There is no output on the HDMI display.
Here you can find the serial port output. There is a boot loop reaching watchdog timeout:
“[0000.175] Power-up reason: ap watchdog timeout”
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x221ff9
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ...
[0000.281] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.302] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI ...
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.525] Bootloader DTB Load Address: 0x83000000
[0000.530] BoardID = 3448, SKU = 0x0
[0000.533] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.537] Nano-SD: checking PT table on QSPI ...
[0000.541] Loading NvTbootKernelDTB
[0000.607] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.680] Kernel DTB Load Address: 0x83100000
[0000.685] BoardID = 3448, SKU = 0x0
[0000.688] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.692] Nano-SD: checking PT table on QSPI ...
[0000.698] Loading cboot binary
[0000.814] Verifying EBT in OdmNonSecureSBK mode
[0000.855] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.862] Bootloader downloaded successfully.
[0000.866] BoardID = 3448, SKU = 0x0
[0000.870] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.873] Nano-SD: checking PT table on QSPI ...
[0000.878] PT: Partition NCT NOT found !
[0000.882] Warning: Find Partition via PT Failed
[0000.886] Next binary entry address: 0x92c00258
[0000.891] BoardId: 3448
[0000.895] Overriding pmu board id with proc board id
[0000.900] Display board id is not available
[0000.904] BoardID = 3448, SKU = 0x0
[0000.907] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.911] Nano-SD: checking PT table on QSPI ...
[0001.016] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.073] /bpmp deleted
[0001.075] SC7EntryFw header found loaded at 0xff700000
[0001.271] OVR2 PMIC
[0001.272] Bpmp FW successfully loaded
[0001.276] BoardID = 3448, SKU = 0x0
[0001.279] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.283] Nano-SD: checking PT table on QSPI ...
[0001.288] WB0 init successfully at 0xff780000
[0001.293] Set NvDecSticky Bits
[0001.296] GSC2 address ff53fffc value c0edbbcc
[0001.302] GSC MC Settings done
[0001.305] BoardID = 3448, SKU = 0x0
[0001.309] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.312] Nano-SD: checking PT table on QSPI ...
[0001.318] TOS Image length 53680
[0001.321] Monitor size 53680
[0001.324] OS size 0
[0001.339] Secure Os AES-CMAC Verification Success!
[0001.343] TOS image cipher info: plaintext
[0001.347] Loading and Validation of Secure OS Successful
[0001.363] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.368] NvTbootPackSdramParams: start.
[0001.373] NvTbootPackSdramParams: done.
[0001.377] Tegraboot started after 51871 us
[0001.381] Basic modules init took 886444 us
[0001.385] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.390] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.396] Next stage binary read took 102861 us
[0001.400] Carveout took -126358 us
[0001.403] CPU initialization took 495393 us
[0001.407] Total time taken by TegraBoot 1358340 us
[0001.412] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 14:33:23, Jan 15 2021
ERROR: Error initializing runtime service trusty_fast
[0001.534] RamCode = 0
[0001.539] LPDDR4 Training: Read DT: Number of tables = 2
[0001.544] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.557] EMC Training Successful
[0001.560] 408000 not found in DVFS table
[0001.566] RamCode = 0
[0001.570] DT Write: emc-table@204000 succeeded
[0001.575] DT Write: emc-table@1600000 succeeded
[0001.580] LPDDR4 Training: Write DT: Number of tables = 2
[0001.626]
[0001.627] Debug Init done
[0001.630] Marked DTB cacheable
[0001.633] Bootloader DTB loaded at 0x83000000
[0001.638] Marked DTB cacheable
[0001.640] Kernel DTB loaded at 0x83100000
[0001.644] DeviceTree Init done
[0001.657] Pinmux applied successfully
[0001.662] gicd_base: 0x50041000
[0001.665] gicc_base: 0x50042000
[0001.668] Interrupts Init done
[0001.672] Using base:0x60005090 & irq:208 for tick-timer
[0001.678] Using base:0x60005098 for delay-timer
[0001.682] platform_init_timer: DONE
[0001.685] Timer(tick) Init done
[0001.689] osc freq = 38400 khz
[0001.693]
[0001.694] Welcome to L4T Cboot
[0001.697]
[0001.698] Cboot Version: 00.00.2018.01-t210-39562017
[0001.703] calling constructors
[0001.706] initializing heap
[0001.709] initializing threads
[0001.712] initializing timers
[0001.715] creating bootstrap completion thread
[0001.719] top of bootstrap2()
[0001.722] CPU: ARM Cortex A57
[0001.725] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.730] initializing platform
[0001.737] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.742] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.746] Macronix QSPI chip present
[0001.750] SPI device register
[0001.753] init boot device
[0001.755] allocating memory for boot device(SPI)
[0001.760] registering boot device
[0001.768] QSPI bdev is already initialized
[0001.772] Enable APE clock
[0001.775] Un-powergate APE partition
[0001.778] of_register: registering tegra_udc to of_hal
[0001.783] of_register: registering inv20628-driver to of_hal
[0001.789] of_register: registering ads1015-driver to of_hal
[0001.794] of_register: registering lp8557-bl-driver to of_hal
[0001.800] of_register: registering bq2419x_charger to of_hal
[0001.806] of_register: registering bq27441_fuel_gauge to of_hal
[0001.817] gpio framework initialized
[0001.821] of_register: registering tca9539_gpio to of_hal
[0001.826] of_register: registering tca9539_gpio to of_hal
[0001.832] of_register: registering i2c_bus_driver to of_hal
[0001.837] of_register: registering i2c_bus_driver to of_hal
[0001.843] of_register: registering i2c_bus_driver to of_hal
[0001.848] pmic framework initialized
[0001.852] of_register: registering max77620_pmic to of_hal
[0001.857] regulator framework initialized
[0001.861] of_register: registering tps65132_bl_driver to of_hal
[0001.867] initializing target
[0001.873] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.881] board ID = D78, board SKU = 0
[0001.885] Skipping Z3!
[0001.889] fixed regulator driver initialized
[0001.907] initializing OF layer
[0001.910] NCK carveout not present
[0001.914] Skipping dts_overrides
[0001.918] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.935] I2C Bus Init done
[0001.937] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.948] I2C Bus Init done
[0001.950] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.961] I2C Bus Init done
[0001.963] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.974] I2C Bus Init done
[0001.976] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.987] I2C Bus Init done
[0001.990] of_children_init: Ops found for compatible string maxim,max77620
[0002.000] max77620_init using irq 118
[0002.005] register 'maxim,max77620' pmic
[0002.009] gpio_driver_register: register 'max77620-gpio' driver
[0002.015] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.026] I2C Bus Init done
[0002.029] NCK carveout not present
[0002.039] Find /i2c@7000c000's alias i2c0
[0002.043] get eeprom at 1-a0, size 256, type 0
[0002.052] Find /i2c@7000c500's alias i2c2
[0002.056] get eeprom at 3-a0, size 256, type 0
[0002.060] get eeprom at 3-ae, size 256, type 0
[0002.065] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.070] I2C slave not started
[0002.073] I2C write failed
[0002.076] Writing offset failed
[0002.079] eeprom_init: EEPROM read failed
[0002.083] pm_ids_update: eeprom init failed
[0002.087] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.117] pm_ids_update: The pm board id is 3448-0000-200
[0002.124] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.132] pm_ids_update: pm id update successful
[0002.137] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.167] pm_ids_update: The pm board id is 3449-0000-200
[0002.173] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.181] pm_ids_update: pm id update successful
[0002.211] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.217] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.225] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.231] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.239] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:1d:8e
[0002.245] Plugin Manager: Parse ODM data 0x000a4000
[0002.258] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.273] Find /i2c@7000c000's alias i2c0
[0002.276] get eeprom at 1-a0, size 256, type 0
[0002.285] Find /i2c@7000c500's alias i2c2
[0002.289] get eeprom at 3-a0, size 256, type 0
[0002.294] get eeprom at 3-ae, size 256, type 0
[0002.298] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.303] I2C slave not started
[0002.306] I2C write failed
[0002.309] Writing offset failed
[0002.312] eeprom_init: EEPROM read failed
[0002.316] pm_ids_update: eeprom init failed
[0002.320] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.350] pm_ids_update: The pm board id is 3448-0000-200
[0002.356] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.363] pm_ids_update: pm id update successful
[0002.368] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.398] pm_ids_update: The pm board id is 3449-0000-200
[0002.404] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.411] pm_ids_update: pm id update successful
[0002.442] Add serial number:1421919044435 as DT property
[0002.449] Applying platform configs
[0002.456] platform-init is not present. Skipping
[0002.461] calling apps_init()
[0002.466] Couldn't find GPT header
[0002.471] Proceeding to Cold Boot
[0002.474] starting app android_boot_app
[0002.478] Device state: unlocked
[0002.481] display console init
[0002.489] could not find regulator
[0002.493] hdmi cable connected
[0002.508] edid read success
[0002.511] width = 640, height = 480, frequency = 25174825
[0002.516] width = 1920, height = 1080, frequency = 148500000
[0002.522] Best mode Width = 640,DT entry for leds-pwm not found
[0002.531] Height = 480, freq = 25174825
[0002.537] tmds-config node not found
[0002.541] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.555] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.563] could not find regulator
[0002.566] could not find regulator
[0002.570] could not find regulator
[0002.598] using default cmu settings
[0002.602] dc_hdmi_enable, starting HDMI initialisation
[0002.608] dc_hdmi_enable, HDMI initialisation complete
[0002.613] list and configure display window
[0002.618] display console init completed
[0002.625] subnode volume_up is not found !
[0002.629] subnode back is not found !
[0002.633] subnode volume_down is not found !
[0002.637] subnode menu is not found !
[0002.641] Gpio keyboard init success
[0002.721] found decompressor handler: lz4-legacy
[0002.735] decompressing blob (type 1)...
[0002.802] load_bmp_blob: panelresolution=480 type=0
[0002.877] decompressor handler not found
[0002.881] load_firmware_blob: Firmware blob loaded, entries=2
[0002.886] XUSB blob version 0 size 124416 @ 0x92dee28c
[0002.892] -------> se_aes_verify_sbk_clear: 747
[0002.897] se_aes_verify_sbk_clear: Error
[0002.901] SE operation failed
[0002.904] bl_battery_charging: connected to external power supply
[0002.916] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.923] MSC Partition not found
[0002.929] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.937] USP partition read failed!
[0002.940] blob_init: blob-partition USP header read failed
[0002.946] android_boot Unable to update recovery partition
[0002.951] kfs_getpartname: name = LNX
[0002.955] Loading kernel from LNX
[0002.964] Found 19 BFS partitions in "spiflash0"
[0003.286] load kernel from storage
[0003.292] decompressor handler not found
[0003.559] Successfully loaded kernel and ramdisk images
[0003.564] board ID = D78, board SKU = 0
[0003.569] sdmmc node status = okay
[0003.572] sdcard instance = 0
[0003.575] sdcard gpio handle 0x5b
[0003.578] sdcard gpio pin 0xc9
[0003.581] sdcard gpio flags 0x0
[0003.585] vmmc-supply 0x9e
[0003.587] cd_gpio_pin = 201
[0003.590] pin_state = 0
[0003.592] Found sdcard
[0003.594] SD-card IS present ...
[0003.597] load_and_boot_kernel: SD card detected OK
[0003.603] load_bmp_blob: panelresolution=480 type=0
[0003.677] display bmp image done
[0003.680] NCK carveout not present
[0003.683] Skipping dts_overrides
[0003.686] NCK carveout not present
[0003.696] Find /i2c@7000c000's alias i2c0
[0003.700] get eeprom at 1-a0, size 256, type 0
[0003.709] Find /i2c@7000c500's alias i2c2
[0003.713] get eeprom at 3-a0, size 256, type 0
[0003.717] get eeprom at 3-ae, size 256, type 0
[0003.721] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.727] I2C slave not started
[0003.730] I2C write failed
[0003.732] Writing offset failed
[0003.735] eeprom_init: EEPROM read failed
[0003.739] pm_ids_update: eeprom init failed
[0003.744] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.774] pm_ids_update: The pm board id is 3448-0000-200
[0003.780] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0003.789] pm_ids_update: pm id update successful
[0003.793] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.823] pm_ids_update: The pm board id is 3449-0000-200
[0003.830] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0003.838] pm_ids_update: pm id update successful
[0003.868] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.874] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.882] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.888] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.896] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:1d:8e
[0003.902] Plugin Manager: Parse ODM data 0x000a4000
[0003.915] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.923] Add serial number:1421919044435 as DT property
[0003.932] "bpmp" doesn't exist, creating
[0003.938] Updated bpmp info to DTB
[0003.942] Updated initrd info to DTB
[0003.946] "proc-board" doesn't exist, creating
[0003.952] Updated board info to DTB
[0003.955] "pmu-board" doesn't exist, creating
[0003.961] Updated board info to DTB
[0003.965] "display-board" doesn't exist, creating
[0003.971] Updated board info to DTB
[0003.974] "reset" doesn't exist, creating
[0003.979] Updated reset info to DTB
[0003.982] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_su
[0004.021] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.027] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.040] Updated bootarg info to DTB
[0004.044] Adding uuid 0000000164441643080000000f008340 to DT
[0004.049] Adding ek[0000.162] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.167] Processing in cold boot mode Bootloader 2
[0000.172] A02 Bootrom Patch rev = 1023
[0000.176] Power-up reason: ap watchdog timeout
[0000.180] No Battery Present
[0000.182] pmic max77620 reset reason
[0000.186] pmic max77620 NVERC : 0x0
[0000.189] RamCode = 0
[0000.192] Platform has DDR4 type RAM
[0000.195] max77620 disabling SD1 Remote Sense
[0000.199] Setting DDR voltage to 1125mv
[0000.203] Serial Number of Pmic Max77663: 0x221ff9
[0000.211] Entering ramdump check
[0000.214] Get RamDumpCarveOut = 0x0
[0000.218] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.223] Last reboot was clean, booting normally!
