) ==> 9437224:12
18:23:31 ERROR : Flash Jetson Nano : 2: RAW: 14680064( 14 blks) ==> 9437236:14680076
18:23:31 ERROR : Flash Jetson Nano : 3: SKP: 81788928( 78 blks) ==> 24117312:12
18:23:31 ERROR : Flash Jetson Nano : 4: RAW: 1048576( 1 blks) ==> 24117324:1048588
18:23:31 ERROR : Flash Jetson Nano : 5: SKP: 3145728( 3 blks) ==> 25165912:12
18:23:31 ERROR : Flash Jetson Nano : 6: RAW: 27262976( 26 blks) ==> 25165924:27262988
18:23:31 ERROR : Flash Jetson Nano : 7: SKP: 1048576( 1 blks) ==> 52428912:12
18:23:31 ERROR : Flash Jetson Nano : 8: RAW: 44040192( 42 blks) ==> 52428924:44040204
18:23:31 ERROR : Flash Jetson Nano : 9: SKP: 15728640( 15 blks) ==> 96469128:12
18:23:31 ERROR : Flash Jetson Nano : 10: RAW: 177209344( 169 blks) ==> 96469140:177209356
18:23:31 ERROR : Flash Jetson Nano : 11: SKP: 3145728( 3 blks) ==> 273678496:12
18:23:32 ERROR : Flash Jetson Nano : 12: RAW: 44040192( 42 blks) ==> 273678508:44040204
18:23:32 ERROR : Flash Jetson Nano : 13: SKP: 2097152( 2 blks) ==> 317718712:12
18:23:32 ERROR : Flash Jetson Nano : 14: RAW: 99614720( 95 blks) ==> 317718724:99614732
18:23:32 ERROR : Flash Jetson Nano : 15: SKP: 1048576( 1 blks) ==> 417333456:12
18:23:32 ERROR : Flash Jetson Nano : 16: RAW: 44040192( 42 blks) ==> 417333468:44040204
18:23:32 ERROR : Flash Jetson Nano : 17: SKP: 6291456( 6 blks) ==> 461373672:12
18:23:32 ERROR : Flash Jetson Nano : 18: RAW: 68157440( 65 blks) ==> 461373684:68157452
18:23:32 ERROR : Flash Jetson Nano : 19: SKP: 3145728( 3 blks) ==> 529531136:12
18:23:32 ERROR : Flash Jetson Nano : 20: RAW: 1048576( 1 blks) ==> 529531148:1048588
18:23:32 ERROR : Flash Jetson Nano : 21: SKP: 3145728( 3 blks) ==> 530579736:12
18:23:32 ERROR : Flash Jetson Nano : 22: RAW: 106954752( 102 blks) ==> 530579748:106954764
18:23:32 ERROR : Flash Jetson Nano : 23: SKP: 2097152( 2 blks) ==> 637534512:12
18:23:32 ERROR : Flash Jetson Nano : 24: RAW: 66060288( 63 blks) ==> 637534524:66060300
18:23:32 ERROR : Flash Jetson Nano : 25: SKP: 1048576( 1 blks) ==> 703594824:12
18:23:32 ERROR : Flash Jetson Nano : 26: RAW: 62914560( 60 blks) ==> 703594836:62914572
18:23:32 ERROR : Flash Jetson Nano : 27: SKP: 4194304( 4 blks) ==> 766509408:12
18:23:32 ERROR : Flash Jetson Nano : 28: RAW: 17825792( 17 blks) ==> 766509420:17825804
18:23:32 ERROR : Flash Jetson Nano : 29: SKP: 3145728( 3 blks) ==> 784335224:12
18:23:32 ERROR : Flash Jetson Nano : 30: RAW: 102760448( 98 blks) ==> 784335236:102760460
18:23:32 ERROR : Flash Jetson Nano : 31: SKP: 27262976( 26 blks) ==> 887095696:12
18:23:32 ERROR : Flash Jetson Nano : 32: RAW: 69206016( 66 blks) ==> 887095708:69206028
18:23:32 ERROR : Flash Jetson Nano : 33: SKP: 6291456( 6 blks) ==> 956301736:12
18:23:32 ERROR : Flash Jetson Nano : 34: RAW: 59768832( 57 blks) ==> 956301748:59768844
18:23:32 ERROR : Flash Jetson Nano : 35: SKP: 3145728( 3 blks) ==> 1016070592:12
18:23:32 ERROR : Flash Jetson Nano : 36: RAW: 19922944( 19 blks) ==> 1016070604:19922956
18:23:32 ERROR : Flash Jetson Nano : 37: SKP: 1048576( 1 blks) ==> 1035993560:12
18:23:32 ERROR : Flash Jetson Nano : 38: RAW: 39845888( 38 blks) ==> 1035993572:39845900
18:23:32 ERROR : Flash Jetson Nano : 39: SKP: 2097152( 2 blks) ==> 1075839472:12
18:23:32 ERROR : Flash Jetson Nano : 40: RAW: 49283072( 47 blks) ==> 1075839484:49283084
18:23:32 ERROR : Flash Jetson Nano : 41: SKP: 1048576( 1 blks) ==> 1125122568:12
18:23:32 ERROR : Flash Jetson Nano : 42: RAW: 20971520( 20 blks) ==> 1125122580:20971532
18:23:32 ERROR : Flash Jetson Nano : 43: SKP: 1048576( 1 blks) ==> 1146094112:12
18:23:32 ERROR : Flash Jetson Nano : 44: RAW: 2097152( 2 blks) ==> 1146094124:2097164
18:23:32 ERROR : Flash Jetson Nano : 45: SKP: 1048576( 1 blks) ==> 1148191288:12
18:23:33 ERROR : Flash Jetson Nano : 46: RAW: 79691776( 76 blks) ==> 1148191300:79691788
18:23:33 ERROR : Flash Jetson Nano : 47: SKP: 4194304( 4 blks) ==> 1227883088:12
18:23:33 ERROR : Flash Jetson Nano : 48: RAW: 63963136( 61 blks) ==> 1227883100:63963148
18:23:33 ERROR : Flash Jetson Nano : 49: SKP: 3145728( 3 blks) ==> 1291846248:12
18:23:33 ERROR : Flash Jetson Nano : 50: RAW: 66060288( 63 blks) ==> 1291846260:66060300
18:23:33 ERROR : Flash Jetson Nano : 51: SKP: 2097152( 2 blks) ==> 1357906560:12
18:23:33 ERROR : Flash Jetson Nano : 52: RAW: 71303168( 68 blks) ==> 1357906572:71303180
18:23:33 ERROR : Flash Jetson Nano : 53: SKP: 3145728( 3 blks) ==> 1429209752:12
18:23:33 ERROR : Flash Jetson Nano : 54: RAW: 12582912( 12 blks) ==> 1429209764:12582924
18:23:33 ERROR : Flash Jetson Nano : 55: SKP: 4194304( 4 blks) ==> 1441792688:12
18:23:33 ERROR : Flash Jetson Nano : 56: RAW: 13631488( 13 blks) ==> 1441792700:13631500
18:23:33 ERROR : Flash Jetson Nano : 57: SKP: 3145728( 3 blks) ==> 1455424200:12
18:23:33 ERROR : Flash Jetson Nano : 58: RAW: 15728640( 15 blks) ==> 1455424212:15728652
18:23:33 ERROR : Flash Jetson Nano : 59: SKP: 1048576( 1 blks) ==> 1471152864:12
18:23:33 ERROR : Flash Jetson Nano : 60: RAW: 15728640( 15 blks) ==> 1471152876:15728652
18:23:33 ERROR : Flash Jetson Nano : 61: SKP: 437256192( 417 blks) ==> 1486881528:12
18:23:34 ERROR : Flash Jetson Nano : 62: RAW: 4194304( 4 blks) ==> 1486881540:4194316
18:23:34 ERROR : Flash Jetson Nano : 63: SKP: 29360128( 28 blks) ==> 1491075856:12
18:23:34 ERROR : Flash Jetson Nano : 64: RAW: 14680064( 14 blks) ==> 1491075868:14680076
18:23:34 ERROR : Flash Jetson Nano : 65: SKP: 85983232( 82 blks) ==> 1505755944:12
18:23:34 ERROR : Flash Jetson Nano : 66: RAW: 131072000( 125 blks) ==> 1505755956:131072012
18:23:35 ERROR : Flash Jetson Nano : 67: SKP: 942669824( 899 blks) ==> 1636827968:12
18:23:35 ERROR : Flash Jetson Nano : 68: RAW: 1048576( 1 blks) ==> 1636827980:1048588
18:23:35 ERROR : Flash Jetson Nano : 69: SKP: 267386880( 255 blks) ==> 1637876568:12
18:23:35 ERROR : Flash Jetson Nano : 70: RAW: 1048576( 1 blks) ==> 1637876580:1048588
18:23:36 ERROR : Flash Jetson Nano : 71: SKP: 670040064( 639 blks) ==> 1638925168:12
18:23:36 ERROR : Flash Jetson Nano : 72: RAW: 5242880( 5 blks) ==> 1638925180:5242892
18:23:36 ERROR : Flash Jetson Nano : 73: SKP: 28311552( 27 blks) ==> 1644168072:12
18:23:36 ERROR : Flash Jetson Nano : 74: RAW: 12582912( 12 blks) ==> 1644168084:12582924
18:23:36 ERROR : Flash Jetson Nano : 75: SKP: 88080384( 84 blks) ==> 1656751008:12
18:23:37 ERROR : Flash Jetson Nano : 76: RAW: 176160768( 168 blks) ==> 1656751020:176160780
18:23:37 ERROR : Flash Jetson Nano : 77: SKP: 25165824( 24 blks) ==> 1832911800:12
18:23:37 ERROR : Flash Jetson Nano : 78: RAW: 33554432( 32 blks) ==> 1832911812:33554444
18:23:38 ERROR : Flash Jetson Nano : 79: SKP: 1778384896( 1696 blks) ==> 1866466256:12
18:23:38 ERROR : Flash Jetson Nano : 80: RAW: 5242880( 5 blks) ==> 1866466268:5242892
18:23:38 ERROR : Flash Jetson Nano : 81: SKP: 28311552( 27 blks) ==> 1871709160:12
18:23:41 ERROR : Flash Jetson Nano : 82: RAW: 13631488( 13 blks) ==> 1871709172:13631500
18:23:41 ERROR : Flash Jetson Nano : 83: SKP: 87031808( 83 blks) ==> 1885340672:12
18:23:41 ERROR : Flash Jetson Nano : 84: RAW: 1048576( 1 blks) ==> 1885340684:1048588
18:23:41 ERROR : Flash Jetson Nano : 85: SKP: 3145728( 3 blks) ==> 1886389272:12
18:23:42 ERROR : Flash Jetson Nano : 86: RAW: 163577856( 156 blks) ==> 1886389284:163577868
18:23:42 ERROR : Flash Jetson Nano : 87: SKP: 33554432( 32 blks) ==> 2049967152:12
18:23:42 ERROR : Flash Jetson Nano : 88: RAW: 18874368( 18 blks) ==> 2049967164:18874380
18:23:43 ERROR : Flash Jetson Nano : 89: SKP: 1793064960( 1710 blks) ==> 2068841544:12
18:23:43 ERROR : Flash Jetson Nano : 90: RAW: 10485760( 10 blks) ==> 2068841556:10485772
18:23:43 ERROR : Flash Jetson Nano : 91: SKP: 23068672( 22 blks) ==> 2079327328:12
18:23:43 ERROR : Flash Jetson Nano : 92: RAW: 13631488( 13 blks) ==> 2079327340:13631500
18:23:43 ERROR : Flash Jetson Nano : 93: SKP: 87031808( 83 blks) ==> 2092958840:12
18:23:45 ERROR : Flash Jetson Nano : 94: RAW: 800063488( 763 blks) ==> 2092958852:800063500
18:23:45 ERROR : Flash Jetson Nano : 95: SKP: 5242880( 5 blks) ==> 2893022352:12
18:23:45 ERROR : Flash Jetson Nano : 96: RAW: 5242880( 5 blks) ==> 2893022364:5242892
18:23:46 ERROR : Flash Jetson Nano : 97: SKP: 1202716672( 1147 blks) ==> 2898265256:12
18:23:46 ERROR : Flash Jetson Nano : 98: RAW: 8388608( 8 blks) ==> 2898265268:8388620
18:23:46 ERROR : Flash Jetson Nano : 99: SKP: 25165824( 24 blks) ==> 2906653888:12
18:23:46 ERROR : Flash Jetson Nano : 100: RAW: 12582912( 12 blks) ==> 2906653900:12582924
18:23:46 ERROR : Flash Jetson Nano : 101: SKP: 88080384( 84 blks) ==> 2919236824:12
18:23:46 ERROR : Flash Jetson Nano : 102: RAW: 1048576( 1 blks) ==> 2919236836:1048588
18:23:46 ERROR : Flash Jetson Nano : 103: SKP: 3145728( 3 blks) ==> 2920285424:12
18:23:46 ERROR : Flash Jetson Nano : 104: RAW: 47185920( 45 blks) ==> 2920285436:47185932
18:23:46 ERROR : Flash Jetson Nano : 105: SKP: 1048576( 1 blks) ==> 2967471368:12
18:23:46 ERROR : Flash Jetson Nano : 106: RAW: 1048576( 1 blks) ==> 2967471380:1048588
18:23:46 ERROR : Flash Jetson Nano : 107: SKP: 1048576( 1 blks) ==> 2968519968:12
18:23:46 ERROR : Flash Jetson Nano : 108: RAW: 3145728( 3 blks) ==> 2968519980:3145740
18:23:46 ERROR : Flash Jetson Nano : 109: SKP: 1048576( 1 blks) ==> 2971665720:12
