I am using jetson nano 2gb for the first time…I downloaded the sd card image file (jetson nano 2gb)…formatted the card…and then flash the zipped folder containing image file to sd card uaing balenaEitcher
Now i connected mouse ,keyboard, and TV monitor (Sony Bravia)…then connected jetson nano to powersupply using micro usb
But nothing is coming on screen…nothing is gappening…just a black screen…showing HDMI1 at top left corner of the monitor and non signal at bottom right corner of the monitor
What is wrong…why is my jetson nano not booting up
I have the same problem, just received my Jetson Nano 2Gb, flashed sd card, connect to hdmi display but there is only Nvidia logo on the screen. I’m using CanaKit 3.5A Raspberry Pi 4 Power Supply (USB-C) and SAMSUNG: EVO Select 128GB MicroSDXC UHS-I U3 100MB/s Full HD & 4K UHD Memory Card
You two may have different cases but the debug method is the same.
Please dump the uart serial console log. Before dumping this log, remove the “quiet” keyword inside /boot/extlinux/extlinux.conf on your sdcard image rootfs.
For @nisar.bukhari, I would suggest you could also try other monitor too.
And for @kozinov.andrey, please make sure you are using 2GB sdcard image but not Nano-4GB sdcard image.
Yes, I downloaded 4Gb image. After installing 2Gb image everything works fine.