[0000.228] Sdram initialization is successful
[0000.232] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.238] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.244] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.250] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.256] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.262] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.268] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.274] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.294] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.301] Platform-DebugCarveout: 0
[0000.304] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.310] Non secure mode, and RB not enabled.
[0000.314] BoardID = 3448, SKU = 0x0
[0000.318] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.322] Nano-SD: checking PT table on QSPI ...
[0000.326] Read PT from (2:0)
[0000.354] Using BFS PT to query partitions
[0000.361] Loading Tboot-CPU binary
[0000.415] Verifying TBC in OdmNonSecureSBK mode
[0000.426] Bootloader load address is 0xa0000000, entry address is 0xa0000258
Can someone help me to fix the boot process? ( increase watchdog timeout possible, or disable boot time watchdog?)
I have access over the “recovery mode” console on the USB cable from host PC.
( sdkmanager is not working for devkit device, it is only for the production module )
But, Yes, I can flash it over the “recovery mode” with the L4T flash.sh command.
Recovery rom "kicks’ the watchdog during the recovery flashing and all is fine.
Here is the output on the host PC during the flash.sh command
Sdkmanager is working for both sdcard and production module. Where did yo get such info that sdkmanger not working for devkit device?
And actually this is contradict to your previous comment because sdkmanager is using flash.sh too.
Although you said the flashing get kicked… but I see flash process get completed… What are you trying to say here?
Are you trying to say the boot process has a watchdog kicks?
Could you remove the “-r” in your flash.sh command to do full flash?
the issue is still there after reflashing without -r option.
No I do not have another Jetson Nano devkit A02 to test and now it is being delivered B01 revision. If you have A02 device, please paste the serial console output from boot process.
With kicking the watchdog I meant: keeping the watchdog timer from expiring.
Here is the output of flash.sh command without -r option:
(from host PC via USB cable in recovery mode)
There is a more verbose output on serial console during the flashing of version L4T 32.2.3
Serial port output during flash.sh with L4T shows clearly that the watchdog is being cleared (expire timer reset, watchdog kicked,etc) - each 30 seconds.
Which makes me wonder why after 3-4 seconds after the board normal start-up watchdog is expiring. Watchdog timer exiration should not have happened so early, right? It looks like a bug in watchdog timer expiration period initial setup (period should be longer than 3-4sec) on normal boot. Is there any option to configure the watchdog expiration timer on early boot - Tegra boot/c-boot?
[0018.570] Enabled early print
[0018.572] [TegraBoot] (version 00.00.2018.01-l4t-e5cfc6a7)
[0018.578] Processing in recovery mode
[0018.581] A02 Bootrom Patch rev = 1023
[0018.585] Power-up reason: pmc por
[0018.588] Established communication link with host
[0019.593] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0019.601] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0019.609] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
[0023.294] Odmdata from BCT: 0x00084000
[0023.298] DebugPort= 0x3
[0023.307] BoardId read from EEPROM/NCT: 3448
[0023.311] BoardID = 3448, SKU = 0x0
[0023.338] NvTbootInit_Porg: Setting GPIO_A6 for HDMI ...
[0023.343] No Battery Present
[0023.346] RamCode = 0
[0023.348] Platform has DDR4 type RAM
[0023.352] max77620 disabling SD1 Remote Sense
[0023.356] Setting DDR voltage to 1125mv
[0023.360] Serial Number of Pmic Max77663: 0x221ff9
[0023.368] Entering ramdump check
[0023.371] Get RamDumpCarveOut = 0x0
[0023.374] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0023.379] Last reboot was clean, booting normally!
[0023.384] Sdram initialization is successful
[0023.388] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0023.394] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0023.400] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0023.406] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0023.412] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0023.417] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0023.423] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0023.429] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0023.445] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0023.451] Platform-DebugCarveout: 0
[0023.455] Downloaded BCT successfully
[0023.660] Downloaded Bootloader successfully
[0023.714] Downloaded rp1 successfully
[0023.744] MAX77620_GPIO5 configured
[0023.747] CPU power rail is up
[0023.750] CPU clock enabled
[0023.754] Performing RAM repair
[0023.757] Updating A64 Warmreset Address to 0x92c002e9
[0023.763] Enable APE clock/reset
[0023.766] Error in NvTbootGetTOSBinaryLength: 0x11 !
[0023.771] Loading Secure OS image failed.
[0023.775] Set NvDecSticky Bits
[0023.778] GSC2 address ff53fffc value c0edbbcc
[0023.785] GSC MC Settings done
[0023.789] Next binary entry address: 0x92c00258
[0023.793] BoardId: 3448
[0023.796] Overriding pmu board id with proc board id
[0023.801] Display board id is not available
[0023.805] Starting CPU & Halting co-processor
[0024.387]
[0024.388] Debug Init done
[0024.392] Marked DTB cacheable
[0024.394] Bootloader DTB loaded at 0x83000400
[0024.399] DeviceTree Init done
[0024.411] Pinmux applied successfully
[0024.415] gicd_base: 0x50041000
[0024.418] gicc_base: 0x50042000
[0024.421] Interrupts Init done
[0024.425] Using base:0x60005090 & irq:208 for tick-timer
[0024.431] Using base:0x60005098 for delay-timer
[0024.435] platform_init_timer: DONE
[0024.439] Timer(tick) Init done
[0024.442] osc freq = 38400 khz
[0024.446]
[0024.447] welcome to cboot
[0024.450]
[0024.451] Cboot Version: 00.00.2018.01-t210-21e03500
[0024.456] calling constructors
[0024.459] initializing heap
[0024.462] initializing threads
[0024.465] initializing timers
[0024.468] creating bootstrap completion thread
[0024.472] top of bootstrap2()
[0024.475] CPU: ARM Cortex A57
[0024.478] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0024.482] initializing platform
[0024.486] Scratch reg 37 & 271 initial value set..
[0024.492] cboot:secure-pmc present
[0024.495] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0024.500] ID LSB = 0x36, ID-CFI len = 194 bytes
[0024.504] Macronix QSPI chip present
[0024.508] SPI device register
[0024.511] init boot device
[0024.513] allocating memory for boot device(SPI)
[0024.518] registering boot device
[0024.527] sdmmc node status = okay
[0024.530] sdcard instance = 0
[0024.533] sdcard gpio handle 0x56
[0024.536] sdcard gpio pin 0xc9
[0024.539] sdcard gpio flags 0x0
[0024.542] vmmc-supply 0x99
[0024.545] Instance: 0
[0024.547] Allocating memory for context
[0024.551] enabling clock
[0024.553] sd card init
[0024.556] Check card present and stable
[0024.559] Send command 0
[0024.664] Send command 3
[0024.669] Set RCA for the card
[0024.671] Query card specific data by command 9
[0024.678] Parse CSD data
[0024.680] Send command 7
[0024.691] Calling sd device register
[0024.694] Init sdcard
[0024.696] Allocating memory for boot device
[0024.700] Registering user device
[0024.714] of_register: registering tegra_udc to of_hal
[0024.719] of_register: registering tegra_udc to of_hal
[0024.724] of_register: registering inv20628-driver to of_hal
[0024.729] of_register: registering ads1015-driver to of_hal
[0024.735] of_register: registering lp8557-bl-driver to of_hal
[0024.741] of_register: registering bq2419x_charger to of_hal
[0024.746] of_register: registering cpc to of_hal
[0024.751] of_register: registering bq27441_fuel_gauge to of_hal
[0024.762] gpio framework initialized
[0024.766] of_register: registering tca9539_gpio to of_hal
[0024.771] of_register: registering tca9539_gpio to of_hal
[0024.776] of_register: registering i2c_bus_driver to of_hal
[0024.782] of_register: registering i2c_bus_driver to of_hal
[0024.788] of_register: registering i2c_bus_driver to of_hal
[0024.793] of_register: registering i2c_bus_driver to of_hal
[0024.799] pmic framework initialized
[0024.802] of_register: registering max77620_pmic to of_hal
[0024.808] regulator framework initialized
[0024.812] of_register: registering tps65132_bl_driver to of_hal
[0024.818] initializing target
[0024.823] gpio_driver_register: register 'tegra_gpio_driver' driver
[0024.832] fixed regulator driver initialized
[0024.849] initializing OF layer
[0024.853] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0024.869] I2C Bus Init done
[0024.872] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0024.882] I2C Bus Init done
[0024.885] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0024.895] I2C Bus Init done
[0024.898] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0024.908] I2C Bus Init done
[0024.911] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0024.921] I2C Bus Init done
[0024.923] of_children_init: Ops found for compatible string maxim,max77620
[0024.934] max77620_init using irq 118
[0024.939] register 'maxim,max77620' pmic
[0024.943] gpio_driver_register: register 'max77620-gpio' driver
[0024.949] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0024.960] I2C Bus Init done
[0024.963] Applying platform configs
[0024.970] platform-init is not present. Skipping
[0024.974] calling apps_init()
[0025.002] Found 1 GPT partitions in "sd0"
[0025.006] Proceeding to flashing Server
[0025.010] usbdcd_reinit Initialize driver to use already enumerated device
[0025.017] nv3p_priv_usbf_open USB configuration success
[0025.114] Writing GPT partition
[0025.118] Erasing Boot device
[0025.121] device_write_gpt: Erasing boot device spiflash0
[0041.467] Erasing Storage Device
[0041.470] Writing protective mbr
[0041.481] Writing primary GPT
[0041.537] Writing secondary GPT
[0041.566] Found 14 GPT partitions in "sd0"
[0041.571] Writing NVC partition
[0052.075] partition NVC write successful.
[0052.084] Writing PT partition
[0052.333] partition PT write successful.
[0052.338] Writing NVC_R partition
[0054.928] max77620_clear_syswdt clearing watchdog
[0062.864] partition NVC_R write successful.
[0062.870] Writing VER partition
[0063.147] partition VER write successful.
[0063.152] Writing APP partition
[0084.928] max77620_clear_syswdt clearing watchdog
[0114.928] max77620_clear_syswdt clearing watchdog
[0144.928] max77620_clear_syswdt clearing watchdog
[0174.928] max77620_clear_syswdt clearing watchdog
[0204.929] max77620_clear_syswdt clearing watchdog
[0234.929] max77620_clear_syswdt clearing watchdog
[0264.929] max77620_clear_syswdt clearing watchdog
[0294.929] max77620_clear_syswdt clearing watchdog
[0324.929] max77620_clear_syswdt clearing watchdog
[0354.929] max77620_clear_syswdt clearing watchdog
[0384.930] max77620_clear_syswdt clearing watchdog
[0414.930] max77620_clear_syswdt clearing watchdog
[0444.930] max77620_clear_syswdt clearing watchdog
[0474.930] max77620_clear_syswdt clearing watchdog
[0479.980] partition APP write successful.
[0479.986] Writing TBC partition
[0480.031] partition TBC write successful.
[0480.036] Writing RP1 partition
[0480.100] partition RP1 write successful.
[0480.106] Writing EBT partition
[0480.203] partition EBT write successful.
[0480.209] Writing WB0 partition
[0480.248] partition WB0 write successful.
[0480.253] Writing BPF partition
[0480.290] partition BPF write successful.
[0480.295] Writing TOS partition
[0480.340] partition TOS write successful.
[0480.345] Writing DTB partition
[0480.409] partition DTB write successful.
[0480.414] Writing LNX partition
[0480.493] partition LNX write successful.
[0480.498] Writing EKS partition
[0480.540] partition EKS write successful.
[0480.545] Writing BMP partition
[0480.630] partition BMP write successful.
[0480.636] Writing RP4 partition
[0480.704] partition RP4 write successful.
[0480.718] Writing BCT partition
[0487.369] partition BCT write successful.
[0487.381] Scratch 37 initial value set..
[0487.385] Change state to cold boot mode
[0000.158] [TegraBoot] (version 00.00.2018.01-l4t-7da7a580)
[0000.164] Processing in cold boot mode Bootloader 2
[0000.168] A02 Bootrom Patch rev = 1023
[0000.172] Power-up reason: software reset
[0000.176] No Battery Present
[0000.178] pmic max77620 reset reason
[0000.182] pmic max77620 NVERC : 0x0
[0000.185] RamCode = 0
[0000.187] Platform has DDR4 type RAM
[0000.191] max77620 disabling SD1 Remote Sense
[0000.195] Setting DDR voltage to 1125mv
[0000.199] Serial Number of Pmic Max77663: 0x221ff9
[0000.206] Entering ramdump check
[0000.209] Get RamDumpCarveOut = 0x0
[0000.213] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.218] Last reboot was clean, booting normally!