18:23:47 ERROR : Flash Jetson Nano : 110: RAW: 49283072( 47 blks) ==> 2971665732:49283084
18:23:47 ERROR : Flash Jetson Nano : 111: SKP: 1048576( 1 blks) ==> 3020948816:12
18:23:50 ERROR : Flash Jetson Nano : 112: RAW: 619708416( 591 blks) ==> 3020948828:619708428
18:23:50 ERROR : Flash Jetson Nano : 113: SKP: 9437184( 9 blks) ==> 3640657256:12
18:23:50 ERROR : Flash Jetson Nano : 114: RAW: 33554432( 32 blks) ==> 3640657268:33554444
18:23:50 ERROR : Flash Jetson Nano : 115: SKP: 1241513984( 1184 blks) ==> 3674211712:12
18:23:50 ERROR : Flash Jetson Nano : 116: RAW: 5242880( 5 blks) ==> 3674211724:5242892
18:23:50 ERROR : Flash Jetson Nano : 117: SKP: 28311552( 27 blks) ==> 3679454616:12
18:23:50 ERROR : Flash Jetson Nano : 118: RAW: 12582912( 12 blks) ==> 3679454628:12582924
18:23:51 ERROR : Flash Jetson Nano : 119: SKP: 88080384( 84 blks) ==> 3692037552:12
18:23:52 ERROR : Flash Jetson Nano : 120: RAW: 235929600( 225 blks) ==> 3692037564:235929612
18:23:52 ERROR : Flash Jetson Nano : 121: SKP: 1048576( 1 blks) ==> 3927967176:12
18:23:54 ERROR : Flash Jetson Nano : 122: RAW: 319815680( 305 blks) ==> 3927967188:319815692
18:23:55 ERROR : Flash Jetson Nano : 123: SKP: 1456472064( 1389 blks) ==> 4247782880:12
18:23:55 ERROR : Flash Jetson Nano : -- Total: ---------------------------------------------------
18:23:55 INFO : Flash Jetson Nano : 124 CHUNK 15032385536( 14336 blks) ==> 4247782892(4051 blks)
18:23:55 INFO : Flash Jetson Nano : done.
18:23:55 INFO : Flash Jetson Nano : system.img built successfully.
18:23:55 INFO : Flash Jetson Nano : Existing tbcfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
18:23:55 INFO : Flash Jetson Nano : copying tbcdtbfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
18:23:55 INFO : Flash Jetson Nano : copying cfgfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
18:23:55 INFO : Flash Jetson Nano : copying flasher(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
18:23:55 INFO : Flash Jetson Nano : Existing flashapp(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/tegraflash.py) reused.
18:23:55 INFO : Flash Jetson Nano : ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21
18:23:55 INFO : Flash Jetson Nano : saving flash command in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flashcmd.txt
18:23:55 INFO : Flash Jetson Nano : copying boot image (boot.img.sb)... done.
18:23:55 INFO : Flash Jetson Nano : copying partition layout (flash.xml.sb)... done.
18:23:55 INFO : Flash Jetson Nano : copying kernel dtb (tegra210-p3448-0000-p3449-0000-a02.dtb.sb)... done.
18:23:55 INFO : Flash Jetson Nano : saving flash parameters in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flash_parameters.txt
18:23:55 INFO : Flash Jetson Nano : --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21
18:23:55 INFO : Flash Jetson Nano : saving Windows flash command to /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flash_win.bat
18:23:55 INFO : Flash Jetson Nano : *** Flashing target device started. ***
18:23:55 INFO : Flash Jetson Nano : Welcome to Tegra Flash
18:23:55 INFO : Flash Jetson Nano : version 1.0.0
18:23:55 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
18:23:55 INFO : Flash Jetson Nano : Use ! to execute system commands
18:23:55 INFO : Flash Jetson Nano : [ 0.0000 ] Generating RCM messages
18:23:55 INFO : Flash Jetson Nano : [ 0.0021 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
18:23:55 INFO : Flash Jetson Nano : [ 0.0031 ] RCM 0 is saved as rcm_0.rcm
18:23:55 INFO : Flash Jetson Nano : [ 0.0058 ] RCM 1 is saved as rcm_1.rcm
18:23:55 INFO : Flash Jetson Nano : [ 0.0058 ] List of rcm files are saved in rcm_list.xml
18:23:55 INFO : Flash Jetson Nano : [ 0.0058 ] Signing RCM messages
18:23:55 INFO : Flash Jetson Nano : [ 0.0079 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
18:23:55 INFO : Flash Jetson Nano : [ 0.0090 ] Assuming zero filled SBK key
18:23:55 INFO : Flash Jetson Nano : [ 0.0172 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.0172 ] Copying signature to RCM mesages
18:23:55 INFO : Flash Jetson Nano : [ 0.0182 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
18:23:55 INFO : Flash Jetson Nano : [ 0.0195 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.0195 ] Parsing partition layout
18:23:55 INFO : Flash Jetson Nano : [ 0.0213 ] tegraparser --pt flash.xml.tmp
18:23:55 INFO : Flash Jetson Nano : [ 0.0292 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.0292 ] Creating list of images to be signed
18:23:55 INFO : Flash Jetson Nano : [ 0.0311 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
18:23:55 INFO : Flash Jetson Nano : [ 0.0378 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.0379 ] Generating signatures
18:23:55 INFO : Flash Jetson Nano : [ 0.0391 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
18:23:55 INFO : Flash Jetson Nano : [ 0.0404 ] Assuming zero filled SBK key
18:23:55 INFO : Flash Jetson Nano : [ 0.0919 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.0919 ] Generating br-bct
18:23:55 INFO : Flash Jetson Nano : [ 0.0939 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
18:23:55 INFO : Flash Jetson Nano : [ 0.0948 ] Copying Sdram info from 0 to 1 set
18:23:55 INFO : Flash Jetson Nano : [ 0.0979 ] Copying Sdram info from 1 to 2 set
18:23:55 INFO : Flash Jetson Nano : [ 0.0979 ] Copying Sdram info from 2 to 3 set
18:23:55 INFO : Flash Jetson Nano : [ 0.0979 ] Updating boot device parameters
18:23:55 INFO : Flash Jetson Nano : [ 0.0991 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
18:23:55 INFO : Flash Jetson Nano : [ 0.1002 ] Warning: No sdram params
18:23:55 INFO : Flash Jetson Nano : [ 0.1004 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1004 ] Updating bl info
18:23:55 INFO : Flash Jetson Nano : [ 0.1015 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
18:23:55 INFO : Flash Jetson Nano : [ 0.1033 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1033 ] Updating secondary storage information into bct
18:23:55 INFO : Flash Jetson Nano : [ 0.1046 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
18:23:55 INFO : Flash Jetson Nano : [ 0.1090 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1090 ] Updating Odmdata
18:23:55 INFO : Flash Jetson Nano : [ 0.1101 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
18:23:55 INFO : Flash Jetson Nano : [ 0.1112 ] Warning: No sdram params
18:23:55 INFO : Flash Jetson Nano : [ 0.1114 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1114 ] Get Signed section of bct
18:23:55 INFO : Flash Jetson Nano : [ 0.1126 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
18:23:55 INFO : Flash Jetson Nano : [ 0.1140 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1140 ] Signing BCT
18:23:55 INFO : Flash Jetson Nano : [ 0.1157 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
18:23:55 INFO : Flash Jetson Nano : [ 0.1166 ] Assuming zero filled SBK key
18:23:55 INFO : Flash Jetson Nano : [ 0.1171 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1171 ] Updating BCT with signature
18:23:55 INFO : Flash Jetson Nano : [ 0.1181 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
18:23:55 INFO : Flash Jetson Nano : [ 0.1194 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1195 ] Copying signatures
18:23:55 INFO : Flash Jetson Nano : [ 0.1206 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
18:23:55 INFO : Flash Jetson Nano : [ 0.1246 ]
18:23:55 INFO : Flash Jetson Nano : [ 0.1246 ] Updating BFS information on BCT
18:23:55 INFO : Flash Jetson Nano : [ 0.1261 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
18:23:55 INFO : Flash Jetson Nano : [ 0.1269 ] BFS:
18:23:55 INFO : Flash Jetson Nano : [ 0.1286 ] 0: [PT ] flash.xml.bin (size=2138/65536)
18:23:55 INFO : Flash Jetson Nano : [ 0.1290 ] 2: [VER] qspi_bootblob_ver.txt (size=153/65536)
18:23:56 INFO : Flash Jetson Nano : [ 0.1295 ] BFS0: 65536 @ 224 SUM f2efddff over 3735552 bytes
18:23:56 INFO : Flash Jetson Nano : [ 0.1298 ]
18:23:56 INFO : Flash Jetson Nano : [ 0.1299 ] Boot Rom communication
18:23:56 INFO : Flash Jetson Nano : [ 0.1309 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
18:23:56 INFO : Flash Jetson Nano : [ 0.1320 ] BootRom is not running
18:23:56 INFO : Flash Jetson Nano : [ 0.2725 ]
18:23:56 INFO : Flash Jetson Nano : [ 0.2726 ] Sending BCTs
18:23:56 INFO : Flash Jetson Nano : [ 0.2754 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
18:23:56 INFO : Flash Jetson Nano : [ 0.2780 ] Applet version 00.01.0000
18:23:56 INFO : Flash Jetson Nano : [ 0.2814 ] Sending bct
18:23:56 INFO : Flash Jetson Nano : [ 0.2816 ] [...] 100%
18:23:56 INFO : Flash Jetson Nano : [ 0.3801 ]
18:23:56 INFO : Flash Jetson Nano : [ 0.3802 ] Sending bootloader and pre-requisite binaries
18:23:56 INFO : Flash Jetson Nano : [ 0.3840 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb 0
18:23:56 INFO : Flash Jetson Nano : [ 0.3858 ] Applet version 00.01.0000
18:23:56 INFO : Flash Jetson Nano : [ 0.3889 ] Sending ebt
18:23:56 INFO : Flash Jetson Nano : [ 0.4559 ]
18:23:56 INFO : Flash Jetson Nano : Error: Return value 1
18:23:56 INFO : Flash Jetson Nano : Command tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb 0
18:23:56 INFO : Flash Jetson Nano : Failed flashing t210ref.
