Jetson Nano 2GB developer kit - tested a suspected firmware flash issue. Created new build image on re-formated SDcard. Image booted and configured as new system.
Ran the standard “apt update -y && apt upgrade -y”. Noticed the kerbnel update. A reboot bricks the board and never boots past the nvidia logo. Only way to recover is to use the Forced Recovery Mode.
Setting up nvidia-l4t-kernel (4.9.201-tegra-32.5.1-20210505093645) ...
Using the existing boot entry 'primary'
3448-300-0003--1--jetson-nano-2gb-devkit-mmcblk0p1
Out from install setup…
Setting up python-apt-common (1.6.5ubuntu0.6) …
Setting up libgs9-common (9.26~dfsg+0-0ubuntu0.18.04.14) …
Setting up imagemagick-6-common (8:6.9.7.4+dfsg-16ubuntu6.11) …
Setting up libapt-inst2.0:arm64 (1.6.13) …
Setting up libnss-systemd:arm64 (237-3ubuntu10.48) …
Setting up aptdaemon-data (1.1.1+bzr982-0ubuntu19.5) …
Setting up git-man (1:2.17.1-1ubuntu0.8) …
Setting up libwbclient0:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.23) …
Setting up libexiv2-14:arm64 (0.25-3.1ubuntu0.18.04.9) …
Setting up xserver-common (2:1.19.6-1ubuntu4.9) …
Setting up libc6-dbg:arm64 (2.27-3ubuntu1.4) …
Setting up python3-apt (1.6.5ubuntu0.6) …
Setting up libssl1.0.0:arm64 (1.0.2n-1ubuntu5.6) …
Setting up runc (1.0.0~rc95-0ubuntu1~18.04.1) …
Setting up update-notifier-common (3.192.1.11) …
Setting up libevdev2:arm64 (1.5.8+dfsg-1ubuntu0.1) …
Setting up libnss-myhostname:arm64 (237-3ubuntu10.48) …
Setting up libwavpack1:arm64 (5.1.0-2ubuntu1.5) …
Setting up isc-dhcp-common (4.3.5-3ubuntu7.3) …
Setting up libldap-common (2.4.45+dfsg-1ubuntu1.10) …
Setting up libdjvulibre-text (3.5.27.1-8ubuntu0.3) …
Setting up multiarch-support (2.27-3ubuntu1.4) …
Setting up tzdata (2021a-0ubuntu0.18.04) …
Current default time zone: ‘America/Edmonton’
Local time is now: Mon Jun 28 07:43:06 MDT 2021.
Universal Time is now: Mon Jun 28 13:43:06 UTC 2021.
Run ‘dpkg-reconfigure tzdata’ if you wish to change it.
Setting up systemd-sysv (237-3ubuntu10.48) …
Setting up mutter-common (3.28.4+git20200505-0ubuntu18.04.2) …
Setting up gpgconf (2.2.4-1ubuntu1.4) …
Setting up libglib2.0-0:arm64 (2.56.4-0ubuntu0.18.04.8) …
Setting up python3-xdg (0.25-4ubuntu1.1) …
Setting up libsasl2-modules-db:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.3) …
Setting up libbluetooth3:arm64 (5.48-0ubuntu3.5) …
Setting up unzip (6.0-21ubuntu1.1) …
Setting up libproxy1v5:arm64 (0.4.15-1ubuntu0.2) …
Setting up linux-libc-dev:arm64 (4.15.0-147.151) …
Setting up python3-colorama (0.3.7-1) …
Setting up libsasl2-2:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.3) …
Setting up gpg-agent (2.2.4-1ubuntu1.4) …
Setting up distro-info-data (0.37ubuntu0.10) …
Setting up libtiff5:arm64 (4.0.9-5ubuntu0.4) …
Setting up wireless-regdb (2020.11.20-0ubuntu1~18.04.1) …
Setting up lshw (02.18-0.1ubuntu6.18.04.2) …
Setting up libopenexr22:arm64 (2.2.0-11.1ubuntu1.7) …
Setting up containerd (1.4.4-0ubuntu1~18.04.2) …
Setting up iproute2 (4.15.0-2ubuntu1.3) …
Setting up libinput-bin (1.10.4-1ubuntu0.18.04.2) …
Setting up libxml2:arm64 (2.9.4+dfsg1-6.1ubuntu1.4) …
Setting up gnupg-l10n (2.2.4-1ubuntu1.4) …