[0000.222] Sdram initialization is successful
[0000.226] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.233] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.238] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.244] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.250] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.256] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.262] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.268] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.284] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.290] Platform-DebugCarveout: 0
[0000.293] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.299] Non secure mode, and RB not enabled.
[0000.367] Csd NumOfBlocks=60579840
[0000.372] Set High speed to 1
[0000.377] Using GPT Primary to query partitions
[0000.382] Loading Tboot-CPU binary
[0000.395] Verifying TBC in OdmNonSecureSBK mode
[0000.405] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.412] Bootloader downloaded successfully.
[0000.416] Downloaded Tboot-CPU binary to 0xa0000258
[0000.421] MAX77620_GPIO5 configured
[0000.424] CPU power rail is up
[0000.427] CPU clock enabled
[0000.431] Performing RAM repair
[0000.434] Updating A64 Warmreset Address to 0xa00002e9
[0000.439] Loading NvTbootBootloaderDTB
[0000.475] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.540] Bootloader DTB Load Address: 0x83000000
[0000.545] Loading NvTbootKernelDTB
[0000.580] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.645] Kernel DTB Load Address: 0x83100000
[0000.650] Loading cboot binary
[0000.694] Verifying EBT in OdmNonSecureSBK mode
[0000.736] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.743] Bootloader downloaded successfully.
[0000.748] Next binary entry address: 0x92c00258
[0000.752] BoardId: 3448
[0000.757] Overriding pmu board id with proc board id
[0000.761] Display board id is not available
[0000.803] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.855] /bpmp deleted
[0000.857] SC7EntryFw header found loaded at 0xff700000
[0001.045] OVR2 PMIC
[0001.047] Bpmp FW successfully loaded
[0001.051] WB0 init successfully at 0xff780000
[0001.055] Set NvDecSticky Bits
[0001.059] GSC2 address ff53fffc value c0edbbcc
[0001.065] GSC MC Settings done
[0001.069] TOS Image length 53680
[0001.072] Monitor size 53680
[0001.074] OS size 0
[0001.083] Secure Os AES-CMAC Verification Success!
[0001.088] TOS image cipher info: plaintext
[0001.092] Loading and Validation of Secure OS Successful
[0001.108] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.112] NvTbootPackSdramParams: start.
[0001.117] NvTbootPackSdramParams: done.
[0001.121] Tegraboot started after 86841 us
[0001.125] Basic modules init took 697761 us
[0001.129] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.134] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.141] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.147] Storage Device Read Time = 164 ms, Read Size = 2226 KB
[0001.152] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.158] Next stage binary read took 37937 us
[0001.162] Carveout took -49601 us
[0001.165] CPU initialization took 375413 us
[0001.169] Total time taken by TegraBoot 1061510 us
[0001.174] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 13:38:45, Nov 5 2019
[0001.296] RamCode = 0
[0001.301] LPDDR4 Training: Read DT: Number of tables = 2
[0001.306] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.319] EMC Training Successful
[0001.322] 408000 not found in DVFS table
[0001.328] RamCode = 0
[0001.331] DT Write: emc-table@204000 succeeded
[0001.337] DT Write: emc-table@1600000 succeeded
[0001.341] LPDDR4 Training: Write DT: Number of tables = 2
[0001.382]
[0001.383] Debug Init done
[0001.386] Marked DTB cacheable
[0001.389] Bootloader DTB loaded at 0x83000000
[0001.394] Marked DTB cacheable
[0001.397] Kernel DTB loaded at 0x83100000
[0001.401] DeviceTree Init done
[0001.412] Pinmux applied successfully
[0001.417] gicd_base: 0x50041000
[0001.420] gicc_base: 0x50042000
[0001.423] Interrupts Init done
[0001.427] Using base:0x60005090 & irq:208 for tick-timer
[0001.432] Using base:0x60005098 for delay-timer
[0001.437] platform_init_timer: DONE
[0001.440] Timer(tick) Init done
[0001.444] osc freq = 38400 khz
[0001.448]
[0001.449] welcome to cboot
[0001.452]
[0001.453] Cboot Version: 00.00.2018.01-t210-21e03500
[0001.458] calling constructors
[0001.461] initializing heap
[0001.464] initializing threads
[0001.467] initializing timers
[0001.469] creating bootstrap completion thread
[0001.474] top of bootstrap2()
[0001.477] CPU: ARM Cortex A57
[0001.480] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.484] initializing platform
[0001.487] Scratch reg 37 & 271 initial value set..
[0001.494] cboot:secure-pmc present
[0001.497] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.502] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.506] Macronix QSPI chip present
[0001.510] SPI device register
[0001.512] init boot device
[0001.515] allocating memory for boot device(SPI)
[0001.520] registering boot device
[0001.529] sdmmc node status = okay
[0001.532] sdcard instance = 0
[0001.535] sdcard gpio handle 0x56
[0001.538] sdcard gpio pin 0xc9
[0001.541] sdcard gpio flags 0x0
[0001.544] vmmc-supply 0x99
[0001.547] Instance: 0
[0001.549] Allocating memory for context
[0001.553] enabling clock
[0001.555] sd card init
[0001.557] Check card present and stable
[0001.561] Send command 0
[0001.578] Send command 3
[0001.582] Set RCA for the card
[0001.585] Query card specific data by command 9
[0001.591] Parse CSD data
[0001.594] Send command 7
[0001.604] Calling sd device register
[0001.608] Init sdcard
[0001.610] Allocating memory for boot device
[0001.614] Registering user device
[0001.627] Enable APE clock
[0001.630] Un-powergate APE partition
[0001.633] of_register: registering tegra_udc to of_hal
[0001.638] of_register: registering tegra_udc to of_hal
[0001.643] of_register: registering inv20628-driver to of_hal
[0001.649] of_register: registering ads1015-driver to of_hal
[0001.654] of_register: registering lp8557-bl-driver to of_hal
[0001.660] of_register: registering bq2419x_charger to of_hal
[0001.666] of_register: registering cpc to of_hal
[0001.670] of_register: registering bq27441_fuel_gauge to of_hal
[0001.682] gpio framework initialized
[0001.685] of_register: registering tca9539_gpio to of_hal
[0001.691] of_register: registering tca9539_gpio to of_hal
[0001.696] of_register: registering i2c_bus_driver to of_hal
[0001.701] of_register: registering i2c_bus_driver to of_hal
[0001.707] of_register: registering i2c_bus_driver to of_hal
[0001.713] of_register: registering i2c_bus_driver to of_hal
[0001.718] pmic framework initialized
[0001.722] of_register: registering max77620_pmic to of_hal
[0001.727] regulator framework initialized
[0001.731] of_register: registering tps65132_bl_driver to of_hal
[0001.737] initializing target
[0001.743] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.751] fixed regulator driver initialized
[0001.768] initializing OF layer
[0001.771] NCK carveout not present
[0001.774] Skipping dts_overrides
[0001.779] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.795] I2C Bus Init done
[0001.798] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.808] I2C Bus Init done
[0001.811] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.821] I2C Bus Init done
[0001.823] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.834] I2C Bus Init done
[0001.836] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.847] I2C Bus Init done
[0001.849] of_children_init: Ops found for compatible string maxim,max77620
[0001.859] max77620_init using irq 118
[0001.864] register 'maxim,max77620' pmic
[0001.869] gpio_driver_register: register 'max77620-gpio' driver
[0001.875] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.885] I2C Bus Init done
[0001.889] NCK carveout not present
[0001.892] shim_invoke: No NCT, Calling dts updates
[0001.903] Find /i2c@7000c000's alias i2c0
[0001.907] get eeprom at 1-a0, size 256, type 0
[0001.916] Find /i2c@7000c500's alias i2c2
[0001.920] get eeprom at 3-a0, size 256, type 0
[0001.924] get eeprom at 3-ae, size 256, type 0
[0001.929] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.934] I2C slave not started
[0001.937] I2C write failed
[0001.940] Writing offset failed
[0001.943] eeprom_init: EEPROM read failed
[0001.947] pm_ids_update: eeprom init failed
[0001.951] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.981] pm_ids_update: The pm board id is 3448-0000-200
[0001.987] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0001.995] pm_ids_update: pm id update successful
[0002.000] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.030] pm_ids_update: The pm board id is 3449-0000-200
[0002.036] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.044] pm_ids_update: pm id update successful
[0002.074] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.080] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.088] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.094] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.103] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:1d:8e
[0002.109] Plugin Manager: Parse ODM data 0x00084000
[0002.119] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.141] Find /i2c@7000c000's alias i2c0
[0002.144] get eeprom at 1-a0, size 256, type 0
[0002.153] Find /i2c@7000c500's alias i2c2
[0002.157] get eeprom at 3-a0, size 256, type 0
[0002.161] get eeprom at 3-ae, size 256, type 0
[0002.166] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.171] I2C slave not started
[0002.174] I2C write failed
[0002.177] Writing offset failed
[0002.180] eeprom_init: EEPROM read failed
[0002.184] pm_ids_update: eeprom init failed
[0002.188] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.218] pm_ids_update: The pm board id is 3448-0000-200
[0002.224] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.231] pm_ids_update: pm id update successful
[0002.236] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.266] pm_ids_update: The pm board id is 3449-0000-200
[0002.273] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.279] pm_ids_update: pm id update successful
[0002.310] Chip UID is 0000000164441643080000000f008340
[0002.315] Add serial number:14219190444350408300 as DT property
[0002.323] Applying platform configs
[0002.330] platform-init is not present. Skipping
[0002.334] calling apps_init()
[0002.354] Found 14 GPT partitions in "sd0"
[0002.358] Proceeding to Cold Boot
[0002.361] starting app android_boot_app
[0002.365] Device state: unlocked
[0002.368] display console init
[0002.377] could not find regulator
[0002.400] hdmi cable not connected
[0002.403] is_hdmi_needed: HDMI not connected, returning false
[000[0002.413] DT entry for leds-pwm not found
2.409] hdmi is not connected
[0002.419] sor0 is not supported
[0002.422] display_console_init: no valid display out_type
[0002.430] subnode volume_up is not found !
[0002.434] subnode back is not found !
[0002.438] subnode volume_down is not found !
[0002.442] subnode menu is not found !
[0002.446] Gpio keyboard init success
[0002.490] found decompressor handler: lz4-legacy
[0002.504] decompressing blob (type 1)...
[0002.538] display_resolution: No display init
[0002.542] Failed to retrieve display resolution
[0002.546] Could not load/initialize BMP blob...ignoring
[0002.598] decompressor handler not found
[0002.602] load_firmware_blob: Firmware blob loaded, entries=2
[0002.607] se_aes_verify_sbk_clear: Error
[0002.611] bl_battery_charging: connected to external power supply
[0002.619] xusb is supported
[0002.625] error while finding nvidia,portmap
[0002.630] could not find regulator
[0003.133] xusb blob version 0 size 124416
[0003.137] firmware size 124416
[0003.142] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.149] xhci0: 64 bytes context size, 32-bit DMA
[0003.189] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.209] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.859] uhub0: 9 ports with 9 removable, self powered
[0000.163] [TegraBoot] (version 00.00.2018.01-l4t-7da7a580)
[0000.169] Processing in cold boot mode Bootloader 2
[0000.173] A02 Bootrom Patch rev = 1023
[0000.177] Power-up reason: ap watchdog timeout
[0000.181] No Battery Present
[0000.184] pmic max77620 reset reason
[0000.187] pmic max77620 NVERC : 0x0
[0000.190] RamCode = 0
[0000.193] Platform has DDR4 type RAM
[0000.196] max77620 disabling SD1 Remote Sense
[0000.201] Setting DDR voltage to 1125mv
[0000.205] Serial Number of Pmic Max77663: 0x221ff9
[0000.213] Entering ramdump check
[0000.216] Get RamDumpCarveOut = 0x0
[0000.219] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.224] Last reboot was clean, booting normally!
[0000.229] Sdram initialization is successful
[0000.233] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.239] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.245] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.252] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.258] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.264] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.270] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.276] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.296] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.302] Platform-DebugCarveout: 0
[0000.305] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.311] Non secure mode, and RB not enabled.
[0000.380] Csd NumOfBlocks=60579840
[0000.386] Set High speed to 1
[0000.391] Using GPT Primary to query partitions
[0000.396] Loading Tboot-CPU binary
[0000.409] Verifying TBC in OdmNonSecureSBK mode
[0000.420] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.427] Bootloader downloaded successfully.
[0000.431] Downloaded Tboot-CPU binary to 0xa0000258
[0000.436] MAX77620_GPIO5 configured
[0000.440] CPU power rail is up
[0000.443] CPU clock enabled
[0000.448] Performing RAM repair
[0000.451] Updating A64 Warmreset Address to 0xa00002e9
[0000.456] Loading NvTbootBootloaderDTB
[0000.492] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.592] Bootloader DTB Load Address: 0x83000000
[0000.597] Loading NvTbootKernelDTB
[0000.633] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.732] Kernel DTB Load Address: 0x83100000
[0000.737] Loading cboot binary
[0000.781] Verifying EBT in OdmNonSecureSBK mode
[0000.831] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.839] Bootloader downloaded successfully.
