Before adding FDT to extlinux.conf, everything is normal APPEND can work normally, but when I add FDT to extlinux.conf, APPEND does not work, even if I use the default dtb in the /boot directory, it does not work.
Added note: There are errors in your “added FDT” case:
DT property /chosen/nvidia,bluetooth-mac missing in source; can't copy
DT property /chosen/nvidia,wifi-mac missing in source; can't copy
DT property /psci/nvidia,system-lp0-disable missing in source; can't copy
This error does not exist in the case of “without” FDT. I am guessing the suggestion to upgrade would include a fix to device tree if an earlier release had a device tree issue. On the other hand, if you created the device tree, then perhaps there is an error somewhere in the edits to the default tree.
Thank you for your reply,
The system cannot be upgraded due to some reasons, can you tell me what caused this? Is there a solution?
By the way, I found that some Nanos can still work (same settings) even after modifying the FDT, and some can’t
Even if I use the default dtb in the /boot directory (in the SD image), it is the same problem.
Using the source code provided by Nvidia to compile, there is a problem even if it is not modified.
What did you add to your “APPEND” and get missed here?
Also, need to confirm that what is your method to install jetpack (l4t 32.5.2) to all these boards? I don’t think it would be “working for some and not work for the rest” would happen if they are same SKU of jetson nano.
As you can see from my previous post, once I added the FDT, all the parameters from the start of quiet to the end were not added to the cmdline correctly.
We use the SD Card Image installation system, all modules are official Jetson Nano development boards,
The ones that don’t work are brand new, and the working Nano is used for development. They have been flashed many times (using flash.sh or SDKManger). From the log, it seems that their bootloader versions are different. I’m not sure if this has any effect.
Yes, this is exactly the point I want to express. The brand new nano is installed using pure SD Card Image, and the Nano used for development has been re-flashed, causing their versions to be different.
I will try to install them using SDKManger.