Setting up libxml2-dev:arm64 (2.9.4+dfsg1-6.1ubuntu1.4) …
Setting up librados2 (12.2.13-0ubuntu0.18.04.8) …
Setting up gnome-shell-common (3.28.4-0ubuntu18.04.7) …
Setting up python3-problem-report (2.20.9-0ubuntu7.24) …
Setting up binutils-common:arm64 (2.30-21ubuntu1~18.04.5) …
Setting up squashfs-tools (1:4.3-6ubuntu0.18.04.2) …
Setting up libappindicator1 (12.10.1+18.04.20200408.1-0ubuntu1) …
Setting up libx11-xcb1:arm64 (2:1.6.4-3ubuntu0.4) …
Setting up libglib2.0-data (2.56.4-0ubuntu0.18.04.8) …
Setting up p11-kit-modules:arm64 (0.23.9-2ubuntu0.1) …
Setting up udev (237-3ubuntu10.48) …
update-initramfs: deferring update (trigger activated)
Setting up libldap-2.4-2:arm64 (2.4.45+dfsg-1ubuntu1.10) …
Setting up libproxy1-plugin-gsettings:arm64 (0.4.15-1ubuntu0.2) …
Setting up grub-common (2.02-2ubuntu8.23) …
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Setting up chromium-codecs-ffmpeg-extra (91.0.4472.101-0ubuntu0.18.04.1) …
Setting up libssl1.1:arm64 (1.1.1-1ubuntu2.1~18.04.9) …
Setting up gpgsm (2.2.4-1ubuntu1.4) …
Setting up bluez-obexd (5.48-0ubuntu3.5) …
Setting up libproxy1-plugin-networkmanager:arm64 (0.4.15-1ubuntu0.2) …
Setting up nvidia-l4t-core (32.5.1-20210519110732) …
Installing new version of config file /etc/nv_tegra_release …
Setting up openssl (1.1.1-1ubuntu2.1~18.04.9) …
Setting up gnupg-utils (2.2.4-1ubuntu1.4) …
Setting up dnsmasq-base (2.79-1ubuntu0.4) …
Setting up libx11-doc (2:1.6.4-3ubuntu0.4) …
Setting up libjavascriptcoregtk-4.0-18:arm64 (2.32.0-0ubuntu0.18.04.1) …
Setting up libmysqlclient20:arm64 (5.7.34-0ubuntu0.18.04.1) …
Setting up libc-dev-bin (2.27-3ubuntu1.4) …
Setting up xwayland (2:1.19.6-1ubuntu4.9) …
Setting up initramfs-tools-bin (0.130ubuntu3.12) …
Setting up libsasl2-modules:arm64 (2.1.27~101-g0780600+dfsg-3ubuntu2.3) …
Setting up libcaca0:arm64 (0.99.beta19-2ubuntu0.18.04.2) …
Setting up libappindicator3-1 (12.10.1+18.04.20200408.1-0ubuntu1) …
Setting up libpython2.7-minimal:arm64 (2.7.17-1~18.04ubuntu1.6) …
Setting up xdg-utils (1.1.2-1ubuntu2.5) …
Setting up ca-certificates (20210119~18.04.1) …
Updating certificates in /etc/ssl/certs…
1 added, 10 removed; done.
Setting up dirmngr (2.2.4-1ubuntu1.4) …
Setting up bluez (5.48-0ubuntu3.5) …
Setting up libgs9:arm64 (9.26~dfsg+0-0ubuntu0.18.04.14) …
Setting up libglib2.0-bin (2.56.4-0ubuntu0.18.04.8) …
Setting up libc6-dev:arm64 (2.27-3ubuntu1.4) …
Setting up locales (2.27-3ubuntu1.4) …
Generating locales (this might take a while)…
en_AG.UTF-8… done
en_AU.UTF-8… done
en_BW.UTF-8… done
en_CA.UTF-8… done
en_DK.UTF-8… done
en_GB.UTF-8… done
en_HK.UTF-8… done
en_IE.UTF-8… done
en_IL.UTF-8… done
en_IN.UTF-8… done
en_NG.UTF-8… done
en_NZ.UTF-8… done
en_PH.UTF-8… done
en_SG.UTF-8… done
en_US.UTF-8… done
en_ZA.UTF-8… done
en_ZM.UTF-8… done
en_ZW.UTF-8… done
Generation complete.
Setting up linux-firmware (1.173.20) …
update-initramfs: Generating /boot/initrd.img-4.9.201-tegra
Warning: couldn’t identify filesystem type for fsck hook, ignoring.
I: The initramfs will attempt to resume from /dev/zram3
I: (UUID=f784567b-8a3e-4991-a9fd-182da03ac1b7)
I: Set the RESUME variable to override this.