[0000.843] Next binary entry address: 0x92c00258
[0000.848] BoardId: 3448
[0000.855] Overriding pmu board id with proc board id
[0000.859] Display board id is not available
[0000.901] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.968] /bpmp deleted
[0000.971] SC7EntryFw header found loaded at 0xff700000
[0001.210] OVR2 PMIC
[0001.212] Bpmp FW successfully loaded
[0001.216] WB0 init successfully at 0xff780000
[0001.221] Set NvDecSticky Bits
[0001.225] GSC2 address ff53fffc value c0edbbcc
[0001.233] GSC MC Settings done
[0001.237] TOS Image length 53680
[0001.240] Monitor size 53680
[0001.243] OS size 0
[0001.252] Secure Os AES-CMAC Verification Success!
[0001.257] TOS image cipher info: plaintext
[0001.261] Loading and Validation of Secure OS Successful
[0001.285] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.289] NvTbootPackSdramParams: start.
[0001.296] NvTbootPackSdramParams: done.
[0001.300] Tegraboot started after 90741 us
[0001.304] Basic modules init took 794446 us
[0001.308] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.313] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.320] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.326] Storage Device Read Time = 164 ms, Read Size = 2226 KB
[0001.332] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.337] Next stage binary read took 37965 us
[0001.342] Carveout took -52279 us
[0001.345] CPU initialization took 460352 us
[0001.349] Total time taken by TegraBoot 1240484 us
[0001.354] Starting CPU & Halting co-processor
[0001.476] RamCode = 0
[0001.481] LPDDR4 Training: Read DT: Number of tables = 2
[0001.486] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.499] EMC Training Successful
[0001.502] 408000 not found in DVFS table
[0001.509] RamCode = 0
[0001.512] DT Write: emc-table@204000 succeeded
[0001.518] DT Write: emc-table@1600000 succeeded
[0001.522] LPDDR4 Training: Write DT: Number of tables = 2
[0001.567]
[0001.568] Debug Init done
[0001.571] Marked DTB cacheable
[0001.574] Bootloader DTB loaded at 0x83000000
[0001.579] Marked DTB cacheable
[0001.582] Kernel DTB loaded at 0x83100000
[0001.586] DeviceTree Init done
[0001.598] Pinmux applied successfully
[0001.602] gicd_base: 0x50041000
[0001.605] gicc_base: 0x50042000
[0001.608] Interrupts Init done
[0001.612] Using base:0x60005090 & irq:208 for tick-timer
[0001.618] Using base:0x60005098 for delay-timer
[0001.622] platform_init_timer: DONE
[0001.626] Timer(tick) Init done
[0001.629] osc freq = 38400 khz
[0001.634]
[0001.635] welcome to cboot
[0001.637]
[0001.638] Cboot Version: 00.00.2018.01-t210-21e03500
[0001.643] calling constructors
[0001.646] initializing heap
[0001.649] initializing threads
[0001.652] initializing timers
[0001.655] creating bootstrap completion thread
[0001.659] top of bootstrap2()
[0001.662] CPU: ARM Cortex A57
[0001.665] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.670] initializing platform
[0001.673] Scratch reg 37 & 271 initial value set..
[0001.679] cboot:secure-pmc present
[0001.683] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.687] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.692] Macronix QSPI chip present
[0001.695] SPI device register
[0001.698] init boot device
[0001.701] allocating memory for boot device(SPI)
[0001.705] registering boot device
[0001.715] sdmmc node status = okay
[0001.718] sdcard instance = 0
[0001.721] sdcard gpio handle 0x56
[0001.724] sdcard gpio pin 0xc9
[0001.727] sdcard gpio flags 0x0
[0001.730] vmmc-supply 0x99
[0001.733] Instance: 0
[0001.735] Allocating memory for context
[0001.739] enabling clock
[0001.741] sd card init
[0001.744] Check card present and stable
[0001.747] Send command 0
[0001.764] Send command 3
[0001.768] Set RCA for the card
[0001.771] Query card specific data by command 9
[0001.778] Parse CSD data
[0001.780] Send command 7
[0001.790] Calling sd device register
[0001.794] Init sdcard
[0001.796] Allocating memory for boot device
[0001.800] Registering user device
[0001.813] Enable APE clock
[0001.816] Un-powergate APE partition
[0001.820] of_register: registering tegra_udc to of_hal
[0001.825] of_register: registering tegra_udc to of_hal
[0001.830] of_register: registering inv20628-driver to of_hal
[0001.835] of_register: registering ads1015-driver to of_hal
[0001.841] of_register: registering lp8557-bl-driver to of_hal
[0001.847] of_register: registering bq2419x_charger to of_hal
[0001.853] of_register: registering cpc to of_hal
[0001.857] of_register: registering bq27441_fuel_gauge to of_hal
[0001.869] gpio framework initialized
[0001.872] of_register: registering tca9539_gpio to of_hal
[0001.877] of_register: registering tca9539_gpio to of_hal
[0001.883] of_register: registering i2c_bus_driver to of_hal
[0001.888] of_register: registering i2c_bus_driver to of_hal
[0001.894] of_register: registering i2c_bus_driver to of_hal
[0001.900] of_register: registering i2c_bus_driver to of_hal
[0001.905] pmic framework initialized
[0001.909] of_register: registering max77620_pmic to of_hal
[0001.914] regulator framework initialized
[0001.918] of_register: registering tps65132_bl_driver to of_hal
[0001.924] initializing target
[0001.930] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.938] fixed regulator driver initialized
[0001.955] initializing OF layer
[0001.958] NCK carveout not present
[0001.962] Skipping dts_overrides
[0001.966] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.982] I2C Bus Init done
[0001.985] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.995] I2C Bus Init done
[0001.998] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.008] I2C Bus Init done
[0002.011] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.021] I2C Bus Init done
[0002.024] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.034] I2C Bus Init done
[0002.037] of_children_init: Ops found for compatible string maxim,max77620
[0002.047] max77620_init using irq 118
[0002.052] register 'maxim,max77620' pmic
[0002.056] gpio_driver_register: register 'max77620-gpio' driver
[0002.063] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.073] I2C Bus Init done
[0002.077] NCK carveout not present
[0002.080] shim_invoke: No NCT, Calling dts updates
[0002.091] Find /i2c@7000c000's alias i2c0
[0002.095] get eeprom at 1-a0, size 256, type 0
[0002.104] Find /i2c@7000c500's alias i2c2
[0002.108] get eeprom at 3-a0, size 256, type 0
[0002.112] get eeprom at 3-ae, size 256, type 0
[0002.117] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.122] I2C slave not started
[0002.125] I2C write failed
[0002.128] Writing offset failed
[0002.131] eeprom_init: EEPROM read failed
[0002.135] pm_ids_update: eeprom init failed
[0002.139] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.169] pm_ids_update: The pm board id is 3448-0000-200
[0002.176] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.184] pm_ids_update: pm id update successful
[0002.188] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.218] pm_ids_update: The pm board id is 3449-0000-200
[0002.225] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.232] pm_ids_update: pm id update successful
[0002.263] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.269] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.277] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.283] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.291] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:1d:8e
[0002.298] Plugin Manager: Parse ODM data 0x00084000
[0002.308] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.330] Find /i2c@7000c000's alias i2c0
[0002.334] get eeprom at 1-a0, size 256, type 0
[0002.342] Find /i2c@7000c500's alias i2c2
[0002.346] get eeprom at 3-a0, size 256, type 0
[0002.351] get eeprom at 3-ae, size 256, type 0
[0002.355] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.360] I2C slave not started
[0002.363] I2C write failed
[0002.366] Writing offset failed
[0002.369] eeprom_init: EEPROM read failed
[0002.373] pm_ids_update: eeprom init failed
[0002.377] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.407] pm_ids_update: The pm board id is 3448-0000-200
[0002.414] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.421] pm_ids_update: pm id update successful
[0002.425] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.456] pm_ids_update: The pm board id is 3449-0000-200
[0002.462] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.469] pm_ids_update: pm id update successful
[0002.500] Chip UID is 0000000164441643080000000f008340
[0002.505] Add serial number:14219190444350408300 as DT property
[0002.513] Applying platform configs
[0002.520] platform-init is not present. Skipping
[0002.524] calling apps_init()
[0002.544] Found 14 GPT partitions in "sd0"
[0002.548] Proceeding to Cold Boot
[0002.551] starting app android_boot_app
[0002.555] Device state: unlocked
[0002.558] display console init
[0002.567] could not find regulator
[0002.590] hdmi cable not connected
[0002.593] is_hdmi_needed: HDMI not connected, returning false
[0002.599] hdmi is not connected
[0002.602] sor0 is not supporDT entry for leds-pwm not found
t[0002.611] ed
[0002.613] display_console_init: no valid display out_type
[0002.621] subnode volume_up is not found !
[0002.625] subnode back is not found !
[0002.628] subnode volume_down is not found !
[0002.632] subnode menu is not found !
[0002.636] Gpio keyboard init success
[0002.686] found decompressor handler: lz4-legacy
[0002.700] decompressing blob (type 1)...
[0002.734] display_resolution: No display init
[0002.738] Failed to retrieve display resolution
[0002.743] Could not load/initialize BMP blob...ignoring
[0002.800] decompressor handler not found
[0002.804] load_firmware_blob: Firmware blob loaded, entries=2
[0002.810] se_aes_verify_sbk_clear: Error
[0002.813] bl_battery_charging: connected to external power supply
[0002.821] xusb is supported
[0002.827] error while finding nvidia,portmap
[0002.832] could not find regulator
[0003.335] xusb blob version 0 size 124416
[0003.339] firmware size 124416
[0003.344] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.355] xhci0: 64 bytes context size, 32-bit DMA
[0003.395] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.415] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.065] uhub0: 9 ports with 9 removable, self powered
[0001.304] Basic modules init took 794441 us
[0001.337] Next stage binary read took 37969 us
[0001.342] Carveout took -52282 us
[0001.345] CPU initialization took 460364 us
[0001.349] Total time taken by TegraBoot 1240492 us
[0001.567]
[0001.634]
[0001.637]
[0001.836] of_register: registering ads1015-driver to of_hal
[0001.939] fixed regulator driver initialized
[0001.956] initializing OF layer
[0001.983] I2C Bus Init done
Here is the output from flash.sh command on L4T 32.2.3:
root@tchome:/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra# ./flash.sh -r jetson-nano-qspi-sd mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 2.3
# Target Board Information:
# Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: NS,
./tegraflash.py --chip 0x21 --applet "/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0150 ] Generating RCM messages
[ 0.0172 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0192 ] RCM 0 is saved as rcm_0.rcm
[ 0.0463 ] RCM 1 is saved as rcm_1.rcm
[ 0.0463 ] List of rcm files are saved in rcm_list.xml
[ 0.0463 ]
[ 0.0464 ] Signing RCM messages
[ 0.0759 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0797 ] Assuming zero filled SBK key
[ 0.1004 ]
[ 0.1004 ] Copying signature to RCM mesages
[ 0.1027 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.1104 ]
[ 0.1105 ] Boot Rom communication
[ 0.1119 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1132 ] RCM version 0X210001
[ 0.1560 ] Boot Rom communication completed
[ 1.1636 ]
[ 1.1637 ] dump EEPROM info
[ 1.1671 ] tegrarcm --oem platformdetails eeprom /home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1700 ] Applet version 00.01.0000
[ 1.1896 ] Saved platform info in /home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/cvm.bin
[ 1.2710 ]
Board ID(3448) version(200)
copying bctfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Existing tbcfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
copying cfgfile(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x84000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb"
saving flash command in /home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/tc/PETER-pmelectrical/nvidia/32.2.3/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0044 ] tegrasign --key None --getmode mode.txt
[ 0.0077 ] Assuming zero filled SBK key
[ 0.0082 ]
[ 0.0084 ] Generating RCM messages
[ 0.0114 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0141 ] RCM 0 is saved as rcm_0.rcm
[ 0.0160 ] RCM 1 is saved as rcm_1.rcm
[ 0.0160 ] List of rcm files are saved in rcm_list.xml
[ 0.0160 ]
[ 0.0161 ] Signing RCM messages
[ 0.0190 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0219 ] Assuming zero filled SBK key
[ 0.0399 ]
[ 0.0407 ] Copying signature to RCM mesages
[ 0.0425 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0449 ]
[ 0.0449 ] Parsing partition layout
[ 0.0839 ] tegraparser --pt flash.xml.tmp
[ 0.0864 ]
[ 0.0865 ] Creating list of images to be signed
[ 0.1238 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.1407 ]
[ 0.1408 ] Generating signatures
[ 0.1441 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1471 ] Assuming zero filled SBK key
[ 0.2028 ]
[ 0.2028 ] Generating br-bct
[ 0.2470 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.2507 ] Copying Sdram info from 0 to 1 set
[ 0.2554 ] Copying Sdram info from 1 to 2 set
[ 0.2561 ] Copying Sdram info from 2 to 3 set
[ 0.2562 ]
[ 0.2562 ] Updating boot device parameters
[ 0.2595 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.2625 ] Warning: No sdram params
[ 0.2631 ]
[ 0.2632 ] Updating bl info
[ 0.2663 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.2700 ]
[ 0.2701 ] Updating secondary storage information into bct
[ 0.2719 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.2738 ]
[ 0.2738 ] Updating Odmdata
[ 0.2753 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x84000
[ 0.2770 ] Warning: No sdram params
[ 0.2772 ]
[ 0.2773 ] Get Signed section of bct
[ 0.2793 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.2814 ]
[ 0.2814 ] Signing BCT
[ 0.2844 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2860 ] Assuming zero filled SBK key
[ 0.2868 ]
[ 0.2869 ] Updating BCT with signature
[ 0.2884 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.2901 ]
[ 0.2902 ] Copying signatures
[ 0.2917 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.3011 ]
[ 0.3012 ] Updating BFS information on BCT
[ 0.3071 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.3086 ]
[ 0.3086 ] Boot Rom communication
[ 0.3097 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.3106 ] BootRom is not running
[ 0.3516 ]
[ 0.3517 ] Sending BCTs
[ 0.3528 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.3538 ] Applet version 00.01.0000
[ 0.3743 ] Sending bct
[ 0.3744 ] [................................................] 100%
[ 0.5480 ]
[ 0.5514 ] tegrahost --chip 0x21 --align cboot.bin
[ 0.5544 ]
[ 0.5575 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 0.5698 ]
[ 0.5748 ] tegrasign --key None --list cboot.bin_list.xml
[ 0.5783 ] Assuming zero filled SBK key
[ 0.6029 ]
[ 0.6043 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 0.6059 ]
[ 0.6074 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
[ 0.6083 ]
[ 0.6091 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
[ 0.6107 ]
[ 0.6118 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
[ 0.6125 ] Assuming zero filled SBK key
[ 0.6173 ]
[ 0.6182 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
[ 0.6193 ]
[ 0.6196 ] Sending bootloader and pre-requisite binaries
[ 0.6203 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
[ 0.6210 ] Applet version 00.01.0000
[ 0.6435 ] Sending ebt
[ 0.6447 ] [................................................] 100%
[ 0.7544 ] Sending rp1
[ 0.7597 ] [................................................] 100%
[ 0.8133 ]
[ 0.8166 ] tegrarcm --boot recovery
[ 0.8194 ] Applet version 00.01.0000
[ 0.8390 ]
[ 0.8391 ] Retrieving storage infomation
[ 0.8406 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 0.8420 ] Applet is not running on device. Continue with Bootloader
[ 1.5498 ]
[ 1.5943 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 1.5975 ] Cboot version 00.01.0000
[ 1.6288 ] Saved platform info in storage_info.bin
[ 1.6299 ]
[ 1.6300 ] Flashing the device
[ 1.6334 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 1.6363 ] Cboot version 00.01.0000
[ 1.6402 ] Writing partition GPT with gpt.bin
[ 1.6411 ] [................................................] 100%
[ 1.6445 ] Writing partition NVC with nvtboot.bin.encrypt
[ 18.0974 ] [................................................] 100%
[ 18.1081 ] Writing partition PT with flash.xml.bin
[ 28.6093 ] [................................................] 100%
[ 28.6147 ] Writing partition NVC_R with nvtboot.bin.encrypt
[ 28.8645 ] [................................................] 100%
[ 28.8807 ] Writing partition VER with qspi_bootblob_ver.txt
[ 39.3963 ] [................................................] 100%
[ 39.4159 ] Writing partition APP with system.img
[ 39.6784 ] [................................................] 100%
[ 446.7941 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[ 456.5198 ] [................................................] 100%
[ 456.5291 ] Writing partition RP1 with tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt
[ 456.5699 ] [................................................] 100%
[ 456.5850 ] Writing partition EBT with cboot.bin.encrypt
[ 456.6390 ] [................................................] 100%
[ 456.6657 ] Writing partition WB0 with warmboot.bin.encrypt
[ 456.7426 ] [................................................] 100%
[ 456.7502 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[ 456.7873 ] [................................................] 100%
[ 456.7939 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 456.8291 ] [................................................] 100%
[ 456.8376 ] Writing partition DTB with tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt
[ 456.8786 ] [................................................] 100%
[ 456.8940 ] Writing partition LNX with boot.img.encrypt
[ 456.9481 ] [................................................] 100%
[ 456.9733 ] Warning: EKS partition magic header mismatch!