18:23:56 INFO : Flash Jetson Nano : exit status 1
18:23:56 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
18:23:56 ERROR : Flash Jetson Nano : NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
18:23:56 INFO : Flash Jetson Nano : [ 7.90 GB used. Disk Avail: 43.43 GB ]
18:23:56 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 6m4s ]
18:23:56 INFO : Flash Jetson Nano : command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
18:23:56 ERROR : Flash Jetson Nano : command terminated with error
18:23:56 ERROR : Flash Jetson Nano : install 'Flash Jetson Nano' failure, command < cd '/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/prafsoni/.nvsdkm/logs/JetPack_4.2_Linux' -p='12876' -t='P3448-0000' -e='undefined' > terminated with error
18:32:49 INFO : Flash Jetson Nano : Start to install 'Flash Jetson Nano'
18:32:49 DEBUG : Flash Jetson Nano : running command < cd '/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/prafsoni/.nvsdkm/logs/JetPack_4.2_Linux' -p='12876' -t='P3448-0000' -e='undefined' >
18:32:49 INFO : Flash Jetson Nano : [ Disk Avail:51.33 GB ]
18:32:49 INFO : Flash Jetson Nano : Using GenericInstaller to Install NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP
18:32:49 INFO : Flash Jetson Nano : enter working directory: /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra
18:32:49 INFO : Flash Jetson Nano : [ Component Install Started ]
18:32:49 INFO : Flash Jetson Nano : current working directory is /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra
18:32:49 INFO : Flash Jetson Nano : exec_command [target]:
18:32:49 INFO : Flash Jetson Nano : **********************
18:32:49 INFO : Flash Jetson Nano : #!/bin/bash
18:32:49 INFO : Flash Jetson Nano : set -e
18:32:49 INFO : Flash Jetson Nano : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
18:32:49 INFO : Flash Jetson Nano : sudo reboot forced-recovery
18:32:49 INFO : Flash Jetson Nano : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh prafsoni@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no prafsoni@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh"
18:34:59 ERROR : Flash Jetson Nano : lost connection
18:37:10 INFO : Flash Jetson Nano : exit status 255
18:37:10 WARNING : Flash Jetson Nano : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh prafsoni@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no prafsoni@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh" finished with error, but ignored
18:37:10 INFO : Flash Jetson Nano : exec_command: sleep 20
18:37:30 INFO : Flash Jetson Nano : exec_command: sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
18:37:30 INFO : Flash Jetson Nano : ###############################################################################
18:37:30 INFO : Flash Jetson Nano : # L4T BSP Information:
18:37:30 INFO : Flash Jetson Nano : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
18:37:30 INFO : Flash Jetson Nano : # DATE: Wed Mar 13 07:46:13 UTC 2019
18:37:31 INFO : Flash Jetson Nano : # Target Board Information:
18:37:31 INFO : Flash Jetson Nano : # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Unknown,
18:37:31 INFO : Flash Jetson Nano : # OpMode: pre-production, Boot Authentication: ,
18:37:31 INFO : Flash Jetson Nano : ###############################################################################
18:37:31 INFO : Flash Jetson Nano : Error: The Actual SoC ID(0x00) mismatches intended jetson-nano-qspi-sd SoC ID(0x21).
18:37:31 INFO : Flash Jetson Nano : exit status 1
18:37:31 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
18:37:31 ERROR : Flash Jetson Nano : NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
18:37:31 INFO : Flash Jetson Nano : [ 48.00 KB used. Disk Avail: 51.33 GB ]
18:37:31 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 4m42s ]
18:37:31 INFO : Flash Jetson Nano : command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
18:37:31 ERROR : Flash Jetson Nano : command terminated with error
18:37:31 ERROR : Flash Jetson Nano : install 'Flash Jetson Nano' failure, command < cd '/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/prafsoni/.nvsdkm/logs/JetPack_4.2_Linux' -p='12876' -t='P3448-0000' -e='undefined' > terminated with error
FLASHING FAILED
Review terminal tab for details. Resolve and RETRY.
 Installation of target SDK components was skipped
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2019,
NVIDIA CORPORATION
All rights reserved.
NVIDIA Developer
I formatted the micro-SD card as ExFat and tried again to flash, it failed again but this time it’s not a Soc ID mismatch.
DETAILS TERMINAL
Component Name: All
Message Type: All
Filter text here...
07:46:26 INFO : null
07:46:33 INFO : Drivers for Jetson Nano : download 'Drivers for Jetson Nano' success
07:46:33 INFO : File System and OS : download 'File System and OS' success
07:46:33 INFO : Drivers for Jetson Nano : install 'Drivers for Jetson Nano' success
07:46:33 INFO : File System and OS : install 'File System and OS' success
07:46:33 INFO : OpenCV on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
07:46:33 INFO : OpenCV on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
07:46:33 INFO : OpenCV on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
07:46:33 INFO : OpenCV on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : cuDNN on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : cuDNN on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : cuDNN on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:34 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:35 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:35 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
07:46:35 INFO : VisionWorks on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
07:46:35 INFO : VisionWorks on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
07:46:35 INFO : VisionWorks on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
07:46:36 INFO : Multimedia API : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
07:46:37 INFO : TensorRT on Target : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
07:46:37 INFO : CUDA Toolkit for L4T : Found file /home/prafsoni/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
07:46:58 INFO : [host] [sudo] password for prafsoni:
07:46:58 INFO :
07:46:58 INFO :
07:46:58 DEBUG : running command < ip addr | grep 192.168.55.100/24 >
07:46:58 ERROR : command terminated with error
07:46:58 DEBUG : running command < lsusb | grep "NVidia Corp" >
07:46:58 INFO : Bus 001 Device 005: ID 0955:7f21 e[01;31me[KNVidia Corpe[me[K.
07:46:58 INFO : command finished successfully
07:46:58 INFO : Jetson device is in recovery mode.
07:46:58 INFO : Device Mode Host Setup in Flash : Start to install 'Device Mode Host Setup in Flash'
07:46:58 DEBUG : Device Mode Host Setup in Flash : running command < cd '/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH' -v='1.0' -l='/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/prafsoni/.nvsdkm/logs/JetPack_4.2_Linux' -p='2094' -t='P3448-0000' -e='undefined' >
07:46:58 INFO : Device Mode Host Setup in Flash : [ Disk Avail:51.30 GB ]
07:46:58 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH
07:46:58 INFO : Device Mode Host Setup in Flash : enter working directory: /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448
07:46:58 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
07:46:58 INFO : Device Mode Host Setup in Flash : current working directory is /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448
07:46:58 INFO : Device Mode Host Setup in Flash : exec_command [host]:
07:46:58 INFO : Device Mode Host Setup in Flash : **********************
07:46:58 INFO : Device Mode Host Setup in Flash : #!/bin/bash
07:46:58 INFO : Device Mode Host Setup in Flash : set -e
07:46:58 INFO : Device Mode Host Setup in Flash : set +e
07:46:58 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk '/default via/ {print $5; exit}')
07:46:58 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == '' ]]; then
07:46:58 INFO : Device Mode Host Setup in Flash : echo 'Can not found route default $eth_port_name, device mode setup failed!'
07:46:58 INFO : Device Mode Host Setup in Flash : exit 0
07:46:58 INFO : Device Mode Host Setup in Flash : fi
07:46:58 INFO : Device Mode Host Setup in Flash : echo 'Found route default' $eth_port_name', setting up device mode'
07:46:58 INFO : Device Mode Host Setup in Flash : setup_t='192.168.55.0/24'
07:46:58 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
07:46:58 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
07:46:58 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
07:46:58 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
07:46:58 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
07:46:58 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == *'Got answer'* ]]; then
07:46:58 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS 8.8.8.8!'
07:46:58 INFO : Device Mode Host Setup in Flash : else
07:46:58 INFO : Device Mode Host Setup in Flash : echo 'Default google DNS is not working, trying to find a valid server in local host settings!'
07:46:58 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep 'DNS' | grep -o '[^:]*$')
07:46:58 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
07:46:58 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
07:46:58 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == *'Got answer'* ]]; then
07:46:58 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
07:46:58 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
07:46:58 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS' $dns'!'
07:46:58 INFO : Device Mode Host Setup in Flash : done
07:46:58 INFO : Device Mode Host Setup in Flash : echo 'Can not found a valid DNS server, device mode setup failed!'
07:46:58 INFO : Device Mode Host Setup in Flash : echo 'If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.'
07:46:58 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH.sh
07:46:58 INFO : Device Mode Host Setup in Flash : Found route default wlp1s0, setting up device mode
07:46:58 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
07:46:58 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 8.8.8.8!
