Jetson nano not booting after writing image to SD card
Hi!
My Jetson Nano was working last week and I was installing packages for my new project. I then rebooted the Nano and it failed to boot:
I then followed the “Getting Started with Jetson Nano Developer Kit” guide to re-flash the SD card and start from scratch but the process isn’t working - I just get a black screen.
So far I have tried jumping pins 9 and 10 of J50 together to put the board in recovery mode but the screen is still black.
My specific product is the P3518.
I have the kernel log; it was stuck in a loop that I broke out of by hitting a key to stop autoboot.
[0002.120] I> Hit any key to stop autoboot:     4       3       2       1
[0004.128] initializing target
[0004.128] calling apps_init()
[0004.129] starting app kernel_boot_app
[0004.153] I> found decompressor handler: lz4-legacy
[0004.153] I> decompressing BMP blob ...
[0004.164] I> Kernel type = Normal
[0004.165] I> Loading kernel-bootctrl from partition
[0004.165] E> Cannot find partition kernel-bootctrl
[0004.165] E> Cannot open partition kernel-bootctrl
[0004.166] W> tegrabl_get_kernel_bootctrl: failed to read primary bootctrl data
[0004.166] I> Loading kernel-bootctrl_b from partition
[0004.168] E> Cannot find partition kernel-bootctrl_b
[0004.173] E> Cannot open partition kernel-bootctrl_b
[0004.178] W> tegrabl_get_kernel_bootctrl: failed to read recovery bootctrl data
[0004.185] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.192] I> ########## SD (0) boot ##########
[0004.197] I> Found sdcard
[0004.200] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.207] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.236] I> sdmmc SDR mode
[0004.250] I> -0 params source =
[0004.250] I> Already published: 00060000
[0004.251] I> Look for boot partition
[0004.251] I> Fallback: assuming 0th partition is boot partition
[0004.251] I> Detect filesystem
[0004.272] I> Loading extlinux.conf ...
[0004.272] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.301] I> L4T boot options
[0004.301] I> [1]: "primary kernel"
[0004.301] I> Enter choice:
[0006.618] I> Selected option: 1
[0006.618] I> Loading kernel sig file from rootfs ...
[0006.618] I> rootfs path: /sd/boot/Image.sig
[0010.758] I> lookup_linear_dir:447: Invalid file block num
[0010.759] I> ext2_walk:142: 'Image.sig' lookup failed
[0010.759] I> ext4_open_file:666: '/boot/Image.sig' lookup failed
[0010.760] E> file /sd/boot/Image.sig open failed!!
[0010.760] W> Failed to load kernel sig file (err=202113041)
[0010.760] I> Loading kernel binary from rootfs ...
[0010.764] I> rootfs path: /sd/boot/Image
[0013.589] I> Validate kernel ...
[0013.590] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0013.590] E> Stage2Signature validation failed with SHA2!!
[0013.591] C> OEM authentication of kernel header failed!