[ 457.0323 ] Writing partition EKS with eks.img
[ 457.0329 ] [................................................] 100%
[ 457.0401 ] Writing partition BMP with bmp.blob
[ 457.0787 ] [................................................] 100%
[ 457.1272 ] Writing partition RP4 with rp4.blob
[ 457.1693 ] [................................................] 100%
[ 457.2426 ]
[ 457.2458 ] tegradevflash --write BCT P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 457.2490 ] Cboot version 00.01.0000
[ 457.2515 ] Writing partition BCT with P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 457.2524 ] [................................................] 100%
[ 463.9073 ]
[ 463.9074 ] Flashing completed
[ 463.9075 ] Coldbooting the device
[ 463.9102 ] tegradevflash --reboot coldboot
[ 463.9122 ] Cboot version 00.01.0000
[ 463.9145 ]
*** The target t210ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
Are there any source codes avalable for c-boot?
How can I set “disable-pmic-wdt”? or get more info from where the cboot is taking the watchdog initial timeout timer period value?
I’ve already tried with ODMDATA without success. (Editing p3448-0000.conf.common and reflashing the device)
ODMDATA=0x94000 - booting, watchdog is reseting the device
ODMDATA=0xA4000 - booting, watchdog is reseting the device
ODMDATA=0x84000 - booting, watchdog is reseting the device
ODMDATA=0x34000 - has not booted at all
Here it is the serial console full log with initially flashing 32.5 L4T:
[0228.053] Enabled early print
[0228.056] [L4T TegraBoot] (version �����B����$�)X�j��:@����)
[0228.062] Processing in recovery mode
[0228.065] A02 Bootrom Patch rev = 1023
[0228.069] Power-up reason: software reset
[0228.073] Established communication link with host
[0229.059] Odmdata from BCT: 0x000a4000
[0229.063] DebugPort= 0x3
[0229.065] SkipQspiOnly= 0x0
[0229.117] BoardId read from EEPROM/NCT: 3448
[0229.122] BoardID = 3448, SKU = 0x0
[0229.149] NvTbootInit_Porg: Setting GPIO_A6 for HDMI ...
[0229.154] max77620 setting MBLPD bit
[0229.157] No Battery Present
[0229.160] RamCode = 0
[0229.162] Platform has DDR4 type RAM
[0229.166] max77620 disabling SD1 Remote Sense
[0229.170] Setting DDR voltage to 1125mv
[0229.174] Serial Number of Pmic Max77663: 0x221ff9
[0229.182] Entering ramdump check
[0229.185] Get RamDumpCarveOut = 0x0
[0229.188] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0229.193] Last reboot was clean, booting normally!
[0229.198] Sdram initialization is successful
[0229.202] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0229.208] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0229.214] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0229.220] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0229.226] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0229.232] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0229.238] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0229.243] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0229.260] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0229.266] Platform-DebugCarveout: 0
[0229.269] Downloaded BCT successfully
[0229.775] Downloaded Bootloader successfully
[0229.835] Downloaded rp1 successfully
[0229.865] MAX77620_GPIO5 configured
[0229.868] CPU power rail is up
[0229.871] CPU clock enabled
[0229.875] Performing RAM repair
[0229.878] Updating A64 Warmreset Address to 0x92c002e9
[0229.884] Enable APE clock/reset
[0229.887] Error in NvTbootGetTOSBinaryLength: 0x11 !
[0229.892] Loading Secure OS image failed.
[0229.896] Set NvDecSticky Bits
[0229.899] GSC2 address ff53fffc value c0edbbcc
[0229.906] GSC MC Settings done
[0229.910] Next binary entry address: 0x92c00258
[0229.914] BoardId: 3448
[0229.917] Overriding pmu board id with proc board id
[0229.922] Display board id is not available
[0229.926] Starting CPU & Halting co-processor
[0235.455]
[0235.456] Debug Init done
[0235.459] Marked DTB cacheable
[0235.462] Bootloader DTB loaded at 0x83000400
[0235.467] DeviceTree Init done
[0235.480] Pinmux applied successfully
[0235.484] gicd_base: 0x50041000
[0235.487] gicc_base: 0x50042000
[0235.490] Interrupts Init done
[0235.495] Using base:0x60005090 & irq:208 for tick-timer
[0235.500] Using base:0x60005098 for delay-timer
[0235.504] platform_init_timer: DONE
[0235.508] Timer(tick) Init done
[0235.511] osc freq = 38400 khz
[0235.515]
[0235.516] Welcome to L4T Cboot
[0235.519]
[0235.520] Cboot Version: 00.00.2018.01-t210-39562017
[0235.525] calling constructors
[0235.528] initializing heap
[0235.531] initializing threads
[0235.534] initializing timers
[0235.537] creating bootstrap completion thread
[0235.541] top of bootstrap2()
[0235.544] CPU: ARM Cortex A57
[0235.547] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0235.552] initializing platform
[0235.559] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0235.564] ID LSB = 0x36, ID-CFI len = 194 bytes
[0235.568] Macronix QSPI chip present
[0235.572] SPI device register
[0235.575] init boot device
[0235.577] allocating memory for boot device(SPI)
[0235.582] registering boot device
[0235.591] sdmmc node status = okay
[0235.595] sdcard instance = 0
[0235.597] sdcard gpio handle 0x5b
[0235.601] sdcard gpio pin 0xc9
[0235.604] sdcard gpio flags 0x0
[0235.607] vmmc-supply 0x9e
[0235.609] Instance: 0
[0235.611] Allocating memory for context
[0235.615] enabling clock
[0235.618] sd card init
[0235.620] Check card present and stable
[0235.624] Send command 0
[0235.724] Send command 3
[0235.729] Set RCA for the card
[0235.732] Query card specific data by command 9
[0235.738] Parse CSD data
[0235.740] Send command 7
[0235.751] Calling sd device register
[0235.754] Init sdcard
[0235.757] Allocating memory for boot device
[0235.761] Registering user device
[0235.774] of_register: registering tegra_udc to of_hal
[0235.779] of_register: registering inv20628-driver to of_hal
[0235.785] of_register: registering ads1015-driver to of_hal
[0235.790] of_register: registering lp8557-bl-driver to of_hal
[0235.796] of_register: registering bq2419x_charger to of_hal
[0235.801] of_register: registering bq27441_fuel_gauge to of_hal
[0235.813] gpio framework initialized
[0235.817] of_register: registering tca9539_gpio to of_hal
[0235.822] of_register: registering tca9539_gpio to of_hal
[0235.827] of_register: registering i2c_bus_driver to of_hal
[0235.833] of_register: registering i2c_bus_driver to of_hal
[0235.839] of_register: registering i2c_bus_driver to of_hal
[0235.844] pmic framework initialized
[0235.848] of_register: registering max77620_pmic to of_hal
[0235.853] regulator framework initialized
[0235.857] of_register: registering tps65132_bl_driver to of_hal
[0235.863] initializing target
[0235.869] gpio_driver_register: register 'tegra_gpio_driver' driver
[0235.877] board ID = D78, board SKU = 0
[0235.881] Skipping Z3!
[0235.886] fixed regulator driver initialized
[0235.904] initializing OF layer
[0235.908] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0235.926] I2C Bus Init done
[0235.928] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0235.938] I2C Bus Init done
[0235.941] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0235.951] I2C Bus Init done
[0235.954] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0235.965] I2C Bus Init done
[0235.967] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0235.978] I2C Bus Init done
[0235.980] of_children_init: Ops found for compatible string maxim,max77620
[0235.991] max77620_init using irq 118
[0235.996] register 'maxim,max77620' pmic
[0236.000] gpio_driver_register: register 'max77620-gpio' driver
[0236.006] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0236.017] I2C Bus Init done
[0236.020] Applying platform configs
[0236.027] platform-init is not present. Skipping
[0236.032] calling apps_init()
[0236.052] Found 14 GPT partitions in "sd0"
[0236.056] Proceeding to flashing Server
[0236.060] usbdcd_reinit Initialize driver to use already enumerated device
[0236.067] nv3p_priv_usbf_open USB configuration success
[0236.141] Writing GPT partition
[0236.146] Erasing Boot device
[0236.149] device_write_gpt: Erasing boot device spiflash0
[0253.798] Erasing Storage Device
[0253.801] Writing protective mbr
[0253.826] Writing primary GPT
[0254.198] Writing secondary GPT
[0254.234] Found 1 GPT partitions in "sd0"
[0296.347] Writing PT partition
[0296.597] partition PT write successful.
[0296.602] Writing NVC partition
[0306.625] partition NVC write successful.
[0306.631] Writing NVC_R partition
[0316.664] partition NVC_R write successful.
[0316.669] Writing TBC partition
[0320.843] partition TBC write successful.
[0320.850] Writing RP1 partition
[0335.523] partition RP1 write successful.
[0335.530] Writing EBT partition
[0364.611] partition EBT write successful.
[0364.619] Writing WB0 partition
[0364.887] partition WB0 write successful.
[0364.894] Writing BPF partition
[0365.162] partition BPF write successful.
[0365.169] Writing TOS partition
[0368.611] partition TOS write successful.
[0368.617] Writing DTB partition
[0383.290] partition DTB write successful.
[0383.296] Writing LNX partition
[0422.875] partition LNX write successful.
[0422.890] Writing EKS partition
[0423.157] partition EKS write successful.
[0423.163] Writing BMP partition
[0432.251] partition BMP write successful.