07:46:58 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
07:46:58 INFO : Device Mode Host Setup in Flash : [ 16.00 KB used. Disk Avail: 51.30 GB ]
07:46:58 INFO : Device Mode Host Setup in Flash : [ NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH Install took 0s ]
07:46:58 INFO : Device Mode Host Setup in Flash : command finished successfully
07:46:58 INFO : Device Mode Host Setup in Flash : install 'Device Mode Host Setup in Flash' success
07:46:58 INFO : Flash Jetson Nano : Start to install 'Flash Jetson Nano'
07:46:58 DEBUG : Flash Jetson Nano : running command < cd '/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/prafsoni/.nvsdkm/logs/JetPack_4.2_Linux' -p='2094' -t='P3448-0000' -e='undefined' >
07:46:58 INFO : Flash Jetson Nano : [ Disk Avail:51.30 GB ]
07:46:58 INFO : Flash Jetson Nano : Using GenericInstaller to Install NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP
07:46:58 INFO : Flash Jetson Nano : enter working directory: /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra
07:46:58 INFO : Flash Jetson Nano : [ Component Install Started ]
07:46:58 INFO : Flash Jetson Nano : current working directory is /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra
07:46:58 INFO : Flash Jetson Nano : exec_command [target]:
07:46:58 INFO : Flash Jetson Nano : **********************
07:46:58 INFO : Flash Jetson Nano : #!/bin/bash
07:46:58 INFO : Flash Jetson Nano : set -e
07:46:58 INFO : Flash Jetson Nano : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
07:46:58 INFO : Flash Jetson Nano : sudo reboot forced-recovery
07:46:58 INFO : Flash Jetson Nano : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh prafsoni@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no prafsoni@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh"
07:49:08 ERROR : Flash Jetson Nano : lost connection
07:51:19 INFO : Flash Jetson Nano : exit status 255
07:51:19 WARNING : Flash Jetson Nano : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh prafsoni@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no prafsoni@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh" finished with error, but ignored
07:51:19 INFO : Flash Jetson Nano : exec_command: sleep 20
07:51:39 INFO : Flash Jetson Nano : exec_command: sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
07:51:39 INFO : Flash Jetson Nano : ###############################################################################
07:51:39 INFO : Flash Jetson Nano : # L4T BSP Information:
07:51:39 INFO : Flash Jetson Nano : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
07:51:39 INFO : Flash Jetson Nano : # DATE: Wed Mar 13 07:46:13 UTC 2019
07:51:39 INFO : Flash Jetson Nano : # Target Board Information:
07:51:39 INFO : Flash Jetson Nano : # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
07:51:39 INFO : Flash Jetson Nano : # OpMode: production, Boot Authentication: ,
07:51:39 INFO : Flash Jetson Nano : ./tegraflash.py --chip 0x21 --applet "/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
07:51:39 INFO : Flash Jetson Nano : Welcome to Tegra Flash
07:51:39 INFO : Flash Jetson Nano : version 1.0.0
07:51:39 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
07:51:39 INFO : Flash Jetson Nano : Use ! to execute system commands
07:51:39 INFO : Flash Jetson Nano : [ 0.0036 ] Generating RCM messages
07:51:39 INFO : Flash Jetson Nano : [ 0.0059 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
07:51:39 INFO : Flash Jetson Nano : [ 0.0070 ] RCM 0 is saved as rcm_0.rcm
07:51:39 INFO : Flash Jetson Nano : [ 0.0086 ] RCM 1 is saved as rcm_1.rcm
07:51:39 INFO : Flash Jetson Nano : [ 0.0086 ] List of rcm files are saved in rcm_list.xml
07:51:39 INFO : Flash Jetson Nano : [ 0.0086 ] Signing RCM messages
07:51:39 INFO : Flash Jetson Nano : [ 0.0105 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
07:51:39 INFO : Flash Jetson Nano : [ 0.0114 ] Assuming zero filled SBK key
07:51:39 INFO : Flash Jetson Nano : [ 0.0214 ]
07:51:39 INFO : Flash Jetson Nano : [ 0.0214 ] Copying signature to RCM mesages
07:51:39 INFO : Flash Jetson Nano : [ 0.0226 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
07:51:39 INFO : Flash Jetson Nano : [ 0.0241 ]
07:51:39 INFO : Flash Jetson Nano : [ 0.0241 ] Boot Rom communication
07:51:39 INFO : Flash Jetson Nano : [ 0.0252 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
07:51:39 INFO : Flash Jetson Nano : [ 0.0262 ] RCM version 0X210001
07:51:40 INFO : Flash Jetson Nano : [ 0.0708 ] Boot Rom communication completed
07:51:40 INFO : Flash Jetson Nano : [ 1.0786 ]
07:51:40 INFO : Flash Jetson Nano : [ 1.0789 ] dump EEPROM info
07:51:40 INFO : Flash Jetson Nano : [ 1.0851 ] tegrarcm --oem platformdetails eeprom /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
07:51:40 INFO : Flash Jetson Nano : [ 1.0914 ] Applet version 00.01.0000
07:51:40 INFO : Flash Jetson Nano : [ 1.0949 ] Saved platform info in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
07:51:40 INFO : Flash Jetson Nano : [ 1.1781 ]
07:51:40 ERROR : Flash Jetson Nano : Board ID(3448) version(200)
07:51:41 INFO : Flash Jetson Nano : creating dummy /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/badpage.bin
07:51:41 ERROR : Flash Jetson Nano : 1+0 records in
07:51:41 INFO : Flash Jetson Nano : 1+0 records out
07:51:41 INFO : Flash Jetson Nano : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000105643 s, 38.8 MB/s
07:51:41 INFO : Flash Jetson Nano : copying bctfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
07:51:41 INFO : Flash Jetson Nano : copying bootloader(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
07:51:41 INFO : Flash Jetson Nano : populating kernel to rootfs... done.
07:51:41 INFO : Flash Jetson Nano : populating initrd to rootfs... done.
07:51:41 INFO : Flash Jetson Nano : populating extlinux.conf.emmc to rootfs... done.
07:51:41 INFO : Flash Jetson Nano : populating /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
07:51:41 INFO : Flash Jetson Nano : done.
07:51:41 INFO : Flash Jetson Nano : Making Boot image... done.
07:51:41 INFO : Flash Jetson Nano : Existing sosfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
07:51:41 INFO : Flash Jetson Nano : copying tegraboot(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
07:51:41 INFO : Flash Jetson Nano : copying cpu_bootloader(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
07:51:41 INFO : Flash Jetson Nano : copying bpffile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
07:51:41 INFO : Flash Jetson Nano : Existing badpagefile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/badpage.bin) reused.
07:51:41 INFO : Flash Jetson Nano : copying wb0boot(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
07:51:41 INFO : Flash Jetson Nano : Existing tosfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
07:51:41 INFO : Flash Jetson Nano : Existing eksfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/eks.img) reused.
07:51:41 INFO : Flash Jetson Nano : copying dtbfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
07:51:41 INFO : Flash Jetson Nano : Making system.img...
07:52:29 INFO : Flash Jetson Nano : populating rootfs from /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/rootfs ... done.
07:52:40 INFO : Flash Jetson Nano : Sync'ing system.img ... done.
07:52:41 INFO : Flash Jetson Nano : Converting RAW image to Sparse image...
07:52:41 ERROR : Flash Jetson Nano :
07:52:41 INFO : Flash Jetson Nano : ---- Raw to Sparse Image Converter v1.0 ----------------------------
07:52:41 ERROR : Flash Jetson Nano : 0: RAW: 9437184( 9 blks) ==> 28:9437196
07:52:41 ERROR : Flash Jetson Nano : 1: SKP: 28311552( 27 blks) ==> 9437224:12
07:52:41 ERROR : Flash Jetson Nano : 2: RAW: 15728640( 15 blks) ==> 9437236:15728652
07:52:41 ERROR : Flash Jetson Nano : 3: SKP: 80740352( 77 blks) ==> 25165888:12
07:52:41 ERROR : Flash Jetson Nano : 4: RAW: 1048576( 1 blks) ==> 25165900:1048588
07:52:41 ERROR : Flash Jetson Nano : 5: SKP: 3145728( 3 blks) ==> 26214488:12
07:52:41 ERROR : Flash Jetson Nano : 6: RAW: 27262976( 26 blks) ==> 26214500:27262988
07:52:41 ERROR : Flash Jetson Nano : 7: SKP: 1048576( 1 blks) ==> 53477488:12
07:52:41 ERROR : Flash Jetson Nano : 8: RAW: 44040192( 42 blks) ==> 53477500:44040204
07:52:41 ERROR : Flash Jetson Nano : 9: SKP: 15728640( 15 blks) ==> 97517704:12
07:52:42 ERROR : Flash Jetson Nano : 10: RAW: 66060288( 63 blks) ==> 97517716:66060300
07:52:42 ERROR : Flash Jetson Nano : 11: SKP: 1048576( 1 blks) ==> 163578016:12
07:52:42 ERROR : Flash Jetson Nano : 12: RAW: 102760448( 98 blks) ==> 163578028:102760460
07:52:42 ERROR : Flash Jetson Nano : 13: SKP: 6291456( 6 blks) ==> 266338488:12
07:52:42 ERROR : Flash Jetson Nano : 14: RAW: 1048576( 1 blks) ==> 266338500:1048588
07:52:42 ERROR : Flash Jetson Nano : 15: SKP: 3145728( 3 blks) ==> 267387088:12
07:52:42 ERROR : Flash Jetson Nano : 16: RAW: 115343360( 110 blks) ==> 267387100:115343372
07:52:42 ERROR : Flash Jetson Nano : 17: SKP: 6291456( 6 blks) ==> 382730472:12
07:52:42 ERROR : Flash Jetson Nano : 18: RAW: 143654912( 137 blks) ==> 382730484:143654924
07:52:42 ERROR : Flash Jetson Nano : 19: SKP: 3145728( 3 blks) ==> 526385408:12
07:52:42 ERROR : Flash Jetson Nano : 20: RAW: 60817408( 58 blks) ==> 526385420:60817420
07:52:42 ERROR : Flash Jetson Nano : 21: SKP: 2097152( 2 blks) ==> 587202840:12
07:52:42 ERROR : Flash Jetson Nano : 22: RAW: 131072000( 125 blks) ==> 587202852:131072012
07:52:42 ERROR : Flash Jetson Nano : 23: SKP: 3145728( 3 blks) ==> 718274864:12
07:52:42 ERROR : Flash Jetson Nano : 24: RAW: 38797312( 37 blks) ==> 718274876:38797324
07:52:42 ERROR : Flash Jetson Nano : 25: SKP: 3145728( 3 blks) ==> 757072200:12
07:52:42 ERROR : Flash Jetson Nano : 26: RAW: 13631488( 13 blks) ==> 757072212:13631500
07:52:42 ERROR : Flash Jetson Nano : 27: SKP: 3145728( 3 blks) ==> 770703712:12
07:52:42 ERROR : Flash Jetson Nano : 28: RAW: 9437184( 9 blks) ==> 770703724:9437196
07:52:43 ERROR : Flash Jetson Nano : 29: SKP: 4194304( 4 blks) ==> 780140920:12
07:52:43 ERROR : Flash Jetson Nano : 30: RAW: 2097152( 2 blks) ==> 780140932:2097164
07:52:43 ERROR : Flash Jetson Nano : 31: SKP: 1048576( 1 blks) ==> 782238096:12
07:52:43 ERROR : Flash Jetson Nano : 32: RAW: 13631488( 13 blks) ==> 782238108:13631500
07:52:43 ERROR : Flash Jetson Nano : 33: SKP: 1048576( 1 blks) ==> 795869608:12
07:52:43 ERROR : Flash Jetson Nano : 34: RAW: 26214400( 25 blks) ==> 795869620:26214412