[0013.591] W> Failed to validate kernel binary (err=1077936152, fail=1)
[0013.592] W> Security fuse not burned, ignore validation failure
[0013.604] I> No kernel-dtb binary path
[0013.604] I> A/B: bin_type (38) slot 1
[0013.604] I> Loading kernel-dtb_b from partition
[0013.609] E> Cannot find partition kernel-dtb_b
[0013.613] E> Cannot open partition kernel-dtb_b
[0013.617] E> A/B loader failure
[0013.6▒▒
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet leve                              l 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x0
[0000.059] I> rst_source : 0xb
[0000.062] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] I> Active Boot chain : 1
[0000.089] I> Boot-device: QSPI
[0000.092] I> Qspi flash params source = brbct
[0000.098] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.104] I> Temperature = 27500
[0000.107] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.111] W> Skipping boost for clk: BPMP_APB
[0000.115] W> Skipping boost for clk: AXI_CBB
[0000.119] W> Skipping boost for clk: AON_CPU_NIC
[0000.124] W> Skipping boost for clk: CAN1
[0000.127] W> Skipping boost for clk: CAN2
[0000.132] I> Boot-device: QSPI
[0000.134] I> Boot-device: QSPI
[0000.137] I> Qspi flash params source = mb1bct
[0000.141] I> Qspi using bpmp-dma
[0000.144] I> Qspi clock source : pllc_out0
[0000.148] I> Qspi reinitialized
[0000.151] I> Qspi flash params source = mb1bct
[0000.156] I> ECC region[0]: Start:0x0, End:0x0
[0000.160] I> ECC region[1]: Start:0x0, End:0x0
[0000.165] I> ECC region[2]: Start:0x0, End:0x0
[0000.169] I> ECC region[3]: Start:0x0, End:0x0
[0000.173] I> ECC region[4]: Start:0x0, End:0x0
[0000.177] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.183] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.187] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.192] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.196] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.201] E> FAILED: Thermal config
[0000.209] E> FAILED: MEMIO rail config
[0000.219] I> Boot-device: QSPI
[0000.222] I> Qspi flash params source = mb1bct
[0000.231] I> Qspi flash params source = mb1bct
[0000.242] I> Qspi flash params source = mb1bct
[0000.309] I> Qspi flash params source = mb1bct
[0000.318] I> Qspi flash params source = mb1bct
[0000.346] I> Qspi flash params source = mb1bct
[0000.358] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
  [0000.366] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-751504                              8c)
[0000.367] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.368] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.368] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.374] W> device prod register failed
[0000.378] I> Boot-device: QSPI
[0000.381] I> Boot_device: QSPI_FLASH instance: 0
[0000.386] I> QSPI Flash Size = 32 MB
[0000.392] I> Qspi initialized successfully
[0000.393] I> qspi flash-0 params source = boot args
[0000.397] E> Failed: Unknown device 6
[0000.404] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.407] I> Active Boot chain : 1
[0000.410] I> parsing oem signed section of bpmp-fw header done
[0000.415] I> bpmp-fw binary init read from storage
[0000.420] I> oem authentication of bpmp-fw header done
[0000.434] I> bpmp-fw binary done read from storage
[0000.435] I> bpmp-fw: Authentication init Done
[0000.436] I> parsing oem signed section of cpubl header done
[0000.439] I> cpubl binary init read from storage
[0000.444] I> bpmp-fw: Authentication Finalize Done
[0000.449] I> oem authentication of cpubl header done
[0000.456] I> cpubl binary done read from storage
[0000.458] I> cpubl: Authentication init Done
[0000.462] I> parsing oem signed section of rce header done
[0000.467] I> rce binary init read from storage
[0000.472] I> Relocating BR-BCT
[0000.474] I> cpubl: Authentication Finalize Done
[0000.479] I> oem authentication of rce header done
[0000.484] I> rce binary done read from storage
[0000.488] I> rce: Authentication init Done
[0000.492] I> parsing oem signed section of ape header done
[0000.497] I> ape binary init read from storage
[0000.501] I> rce: Authentication Finalize Done
[0000.506] I> oem authentication of ape header done
[0000.510] I> ape binary done read from storage
[0000.514] I> ape: Authentication init Done
[0000.519] I> parsing oem signed section of tos header done
[0000.524] I> tos binary init read from storage
[0000.528] I> ape: Authentication Finalize Done
[0000.533] I> oem authentication of tos header done
[0000.539] I> tos binary done read from storage
[0000.541] I> tos: Authentication init Done
[0000.546] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.551] I> bpmp-fw-dtb binary init read from storage
[0000.556] I> tos: Authentication Finalize Done
[0000.562] I> oem authentication of bpmp-fw-dtb header done
[0000.566] I> bpmp-fw-dtb binary done read from storage
[0000.571] I> bpmp-fw-dtb: Authentication init Done
[0000.576] I> parsing oem signed section of cpubl-dtb header done
[0000.581] I> cpubl-dtb binary init read from storage
[0000.586] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.633] I> oem authentication of cpubl-dtb header done
[0000.633] I> cpubl-dtb binary done read from storage
[0000.634] I> cpubl-dtb: Authentication init Done
[0000.635] I> parsing oem signed section of eks header done
[0000.636] I> eks binary init read from storage
[0000.636] I> cpubl-dtb: Authentication Finalize Done
[0000.637] I> oem authentication of eks header done
[0000.642] I> eks binary done read from storage
[0000.646] I> eks: Authentication init Done
[0000.650] I> eks: Authentication Finalize Done
[0000.654] I> EKB detected (length: 0x410) @ VA:0x52700400
▒▒NOTICE:  BL31: v1.3(release):5b49e7f80
NOTICE:  BL31: Built : 08:54:10, Jul  9 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing .......
