Hello Experts,
CC: @Honey_Patouceul @DaneLLL @amycao @kayccc @WayneWWW @icornejo.a @AastaLLL
I am using Jetson Nano developer kit in long run (almost 24 x 7) for OpenCV face recognition CNN with peripherals such as PC LCD screen, Mouse, Keypad, USB-WiFi Adapter, Ethernet being connected.
In long run usually after 30 Hours the system stalls while accessing it. Heat sink reads around 60 degree C while measured using IR thermal scanner.
Is it due to overheat or anyways to overcome the same ? We are planning to deploy it over the security applications where it should work reliably