07:52:43 ERROR : Flash Jetson Nano : 35: SKP: 1048576( 1 blks) ==> 822084032:12
07:52:43 ERROR : Flash Jetson Nano : 36: RAW: 63963136( 61 blks) ==> 822084044:63963148
07:52:43 ERROR : Flash Jetson Nano : 37: SKP: 3145728( 3 blks) ==> 886047192:12
07:52:43 ERROR : Flash Jetson Nano : 38: RAW: 12582912( 12 blks) ==> 886047204:12582924
07:52:43 ERROR : Flash Jetson Nano : 39: SKP: 4194304( 4 blks) ==> 898630128:12
07:52:43 ERROR : Flash Jetson Nano : 40: RAW: 112197632( 107 blks) ==> 898630140:112197644
07:52:43 ERROR : Flash Jetson Nano : 41: SKP: 5242880( 5 blks) ==> 1010827784:12
07:52:43 ERROR : Flash Jetson Nano : 42: RAW: 17825792( 17 blks) ==> 1010827796:17825804
07:52:43 ERROR : Flash Jetson Nano : 43: SKP: 3145728( 3 blks) ==> 1028653600:12
07:52:43 ERROR : Flash Jetson Nano : 44: RAW: 4194304( 4 blks) ==> 1028653612:4194316
07:52:43 ERROR : Flash Jetson Nano : 45: SKP: 1048576( 1 blks) ==> 1032847928:12
07:52:43 ERROR : Flash Jetson Nano : 46: RAW: 6291456( 6 blks) ==> 1032847940:6291468
07:52:43 ERROR : Flash Jetson Nano : 47: SKP: 1048576( 1 blks) ==> 1039139408:12
07:52:43 ERROR : Flash Jetson Nano : 48: RAW: 139460608( 133 blks) ==> 1039139420:139460620
07:52:43 ERROR : Flash Jetson Nano : 49: SKP: 3145728( 3 blks) ==> 1178600040:12
07:52:43 ERROR : Flash Jetson Nano : 50: RAW: 66060288( 63 blks) ==> 1178600052:66060300
07:52:43 ERROR : Flash Jetson Nano : 51: SKP: 2097152( 2 blks) ==> 1244660352:12
07:52:43 ERROR : Flash Jetson Nano : 52: RAW: 71303168( 68 blks) ==> 1244660364:71303180
07:52:43 ERROR : Flash Jetson Nano : 53: SKP: 3145728( 3 blks) ==> 1315963544:12
07:52:43 ERROR : Flash Jetson Nano : 54: RAW: 12582912( 12 blks) ==> 1315963556:12582924
07:52:43 ERROR : Flash Jetson Nano : 55: SKP: 4194304( 4 blks) ==> 1328546480:12
07:52:43 ERROR : Flash Jetson Nano : 56: RAW: 13631488( 13 blks) ==> 1328546492:13631500
07:52:43 ERROR : Flash Jetson Nano : 57: SKP: 3145728( 3 blks) ==> 1342177992:12
07:52:43 ERROR : Flash Jetson Nano : 58: RAW: 15728640( 15 blks) ==> 1342178004:15728652
07:52:43 ERROR : Flash Jetson Nano : 59: SKP: 1048576( 1 blks) ==> 1357906656:12
07:52:43 ERROR : Flash Jetson Nano : 60: RAW: 15728640( 15 blks) ==> 1357906668:15728652
07:52:44 ERROR : Flash Jetson Nano : 61: SKP: 571473920( 545 blks) ==> 1373635320:12
07:52:44 ERROR : Flash Jetson Nano : 62: RAW: 3145728( 3 blks) ==> 1373635332:3145740
07:52:44 ERROR : Flash Jetson Nano : 63: SKP: 30408704( 29 blks) ==> 1376781072:12
07:52:44 ERROR : Flash Jetson Nano : 64: RAW: 12582912( 12 blks) ==> 1376781084:12582924
07:52:44 ERROR : Flash Jetson Nano : 65: SKP: 88080384( 84 blks) ==> 1389364008:12
07:52:45 ERROR : Flash Jetson Nano : 66: RAW: 53477376( 51 blks) ==> 1389364020:53477388
07:52:45 ERROR : Flash Jetson Nano : 67: SKP: 13631488( 13 blks) ==> 1442841408:12
07:52:45 ERROR : Flash Jetson Nano : 68: RAW: 33554432( 32 blks) ==> 1442841420:33554444
07:52:45 ERROR : Flash Jetson Nano : 69: SKP: 973078528( 928 blks) ==> 1476395864:12
07:52:45 ERROR : Flash Jetson Nano : 70: RAW: 1048576( 1 blks) ==> 1476395876:1048588
07:52:46 ERROR : Flash Jetson Nano : 71: SKP: 267386880( 255 blks) ==> 1477444464:12
07:52:46 ERROR : Flash Jetson Nano : 72: RAW: 1048576( 1 blks) ==> 1477444476:1048588
07:52:46 ERROR : Flash Jetson Nano : 73: SKP: 670040064( 639 blks) ==> 1478493064:12
07:52:46 ERROR : Flash Jetson Nano : 74: RAW: 6291456( 6 blks) ==> 1478493076:6291468
07:52:47 ERROR : Flash Jetson Nano : 75: SKP: 27262976( 26 blks) ==> 1484784544:12
07:52:47 ERROR : Flash Jetson Nano : 76: RAW: 13631488( 13 blks) ==> 1484784556:13631500
07:52:47 ERROR : Flash Jetson Nano : 77: SKP: 87031808( 83 blks) ==> 1498416056:12
07:52:49 ERROR : Flash Jetson Nano : 78: RAW: 217055232( 207 blks) ==> 1498416068:217055244
07:52:50 ERROR : Flash Jetson Nano : 79: SKP: 1796210688( 1713 blks) ==> 1715471312:12
07:52:50 ERROR : Flash Jetson Nano : 80: RAW: 5242880( 5 blks) ==> 1715471324:5242892
07:52:50 ERROR : Flash Jetson Nano : 81: SKP: 28311552( 27 blks) ==> 1720714216:12
07:52:50 ERROR : Flash Jetson Nano : 82: RAW: 13631488( 13 blks) ==> 1720714228:13631500
07:52:50 ERROR : Flash Jetson Nano : 83: SKP: 87031808( 83 blks) ==> 1734345728:12
07:52:50 ERROR : Flash Jetson Nano : 84: RAW: 1048576( 1 blks) ==> 1734345740:1048588
07:52:50 ERROR : Flash Jetson Nano : 85: SKP: 3145728( 3 blks) ==> 1735394328:12
07:52:50 ERROR : Flash Jetson Nano : 86: RAW: 163577856( 156 blks) ==> 1735394340:163577868
07:52:50 ERROR : Flash Jetson Nano : 87: SKP: 33554432( 32 blks) ==> 1898972208:12
07:52:50 ERROR : Flash Jetson Nano : 88: RAW: 19922944( 19 blks) ==> 1898972220:19922956
07:52:51 ERROR : Flash Jetson Nano : 89: SKP: 1792016384( 1709 blks) ==> 1918895176:12
07:52:52 ERROR : Flash Jetson Nano : 90: RAW: 11534336( 11 blks) ==> 1918895188:11534348
07:52:52 ERROR : Flash Jetson Nano : 91: SKP: 22020096( 21 blks) ==> 1930429536:12
07:52:52 ERROR : Flash Jetson Nano : 92: RAW: 13631488( 13 blks) ==> 1930429548:13631500
07:52:52 ERROR : Flash Jetson Nano : 93: SKP: 87031808( 83 blks) ==> 1944061048:12
07:52:53 ERROR : Flash Jetson Nano : 94: RAW: 445644800( 425 blks) ==> 1944061060:445644812
07:52:53 ERROR : Flash Jetson Nano : 95: SKP: 1048576( 1 blks) ==> 2389705872:12
07:52:55 ERROR : Flash Jetson Nano : 96: RAW: 679477248( 648 blks) ==> 2389705884:679477260
07:52:56 ERROR : Flash Jetson Nano : 97: SKP: 887095296( 846 blks) ==> 3069183144:12
07:52:56 ERROR : Flash Jetson Nano : 98: RAW: 7340032( 7 blks) ==> 3069183156:7340044
07:52:56 ERROR : Flash Jetson Nano : 99: SKP: 26214400( 25 blks) ==> 3076523200:12
07:52:56 ERROR : Flash Jetson Nano : 100: RAW: 12582912( 12 blks) ==> 3076523212:12582924
07:52:56 ERROR : Flash Jetson Nano : 101: SKP: 88080384( 84 blks) ==> 3089106136:12
07:52:56 ERROR : Flash Jetson Nano : 102: RAW: 1048576( 1 blks) ==> 3089106148:1048588
07:52:56 ERROR : Flash Jetson Nano : 103: SKP: 3145728( 3 blks) ==> 3090154736:12
07:52:57 ERROR : Flash Jetson Nano : 104: RAW: 231735296( 221 blks) ==> 3090154748:231735308
07:52:57 ERROR : Flash Jetson Nano : 105: SKP: 1048576( 1 blks) ==> 3321890056:12
07:52:57 ERROR : Flash Jetson Nano : 106: RAW: 5242880( 5 blks) ==> 3321890068:5242892
07:52:57 ERROR : Flash Jetson Nano : 107: SKP: 1048576( 1 blks) ==> 3327132960:12
07:52:57 ERROR : Flash Jetson Nano : 108: RAW: 9437184( 9 blks) ==> 3327132972:9437196
07:52:57 ERROR : Flash Jetson Nano : 109: SKP: 1048576( 1 blks) ==> 3336570168:12
07:52:58 ERROR : Flash Jetson Nano : 110: RAW: 327155712( 312 blks) ==> 3336570180:327155724
07:52:58 ERROR : Flash Jetson Nano : 111: SKP: 23068672( 22 blks) ==> 3663725904:12
07:52:59 ERROR : Flash Jetson Nano : 112: RAW: 29360128( 28 blks) ==> 3663725916:29360140
07:52:59 ERROR : Flash Jetson Nano : 113: SKP: 1379926016( 1316 blks) ==> 3693086056:12
07:52:59 ERROR : Flash Jetson Nano : 114: RAW: 6291456( 6 blks) ==> 3693086068:6291468
07:52:59 ERROR : Flash Jetson Nano : 115: SKP: 27262976( 26 blks) ==> 3699377536:12
07:52:59 ERROR : Flash Jetson Nano : 116: RAW: 13631488( 13 blks) ==> 3699377548:13631500
07:53:00 ERROR : Flash Jetson Nano : 117: SKP: 87031808( 83 blks) ==> 3713009048:12
07:53:02 ERROR : Flash Jetson Nano : 118: RAW: 235929600( 225 blks) ==> 3713009060:235929612
07:53:02 ERROR : Flash Jetson Nano : 119: SKP: 1048576( 1 blks) ==> 3948938672:12
07:53:03 ERROR : Flash Jetson Nano : 120: RAW: 295698432( 282 blks) ==> 3948938684:295698444
07:53:03 ERROR : Flash Jetson Nano : 121: SKP: 4194304( 4 blks) ==> 4244637128:12
07:53:03 ERROR : Flash Jetson Nano : 122: RAW: 5242880( 5 blks) ==> 4244637140:5242892
07:53:04 ERROR : Flash Jetson Nano : 123: SKP: 1471152128( 1403 blks) ==> 4249880032:12
07:53:04 ERROR : Flash Jetson Nano : -- Total: ---------------------------------------------------
07:53:04 INFO : Flash Jetson Nano : 124 CHUNK 15032385536( 14336 blks) ==> 4249880044(4053 blks)
07:53:04 INFO : Flash Jetson Nano : done.
07:53:04 INFO : Flash Jetson Nano : system.img built successfully.
07:53:04 INFO : Flash Jetson Nano : Existing tbcfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
07:53:04 INFO : Flash Jetson Nano : copying tbcdtbfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
07:53:05 INFO : Flash Jetson Nano : copying cfgfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
07:53:05 INFO : Flash Jetson Nano : copying flasher(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
07:53:05 INFO : Flash Jetson Nano : Existing flashapp(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/tegraflash.py) reused.
07:53:05 INFO : Flash Jetson Nano : ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21
07:53:05 INFO : Flash Jetson Nano : saving flash command in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flashcmd.txt
07:53:05 INFO : Flash Jetson Nano : copying boot image (boot.img.sb)... done.
07:53:05 INFO : Flash Jetson Nano : copying partition layout (flash.xml.sb)... done.
07:53:05 INFO : Flash Jetson Nano : copying kernel dtb (tegra210-p3448-0000-p3449-0000-a02.dtb.sb)... done.
07:53:05 INFO : Flash Jetson Nano : saving flash parameters in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flash_parameters.txt
07:53:05 INFO : Flash Jetson Nano : --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21
07:53:05 INFO : Flash Jetson Nano : saving Windows flash command to /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flash_win.bat
07:53:05 INFO : Flash Jetson Nano : *** Flashing target device started. ***
07:53:05 INFO : Flash Jetson Nano : Welcome to Tegra Flash
07:53:05 INFO : Flash Jetson Nano : version 1.0.0
FLASHING FAILED
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2019,
NVIDIA CORPORATION
NVIDIA Developer
This one is really weird. We could focus on the socid error first.
Could you check if the chip id is really fused? I think you could dump the value “hwchipid” right after get_fuse_level.
# get the fuse level and update the data accordingly
1021 fuselevel="${FUSELEVEL}";
1022 hwchipid="";
1023 hwchiprev="${CHIPREV}";
1024 if [ "${hwchiprev}" = "" ]; then
1025 	hwchiprev="0";
1026 fi;
1027 bootauth="";
1028 if [ "${fuselevel}" = "" ]; then
1029 	<b>get_fuse_level</b> fuselevel hwchipid bootauth;
1030 	# fuselevel_unknown or empty will be handled as fuselevel_production
1031 	if [ "${fuselevel}" = "fuselevel_unknown" ] || [ "${fuselevel}" = "" ]; then
1032 		fuselevel="fuselevel_production";
1033 	fi;
1034 else
1035 	# can not "--skipuid" when function get_fuse_level is skipped.