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
  [0000.994] I> Welcome to Cboot▒▒mrq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
[0000.995] I> Cboot Version: t194-f9317da2
[0000.997] I> CPU-BL Params @ 0xf2820000
[0001.000] I>  0) Base:0x00000000 Size:0x00000000
[0001.005] I>  1) Base:0xf1100000 Size:0x00100000
▒▒clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.009] I>  2) Base:0xf2000000 Size:0x00200000
[0001.163] I>  3) Base:0xf1200000 Size:0x00200000
[0001.168] I>  4) Base:0xf1000000 Size:0x00100000
[0001.172] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.177] I>  6) Base:0xf3800000 Size:0x00400000
[0001.181] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.186] I>  8) Base:0xf0e00000 Size:0x00100000
[0001.190] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.195] I> 10) Base:0xf3000000 Size:0x00800000
[0001.199] I> 11) Base:0x40000000 Size:0x00040000
[0001.204] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.208] I> 13) Base:0x40046000 Size:0x00002000
[0001.213] I> 14) Base:0x40048000 Size:0x00002000
[0001.217] I> 15) Base:0xac000000 Size:0x00004000
[0001.221] I> 16) Base:0x4004a000 Size:0x00002000
[0001.226] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.230] I> 18) Base:0x4004c000 Size:0x00002000
[0001.235] I> 19) Base:0xf2200000 Size:0x00600000
[0001.239] I> 20) Base:0x4004e000 Size:0x00002000
[0001.244] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.248] I> 22) Base:0x00000000 Size:0x00000000
[0001.253] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.257] I> 24) Base:0xf6000000 Size:0x02000000
[0001.262] I> 25) Base:0x40050000 Size:0x00002000
[0001.266] I> 26) Base:0x40040000 Size:0x00006000
[0001.271] I> 27) Base:0xf1800000 Size:0x00400000
[0001.275] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.280] I> 29) Base:0xf1400000 Size:0x00400000
[0001.284] I> 30) Base:0x00000000 Size:0x00000000
[0001.288] I> 31) Base:0x00000000 Size:0x00000000
[0001.293] I> 32) Base:0xf8000000 Size:0x08000000
[0001.297] I> 33) Base:0x00000000 Size:0x00000000
[0001.302] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.306] I> 35) Base:0xab000000 Size:0x01000000
[0001.311] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.315] I> 37) Base:0xf2800000 Size:0x00800000
[0001.320] I> 38) Base:0x80000000 Size:0x20000000
[0001.324] I> 39) Base:0xb0000000 Size:0x08000000
[0001.329] I> 40) Base:0x00000000 Size:0x00000000
[0001.333] I> 41) Base:0x00000000 Size:0x00000000
[0001.338] I> 42) Base:0x00000000 Size:0x00000000
[0001.342] I> 43) Base:0x00000000 Size:0x00000000
[0001.346] I> 44) Base:0x00000000 Size:0x00000000
[0001.351] I> 45) Base:0x00000000 Size:0x00000000
[0001.355] GIC-SPI Target CPU: 0
[0001.358] Interrupts Init done
[0001.361] calling constructors
[0001.364] initializing heap
[0001.367] I> Heap: [0xa0694618 ... 0xab000000]
[0001.371] initializing threads
[0001.374] initializing timers
[0001.377] creating bootstrap completion thread
[0001.381] top of bootstrap2()
[0001.384] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.388] initializing platform
[0001.391] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.397] W> device prod register failed
[0001.401] I> Bl_dtb @0xaaf00000
[0001.406] W> "plugin-manager" doesn't exist, creating
[0001.409] W> "ids" doesn't exist, creating
[0001.413] W> "connection" doesn't exist, creating
[0001.417] W> "configs" doesn't exist, creating
[0001.426] I> Find /i2c@3160000's alias i2c0
[0001.427] I> Reading eeprom i2c=0 address=0x50
[0001.455] I> Device at /i2c@3160000:0x50
[0001.455] I> Reading eeprom i2c=0 address=0x57
[0001.480] I> Device at /i2c@3160000:0x57
[0001.482] I> Find /i2c@c240000's alias i2c1
[0001.482] I> Reading eeprom i2c=1 address=0x50
[0001.484] E> I2C: slave not found in slaves.
[0001.484] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr                              ue.
[0001.485] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.485] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at                               0x00000000 via instance 1.
[0001.494] E> eeprom: Retry to read I2C slave device.
[0001.499] E> I2C: slave not found in slaves.
[0001.503] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr                              ue.
