Jetson nano module compatibility with other carrier boards
i have a jetson nano module which theoretically compatible with one ur partner seeed’s studio j1010. but when i flash i found below errors
10:52:05 INFO: Flash Jetson Nano - flash: *** Checking ONLINE mode … OK.
10:52:06 INFO: Flash Jetson Nano - flash: *** Checking target board connection … 1 connections found.
10:52:07 INFO: Flash Jetson Nano - flash: *** Reading ECID … FUSELEVEL=fuselevel_nofuse hwchipid=0x00 bootauth=
10:52:07 ERROR: Flash Jetson Nano - flash: *** Error: Unsupported Tegra SoC ID 0x00 found.
10:52:07 ERROR: Flash Jetson Nano - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.aymen.sh; [error]: *** Error: Unsupported Tegra SoC ID 0x00 found.
10:52:07 INFO: Flash Jetson Nano - flash: [ Component Install Finished with Error ]
10:52:07 INFO: Flash Jetson Nano - flash: [host] [ 8.00 KB used. Disk Avail: 380.57 GB ]
10:52:07 INFO: Flash Jetson Nano - flash: [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 5s ]
10:52:07 ERROR: Flash Jetson Nano - flash: command terminated with error
10:52:07 SUMMARY: Flash Jetson Nano - flash: First Error: Installation failed.
Please contact with Seeed to know how to flash the SW to their board.