[0432.257] Writing RP4 partition
[0439.851] partition RP4 write successful.
[0439.857] Writing VER_b partition
[0440.146] partition VER_b write successful.
[0440.151] Writing VER partition
[0440.419] partition VER write successful.
[0440.424] Writing APP partition
[0962.135] partition APP write successful.
[0962.152] Writing BCT partition
[0968.803] partition BCT write successful.
[0968.813] Change state to cold boot mode
[0000.157] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.162] Processing in cold boot mode Bootloader 2
[0000.167] A02 Bootrom Patch rev = 1023
[0000.171] Power-up reason: software reset
[0000.174] No Battery Present
[0000.177] pmic max77620 reset reason
[0000.180] pmic max77620 NVERC : 0x0
[0000.184] RamCode = 0
[0000.186] Platform has DDR4 type RAM
[0000.189] max77620 disabling SD1 Remote Sense
[0000.193] Setting DDR voltage to 1125mv
[0000.197] Serial Number of Pmic Max77663: 0x221ff9
[0000.205] Entering ramdump check
[0000.208] Get RamDumpCarveOut = 0x0
[0000.211] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.217] Last reboot was clean, booting normally!
[0000.221] Sdram initialization is successful
[0000.225] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.231] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.237] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.243] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.249] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.255] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.261] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.266] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.283] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.289] Platform-DebugCarveout: 0
[0000.292] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.298] Non secure mode, and RB not enabled.
[0000.302] BoardID = 3448, SKU = 0x0
[0000.305] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.309] Nano-SD: checking PT table on QSPI ...
[0000.313] Read PT from (2:0)
[0000.329] Using BFS PT to query partitions
[0000.334] Loading Tboot-CPU binary
[0000.363] Verifying TBC in OdmNonSecureSBK mode
[0000.373] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.380] Bootloader downloaded successfully.
[0000.384] Downloaded Tboot-CPU binary to 0xa0000258
[0000.389] MAX77620_GPIO5 configured
[0000.392] CPU power rail is up
[0000.395] CPU clock enabled
[0000.399] Performing RAM repair
[0000.402] Updating A64 Warmreset Address to 0xa00002e9
[0000.407] BoardID = 3448, SKU = 0x0
[0000.410] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.414] Nano-SD: checking PT table on QSPI ...
[0000.418] Loading NvTbootBootloaderDTB
[0000.485] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.558] Bootloader DTB Load Address: 0x83000000
[0000.562] BoardID = 3448, SKU = 0x0
[0000.566] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.570] Nano-SD: checking PT table on QSPI ...
[0000.574] Loading NvTbootKernelDTB
[0000.640] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.713] Kernel DTB Load Address: 0x83100000
[0000.717] BoardID = 3448, SKU = 0x0
[0000.721] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.724] Nano-SD: checking PT table on QSPI ...
[0000.731] Loading cboot binary
[0000.846] Verifying EBT in OdmNonSecureSBK mode
[0000.888] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.895] Bootloader downloaded successfully.
[0000.899] BoardID = 3448, SKU = 0x0
[0000.902] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.906] Nano-SD: checking PT table on QSPI ...
[0000.911] PT: Partition NCT NOT found !
[0000.915] Warning: Find Partition via PT Failed
[0000.919] Next binary entry address: 0x92c00258
[0000.923] BoardId: 3448
[0000.928] Overriding pmu board id with proc board id
[0000.933] Display board id is not available
[0000.937] BoardID = 3448, SKU = 0x0
[0000.940] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.944] Nano-SD: checking PT table on QSPI ...
[0001.049] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.106] /bpmp deleted
[0001.108] SC7EntryFw header found loaded at 0xff700000
[0001.303] OVR2 PMIC
[0001.305] Bpmp FW successfully loaded
[0001.309] BoardID = 3448, SKU = 0x0
[0001.312] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.316] Nano-SD: checking PT table on QSPI ...
[0001.321] WB0 init successfully at 0xff780000
[0001.325] Set NvDecSticky Bits
[0001.329] GSC2 address ff53fffc value c0edbbcc
[0001.335] GSC MC Settings done
[0001.338] BoardID = 3448, SKU = 0x0
[0001.341] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.345] Nano-SD: checking PT table on QSPI ...
[0001.351] TOS Image length 53680
[0001.354] Monitor size 53680
[0001.356] OS size 0
[0001.372] Secure Os AES-CMAC Verification Success!
[0001.376] TOS image cipher info: plaintext
[0001.380] Loading and Validation of Secure OS Successful
[0001.396] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.401] NvTbootPackSdramParams: start.
[0001.406] NvTbootPackSdramParams: done.
[0001.410] Tegraboot started after 84893 us
[0001.414] Basic modules init took 887021 us
[0001.418] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.423] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.429] Next stage binary read took 102860 us
[0001.433] Carveout took -126355 us
[0001.436] CPU initialization took 495395 us
[0001.440] Total time taken by TegraBoot 1358921 us
[0001.445] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 14:33:23, Jan 15 2021
ERROR: Error initializing runtime service trusty_fast
[0001.567] RamCode = 0
[0001.572] LPDDR4 Training: Read DT: Number of tables = 2
[0001.577] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.590] EMC Training Successful
[0001.593] 408000 not found in DVFS table
[0001.599] RamCode = 0
[0001.603] DT Write: emc-table@204000 succeeded
[0001.608] DT Write: emc-table@1600000 succeeded
[0001.612] LPDDR4 Training: Write DT: Number of tables = 2
[0001.660]
[0001.661] Debug Init done
[0001.663] Marked DTB cacheable
[0001.666] Bootloader DTB loaded at 0x83000000
[0001.671] Marked DTB cacheable
[0001.674] Kernel DTB loaded at 0x83100000
[0001.678] DeviceTree Init done
[0001.691] Pinmux applied successfully
[0001.695] gicd_base: 0x50041000
[0001.699] gicc_base: 0x50042000
[0001.702] Interrupts Init done
[0001.706] Using base:0x60005090 & irq:208 for tick-timer
[0001.711] Using base:0x60005098 for delay-timer
[0001.716] platform_init_timer: DONE
[0001.719] Timer(tick) Init done
[0001.723] osc freq = 38400 khz
[0001.727]
[0001.728] Welcome to L4T Cboot
[0001.731]
[0001.732] Cboot Version: 00.00.2018.01-t210-39562017
[0001.737] calling constructors
[0001.740] initializing heap
[0001.742] initializing threads
[0001.745] initializing timers
[0001.748] creating bootstrap completion thread
[0001.753] top of bootstrap2()
[0001.756] CPU: ARM Cortex A57
[0001.758] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.763] initializing platform
[0001.771] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.775] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.780] Macronix QSPI chip present
[0001.783] SPI device register
[0001.786] init boot device
[0001.789] allocating memory for boot device(SPI)
[0001.793] registering boot device
[0001.802] QSPI bdev is already initialized
[0001.806] Enable APE clock
[0001.808] Un-powergate APE partition
[0001.812] of_register: registering tegra_udc to of_hal
[0001.817] of_register: registering inv20628-driver to of_hal
[0001.822] of_register: registering ads1015-driver to of_hal
[0001.828] of_register: registering lp8557-bl-driver to of_hal
[0001.834] of_register: registering bq2419x_charger to of_hal
[0001.839] of_register: registering bq27441_fuel_gauge to of_hal
[0001.851] gpio framework initialized
[0001.854] of_register: registering tca9539_gpio to of_hal
[0001.860] of_register: registering tca9539_gpio to of_hal
[0001.865] of_register: registering i2c_bus_driver to of_hal
[0001.871] of_register: registering i2c_bus_driver to of_hal
[0001.876] of_register: registering i2c_bus_driver to of_hal
[0001.882] pmic framework initialized
[0001.885] of_register: registering max77620_pmic to of_hal
[0001.891] regulator framework initialized
[0001.895] of_register: registering tps65132_bl_driver to of_hal
[0001.901] initializing target
[0001.906] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.915] board ID = D78, board SKU = 0
[0001.918] Skipping Z3!
[0001.923] fixed regulator driver initialized
[0001.941] initializing OF layer
[0001.944] NCK carveout not present
[0001.947] Skipping dts_overrides
[0001.951] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.968] I2C Bus Init done
[0001.971] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.981] I2C Bus Init done
[0001.984] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.994] I2C Bus Init done
[0001.997] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.007] I2C Bus Init done
[0002.010] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.020] I2C Bus Init done
[0002.023] of_children_init: Ops found for compatible string maxim,max77620
[0002.033] max77620_init using irq 118
[0002.038] register 'maxim,max77620' pmic
[0002.043] gpio_driver_register: register 'max77620-gpio' driver
[0002.049] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.059] I2C Bus Init done
[0002.063] NCK carveout not present
[0002.073] Find /i2c@7000c000's alias i2c0
[0002.077] get eeprom at 1-a0, size 256, type 0
[0002.086] Find /i2c@7000c500's alias i2c2
[0002.089] get eeprom at 3-a0, size 256, type 0
[0002.094] get eeprom at 3-ae, size 256, type 0
[0002.098] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.104] I2C slave not started
[0002.107] I2C write failed
[0002.109] Writing offset failed
[0002.112] eeprom_init: EEPROM read failed
[0002.116] pm_ids_update: eeprom init failed
[0002.120] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.150] pm_ids_update: The pm board id is 3448-0000-200
[0002.157] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.166] pm_ids_update: pm id update successful
[0002.170] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.200] pm_ids_update: The pm board id is 3449-0000-200
[0002.206] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.214] pm_ids_update: pm id update successful
[0002.245] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.251] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.258] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.264] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.273] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:1d:8e
[0002.279] Plugin Manager: Parse ODM data 0x000a4000
[0002.291] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.306] Find /i2c@7000c000's alias i2c0
[0002.310] get eeprom at 1-a0, size 256, type 0
[0002.319] Find /i2c@7000c500's alias i2c2
[0002.323] get eeprom at 3-a0, size 256, type 0
[0002.327] get eeprom at 3-ae, size 256, type 0
[0002.332] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.337] I2C slave not started
[0002.340] I2C write failed
[0002.343] Writing offset failed
[0002.346] eeprom_init: EEPROM read failed
[0002.350] pm_ids_update: eeprom init failed
[0002.354] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.384] pm_ids_update: The pm board id is 3448-0000-200
[0002.390] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.397] pm_ids_update: pm id update successful
[0002.402] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.432] pm_ids_update: The pm board id is 3449-0000-200
[0002.438] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.445] pm_ids_update: pm id update successful
[0002.475] Add serial number:1421919044435 as DT property
[0002.483] Applying platform configs
[0002.490] platform-init is not present. Skipping
[0002.494] calling apps_init()
[0002.500] Couldn't find GPT header
[0002.505] Proceeding to Cold Boot
[0002.508] starting app android_boot_app
[0002.511] Device state: unlocked
[0002.515] display console init
[0002.523] could not find regulator
[0002.546] hdmi cable not connected
[0002.549] is_hdmi_needed: HDMI not connected, returning false
[0002.555] hdmi is not connected
[0002.562] DT entry for leds-pwm not found
[0002.558] sor0 is not supported
[0002.569] display_console_init: no valid display out_type
[0002.577] subnode volume_up is not found !
[0002.581] subnode back is not found !
[0002.584] subnode volume_down is not found !
[0002.589] subnode menu is not found !
[0002.592] Gpio keyboard init success
[0002.673] found decompressor handler: lz4-legacy
[0002.687] decompressing blob (type 1)...
[0002.753] display_resolution: No display init
[0002.758] Failed to retrieve display resolution
[0002.762] Could not load/initialize BMP blob...ignoring
[0002.837] decompressor handler not found
[0002.841] load_firmware_blob: Firmware blob loaded, entries=2
[0002.847] XUSB blob version 0 size 124416 @ 0x92ca828c
[0002.853] -------> se_aes_verify_sbk_clear: 747
[0002.857] se_aes_verify_sbk_clear: Error
[0002.861] SE operation failed
[0002.864] bl_battery_charging: connected to external power supply
[0002.873] display_console_ioctl: No display init
[0002.877] switch_backlight failed
[0002.884] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.891] MSC Partition not found
[0002.897] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.904] USP partition read failed!
[0002.908] blob_init: blob-partition USP header read failed
[0002.913] android_boot Unable to update recovery partition
[0002.919] kfs_getpartname: name = LNX
[0002.922] Loading kernel from LNX
[0002.932] Found 19 BFS partitions in "spiflash0"
[0003.250] load kernel from storage
[0003.255] decompressor handler not found
[0003.519] Successfully loaded kernel and ramdisk images
[0003.524] board ID = D78, board SKU = 0
[0003.529] sdmmc node status = okay
[0003.532] sdcard instance = 0
[0003.535] sdcard gpio handle 0x5b
[0003.538] sdcard gpio pin 0xc9
[0003.541] sdcard gpio flags 0x0
[0003.544] vmmc-supply 0x9e
[0003.547] cd_gpio_pin = 201
[0003.550] pin_state = 0
[0003.552] Found sdcard
[0003.554] SD-card IS present ...
