Jetson Nano: jetson_util camera capture failed when flipMethod = rotate-180
I am trying my Jetson Nano by following this link to capture video from camera and displaying it on the screen and ran into issue when setting the flipMethod to rotate-180.
jetson-inference/docs/aux-streaming.md at master · dusty-nv/jetson-inference · GitHub
Setup:
Jetpack 4.6.4
Raspberry Pi Camera Module V2
i built the project from Source per this instruction:
(jetson-inference/docs/building-repo-2.md at master · dusty-nv/jetson-inference · GitHub)
and ran this python script that comes with it:
works fine when flip method set to “none” and I can see the captured video on my screen.
but when set to rotate-180, the screen freezes and only shows the first frame.
on the failed case, the log shows:
nvbuf_utils: dmabuf_fd 1053 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD… Exiting…
NvBufferGetParams failed for dst_dmabuf_fd
nvbuffer_transform Failed
Attached are 2 logs. Any help would be appreciated. Thanks
flip180.log (6.7 KB)
noflip.log (6.6 KB)
found solution in here:
CSI Camera Freeze on --input-flip=rotate-180 · Issue #1673 · dusty-nv/jetson-inference · GitHub
cd jetson-inference/build
cmake -DENABLE_NVMM=off …/
make
sudo make install