[0001.510] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.516] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at                               0x00000000 via instance 1.
[0001.525] E> eeprom: Failed to read I2C slave device
[0001.530] I> Eeprom read failed 0x3526070d
[0001.534] I> create_pm_ids: id: 3668-0000-300-B, len: 15
[0001.539] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00                              ,touch-config:00,display-config:00,, len: 93
[0001.550] I> create_pm_ids: id: 3509-0000-100-J, len: 15
[0001.556] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00                              ,touch-config:00,display-config:00,, len: 93
[0001.567] I> Adding plugin-manager/ids/3668-0000-300=/i2c@3160000:module@0x50
[0001.574] W> "i2c@3160000" doesn't exist, creating
[0001.578] W> "module@0x50" doesn't exist, creating
[0001.583] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.590] W> "module@0x57" doesn't exist, creating
[0001.596] I> Adding plugin-manager/cvm
[0001.598] W> "chip-id" doesn't exist, creating
[0001.602] I> Adding plugin-manager/chip-id/A02P
[0001.607] I> Plugin-manager override starting
[0001.612] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.620] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.626] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.633] I> Disable plugin-manager status in FDT
[0001.634] I> Plugin-manager override finished successfully
[0001.639] I> gpio framework initialized
[0001.644] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driv                              er
[0001.651] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'                               driver
[0001.658] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.664] W> fetch_driver_phandle_from_dt: failed to get node with compatible t                              i,tca9539
[0001.672] W> fetch_driver_phandle_from_dt: failed to get node with compatible n                              xp,tca9539
[0001.679] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.685] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.692] W> fetch_driver_phandle_from_dt: failed to get node with compatible t                              i,tca9539
[0001.700] W> fetch_driver_phandle_from_dt: failed to get node with compatible n                              xp,tca9539
[0001.707] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.714] I> fixed regulator driver initialized
[0001.721] I> register 'maxim' power off handle
[0001.722] I> virtual i2c enabled
[0001.725] I> registered 'maxim,max20024' pmic
[0001.729] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.736] I> Boot-device: QSPI
[0001.739] I> Boot_device: QSPI_FLASH instance: 0
[0001.744] I> QSPI source rate = 204000 Khz
[0001.747] I> Requested rate for QSPI clock = 34000 Khz
[0001.752] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.757] I> QSPI Flash Size = 32 MB
[0001.765] I> Qspi initialized successfully
[0001.765] I> qspi flash-0 params source = boot args
[0001.769] I> create_pm_ids: id: 3668-0000-300-B, len: 15
[0001.774] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00                              ,touch-config:00,display-config:00,, len: 93
[0001.785] I> create_pm_ids: id: 3509-0000-100-J, len: 15
[0001.790] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00                              ,touch-config:00,display-config:00,, len: 93
[0001.801] I> Found sdcard
[0001.805] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.811] I> regulator 'vdd-sdmmc1-sw' already enabled
[0002.041] I> sdmmc SDR mode
[0002.055] I> -0 params source =
[0002.056] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.065] I> Found 14 partitions in SDCARD (instance 0)
[0002.073] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.076] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.076] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.077] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.079] E> invalid display type
[0002.080] E> cannot find any other nvdisp nodes
[0002.080] E> no valid display unit config found in dtb
[0002.084] W> display init failed
[0002.086] I> Load in CBoot Boot Options partition and parse it
[0002.092] E> Error -9 when finding node with path /boot-configuration
[0002.098] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file                              .