[0003.557] load_and_boot_kernel: SD card detected OK
[0003.563] display_resolution: No display init
[0003.567] Failed to retrieve display resolution
[0003.572] bmp blob is not loaded and initialized
[0003.576] Failed to display boot-logo
[0003.580] NCK carveout not present
[0003.583] Skipping dts_overrides
[0003.586] NCK carveout not present
[0003.596] Find /i2c@7000c000's alias i2c0
[0003.600] get eeprom at 1-a0, size 256, type 0
[0003.609] Find /i2c@7000c500's alias i2c2
[0003.613] get eeprom at 3-a0, size 256, type 0
[0003.617] get eeprom at 3-ae, size 256, type 0
[0003.622] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.627] I2C slave not started
[0003.630] I2C write failed
[0003.633] Writing offset failed
[0003.636] eeprom_init: EEPROM read failed
[0003.640] pm_ids_update: eeprom init failed
[0003.644] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.674] pm_ids_update: The pm board id is 3448-0000-200
[0003.681] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0003.689] pm_ids_update: pm id update successful
[0003.694] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.724] pm_ids_update: The pm board id is 3449-0000-200
[0003.730] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0003.738] pm_ids_update: pm id update successful
[0003.768] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.774] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.782] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.788] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.796] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:1d:8e
[0003.802] Plugin Manager: Parse ODM data 0x000a4000
[0003.815] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.823] Add serial number:1421919044435 as DT property
[0003.832] "bpmp" doesn't exist, creating
[0003.838] Updated bpmp info to DTB
[0003.843] Updated initrd info to DTB
[0003.846] "proc-board" doesn't exist, creating
[0003.852] Updated board info to DTB
[0003.855] "pmu-board" doesn't exist, creating
[0003.862] Updated board info to DTB
[0003.865] "display-board" doesn't exist, creating
[0003.871] Updated board info to DTB
[0003.874] "reset" doesn't exist, creating
[0003.879] Updated reset info to DTB
[0003.882] display_console_ioctl: No display init
[0003.887] display_console_ioctl: No display init
[0003.891] display_console_ioctl: No display init
[0003.896] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_su
[0003.930] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.936] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0003.949] Updated bootarg info to DTB
[0003.953] Adding uuid 0000000164441643080000000f008340 to DT
[0003.959] Adding eks info 0 to DT
[0003.964] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.970] Updated memory info to DTB
[0003.976] Updated system-lp0-disable info to DTB
[0003.984] set vdd_core voltage to 1075 mv
[0003.988] setting 'vdd-core' regulator to 1075000 micro volts
[0003.994] Found secure-pmc; disable BPMP
[0000.162] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.167] Processing in cold boot mode Bootloader 2
[0000.172] A02 Bootrom Patch rev = 1023
[0000.176] Power-up reason: ap watchdog timeout
[0000.180] No Battery Present
[0000.182] pmic max77620 reset reason
[0000.186] pmic max77620 NVERC : 0x0
[0000.189] RamCode = 0
[0000.192] Platform has DDR4 type RAM
[0000.195] max77620 disabling SD1 Remote Sense
[0000.199] Setting DDR voltage to 1125mv
[0000.203] Serial Number of Pmic Max77663: 0x221ff9
[0000.211] Entering ramdump check
[0000.214] Get RamDumpCarveOut = 0x0
[0000.218] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.223] Last reboot was clean, booting normally!
[0000.228] Sdram initialization is successful
[0000.232] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.238] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.244] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.250] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.256] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.262] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.268] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.274] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.294] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.301] Platform-DebugCarveout: 0
[0000.304] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.310] Non secure mode, and RB not enabled.
[0000.314] BoardID = 3448, SKU = 0x0
[0000.318] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.322] Nano-SD: checking PT table on QSPI ...
[0000.326] Read PT from (2:0)
[0000.354] Using BFS PT to query partitions
[0000.361] Loading Tboot-CPU binary
[0000.415] Verifying TBC in OdmNonSecureSBK mode
[0000.426] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.433] Bootloader downloaded successfully.
[0000.437] Downloaded Tboot-CPU binary to 0xa0000258
[0000.443] MAX77620_GPIO5 configured
[0000.446] CPU power rail is up
[0000.449] CPU clock enabled
[0000.454] Performing RAM repair
[0000.457] Updating A64 Warmreset Address to 0xa00002e9
[0000.462] BoardID = 3448, SKU = 0x0
[0000.465] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.469] Nano-SD: checking PT table on QSPI ...
[0000.474] Loading NvTbootBootloaderDTB
[0000.603] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.716] Bootloader DTB Load Address: 0x83000000
[0000.721] BoardID = 3448, SKU = 0x0
[0000.724] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.728] Nano-SD: checking PT table on QSPI ...
[0000.733] Loading NvTbootKernelDTB
[0000.861] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.974] Kernel DTB Load Address: 0x83100000
[0000.978] BoardID = 3448, SKU = 0x0
[0000.982] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.985] Nano-SD: checking PT table on QSPI ...
[0000.993] Loading cboot binary
[0001.222] Verifying EBT in OdmNonSecureSBK mode
[0001.271] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.279] Bootloader downloaded successfully.
[0001.283] BoardID = 3448, SKU = 0x0
[0001.286] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.290] Nano-SD: checking PT table on QSPI ...
[0001.295] PT: Partition NCT NOT found !
[0001.299] Warning: Find Partition via PT Failed
[0001.303] Next binary entry address: 0x92c00258
[0001.308] BoardId: 3448
[0001.315] Overriding pmu board id with proc board id
[0001.319] Display board id is not available
[0001.324] BoardID = 3448, SKU = 0x0
[0001.327] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.331] Nano-SD: checking PT table on QSPI ...
[0001.537] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.610] /bpmp deleted
[0001.613] SC7EntryFw header found loaded at 0xff700000
[0001.861] OVR2 PMIC
[0001.863] Bpmp FW successfully loaded
[0001.867] BoardID = 3448, SKU = 0x0
[0001.870] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.874] Nano-SD: checking PT table on QSPI ...
[0001.880] WB0 init successfully at 0xff780000
[0001.885] Set NvDecSticky Bits
[0001.889] GSC2 address ff53fffc value c0edbbcc
[0001.897] GSC MC Settings done
[0001.900] BoardID = 3448, SKU = 0x0
[0001.904] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.908] Nano-SD: checking PT table on QSPI ...
[0001.914] TOS Image length 53680
[0001.917] Monitor size 53680
[0001.920] OS size 0
[0001.947] Secure Os AES-CMAC Verification Success!
[0001.951] TOS image cipher info: plaintext
[0001.955] Loading and Validation of Secure OS Successful
[0001.979] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.984] NvTbootPackSdramParams: start.
[0001.990] NvTbootPackSdramParams: done.
[0001.994] Tegraboot started after 88673 us
[0001.998] Basic modules init took 1279723 us
[0002.003] Sec Bootdevice Read Time = 24 ms, Read Size = 61 KB
[0002.008] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0002.014] Next stage binary read took 205687 us
[0002.018] Carveout took -232108 us
[0002.022] CPU initialization took 700504 us
[0002.026] Total time taken by TegraBoot 1953806 us
[0002.031] Starting CPU & Halting co-processor
[0002.153] RamCode = 0
[0002.158] LPDDR4 Training: Read DT: Number of tables = 2
[0002.163] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.176] EMC Training Successful
[0002.179] 408000 not found in DVFS table
[0002.185] RamCode = 0
[0002.189] DT Write: emc-table@204000 succeeded
[0002.194] DT Write: emc-table@1600000 succeeded
[0002.199] LPDDR4 Training: Write DT: Number of tables = 2
[0002.260]
[0002.261] Debug Init done
[0002.264] Marked DTB cacheable
[0002.267] Bootloader DTB loaded at 0x83000000
[0002.272] Marked DTB cacheable
[0002.275] Kernel DTB loaded at 0x83100000
[0002.279] DeviceTree Init done
[0002.292] Pinmux applied successfully
[0002.296] gicd_base: 0x50041000
[0002.299] gicc_base: 0x50042000
[0002.302] Interrupts Init done
[0002.307] Using base:0x60005090 & irq:208 for tick-timer
[0002.312] Using base:0x60005098 for delay-timer
[0002.316] platform_init_timer: DONE
[0002.320] Timer(tick) Init done
[0002.324] osc freq = 38400 khz
[0002.328]
[0002.329] Welcome to L4T Cboot
[0002.332]
[0002.333] Cboot Version: 00.00.2018.01-t210-39562017
[0002.338] calling constructors
[0002.341] initializing heap
[0002.343] initializing threads
[0002.346] initializing timers
[0002.349] creating bootstrap completion thread
[0002.354] top of bootstrap2()
[0002.357] CPU: ARM Cortex A57
[0002.359] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.364] initializing platform
[0002.372] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0002.376] ID LSB = 0x36, ID-CFI len = 194 bytes
[0002.381] Macronix QSPI chip present
[0002.384] SPI device register
[0002.387] init boot device
[0002.390] allocating memory for boot device(SPI)
[0002.395] registering boot device
[0002.403] QSPI bdev is already initialized
[0002.407] Enable APE clock
[0002.410] Un-powergate APE partition
[0002.413] of_register: registering tegra_udc to of_hal
[0002.418] of_register: registering inv20628-driver to of_hal
[0002.424] of_register: registering ads1015-driver to of_hal
[0002.430] of_register: registering lp8557-bl-driver to of_hal
[0002.435] of_register: registering bq2419x_charger to of_hal
[0002.441] of_register: registering bq27441_fuel_gauge to of_hal
[0002.453] gpio framework initialized
[0002.456] of_register: registering tca9539_gpio to of_hal
[0002.461] of_register: registering tca9539_gpio to of_hal
[0002.467] of_register: registering i2c_bus_driver to of_hal
[0002.472] of_register: registering i2c_bus_driver to of_hal
[0002.478] of_register: registering i2c_bus_driver to of_hal
[0002.484] pmic framework initialized
[0002.487] of_register: registering max77620_pmic to of_hal
[0002.493] regulator framework initialized
[0002.497] of_register: registering tps65132_bl_driver to of_hal
[0002.503] initializing target
[0002.508] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.517] board ID = D78, board SKU = 0
[0002.520] Skipping Z3!
[0002.525] fixed regulator driver initialized
[0002.543] initializing OF layer
[0002.546] NCK carveout not present
[0002.549] Skipping dts_overrides
[0002.554] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.571] I2C Bus Init done
[0002.573] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.584] I2C Bus Init done
[0002.586] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.597] I2C Bus Init done
[0002.599] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.610] I2C Bus Init done
[0002.613] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.623] I2C Bus Init done
[0002.626] of_children_init: Ops found for compatible string maxim,max77620
[0002.636] max77620_init using irq 118
[0002.641] register 'maxim,max77620' pmic
[0002.645] gpio_driver_register: register 'max77620-gpio' driver
[0002.652] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.662] I2C Bus Init done
[0002.666] NCK carveout not present
[0002.676] Find /i2c@7000c000's alias i2c0
[0002.679] get eeprom at 1-a0, size 256, type 0
[0002.688] Find /i2c@7000c500's alias i2c2
[0002.692] get eeprom at 3-a0, size 256, type 0
[0002.697] get eeprom at 3-ae, size 256, type 0
[0002.701] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.707] I2C slave not started
[0002.710] I2C write failed
[0002.712] Writing offset failed
[0002.715] eeprom_init: EEPROM read failed
[0002.719] pm_ids_update: eeprom init failed
[0002.723] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.754] pm_ids_update: The pm board id is 3448-0000-200
[0002.760] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.769] pm_ids_update: pm id update successful
[0002.773] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.804] pm_ids_update: The pm board id is 3449-0000-200
[0002.810] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.818] pm_ids_update: pm id update successful
[0002.848] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.854] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.862] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.868] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.876] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:1d:8e
[0002.883] Plugin Manager: Parse ODM data 0x000a4000
[0002.895] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.910] Find /i2c@7000c000's alias i2c0
[0002.914] get eeprom at 1-a0, size 256, type 0
[0002.923] Find /i2c@7000c500's alias i2c2
[0002.927] get eeprom at 3-a0, size 256, type 0
[0002.931] get eeprom at 3-ae, size 256, type 0
[0002.936] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.941] I2C slave not started
[0002.944] I2C write failed
[0002.947] Writing offset failed
[0002.950] eeprom_init: EEPROM read failed
[0002.954] pm_ids_update: eeprom init failed
[0002.958] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.988] pm_ids_update: The pm board id is 3448-0000-200
[0002.994] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0003.001] pm_ids_update: pm id update successful
[0003.006] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.036] pm_ids_update: The pm board id is 3449-0000-200
[0003.042] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0003.049] pm_ids_update: pm id update successful
[0003.080] Add serial number:1421919044435 as DT property
[0003.087] Applying platform configs
[0003.094] platform-init is not present. Skipping
[0003.099] calling apps_init()
[0003.106] Couldn't find GPT header
[0003.111] Proceeding to Cold Boot
[0003.114] starting app android_boot_app
[0003.118] Device state: unlocked
[0003.121] display console init
[0003.130] could not find regulator
[0003.153] hdmi cable not connected
[0003.156] is_hdmi_needed: HDMIDT entry for leds-pwm not found
[0003.166] not connected, returning false
[0003.170] hdmi is not connected
[0003.173] sor0 is not supported
[0003.176] display_console_init: no valid display out_type
[0003.184] subnode volume_up is not found !
[0003.188] subnode back is not found !