1036 	SKIPUID="";
1037 fi;
1038
I added a bunch of echo in the section to log all the variables which looks like as follows.
echo "####################### HWCHIPID ##################################"
hwchipid="";
echo "fuselevel: "  $fuselevel
echo "hwchipid: "  $hwchipid
echo "hwchiprev: "  $hwchiprev
	hwchiprev="0";
fi;
bootauth="";
echo "bootauth: " $bootauth
	get_fuse_level fuselevel hwchipid bootauth;
	fi;
else
	SKIPUID="";
	echo "get_fuse_level skipped"
fi;
here is are the logs
09:15:39 INFO : Flash Jetson Nano : exec_command: sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
09:15:39 INFO : Flash Jetson Nano : ###############################################################################
09:15:39 INFO : Flash Jetson Nano : # L4T BSP Information:
09:15:39 INFO : Flash Jetson Nano : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
09:15:39 INFO : Flash Jetson Nano : # DATE: Wed Mar 13 07:46:13 UTC 2019
09:15:39 INFO : Flash Jetson Nano : ####################### HWCHIPID ##################################
09:15:39 INFO : Flash Jetson Nano : fuselevel:
09:15:39 INFO : Flash Jetson Nano : hwchipid:
09:15:39 INFO : Flash Jetson Nano : hwchiprev:
09:15:39 INFO : Flash Jetson Nano : hwchiprev: 0
09:15:39 INFO : Flash Jetson Nano : bootauth:
09:15:39 INFO : Flash Jetson Nano : fuselevel: fuselevel_nofuse
09:15:39 INFO : Flash Jetson Nano : hwchipid: 0x00
09:15:39 INFO : Flash Jetson Nano : # Target Board Information:
09:15:39 INFO : Flash Jetson Nano : # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Unknown,
09:15:39 INFO : Flash Jetson Nano : # OpMode: pre-production, Boot Authentication: ,
09:15:39 INFO : Flash Jetson Nano : Error: The Actual SoC ID(0x00) mismatches intended jetson-nano-qspi-sd SoC ID(0x21).
09:15:39 INFO : Flash Jetson Nano : exit status 1
09:15:39 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
09:15:39 ERROR : Flash Jetson Nano : NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
09:15:39 INFO : Flash Jetson Nano : [ 12.00 KB used. Disk Avail: 24.31 GB ]
09:15:39 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 4m42s ]
09:15:39 INFO : Flash Jetson Nano : command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
09:15:39 ERROR : Flash Jetson Nano : command terminated with error
Because of the inconsistency in the soc id error, I see the hwchipid is not consistent in all the across the executions. The last run echo hwchipid: 0x00 for next run 0x42.
Also, the fuselevel value is also inconsistent changed from fuselevel_nofuse to fuselevel_unknown
2nd run logs
09:41:11 INFO : Flash Jetson Nano : exec_command: sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
09:41:11 INFO : Flash Jetson Nano : ###############################################################################
09:41:11 INFO : Flash Jetson Nano : # L4T BSP Information:
09:41:11 INFO : Flash Jetson Nano : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
09:41:11 INFO : Flash Jetson Nano : # DATE: Wed Mar 13 07:46:13 UTC 2019
09:41:11 INFO : Flash Jetson Nano : ####################### HWCHIPID ##################################
09:41:11 INFO : Flash Jetson Nano : fuselevel:
09:41:11 INFO : Flash Jetson Nano : hwchipid:
09:41:11 INFO : Flash Jetson Nano : hwchiprev:
09:41:11 INFO : Flash Jetson Nano : hwchiprev: 0
09:41:11 INFO : Flash Jetson Nano : bootauth:
09:41:11 INFO : Flash Jetson Nano : fuselevel: fuselevel_unknown
09:41:11 INFO : Flash Jetson Nano : hwchipid: 0x42
09:41:11 INFO : Flash Jetson Nano : fuselevel: fuselevel_production
09:41:11 INFO : Flash Jetson Nano : # Target Board Information:
09:41:11 INFO : Flash Jetson Nano : # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Unknown,
09:41:11 INFO : Flash Jetson Nano : # OpMode: production, Boot Authentication: ,
09:41:11 INFO : Flash Jetson Nano : Error: The Actual SoC ID(0x42) mismatches intended jetson-nano-qspi-sd SoC ID(0x21).
09:41:11 INFO : Flash Jetson Nano : exit status 1
09:41:11 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
09:41:11 ERROR : Flash Jetson Nano : NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
09:41:11 INFO : Flash Jetson Nano : [ 12.00 KB used. Disk Avail: 24.32 GB ]
09:41:11 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 4m42s ]
09:41:11 INFO : Flash Jetson Nano : command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
09:41:11 ERROR : Flash Jetson Nano : command terminated with error
Interestingly on the 3rd run, SocID is 0x21 expected value and fails at a later stage
3rd run logs
09:49:50 INFO : Flash Jetson Nano : **********************
09:49:50 INFO : Flash Jetson Nano : #!/bin/bash
09:49:50 INFO : Flash Jetson Nano : set -e
09:49:50 INFO : Flash Jetson Nano : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
09:49:50 INFO : Flash Jetson Nano : sudo reboot forced-recovery
09:49:50 INFO : Flash Jetson Nano : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh prafsoni@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no prafsoni@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh"
09:52:01 ERROR : Flash Jetson Nano : lost connection
09:54:12 INFO : Flash Jetson Nano : exit status 255
09:54:12 WARNING : Flash Jetson Nano : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh prafsoni@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no prafsoni@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh" finished with error, but ignored
09:54:12 INFO : Flash Jetson Nano : exec_command: sleep 20
09:54:32 INFO : Flash Jetson Nano : exec_command: sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
09:54:32 INFO : Flash Jetson Nano : ###############################################################################
09:54:32 INFO : Flash Jetson Nano : # L4T BSP Information:
09:54:32 INFO : Flash Jetson Nano : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
09:54:32 INFO : Flash Jetson Nano : # DATE: Wed Mar 13 07:46:13 UTC 2019
09:54:32 INFO : Flash Jetson Nano : ####################### HWCHIPID ##################################
09:54:32 INFO : Flash Jetson Nano : fuselevel:
09:54:32 INFO : Flash Jetson Nano : hwchipid:
09:54:32 INFO : Flash Jetson Nano : hwchiprev:
09:54:32 INFO : Flash Jetson Nano : hwchiprev: 0
09:54:32 INFO : Flash Jetson Nano : bootauth:
09:54:32 INFO : Flash Jetson Nano : fuselevel: fuselevel_production
09:54:32 INFO : Flash Jetson Nano : hwchipid: 0x21
09:54:32 INFO : Flash Jetson Nano : # Target Board Information:
09:54:32 INFO : Flash Jetson Nano : # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
09:54:32 INFO : Flash Jetson Nano : # OpMode: production, Boot Authentication: ,
09:54:32 INFO : Flash Jetson Nano : ./tegraflash.py --chip 0x21 --applet "/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
09:54:32 INFO : Flash Jetson Nano : Welcome to Tegra Flash
09:54:32 INFO : Flash Jetson Nano : version 1.0.0
09:54:32 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
09:54:32 INFO : Flash Jetson Nano : Use ! to execute system commands
09:54:32 INFO : Flash Jetson Nano : [ 0.0018 ] Generating RCM messages
09:54:32 INFO : Flash Jetson Nano : [ 0.0041 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
09:54:32 INFO : Flash Jetson Nano : [ 0.0053 ] RCM 0 is saved as rcm_0.rcm
09:54:32 INFO : Flash Jetson Nano : [ 0.0071 ] RCM 1 is saved as rcm_1.rcm
09:54:32 INFO : Flash Jetson Nano : [ 0.0071 ] List of rcm files are saved in rcm_list.xml
09:54:32 INFO : Flash Jetson Nano : [ 0.0071 ] Signing RCM messages
09:54:32 INFO : Flash Jetson Nano : [ 0.0092 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
09:54:32 INFO : Flash Jetson Nano : [ 0.0102 ] Assuming zero filled SBK key
09:54:32 INFO : Flash Jetson Nano : [ 0.0348 ]
09:54:32 INFO : Flash Jetson Nano : [ 0.0348 ] Copying signature to RCM mesages
09:54:32 INFO : Flash Jetson Nano : [ 0.0362 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
09:54:32 INFO : Flash Jetson Nano : [ 0.0377 ]
09:54:32 INFO : Flash Jetson Nano : [ 0.0378 ] Boot Rom communication
09:54:32 INFO : Flash Jetson Nano : [ 0.0389 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
09:54:32 INFO : Flash Jetson Nano : [ 0.0399 ] RCM version 0X210001
09:54:33 INFO : Flash Jetson Nano : [ 0.0810 ] Boot Rom communication completed
09:54:33 INFO : Flash Jetson Nano : [ 1.0886 ]
09:54:33 INFO : Flash Jetson Nano : [ 1.0889 ] dump EEPROM info
09:54:33 INFO : Flash Jetson Nano : [ 1.0956 ] tegrarcm --oem platformdetails eeprom /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
09:54:33 INFO : Flash Jetson Nano : [ 1.1031 ] Applet version 00.01.0000
09:54:33 INFO : Flash Jetson Nano : [ 1.1066 ] Saved platform info in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
09:54:33 INFO : Flash Jetson Nano : [ 1.1827 ]
09:54:33 ERROR : Flash Jetson Nano : Board ID(3448) version(200)
09:54:33 INFO : Flash Jetson Nano : creating dummy /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/badpage.bin
09:54:33 ERROR : Flash Jetson Nano : 1+0 records in
09:54:33 INFO : Flash Jetson Nano : 1+0 records out
09:54:33 INFO : Flash Jetson Nano : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000109274 s, 37.5 MB/s
09:54:33 INFO : Flash Jetson Nano : copying bctfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
09:54:33 INFO : Flash Jetson Nano : copying bootloader(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
09:54:34 INFO : Flash Jetson Nano : populating kernel to rootfs... done.
09:54:34 INFO : Flash Jetson Nano : populating initrd to rootfs... done.
09:54:34 INFO : Flash Jetson Nano : populating extlinux.conf.emmc to rootfs... done.
09:54:34 INFO : Flash Jetson Nano : populating /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
09:54:34 INFO : Flash Jetson Nano : done.
09:54:34 INFO : Flash Jetson Nano : Making Boot image... done.
09:54:34 INFO : Flash Jetson Nano : Existing sosfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
09:54:34 INFO : Flash Jetson Nano : copying tegraboot(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
09:54:34 INFO : Flash Jetson Nano : copying cpu_bootloader(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
09:54:34 INFO : Flash Jetson Nano : copying bpffile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
09:54:34 INFO : Flash Jetson Nano : Existing badpagefile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/badpage.bin) reused.
09:54:34 INFO : Flash Jetson Nano : copying wb0boot(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
09:54:34 INFO : Flash Jetson Nano : Existing tosfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
09:54:34 INFO : Flash Jetson Nano : Existing eksfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/eks.img) reused.
09:54:34 INFO : Flash Jetson Nano : copying dtbfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
09:54:34 INFO : Flash Jetson Nano : Making system.img...
09:55:19 INFO : Flash Jetson Nano : populating rootfs from /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/rootfs ... done.
09:55:25 INFO : Flash Jetson Nano : Sync'ing system.img ... done.
09:55:27 INFO : Flash Jetson Nano : Converting RAW image to Sparse image...