[0002.105] I> Using default boot order
[0002.108] I> boot-dev-order :-
[0002.111] I> 1.sd
[0002.113] I> 2.usb
[0002.115] I> 3.nvme
[0002.117] I> 4.emmc
[0002.119] I> 5.net
[0002.121] I> Hit any key to stop autoboot:     4       3E> tegrabl_display_prin
Here are some more logs:
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
  [0000.997] I> Welcome to Cboot▒▒mrq initialized
[0000.998] I> Cboot Version: t194-f9317da2
[0000.998] I> CPU-BL Params @ 0xf2820000
[0001.001] I>  0) Base:0x00000000 Size:0x00000000
[0001.010] I>  2) Base:0xf2000000 Size:0x00200000
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
] ▒▒[0001.014] I>  3) Base:0xf1200000 Size:0x00200000
[0001.173] I>  5) Base:0xf0f00000 Size:0x00100000
[0001.182] I>  7) Base:0xf1c00000 Size:0x00400000
[0001.191] I>  9) Base:0xf0d00000 Size:0x00100000
[0001.200] I> 11) Base:0x40000000 Size:0x00040000
[0001.209] I> 13) Base:0x40046000 Size:0x00002000
[0001.222] I> 16) Base:0x4004a000 Size:0x00002000
[0001.231] I> 18) Base:0x4004c000 Size:0x00002000
[0001.240] I> 20) Base:0x4004e000 Size:0x00002000
[0001.249] I> 22) Base:0x00000000 Size:0x00000000
[0001.258] I> 24) Base:0xf6000000 Size:0x02000000
[0001.267] I> 26) Base:0x40040000 Size:0x00006000
[0001.289] I> 31) Base:0x00000000 Size:0x00000000
[0001.298] I> 33) Base:0x00000000 Size:0x00000000
[0001.307] I> 35) Base:0xab000000 Size:0x01000000
[0001.316] I> 37) Base:0xf2800000 Size:0x00800000
[0001.325] I> 39) Base:0xb0000000 Size:0x08000000
[0001.347] I> 44) Base:0x00000000 Size:0x00000000
[0001.356] GIC-SPI Target CPU: 0
[0001.359] Interrupts Init done
[0001.362] calling constructors
[0001.365] initializing heap
[0001.389] initializing platform
[0001.392] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.427] I> Find /i2c@3160000's alias i2c0
[0001.428] I> Reading eeprom i2c=0 address=0x50
[0001.456] I> Reading eeprom i2c=0 address=0x57
[0001.484] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.486] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.503] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.511] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.526] E> eeprom: Failed to read I2C slave device
[0001.531] I> Eeprom read failed 0x3526070d
[0001.535] I> create_pm_ids: id: 3668-0000-300-B, len: 15
[0001.540] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.551] I> create_pm_ids: id: 3509-0000-100-J, len: 15
[0001.556] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.579] W> "module@0x50" doesn't exist, creating
[0001.584] I> Adding plugin-manager/ids/3509-0000-100=/i2c@3160000:module@0x57
[0001.591] W> "module@0x57" doesn't exist, creating
[0001.597] I> Adding plugin-manager/cvm
[0001.599] W> "chip-id" doesn't exist, creating
[0001.603] I> Adding plugin-manager/chip-id/A02P
[0001.621] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.644] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.665] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.673] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.680] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.686] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.693] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.701] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.708] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.715] I> fixed regulator driver initialized
[0001.724] I> register 'maxim' power off handle
