When I install python3-pip,libhdf5-serial-dev and hdf5-tools on my Jetson Nano board.
python3-pip and hdf5-tools is fine, but installation of hdf5-tools has some error as follow.
yaobmc@R2D2:~$ sudo apt-get install libhdf5-serial-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libhdf5-serial-dev : Depends: libhdf5-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
yaobmc@R2D2:~$ sudo apt-get install libhdf5-dev
libhdf5-dev : Depends: libjpeg-dev
yaobmc@R2D2:~$ sudo apt-get install libjpeg-dev
libjpeg-dev : Depends: libjpeg8-dev but it is not going to be installed
yaobmc@R2D2:~$ sudo apt-get install libjpeg8-dev
libjpeg8-dev : Depends: libjpeg-turbo8-dev (>= 1.1.90+svn722-1ubuntu6) but it is not going to be installed
yaobmc@R2D2:~$ sudo apt-get install libjpeg-turbo8-dev
libjpeg-turbo8-dev : Depends: libjpeg-turbo8 (= 1.4.2-0ubuntu3.1) but 1.5.2-0ubuntu5.18.04.1 is to be installed
Is ‘sudo apt-get install libjpeg-turbo8=1.4.2-0ubuntu3.1’ right?
Is there any other way to solve the issue?