[0003.192] subnode volume_down is not found !
[0003.196] subnode menu is not found !
[0003.199] Gpio keyboard init success
[0003.318] found decompressor handler: lz4-legacy
[0003.332] decompressing blob (type 1)...
[0003.399] display_resolution: No display init
[0003.403] Failed to retrieve display resolution
[0003.407] Could not load/initialize BMP blob...ignoring
[0003.516] decompressor handler not found
[0003.520] load_firmware_blob: Firmware blob loaded, entries=2
[0003.526] XUSB blob version 0 size 124416 @ 0x92ca828c
[0003.532] -------> se_aes_verify_sbk_clear: 747
[0003.536] se_aes_verify_sbk_clear: Error
[0003.540] SE operation failed
[0003.543] bl_battery_charging: connected to external power supply
[0003.552] display_console_ioctl: No display init
[0003.557] switch_backlight failed
[0003.564] device_query_partition_size: failed to open partition spiflash0:MSC !
[0003.572] MSC Partition not found
[0003.579] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.587] USP partition read failed!
[0003.590] blob_init: blob-partition USP header read failed
[0003.596] android_boot Unable to update recovery partition
[0003.601] kfs_getpartname: name = LNX
[0003.605] Loading kernel from LNX
[0003.617] Found 19 BFS partitions in "spiflash0"
[0004.064] load kernel from storage
[0004.069] decompressor handler not found
[0001.998] Basic modules init took 1279740 us
[0002.014] Next stage binary read took 205686 us
[0002.022] CPU initialization took 700496 us
[0002.026] Total time taken by TegraBoot 1953814 us
[0002.186] RamCode = 0
[0002.260]
[0002.328]
[0002.332]
[0003.079] Add serial number:1421919044435 as DT property
[0003.156] is_hdmi_needed: HDMI nDT entry for leds-pwm not found
o[0003.166] t connected, returning false
[0003.169] hdmi is not connected
[0003.172] sor0 is not supported
[0003.175] display_console_init: no valid display out_type
[0003.191] subnode volume_down is not found !
[0003.398] display_resolution: No display init
[0004.063] load kernel from storage
[0001.998] Basic modules init took 1279716 us
[0002.014] Next stage binary read took 205685 us
[0002.018] Carveout took -232106 us
[0002.022] CPU initialization took 700495 us
[0002.026] Total time taken by TegraBoot 1953790 us
[0002.260]
[0002.278] DeviceTree Init done
[0002.327]
[0002.332]
[0002.394] registering boot device
[0002.429] of_register: registering lp8557-bl-driver to of_hal
[0002.553] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.612] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.753] pm_ids_update: The pm board id is 3448-0000-200
[0003.156] is_hdmi_needed: HDMI DT entry for leds-pwm not found
n[0003.166] ot connected, returning false
First: I’ve extracted in new directory clean L4T 32.5
tar -xjf Tegra210_Linux_R32.5.0_aarch64.tbz2
tar -xjf secureboot_R32.5.0_aarch64.tbz2
cd Linux_for_Tegra/rootfs/
tar -xjf Tegra_Linux_Sample-Root-Filesystem_R32.5.0_aarch64.tbz2
cd …
./apply_binaries.sh
Here it is the flash.sh output:
root@tchome:/l4t/Linux_for_Tegra# ./flash.sh jetson-nano-qspi-sd.conf ./flash.sh jetson-nano-qspi-sd mmcblk0p1
# R32 , REVISION: 5.0
# Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet "/l4t/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
/l4t/Linux_for_Tegra/bootloader/tegraflash_internal.py:1978: SyntaxWarning: "is not" with a literal. Did you mean "!="?
if sig_type is not "zerosbk":
/l4t/Linux_for_Tegra/bootloader/tegraflash_internal.py:1981: SyntaxWarning: "is" with a literal. Did you mean "=="?
if sig_type is "oem-rsa":
/l4t/Linux_for_Tegra/bootloader/tegraflash_internal.py:2416: SyntaxWarning: "is not" with a literal. Did you mean "!="?
while count is not 0 and not check_ismb2():
/l4t/Linux_for_Tegra/bootloader/tegraflash_internal.py:2425: SyntaxWarning: "is not" with a literal. Did you mean "!="?
while count is not 0:
version 1.0.0
[ 0.0008 ] Generating RCM messages
[ 0.0016 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /l4t/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0023 ] RCM 0 is saved as rcm_0.rcm
[ 0.0026 ] RCM 1 is saved as rcm_1.rcm
[ 0.0026 ] List of rcm files are saved in rcm_list.xml
[ 0.0026 ]
[ 0.0027 ] Signing RCM messages
[ 0.0033 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0040 ] Assuming zero filled SBK key
[ 0.0082 ]
[ 0.0083 ] Copying signature to RCM mesages
[ 0.0092 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0102 ]
[ 0.0103 ] Boot Rom communication
[ 0.0110 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0117 ] RCM version 0X210001
[ 0.0558 ] Boot Rom communication completed
[ 1.0642 ]
[ 1.0644 ] dump EEPROM info
[ 1.0690 ] tegrarcm --oem platformdetails eeprom /l4t/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0727 ] Applet version 00.01.0000
[ 1.0892 ] Saved platform info in /l4t/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1684 ]
[ 1.1724 ] tegrarcm --reboot recovery
[ 1.1759 ] Applet version 00.01.0000
[ 1.1936 ]
creating dummy /l4t/Linux_for_Tegra/bootloader/badpage.bin
1+0 прочетени блока
1+0 записани блока
изкопирани са 4096 байта (4,1 kB, 4,0 KiB), 0,000132542 s, 30,9 MB/s
copying bctfile(/l4t/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/l4t/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/l4t/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating /l4t/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
Existing sosfile(/l4t/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/l4t/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/l4t/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/l4t/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/l4t/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/l4t/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/l4t/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/l4t/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/l4t/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
Making system.img...
populating rootfs from /l4t/Linux_for_Tegra/rootfs ... done.
populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/l4t/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/l4t/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
copying cfgfile(/l4t/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/l4t/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/l4t/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb"
saving flash command in /l4t/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /l4t/Linux_for_Tegra/bootloader/flash_win.bat
version 1.0.0
[ 0.0349 ] tegrasign --key None --getmode mode.txt
[ 0.0358 ] Assuming zero filled SBK key
[ 0.0805 ]
[ 0.0808 ] Generating RCM messages
[ 0.1132 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.1161 ] RCM 0 is saved as rcm_0.rcm
[ 0.1325 ] RCM 1 is saved as rcm_1.rcm
[ 0.1325 ] List of rcm files are saved in rcm_list.xml
[ 0.1325 ]
[ 0.1326 ] Signing RCM messages
[ 0.1356 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1383 ] Assuming zero filled SBK key
[ 0.1576 ]
[ 0.1577 ] Copying signature to RCM mesages
[ 0.1608 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.1651 ]
[ 0.1652 ] Parsing partition layout
[ 0.1892 ] tegraparser --pt flash.xml.tmp
[ 0.1970 ]
[ 0.1972 ] Creating list of images to be signed
[ 0.2118 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.3090 ]
[ 0.3092 ] Generating signatures
[ 0.3122 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3149 ] Assuming zero filled SBK key
[ 0.4502 ]
[ 0.4503 ] Generating br-bct
[ 0.4971 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.4998 ] Copying Sdram info from 2 to 3 set
[ 0.5404 ]
[ 0.5405 ] Updating boot device parameters
[ 0.5436 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.5462 ] Warning: No sdram params
[ 0.5468 ]
[ 0.5469 ] Updating bl info
[ 0.5497 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.5549 ]
[ 0.5550 ] Updating secondary storage information into bct
[ 0.5579 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.5615 ]
[ 0.5616 ] Updating Odmdata
[ 0.5646 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.5671 ] Warning: No sdram params
[ 0.5677 ]
[ 0.5678 ] Get Signed section of bct
[ 0.5707 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.5739 ]
[ 0.5740 ] Signing BCT
[ 0.5795 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.5822 ] Assuming zero filled SBK key
[ 0.5833 ]
[ 0.5834 ] Updating BCT with signature
[ 0.5852 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.6039 ]
[ 0.6040 ] Copying signatures
[ 0.6056 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.6144 ]
[ 0.6145 ] Updating BFS information on BCT
[ 0.6161 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.6179 ]
[ 0.6180 ] Boot Rom communication
[ 0.6193 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.6206 ] BR_CID: 0x4210100164441643080000000f008340
[ 0.6215 ] RCM version 0X210001
[ 0.6374 ] Boot Rom communication completed
[ 1.6456 ]
[ 1.6458 ] Sending BCTs
[ 1.6503 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.6539 ] Applet version 00.01.0000
[ 1.6712 ] Sending bct
[ 1.6713 ] [................................................] 100%
[ 1.8958 ]
[ 1.8978 ] tegrahost --chip 0x21 --align cboot.bin
[ 1.8999 ]
[ 1.9025 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 1.9114 ]
[ 1.9533 ] tegrasign --key None --list cboot.bin_list.xml
[ 1.9560 ] Assuming zero filled SBK key
[ 2.0859 ]
[ 2.0906 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 2.0970 ]
[ 2.1029 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
[ 2.1070 ]
[ 2.1103 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
[ 2.1168 ]
[ 2.1210 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
[ 2.1237 ] Assuming zero filled SBK key
[ 2.1453 ]
[ 2.1472 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
[ 2.1493 ]
[ 2.2757 ] Sending bootloader and pre-requisite binaries
[ 2.2794 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
[ 2.2825 ] Applet version 00.01.0000
[ 2.3045 ] Sending ebt
[ 2.3047 ] [................................................] 100%
[ 2.4105 ] Sending rp1
[ 2.4158 ] [................................................] 100%
[ 2.4759 ]
[ 2.4789 ] tegrarcm --boot recovery
[ 2.4813 ] Applet version 00.01.0000
[ 2.5011 ]
[ 2.5013 ] Retrieving storage infomation
[ 2.5042 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 2.5067 ] Applet is not running on device. Continue with Bootloader
[ 3.1944 ]
[ 3.2403 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 3.2430 ] Cboot version 00.01.0000
[ 3.2500 ] Saved platform info in storage_info.bin
[ 3.2515 ]
[ 3.2517 ] Flashing the device
[ 3.2546 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 3.2572 ] Cboot version 00.01.0000
[ 3.2606 ] Writing partition GPT with gpt.bin
[ 3.2613 ] [................................................] 100%
[ 3.2674 ] Writing partition PT with flash.xml.bin
[ 63.4994 ] [................................................] 100%
[ 63.5034 ] Writing partition NVC with nvtboot.bin.encrypt
[ 63.7545 ] [................................................] 100%
[ 63.7686 ] Writing partition NVC_R with nvtboot.bin.encrypt
[ 73.7882 ] [................................................] 100%
[ 73.8040 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[ 83.8309 ] [................................................] 100%
[ 83.8432 ] Writing partition RP1 with kernel_tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt
[ 88.0148 ] [................................................] 100%
[ 88.0328 ] Writing partition EBT with cboot.bin.encrypt
[ 102.7020 ] [................................................] 100%
[ 102.7327 ] Writing partition WB0 with warmboot.bin.encrypt
[ 131.8057 ] [................................................] 100%
[ 131.8174 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[ 132.0814 ] [................................................] 100%
[ 132.0920 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 132.3567 ] [................................................] 100%
[ 132.3691 ] Writing partition DTB with kernel_tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt
[ 135.8069 ] [................................................] 100%
[ 135.8254 ] Writing partition LNX with boot.img.encrypt
[ 150.4933 ] [................................................] 100%
[ 150.5289 ] Warning: EKS partition magic header mismatch!
[ 190.1073 ] Writing partition EKS with eks.img
[ 190.1081 ] [................................................] 100%
[ 190.1176 ] Writing partition BMP with bmp.blob
[ 190.3808 ] [................................................] 100%
[ 190.4273 ] Writing partition RP4 with rp4.blob
[ 199.4796 ] [................................................] 100%
[ 199.4957 ] Writing partition VER_b with qspi_bootblob_ver.txt
[ 207.0833 ] [................................................] 100%
[ 207.1139 ] Writing partition VER with qspi_bootblob_ver.txt
[ 207.3781 ] [................................................] 100%
[ 207.3884 ] Writing partition APP with system.img
[ 207.6510 ] [................................................] 100%
[ 729.6374 ]
[ 729.6406 ] tegradevflash --write BCT P3448_A00_lpddr4_204Mhz_P987.bct
[ 729.6437 ] Cboot version 00.01.0000
[ 729.6466 ] Writing partition BCT with P3448_A00_lpddr4_204Mhz_P987.bct
[ 729.6479 ] [................................................] 100%
[ 736.3082 ]
[ 736.3083 ] Flashing completed
[ 736.3084 ] Coldbooting the device
[ 736.3099 ] tegradevflash --reboot coldboot
[ 736.3111 ] Cboot version 00.01.0000
[ 736.3137 ]
I see some error in the flash.sh initial part boardinfo parsing which looks connected with detecting the SB/PKC configuration:
Have in mind that I’ve tryed SB/PKC configuration which was not successful. Here is the Topic where I’ve shared my expirience on Jetson Nano devkit A02 SB/PKC capabilities which are not supported on devkit edvices and only supported on production module wth internal emmc):