[0001.724] I> virtual i2c enabled
[0001.730] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.748] I> Requested rate for QSPI clock = 34000 Khz
[0001.753] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.758] I> QSPI Flash Size = 32 MB
[0001.766] I> qspi flash-0 params source = boot args
[0001.775] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.786] I> create_pm_ids: id: 3509-0000-100-J, len: 15
[0001.791] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.802] I> Found sdcard
[0001.806] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.812] I> regulator 'vdd-sdmmc1-sw' already enabled
[0002.056] I> -0 params source =
[0002.057] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.066] I> Found 14 partitions in SDCARD (instance 0)
[0002.077] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.077] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.078] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.081] E> invalid display type
[0002.081] E> cannot find any other nvdisp nodes
[0002.082] E> no valid display unit config found in dtb
[0002.087] I> Load in CBoot Boot Options partition and parse it
[0002.093] E> Error -9 when finding node with path /boot-configuration
[0002.099] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.106] I> Using default boot order
[0002.109] I> boot-dev-order :-
[0002.112] I> 1.sd
[0002.114] I> 2.usb
[0002.116] I> 3.nvme
[0002.118] I> 4.emmc
[0002.120] I> 5.net
[0002.121] I> Hit any key to stop autoboot:     4       3       2       1
[0004.129] initializing target
[0004.129] calling apps_init()
[0004.130] starting app kernel_boot_app
[0004.154] I> found decompressor handler: lz4-legacy
[0004.154] I> decompressing BMP blob ...
[0004.165] I> Kernel type = Normal
[0004.166] I> Loading kernel-bootctrl from partition
[0004.166] E> Cannot find partition kernel-bootctrl
[0004.166] E> Cannot open partition kernel-bootctrl
[0004.167] W> tegrabl_get_kernel_bootctrl: failed to read primary bootctrl data
[0004.167] I> Loading kernel-bootctrl_b from partition
[0004.170] E> Cannot find partition kernel-bootctrl_b
[0004.174] E> Cannot open partition kernel-bootctrl_b
[0004.179] W> tegrabl_get_kernel_bootctrl: failed to read recovery bootctrl data
[0004.186] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.193] I> ########## SD (0) boot ##########
[0004.198] I> Found sdcard
[0004.201] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.237] I> sdmmc SDR mode
[0004.251] I> -0 params source =
[0004.251] I> Already published: 00060000
[0004.252] I> Look for boot partition
[0004.252] I> Fallback: assuming 0th partition is boot partition
[0004.253] I> Detect filesystem
[0004.273] I> Loading extlinux.conf ...
[0004.273] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.302] I> L4T boot options
[0004.302] I> [1]: "primary kernel"
[0004.303] I> Enter choice:
[0007.304] I> Continuing with default option: 1
[0007.304] I> Loading kernel sig file from rootfs ...
[0007.304] I> rootfs path: /sd/boot/Image.sig
[0011.446] I> lookup_linear_dir:447: Invalid file block num
[0011.447] I> ext2_walk:142: 'Image.sig' lookup failed
[0011.447] I> ext4_open_file:666: '/boot/Image.sig' lookup failed
[0011.447] E> file /sd/boot/Image.sig open failed!!
[0011.448] W> Failed to load kernel sig file (err=202113041)
[0011.448] I> Loading kernel binary from rootfs ...