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf: No such file or directory
/sbin/ldconfig.real: Warning: ignoring configuration file that cannot be opened: /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf: No such file or directory
Setting up libwhoopsie0:arm64 (0.2.62ubuntu0.6) …
Setting up liblwres160:arm64 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up libx11-data (2:1.6.4-3ubuntu0.4) …
Setting up libpython2.7-stdlib:arm64 (2.7.17-1~18.04ubuntu1.6) …
Setting up xserver-xorg-legacy (2:1.19.6-1ubuntu4.9) …
setting xserver-xorg-legacy/xwrapper/allowed_users from configuration file
Setting up python3-distupgrade (1:18.04.44) …
Setting up gpg (2.2.4-1ubuntu1.4) …
Setting up python2.7-minimal (2.7.17-1~18.04ubuntu1.6) …
Setting up rpcbind (0.2.3-0.6ubuntu0.18.04.4) …
Setting up libwebp6:arm64 (0.6.1-2ubuntu0.18.04.1) …
Setting up libisc169:arm64 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up libisccc160:arm64 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up nvidia-l4t-libvulkan (32.5.1-20210519110732) …
Setting up libpam-systemd:arm64 (237-3ubuntu10.48) …
Setting up libgstreamer1.0-0:arm64 (1.14.5-0ubuntu1~18.04.2) …
Setcap worked! gst-ptp-helper is not suid!
Setting up docker.io (20.10.2-0ubuntu1~18.04.2) …
Created symlink /etc/systemd/system/multi-user.target.wants/docker.service → /lib/systemd/system/docker.service.
Setting up python3-lxml:arm64 (4.2.1-1ubuntu0.4) …
Setting up libglib2.0-dev-bin (2.56.4-0ubuntu0.18.04.8) …
Setting up nvidia-l4t-firmware (32.5.1-20210519110732) …
Setting up libdjvulibre21:arm64 (3.5.27.1-8ubuntu0.3) …
Setting up libbinutils:arm64 (2.30-21ubuntu1~18.04.5) …
Setting up nvidia-l4t-init (32.5.1-20210519110732) …
Setting up libarchive13:arm64 (3.2.2-3.1ubuntu0.7) …
Setting up initramfs-tools-core (0.130ubuntu3.12) …
Setting up libisc-export169:arm64 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up libcurl3-gnutls:arm64 (7.58.0-2ubuntu3.13) …
Setting up nfs-common (1:1.3.4-2.1ubuntu5.5) …
Setting up p11-kit (0.23.9-2ubuntu0.1) …
Setting up nvidia-l4t-tools (32.5.1-20210614115125) …
Setting up libldb1:arm64 (2:1.2.3-1ubuntu0.2) …
Setting up python3-click (6.7-3) …
Setting up libcurl4:arm64 (7.58.0-2ubuntu3.13) …
Setting up libx11-6:arm64 (2:1.6.4-3ubuntu0.4) …
Setting up libinput10:arm64 (1.10.4-1ubuntu0.18.04.2) …
Setting up wpasupplicant (2:2.6-15ubuntu2.8) …
Setting up python2.7 (2.7.17-1~18.04ubuntu1.6) …
Setting up nvidia-l4t-wayland (32.5.1-20210519110732) …
Setting up initramfs-tools (0.130ubuntu3.12) …
Setting up ghostscript (9.26~dfsg+0-0ubuntu0.18.04.14) …
Setting up librbd1 (12.2.13-0ubuntu0.18.04.8) …
Setting up xserver-xephyr (2:1.19.6-1ubuntu4.9) …
Setting up gpg-wks-server (2.2.4-1ubuntu1.4) …
Setting up ubuntu-release-upgrader-core (1:18.04.44) …
Setting up gpg-wks-client (2.2.4-1ubuntu1.4) …
Setting up xterm (330-1ubuntu2.2) …
Setting up xserver-xorg-core (2:1.19.6-1ubuntu4.9) …
Setting up whoopsie (0.2.62ubuntu0.6) …
Setting up libglib2.0-dev:arm64 (2.56.4-0ubuntu0.18.04.8) …
Setting up nvidia-l4t-x11 (32.5.1-20210519110732) …
Setting up gstreamer1.0-tools (1.14.5-0ubuntu1~18.04.2) …
Setting up gir1.2-javascriptcoregtk-4.0:arm64 (2.32.0-0ubuntu0.18.04.1) …
Setting up thunderbird (1:78.11.0+build1-0ubuntu0.18.04.2) …
Setting up libgnome-autoar-0-0:arm64 (0.2.3-1ubuntu0.4) …
Setting up libpython3.6-minimal:arm64 (3.6.9-1~18.04ubuntu1.4) …
Setting up file-roller (3.28.0-1ubuntu1.3) …
Setting up ubuntu-drivers-common (1:0.8.6.3~0.18.04.1) …
Setting up snapd (2.49.2+18.04) …
Installing new version of config file /etc/apparmor.d/usr.lib.snapd.snap-confine.real …
snapd.failure.service is a disabled or a static unit, not starting it.
