please do not tar the secureboot folder
tar -xjf secureboot_R32.5.0_aarch64.tbz2
Just use Tegra210_Linux_R32.5.0_aarch64.tbz2 and Tegra_Linux_Sample-Root-Filesystem_R32.5.0_aarch64.tbz2
BTW, didn’t you already flash your board yesterday? Why you flash it again?
Also, did you ever flash NS boot to this jetson nano before you tried any SB things?
yes, it was working fine before the SB tests.
Then I guess directly RMA this device would be the fast way… the board is probably defective now.
RMA process is not working properly for my location.
I just need to disable the watchdog timer and it might boot otherwise it will be another brick on the shelf
The watchdog is enabled from cboot and could be diabled via ODMDATA according to some of your docs. But ODM data is not fully documented for jetson nano device :(
We don’t document odmdata because generally nobody should need to modify it.
If you still want to try disabling WDT, Set bit 17:16 to 0 in your ODMDATA and it will disable WDT.
May I know why RMA process is no working at your location?
I do not keep the reciept and I cannot return it to the local supplier.
