hi
I’m using Jetson Nano.
Jetson nano has a login loop.
I tried ctr+alt+F1-F6 to change CUI.
But it didn’t change.
Could you tell me to resolve the trouble?
hi
So you make the situation even worse after the post you filed few days ago?
I changed from gdm3 to lightdm, thinking I could change it right back.
However, I ran into this problem.
You can try to operate with serial console.
However, if you don’t want to check those logs, you can directly reflash the board.