[0011.452] I> rootfs path: /sd/boot/Image
[0014.277] I> Validate kernel ...
[0014.277] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0014.277] E> Stage2Signature validation failed with SHA2!!
[0014.278] C> OEM authentication of kernel header failed!
[0014.278] W> Failed to validate kernel binary (err=1077936152, fail=1)
[0014.279] W> Security fuse not burned, ignore validation failure
[0014.291] I> No kernel-dtb binary path
[0014.291] I> A/B: bin_type (38) slot 0
[0014.291] I> Loading kernel-dtb from partition
[0014.295] E> Cannot find partition kernel-dtb
[0014.300] E> Cannot open partition kernel-dtb
[0014.304] E> A/B loader failure
[00▒▒
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.086] I> Active Boot chain : 0
[0000.104] I> Temperature = 49000
[0000.202] E> FAILED: Thermal config
[0000.347] I> Qspi flash params source = mb1bct
▒▒▒▒main enter
HW Function test
Start Scheduler.
in late init
  [0000.367] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-7515048c)
[0000.368] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.369] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.375] W> device prod register failed
[0000.379] I> Boot-device: QSPI
[0000.398] E> Failed: Unknown device 6
[0000.405] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.407] I> Active Boot chain : 0
[0000.411] I> parsing oem signed section of bpmp-fw header done
[0000.416] I> bpmp-fw binary init read from storage
[0000.421] I> oem authentication of bpmp-fw header done
[0000.435] I> bpmp-fw binary done read from storage
[0000.440] I> cpubl binary init read from storage
[0000.457] I> cpubl binary done read from storage
[0000.463] I> parsing oem signed section of rce header done
[0000.468] I> rce binary init read from storage
[0000.475] I> cpubl: Authentication Finalize Done
[0000.480] I> oem authentication of rce header done
[0000.493] I> parsing oem signed section of ape header done
[0000.498] I> ape binary init read from storage
[0000.502] I> rce: Authentication Finalize Done
[0000.511] I> ape binary done read from storage
[0000.515] I> ape: Authentication init Done
[0000.529] I> ape: Authentication Finalize Done
[0000.540] I> tos binary done read from storage
[0000.542] I> tos: Authentication init Done
[0000.552] I> bpmp-fw-dtb binary init read from storage
[0000.557] I> tos: Authentication Finalize Done
[0000.563] I> oem authentication of bpmp-fw-dtb header done
[0000.582] I> cpubl-dtb binary init read from storage
[0000.587] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.632] I> oem authentication of cpubl-dtb header done
[0000.635] I> eks binary init read from storage
[0000.641] I> eks binary done read from storage
[0000.645] I> eks: Authentication init Done
[0000.649] I> eks: Authentication Finalize Done
welcome to lk
initializing heap
top of bootstrap2()
bpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
ec_mrq initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
  ▒▒mrq initialized
▒▒[0000.996] I> Welcome to Cboot
▒▒WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
▒▒[0000.997] I> Cboot Version: t194-f9317da2
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
mail_fs initialized
profile initialized
mods initialized
dt_fs initialized
initializing target
calling apps_init()
starting app shell
[0001.613] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.627] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.634] I> Disable plugin-manager status in FDT
[0001.635] I> Plugin-manager override finished successfully
[0001.645] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.652] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.666] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.716] I> fixed regulator driver initialized
[0001.723] I> register 'maxim' power off handle
[0001.807] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.813] I> regulator 'vdd-sdmmc1-sw' already enabled
[0002.072] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.075] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.076] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.083] W> display init failed
[0002.085] I> Load in CBoot Boot Options partition and parse it
[0002.091] E> Error -9 when finding node with path /boot-configuration
[0002.097] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.104] I> Using default boot order
[0002.111] I> 1.sd
[0002.113] I> 2.usb
[0002.114] I> 3.nvme
[0002.116] I> 4.emmc
[0002.118] I> 5.net
[0004.166] I> Kernel type = Normal
[0004.167] I> Loading kernel-bootctrl from partition
[0004.167] E> Cannot find partition kernel-bootctrl
[0004.167] E> Cannot open partition kernel-bootctrl
[0004.168] W> tegrabl_get_kernel_bootctrl: failed to read primary bootctrl data
[0004.168] I> Loading kernel-bootctrl_b from partition
[0004.175] E> Cannot open partition kernel-bootctrl_b
[0004.180] W> tegrabl_get_kernel_bootctrl: failed to read recovery bootctrl data
[0004.187] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.194] I> ########## SD (0) boot ##########
[0004.199] I> Found sdcard
[0004.202] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.208] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.238] I> sdmmc SDR mode
[0004.252] I> -0 params source =
[0004.252] I> Already published: 00060000
[0004.253] I> Look for boot partition
[0004.253] I> Fallback: assuming 0th partition is boot partition
[0004.274] I> Loading extlinux.conf ...