09:55:27 ERROR : Flash Jetson Nano :
09:55:27 INFO : Flash Jetson Nano : ---- Raw to Sparse Image Converter v1.0 ----------------------------
09:55:27 ERROR : Flash Jetson Nano : 0: RAW: 5242880( 5 blks) ==> 28:5242892
09:55:27 ERROR : Flash Jetson Nano : 1: SKP: 32505856( 31 blks) ==> 5242920:12
09:55:27 ERROR : Flash Jetson Nano : 2: RAW: 1048576( 1 blks) ==> 5242932:1048588
09:55:27 ERROR : Flash Jetson Nano : 3: SKP: 95420416( 91 blks) ==> 6291520:12
09:55:27 ERROR : Flash Jetson Nano : 4: RAW: 1048576( 1 blks) ==> 6291532:1048588
09:55:27 ERROR : Flash Jetson Nano : 5: SKP: 3145728( 3 blks) ==> 7340120:12
09:55:27 ERROR : Flash Jetson Nano : 6: RAW: 27262976( 26 blks) ==> 7340132:27262988
09:55:27 ERROR : Flash Jetson Nano : 7: SKP: 1048576( 1 blks) ==> 34603120:12
09:55:28 ERROR : Flash Jetson Nano : 8: RAW: 44040192( 42 blks) ==> 34603132:44040204
09:55:28 ERROR : Flash Jetson Nano : 9: SKP: 15728640( 15 blks) ==> 78643336:12
09:55:28 ERROR : Flash Jetson Nano : 10: RAW: 177209344( 169 blks) ==> 78643348:177209356
09:55:28 ERROR : Flash Jetson Nano : 11: SKP: 3145728( 3 blks) ==> 255852704:12
09:55:28 ERROR : Flash Jetson Nano : 12: RAW: 228589568( 218 blks) ==> 255852716:228589580
09:55:28 ERROR : Flash Jetson Nano : 13: SKP: 2097152( 2 blks) ==> 484442296:12
09:55:29 ERROR : Flash Jetson Nano : 14: RAW: 34603008( 33 blks) ==> 484442308:34603020
09:55:29 ERROR : Flash Jetson Nano : 15: SKP: 3145728( 3 blks) ==> 519045328:12
09:55:29 ERROR : Flash Jetson Nano : 16: RAW: 3145728( 3 blks) ==> 519045340:3145740
09:55:29 ERROR : Flash Jetson Nano : 17: SKP: 1048576( 1 blks) ==> 522191080:12
09:55:29 ERROR : Flash Jetson Nano : 18: RAW: 15728640( 15 blks) ==> 522191092:15728652
09:55:29 ERROR : Flash Jetson Nano : 19: SKP: 1048576( 1 blks) ==> 537919744:12
09:55:29 ERROR : Flash Jetson Nano : 20: RAW: 55574528( 53 blks) ==> 537919756:55574540
09:55:29 ERROR : Flash Jetson Nano : 21: SKP: 3145728( 3 blks) ==> 593494296:12
09:55:29 ERROR : Flash Jetson Nano : 22: RAW: 88080384( 84 blks) ==> 593494308:88080396
09:55:29 ERROR : Flash Jetson Nano : 23: SKP: 4194304( 4 blks) ==> 681574704:12
09:55:29 ERROR : Flash Jetson Nano : 24: RAW: 93323264( 89 blks) ==> 681574716:93323276
09:55:29 ERROR : Flash Jetson Nano : 25: SKP: 3145728( 3 blks) ==> 774897992:12
09:55:29 ERROR : Flash Jetson Nano : 26: RAW: 51380224( 49 blks) ==> 774898004:51380236
09:55:29 ERROR : Flash Jetson Nano : 27: SKP: 3145728( 3 blks) ==> 826278240:12
09:55:29 ERROR : Flash Jetson Nano : 28: RAW: 63963136( 61 blks) ==> 826278252:63963148
09:55:29 ERROR : Flash Jetson Nano : 29: SKP: 3145728( 3 blks) ==> 890241400:12
09:55:29 ERROR : Flash Jetson Nano : 30: RAW: 103809024( 99 blks) ==> 890241412:103809036
09:55:29 ERROR : Flash Jetson Nano : 31: SKP: 1048576( 1 blks) ==> 994050448:12
09:55:30 ERROR : Flash Jetson Nano : 32: RAW: 38797312( 37 blks) ==> 994050460:38797324
09:55:30 ERROR : Flash Jetson Nano : 33: SKP: 3145728( 3 blks) ==> 1032847784:12
09:55:30 ERROR : Flash Jetson Nano : 34: RAW: 142606336( 136 blks) ==> 1032847796:142606348
09:55:30 ERROR : Flash Jetson Nano : 35: SKP: 4194304( 4 blks) ==> 1175454144:12
09:55:30 ERROR : Flash Jetson Nano : 36: RAW: 66060288( 63 blks) ==> 1175454156:66060300
09:55:30 ERROR : Flash Jetson Nano : 37: SKP: 2097152( 2 blks) ==> 1241514456:12
09:55:30 ERROR : Flash Jetson Nano : 38: RAW: 71303168( 68 blks) ==> 1241514468:71303180
09:55:30 ERROR : Flash Jetson Nano : 39: SKP: 3145728( 3 blks) ==> 1312817648:12
09:55:30 ERROR : Flash Jetson Nano : 40: RAW: 12582912( 12 blks) ==> 1312817660:12582924
09:55:30 ERROR : Flash Jetson Nano : 41: SKP: 4194304( 4 blks) ==> 1325400584:12
09:55:30 ERROR : Flash Jetson Nano : 42: RAW: 13631488( 13 blks) ==> 1325400596:13631500
09:55:30 ERROR : Flash Jetson Nano : 43: SKP: 3145728( 3 blks) ==> 1339032096:12
09:55:30 ERROR : Flash Jetson Nano : 44: RAW: 15728640( 15 blks) ==> 1339032108:15728652
09:55:30 ERROR : Flash Jetson Nano : 45: SKP: 1048576( 1 blks) ==> 1354760760:12
09:55:30 ERROR : Flash Jetson Nano : 46: RAW: 15728640( 15 blks) ==> 1354760772:15728652
09:55:31 ERROR : Flash Jetson Nano : 47: SKP: 579862528( 553 blks) ==> 1370489424:12
09:55:31 ERROR : Flash Jetson Nano : 48: RAW: 10485760( 10 blks) ==> 1370489436:10485772
09:55:31 ERROR : Flash Jetson Nano : 49: SKP: 23068672( 22 blks) ==> 1380975208:12
09:55:31 ERROR : Flash Jetson Nano : 50: RAW: 14680064( 14 blks) ==> 1380975220:14680076
09:55:31 ERROR : Flash Jetson Nano : 51: SKP: 85983232( 82 blks) ==> 1395655296:12
09:55:35 ERROR : Flash Jetson Nano : 52: RAW: 344981504( 329 blks) ==> 1395655308:344981516
09:55:35 ERROR : Flash Jetson Nano : 53: SKP: 1048576( 1 blks) ==> 1740636824:12
09:55:35 ERROR : Flash Jetson Nano : 54: RAW: 3145728( 3 blks) ==> 1740636836:3145740
09:55:35 ERROR : Flash Jetson Nano : 55: SKP: 1048576( 1 blks) ==> 1743782576:12
09:55:35 ERROR : Flash Jetson Nano : 56: RAW: 3145728( 3 blks) ==> 1743782588:3145740
09:55:35 ERROR : Flash Jetson Nano : 57: SKP: 1048576( 1 blks) ==> 1746928328:12
09:55:35 ERROR : Flash Jetson Nano : 58: RAW: 145752064( 139 blks) ==> 1746928340:145752076
09:55:35 ERROR : Flash Jetson Nano : 59: SKP: 1048576( 1 blks) ==> 1892680416:12
09:55:35 ERROR : Flash Jetson Nano : 60: RAW: 179306496( 171 blks) ==> 1892680428:179306508
09:55:35 ERROR : Flash Jetson Nano : 61: SKP: 393216000( 375 blks) ==> 2071986936:12
09:55:35 ERROR : Flash Jetson Nano : 62: RAW: 1048576( 1 blks) ==> 2071986948:1048588
09:55:35 ERROR : Flash Jetson Nano : 63: SKP: 267386880( 255 blks) ==> 2073035536:12
09:55:35 ERROR : Flash Jetson Nano : 64: RAW: 1048576( 1 blks) ==> 2073035548:1048588
09:55:36 ERROR : Flash Jetson Nano : 65: SKP: 670040064( 639 blks) ==> 2074084136:12
09:55:36 ERROR : Flash Jetson Nano : 66: RAW: 8388608( 8 blks) ==> 2074084148:8388620
09:55:36 ERROR : Flash Jetson Nano : 67: SKP: 25165824( 24 blks) ==> 2082472768:12
09:55:37 ERROR : Flash Jetson Nano : 68: RAW: 13631488( 13 blks) ==> 2082472780:13631500
09:55:37 ERROR : Flash Jetson Nano : 69: SKP: 87031808( 83 blks) ==> 2096104280:12
09:55:44 ERROR : Flash Jetson Nano : 70: RAW: 923795456( 881 blks) ==> 2096104292:923795468
09:55:44 ERROR : Flash Jetson Nano : 71: SKP: 1089470464( 1039 blks) ==> 3019899760:12
09:55:45 ERROR : Flash Jetson Nano : 72: RAW: 7340032( 7 blks) ==> 3019899772:7340044
09:55:45 ERROR : Flash Jetson Nano : 73: SKP: 26214400( 25 blks) ==> 3027239816:12
09:55:45 ERROR : Flash Jetson Nano : 74: RAW: 20971520( 20 blks) ==> 3027239828:20971532
09:55:45 ERROR : Flash Jetson Nano : 75: SKP: 79691776( 76 blks) ==> 3048211360:12
09:55:45 ERROR : Flash Jetson Nano : 76: RAW: 1048576( 1 blks) ==> 3048211372:1048588
09:55:45 ERROR : Flash Jetson Nano : 77: SKP: 3145728( 3 blks) ==> 3049259960:12
09:55:47 ERROR : Flash Jetson Nano : 78: RAW: 297795584( 284 blks) ==> 3049259972:297795596
09:55:47 ERROR : Flash Jetson Nano : 79: SKP: 33554432( 32 blks) ==> 3347055568:12
09:55:47 ERROR : Flash Jetson Nano : 80: RAW: 7340032( 7 blks) ==> 3347055580:7340044
09:55:48 ERROR : Flash Jetson Nano : 81: SKP: 1670381568( 1593 blks) ==> 3354395624:12
09:55:48 ERROR : Flash Jetson Nano : 82: RAW: 5242880( 5 blks) ==> 3354395636:5242892
09:55:48 ERROR : Flash Jetson Nano : 83: SKP: 28311552( 27 blks) ==> 3359638528:12
09:55:48 ERROR : Flash Jetson Nano : 84: RAW: 15728640( 15 blks) ==> 3359638540:15728652
09:55:48 ERROR : Flash Jetson Nano : 85: SKP: 84934656( 81 blks) ==> 3375367192:12
09:55:48 ERROR : Flash Jetson Nano : 86: RAW: 66060288( 63 blks) ==> 3375367204:66060300
09:55:48 ERROR : Flash Jetson Nano : 87: SKP: 1048576( 1 blks) ==> 3441427504:12
09:55:48 ERROR : Flash Jetson Nano : 88: RAW: 59768832( 57 blks) ==> 3441427516:59768844
09:55:49 ERROR : Flash Jetson Nano : 89: SKP: 1886388224( 1799 blks) ==> 3501196360:12
09:55:50 ERROR : Flash Jetson Nano : 90: RAW: 7340032( 7 blks) ==> 3501196372:7340044
09:55:50 ERROR : Flash Jetson Nano : 91: SKP: 26214400( 25 blks) ==> 3508536416:12
09:55:50 ERROR : Flash Jetson Nano : 92: RAW: 14680064( 14 blks) ==> 3508536428:14680076
09:55:50 ERROR : Flash Jetson Nano : 93: SKP: 85983232( 82 blks) ==> 3523216504:12
09:55:50 ERROR : Flash Jetson Nano : 94: RAW: 1048576( 1 blks) ==> 3523216516:1048588
09:55:50 ERROR : Flash Jetson Nano : 95: SKP: 3145728( 3 blks) ==> 3524265104:12
09:55:50 ERROR : Flash Jetson Nano : 96: RAW: 163577856( 156 blks) ==> 3524265116:163577868
09:55:50 ERROR : Flash Jetson Nano : 97: SKP: 33554432( 32 blks) ==> 3687842984:12
09:55:50 ERROR : Flash Jetson Nano : 98: RAW: 12582912( 12 blks) ==> 3687842996:12582924
09:55:51 ERROR : Flash Jetson Nano : 99: SKP: 1799356416( 1716 blks) ==> 3700425920:12
09:55:51 ERROR : Flash Jetson Nano : 100: RAW: 5242880( 5 blks) ==> 3700425932:5242892
09:55:51 ERROR : Flash Jetson Nano : 101: SKP: 28311552( 27 blks) ==> 3705668824:12
09:55:51 ERROR : Flash Jetson Nano : 102: RAW: 12582912( 12 blks) ==> 3705668836:12582924
09:55:51 ERROR : Flash Jetson Nano : 103: SKP: 88080384( 84 blks) ==> 3718251760:12
09:55:52 ERROR : Flash Jetson Nano : 104: RAW: 235929600( 225 blks) ==> 3718251772:235929612
09:55:52 ERROR : Flash Jetson Nano : 105: SKP: 1048576( 1 blks) ==> 3954181384:12
09:55:54 ERROR : Flash Jetson Nano : 106: RAW: 293601280( 280 blks) ==> 3954181396:293601292
09:55:55 ERROR : Flash Jetson Nano : 107: SKP: 1482686464( 1414 blks) ==> 4247782688:12
09:55:56 ERROR : Flash Jetson Nano : -- Total: ---------------------------------------------------
09:55:56 INFO : Flash Jetson Nano : 108 CHUNK 15032385536( 14336 blks) ==> 4247782700(4051 blks)
09:55:57 INFO : Flash Jetson Nano : done.
