Hi! I am a new user of Jetson Nano. I tried to do inference using Yolov9 and then I was given a low memory warning. The entire system was hanging and I could not shut down properly. After booting back up I am getting the following error screen:
Hi mmurshe8,
Are you using the devkit or custom board for Jetson Nano?
Is your board in high temperature now?
Please share the full serial console log for further check.
Hi KevinFFF,
Yes I am using NVIDIA Jetson Nano Developer Kit (B01). Jetpack is 4.6.3. The board should not be in high temperature. I am unable to run anything as I am not able to access the terminal. Could you please tell me how to get the full serial log? Thanks.
For Jetson Nano devkit, please refer to the following instruction to get serial console log.
Jetson Nano & NX Style - Serial Debug Console - JetsonHacks