snapd.snap-repair.service is a disabled or a static unit, not starting it.
Setting up dnsmasq (2.79-1ubuntu0.4) …
Setting up binutils-aarch64-linux-gnu (2.30-21ubuntu1~18.04.5) …
Setting up libwebpmux3:arm64 (0.6.1-2ubuntu0.18.04.1) …
Setting up thunderbird-gnome-support (1:78.11.0+build1-0ubuntu0.18.04.2) …
Setting up libpython2.7:arm64 (2.7.17-1~18.04ubuntu1.6) …
Setting up python3-httplib2 (0.9.2+dfsg-1ubuntu0.3) …
Setting up libdns-export1100 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up nvidia-l4t-kernel (4.9.201-tegra-32.5.1-20210505093645) …
Using the existing boot entry ‘primary’
3448-300-0003–1–jetson-nano-2gb-devkit-mmcblk0p1
Setting up libwebpdemux2:arm64 (0.6.1-2ubuntu0.18.04.1) …
Setting up libpython2.7-dev:arm64 (2.7.17-1~18.04ubuntu1.6) …
Setting up binutils (2.30-21ubuntu1~18.04.5) …
Setting up libx11-dev:arm64 (2:1.6.4-3ubuntu0.4) …
Setting up gir1.2-appindicator3-0.1 (12.10.1+18.04.20200408.1-0ubuntu1) …
Setting up ghostscript-x (9.26~dfsg+0-0ubuntu0.18.04.14) …
Setting up libdns1100:arm64 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up nvidia-l4t-weston (32.5.1-20210519110732) …
Setting up gir1.2-gstreamer-1.0:arm64 (1.14.5-0ubuntu1~18.04.2) …
Setting up python2.7-dev (2.7.17-1~18.04ubuntu1.6) …
Setting up git (1:2.17.1-1ubuntu0.8) …
Setting up libx11-xcb-dev:arm64 (2:1.6.4-3ubuntu0.4) …
Setting up libgstreamer-plugins-base1.0-0:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up nvidia-l4t-kernel-dtbs (4.9.201-tegra-32.5.1-20210505093645) …
Setting up libpython3.6-stdlib:arm64 (3.6.9-1~18.04ubuntu1.4) …
Setting up nvidia-l4t-bootloader (32.5.1-20210614115125) …
Starting bootloader post-install procedure.
Update bootloader completed.
Reboot the target system for changes to take effect.
Updating extlinux.conf…
Root device is set in the extlinux.conf
Setting up chromium-browser (91.0.4472.101-0ubuntu0.18.04.1) …
Setting up gstreamer1.0-plugins-base:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up nvidia-l4t-xusb-firmware (32.5.1-20210614115125) …
Starting xusb firmware post-install procedure.
Update xusb firmware completed.
Setting up samba-libs:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.23) …
Setting up nvidia-l4t-initrd (32.5.1-20210614115125) …
Setting up libmagickcore-6.q16-3:arm64 (8:6.9.7.4+dfsg-16ubuntu6.11) …
Setting up nvidia-l4t-multimedia-utils (32.5.1-20210519110732) …
Setting up gstreamer1.0-pulseaudio:arm64 (1.14.5-0ubuntu1~18.04.2) …
Setting up nvidia-l4t-3d-core (32.5.1-20210519110732) …
Setting up libgstreamer-gl1.0-0:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up gnupg (2.2.4-1ubuntu1.4) …
Setting up gstreamer1.0-gl:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up libisccfg-export160 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up python3.6-minimal (3.6.9-1~18.04ubuntu1.4) …
Setting up gir1.2-gst-plugins-base-1.0:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up chromium-browser-l10n (91.0.4472.101-0ubuntu0.18.04.1) …
Setting up python3-apport (2.20.9-0ubuntu7.24) …
Setting up nvidia-l4t-kernel-headers (4.9.201-tegra-32.5.1-20210505093645) …
Setting up nvidia-l4t-cuda (32.5.1-20210519110732) …
Setting up libsmbclient:arm64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.23) …
Setting up isc-dhcp-client (4.3.5-3ubuntu7.3) …
Setting up libisccfg160:arm64 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up nvidia-l4t-multimedia (32.5.1-20210519110732) …
Setting up nvidia-l4t-camera (32.5.1-20210519110732) …
Setting up libmagickwand-6.q16-3:arm64 (8:6.9.7.4+dfsg-16ubuntu6.11) …
Setting up apport (2.20.9-0ubuntu7.24) …
apport-autoreport.service is a disabled or a static unit, not starting it.