09:55:57 INFO : Flash Jetson Nano : system.img built successfully.
09:55:57 INFO : Flash Jetson Nano : Existing tbcfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
09:55:57 INFO : Flash Jetson Nano : copying tbcdtbfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
09:55:57 INFO : Flash Jetson Nano : copying cfgfile(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
09:55:57 INFO : Flash Jetson Nano : copying flasher(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
09:55:57 INFO : Flash Jetson Nano : Existing flashapp(/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/tegraflash.py) reused.
09:55:57 INFO : Flash Jetson Nano : ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21
09:55:57 INFO : Flash Jetson Nano : saving flash command in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flashcmd.txt
09:55:57 INFO : Flash Jetson Nano : copying boot image (boot.img.sb)... done.
09:55:57 INFO : Flash Jetson Nano : copying partition layout (flash.xml.sb)... done.
09:55:57 INFO : Flash Jetson Nano : copying kernel dtb (tegra210-p3448-0000-p3449-0000-a02.dtb.sb)... done.
09:55:57 INFO : Flash Jetson Nano : saving flash parameters in /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flash_parameters.txt
09:55:57 INFO : Flash Jetson Nano : --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21
09:55:57 INFO : Flash Jetson Nano : saving Windows flash command to /home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/flash_win.bat
09:55:57 INFO : Flash Jetson Nano : *** Flashing target device started. ***
09:55:57 INFO : Flash Jetson Nano : Welcome to Tegra Flash
09:55:57 INFO : Flash Jetson Nano : version 1.0.0
09:55:57 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
09:55:57 INFO : Flash Jetson Nano : Use ! to execute system commands
09:55:57 INFO : Flash Jetson Nano : [ 0.0000 ] Generating RCM messages
09:55:57 INFO : Flash Jetson Nano : [ 0.0032 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
09:55:57 INFO : Flash Jetson Nano : [ 0.0042 ] RCM 0 is saved as rcm_0.rcm
09:55:57 INFO : Flash Jetson Nano : [ 0.0070 ] RCM 1 is saved as rcm_1.rcm
09:55:57 INFO : Flash Jetson Nano : [ 0.0070 ] List of rcm files are saved in rcm_list.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.0070 ] Signing RCM messages
09:55:57 INFO : Flash Jetson Nano : [ 0.0087 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
09:55:57 INFO : Flash Jetson Nano : [ 0.0095 ] Assuming zero filled SBK key
09:55:57 INFO : Flash Jetson Nano : [ 0.0264 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.0265 ] Copying signature to RCM mesages
09:55:57 INFO : Flash Jetson Nano : [ 0.0277 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.0292 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.0293 ] Parsing partition layout
09:55:57 INFO : Flash Jetson Nano : [ 0.0320 ] tegraparser --pt flash.xml.tmp
09:55:57 INFO : Flash Jetson Nano : [ 0.0348 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.0348 ] Creating list of images to be signed
09:55:57 INFO : Flash Jetson Nano : [ 0.0369 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.0444 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.0444 ] Generating signatures
09:55:57 INFO : Flash Jetson Nano : [ 0.0455 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
09:55:57 INFO : Flash Jetson Nano : [ 0.0466 ] Assuming zero filled SBK key
09:55:57 INFO : Flash Jetson Nano : [ 0.1001 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1001 ] Generating br-bct
09:55:57 INFO : Flash Jetson Nano : [ 0.1021 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
09:55:57 INFO : Flash Jetson Nano : [ 0.1030 ] Copying Sdram info from 0 to 1 set
09:55:57 INFO : Flash Jetson Nano : [ 0.1059 ] Copying Sdram info from 1 to 2 set
09:55:57 INFO : Flash Jetson Nano : [ 0.1060 ] Copying Sdram info from 2 to 3 set
09:55:57 INFO : Flash Jetson Nano : [ 0.1060 ] Updating boot device parameters
09:55:57 INFO : Flash Jetson Nano : [ 0.1072 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
09:55:57 INFO : Flash Jetson Nano : [ 0.1080 ] Warning: No sdram params
09:55:57 INFO : Flash Jetson Nano : [ 0.1082 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1082 ] Updating bl info
09:55:57 INFO : Flash Jetson Nano : [ 0.1091 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.1103 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1104 ] Updating secondary storage information into bct
09:55:57 INFO : Flash Jetson Nano : [ 0.1114 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
09:55:57 INFO : Flash Jetson Nano : [ 0.1127 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1127 ] Updating Odmdata
09:55:57 INFO : Flash Jetson Nano : [ 0.1140 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
09:55:57 INFO : Flash Jetson Nano : [ 0.1149 ] Warning: No sdram params
09:55:57 INFO : Flash Jetson Nano : [ 0.1151 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1151 ] Get Signed section of bct
09:55:57 INFO : Flash Jetson Nano : [ 0.1160 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.1170 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1170 ] Signing BCT
09:55:57 INFO : Flash Jetson Nano : [ 0.1188 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
09:55:57 INFO : Flash Jetson Nano : [ 0.1198 ] Assuming zero filled SBK key
09:55:57 INFO : Flash Jetson Nano : [ 0.1204 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1204 ] Updating BCT with signature
09:55:57 INFO : Flash Jetson Nano : [ 0.1215 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.1226 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1226 ] Copying signatures
09:55:57 INFO : Flash Jetson Nano : [ 0.1235 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.1275 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1276 ] Updating BFS information on BCT
09:55:57 INFO : Flash Jetson Nano : [ 0.1287 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
09:55:57 INFO : Flash Jetson Nano : [ 0.1297 ] BFS:
09:55:57 INFO : Flash Jetson Nano : [ 0.1314 ] 0: [PT ] flash.xml.bin (size=2138/65536)
09:55:57 INFO : Flash Jetson Nano : [ 0.1317 ] 2: [VER] qspi_bootblob_ver.txt (size=153/65536)
09:55:57 INFO : Flash Jetson Nano : [ 0.1321 ] BFS0: 65536 @ 224 SUM c9ec51e4 over 3735552 bytes
09:55:57 INFO : Flash Jetson Nano : [ 0.1325 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.1326 ] Boot Rom communication
09:55:57 INFO : Flash Jetson Nano : [ 0.1337 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
09:55:57 INFO : Flash Jetson Nano : [ 0.1347 ] BootRom is not running
09:55:57 INFO : Flash Jetson Nano : [ 0.2795 ]
09:55:57 INFO : Flash Jetson Nano : [ 0.2796 ] Sending BCTs
09:55:57 INFO : Flash Jetson Nano : [ 0.2808 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
09:55:57 INFO : Flash Jetson Nano : [ 0.2821 ] Applet version 00.01.0000
09:55:57 INFO : Flash Jetson Nano : [ 0.2839 ] Sending bct
09:55:57 INFO : Flash Jetson Nano : [ 0.2839 ] [...] 100%
09:55:58 INFO : Flash Jetson Nano : [ 0.3793 ]
09:55:58 INFO : Flash Jetson Nano : [ 0.3794 ] Sending bootloader and pre-requisite binaries
09:55:58 INFO : Flash Jetson Nano : [ 0.3806 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb 0
09:55:58 INFO : Flash Jetson Nano : [ 0.3815 ] Applet version 00.01.0000
09:55:58 INFO : Flash Jetson Nano : [ 0.3836 ] Sending ebt
09:55:58 INFO : Flash Jetson Nano : [ 0.4483 ]
09:55:58 INFO : Flash Jetson Nano : Error: Return value 1
09:55:58 INFO : Flash Jetson Nano : Command tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb 0
09:55:58 INFO : Flash Jetson Nano : Failed flashing t210ref.
09:55:58 INFO : Flash Jetson Nano : exit status 1
09:55:58 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
09:55:58 ERROR : Flash Jetson Nano : NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
09:55:58 INFO : Flash Jetson Nano : [ 7.90 GB used. Disk Avail: 16.42 GB ]
09:55:58 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 6m7s ]
09:55:58 INFO : Flash Jetson Nano : command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
09:55:58 ERROR : Flash Jetson Nano : command terminated with error
09:55:58 ERROR : Flash Jetson Nano : install 'Flash Jetson Nano' failure, command < cd '/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/prafsoni/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/prafsoni/.nvsdkm/logs/JetPack_4.2_Linux' -p='9082' -t='P3448-0000' -e='undefined' > terminated with error
09:55:59 INFO : Device Mode Host Setup in Target SDK : install 'Device Mode Host Setup in Target SDK' Skipped
09:55:59 INFO : DateTime Target Setup : install 'DateTime Target Setup' Skipped
09:55:59 INFO : CUDA Toolkit for L4T : install 'CUDA Toolkit for L4T' Skipped
09:55:59 INFO : cuDNN on Target : install 'cuDNN on Target' Skipped
09:56:00 INFO : TensorRT on Target : install 'TensorRT on Target' Skipped
09:56:00 INFO : OpenCV on Target : install 'OpenCV on Target' Skipped
09:56:00 INFO : VisionWorks on Target : install 'VisionWorks on Target' Skipped
09:56:00 INFO : Multimedia API : install 'Multimedia API' Skipped
09:56:01 INFO : All done!
FLASHING FAILED
Review terminal tab for details. Resolve and RETRY.
 Installation of target SDK components was skipped
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2019,
NVIDIA CORPORATION
All rights reserved.
NVIDIA Developer
Is there any power adapter issue? Maybe you could try to change usb cable.
If that still cannot help, maybe it is time for RMA.
Tried different power supplies and usb cable no difference. What’s the process for RMA?
Please check this page.
Could you also share the serial number on your nano?
Could you share your RMA number?
Hi, here’s the RMA #65055679101