[0004.274] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.303] I> L4T boot options
[0004.303] I> [1]: "primary kernel"
[0007.305] I> Continuing with default option: 1
[0007.305] I> Loading kernel sig file from rootfs ...
[0007.305] I> rootfs path: /sd/boot/Image.sig
[0014.266] I> Validate kernel ...
[0014.266] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0014.266] E> Stage2Signature validation failed with SHA2!!
[0014.267] C> OEM authentication of kernel header failed!
[0014.267] W> Failed to validate kernel binary (err=1077936152, fail=1)
[0014.268] W> Security fuse not burned, ignore validation failure
[0014.276] I> No kernel-dtb binary path
[0014.277] I> A/B: bin_type (38) slot 0
[0014.280] I> Loading kernel-dtb from partition
[0014.285] E> Cannot find partition kernel-dtb
[0014.289] E> Cannot open partition kernel-dtb
[0014.293] E> A/B loader failure
[0000.053] I> Ram repair fuse : 0x0
[0000.086] E> No bootable slot found
[0000.089] E> LOADER: Failed to get slot for boot chain from SMD.
[0000.095] E> LOADER: Failed to get storage info for binary 0 from loader.
[0000.101] E> LOADER: Failed to get info for binary 0 from loader.
[0000.107] C> LOADER: Could not read binary 0.
[0000.111] C> Fail to load mb1-bct bin
[0000.114] E> Task 24 failed (err: 0x1d540102)
[0000.118] E> Top caller module: LOADER, error module: AB_BOOTCTRL, reason: 0x02, aux_info: 0x01
[0000.127] I> MB1(1.5.1.6-t194-41334769-1740dd39) BIT boot status dump :
0000000000011111111110111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0000.157] I> Reset to recovery mode
Hi kmarx,
Are you using the devkit or custom board?
Please confirm the board is in Force Recovery Mode.
You should see information by lsusb when the board is in Force Recovery Mode.
To Determine Whether the Developer Kit Is in Force Recovery Mode
After you see your device in Force Recovery Mode by lsusb, you could refer to the following link to flash board by SDK Manager with Manual Setup.
Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation
Hi!
I’m using the dev kit.
I do not have a Linux machine and the lsusb command does not run on WSL - do you have a guide for Windows users?
Hi kmarx,
Sorry, we do not have solution for Windows Environment.
SDK Manager and related components are also only available on Linux.
So, please use the Linux Host PC for development.
I highly recommend dual boot with Ubuntu 18.04 for a Nano, but make sure you have enough disk space (flashing builds entire partitions on the host PC). If for some reason you can’t do this, there are some VMs which will work if you can get USB passthrough to work correctly even upon USB disconnect and reconnect. There is no support for this, it is up to the VM manufacturer to help configure USB correctly since they all differ. Dual boot with native Ubuntu 18.04 (20.04 for Xavier and newer) will save you a lot of headaches and work.