Setting up gstreamer1.0-plugins-base-apps (1.14.5-0ubuntu1~18.04.3) …
Setting up libirs-export160 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up isc-dhcp-server (4.3.5-3ubuntu7.3) …
isc-dhcp-server6.service is a disabled or a static unit, not starting it.
Setting up gstreamer1.0-x:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up libgstreamer-plugins-good1.0-0:arm64 (1.14.5-0ubuntu1~18.04.2) …
Setting up libgstreamer1.0-dev:arm64 (1.14.5-0ubuntu1~18.04.2) …
Setting up gstreamer1.0-alsa:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up libpython3.6:arm64 (3.6.9-1~18.04ubuntu1.4) …
Setting up nvidia-l4t-graphics-demos (32.5.1-20210519110732) …
Setting up python3.6 (3.6.9-1~18.04ubuntu1.4) …
Setting up libwebkit2gtk-4.0-37:arm64 (2.32.0-0ubuntu0.18.04.1) …
Setting up gstreamer1.0-gtk3:arm64 (1.14.5-0ubuntu1~18.04.2) …
Setting up libbind9-160:arm64 (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up nvidia-l4t-gstreamer (32.5.1-20210519110732) …
Setting up imagemagick-6.q16 (8:6.9.7.4+dfsg-16ubuntu6.11) …
Setting up apport-gtk (2.20.9-0ubuntu7.24) …
Setting up nvidia-l4t-jetson-multimedia-api (32.5.1-20210519110732) …
Setting up libmagickcore-6.q16-3-extra:arm64 (8:6.9.7.4+dfsg-16ubuntu6.11) …
Setting up libgstreamer-plugins-base1.0-dev:arm64 (1.14.5-0ubuntu1~18.04.3) …
Setting up imagemagick (8:6.9.7.4+dfsg-16ubuntu6.11) …
Setting up gstreamer1.0-plugins-good:arm64 (1.14.5-0ubuntu1~18.04.2) …
Setting up bind9-host (1:9.11.3+dfsg-1ubuntu1.15) …
Setting up gir1.2-webkit2-4.0:arm64 (2.32.0-0ubuntu0.18.04.1) …
Setting up ubuntu-release-upgrader-gtk (1:18.04.44) …
Setting up update-notifier (3.192.1.11) …
Setting up aptdaemon (1.1.1+bzr982-0ubuntu19.5) …
Setting up python3-aptdaemon (1.1.1+bzr982-0ubuntu19.5) …
Setting up python3-aptdaemon.gtk3widgets (1.1.1+bzr982-0ubuntu19.5) …
Processing triggers for bamfdaemon (0.5.3+18.04.20180207.2-0ubuntu1) …
Rebuilding /usr/share/applications/bamf-2.index…
Processing triggers for libc-bin (2.27-3ubuntu1.4) …
Processing triggers for systemd (237-3ubuntu10.48) …
Processing triggers for man-db (2.8.3-2ubuntu0.1) …
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) …
Processing triggers for dbus (1.12.2-1ubuntu1.2) …
Processing triggers for hicolor-icon-theme (0.17-2) …
Processing triggers for gconf2 (3.2.6-4ubuntu1) …
Setting up libmutter-2-0:arm64 (3.28.4+git20200505-0ubuntu18.04.2) …
Processing triggers for mime-support (3.60ubuntu1) …
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) …
Setting up gir1.2-mutter-2:arm64 (3.28.4+git20200505-0ubuntu18.04.2) …
Setting up mutter (3.28.4+git20200505-0ubuntu18.04.2) …
Setting up gnome-shell (3.28.4-0ubuntu18.04.7) …
Processing triggers for ca-certificates (20210119~18.04.1) …
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d…
done.
Processing triggers for initramfs-tools (0.130ubuntu3.12) …
Processing triggers for nvidia-l4t-kernel (4.9.201-tegra-32.5.1-20210505093645) …
root@skylab:~#
